Social Media Aggregator
node-red-social-aggregator
Multiple social platform aggregator using the rivus lib on node-red. The input object into the node-red node can be used to retreve user feeds from a multiple of sources with different keys (if needed). This makes the aggregation and normalisation of data easier as it retrieves and attempts to handle each of the below sources in a number of different ways.
Node Input
To load send an array object to the node
"name": "rss",
"feed_url": "https://sitepoint.com/feed/"
"name": "twitter",
"user": "@developersteve",
"consumer_key": "eWxCQh9fLgzNRGA31pyaaaaaaa",
"consumer_secret": "mG75BmuM9EovWKRff3oLHLBs4r1pSB02IsssGqgtXdHhtsk8",
"access_token_key": "1234567878-bKOvuci3Dlcm2sssf2FeiQmi6y9F0hBZMk36EhSXI",
"access_token_secret": "c6Kh5BRSh5Yeq9sssadsd5i4zUozAtqLWEeczTOBJkMdRfpGz"
Input types
Example of input types and how to load them, these can be multiples and remember to watch the rate-limits when dealing with some of the API's (im looking at you twitter).
"name": "rss",
"feed_url": "https://developer.ibm.com/feed/"
"name": "instagram",
"access_token": ""
"name": "medium",
"user": "@username"
"name": "medium",
"publication": "blog_title"
"name": "medium",
"publication_with_custom_domain": "http://www.developer.ibm.com"
"name": "twitter",
"consumer_key": "",
"consumer_secret": "",
"access_token_key": "",
"access_token_secret": ""
"name": "facebook",
"app_id": "",
"app_secret": "",
"user_id": ""
Node Output
Output response will be via msg.payload
which should return something like the following
title: '',
content: '',
created_time: {},
images: {
thumbnail: {url: ''},
content: {url: ''}
link: "",
extra: {},
source: {
feed: ''
[{"id":"14312521.8b4dbb","type":"inject","z":"be81f6c.cc69008","name":"","topic":"","payload":"[{\"name\":\"rss\",\"feed_url\":\"https://sitepoint.com/feed/\"},{\"name\":\"twitter\",\"user\":\"@developersteve\",\"consumer_key\":\"\",\"consumer_secret\":\"\",\"access_token_key\":\"\",\"access_token_secret\":\"\"}]","payloadType":"json","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":310,"y":280,"wires":[["4a67cdd8.78b234"]]}]
