2FA in NodeRED (Two Factor Authentication)
enter image description here Two Factor Authentication made for NodeRED needs. Control payload flow with an Android prompt. This is best used when the automatic trigger needs a possible human oversight.
Features:
  • Android Notification
  • Automatic Timeout
  • Custom Default Action
  • Allow/Reject
  • Progress bar
  • Subflow deployment
You will need the following Android Apps:
Download a complete Tasker profile from TaskerNET
This Setup leans on the following guides: Perfect Autonotifications, Credentials in NodeRED,
Settings
  • default2fa - Default behaviour true|false
  • timer - timeout in seconds
  • AR Device - name of AutoRemote device served with credential system
  • title - title of the notification
  • text - text of the notification
  • 2FApath - path for HTTP request
  • ID - unique ID
More about me:
[{"id":"b44411e6.28ae6","type":"subflow","name":"2FA","info":"","category":"","in":[{"x":320,"y":240,"wires":[{"id":"54d21981.c2c698"}]}],"out":[{"x":1040,"y":220,"wires":[{"id":"d6bdef4b.09f4b","port":0}]}],"env":[{"name":"default2fa","type":"bool","value":"false"},{"name":"timer","type":"num","value":"20"},{"name":"ARdevice","type":"str","value":""},{"name":"title","type":"str","value":""},{"name":"text","type":"str","value":""},{"name":"2FApath","type":"str","value":""},{"name":"ID","type":"str","value":""}],"color":"#DDAA99"},{"id":"54d21981.c2c698","type":"function","z":"b44411e6.28ae6","name":"Set alarm","func":"var x = env.get(\"timer\");\nvar timer = x *1000;\nvar time = new Date();\nvar timeseconds = time.getTime();\nvar alarm = timeseconds + timer;\n\n\nflow.set(\"$parent.alarm\", alarm);\nflow.set(\"$parent.time\", timeseconds);\nflow.set(\"$parent.authentication\", \"pending\");\n\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":240,"wires":[["978a4770.9effd8","d6bdef4b.09f4b"]]},{"id":"7aedd4b4.d3497c","type":"delay","z":"b44411e6.28ae6","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":740,"y":320,"wires":[["d6bdef4b.09f4b"]]},{"id":"978a4770.9effd8","type":"function","z":"b44411e6.28ae6","name":"2FA Push","func":"var device = env.get(\"ARdevice\");\nvar timer = env.get(\"timer\");\nvar title = env.get(\"title\");\nvar text = env.get(\"text\");\nvar path = env.get(\"2FApath\");\nvar ID = env.get(\"ID\");\nvar default2fa = env.get(\"default2fa\");\nvar status2fa;\n\nif(default2fa === true){\n    status2fa = \"approved\";\n}\n\nif(default2fa === false){\n    status2fa = \"declined\";\n}\n\n\nvar key = global.get(device);\nvar time = flow.get(\"$parent.time\");\nvar alarm = flow.get(\"$parent.alarm\");\nvar url = \"https://autoremotejoaomgcd.appspot.com/sendmessage\";\nvar command = \"2FA\";\nvar body = {\n    \"title\": {\n        \"title\": title,\n        \"titleexpanded\": title\n  },\n  \"text\": {\n        \"text\": text,\n        \"textexpanded\": text\n  },\n  \"icons\": {\n    \"navbaricon\": \"android.resource://net.dinglisch.android.taskerm/hl_device_access_new_account\",\n    \"bigicon\": \"android.resource://net.dinglisch.android.taskerm/hl_device_access_new_account\"\n  },\n  \"notificationid\": ID,\n  \"persistent\": true,\n  \"priority\": 1,\n  \"default2fa\": default2fa,\n  \"status2fa\" : status2fa,\n  \"path\" : path,\n  \"timer\": timer,  // in seconds\n  \"start\": time,   // in ms\n  \"alarm\": alarm,  // in ms\n  \"buttons\": [\n    {\n      \"button1\": {\n        \"icon\": \"\",\n        \"label\": \"Allow\",\n        \"command\": \"2faresponse_true\"\n      },\n     \n      \"button2\": {\n        \"icon\": \"\",\n        \"label\": \"Deny\",\n        \"command\": \"2faresponse_false\"\n      }\n    \n    }\n  ]\n};\nmsg.data = body;\nvar x = JSON.stringify(body);\nvar encodedBody = encodeURIComponent(x);\n\nmsg.url = url + \"?key=\" + key + \"&message=\" +command + \"=:=\"+ encodedBody;\nreturn msg;\n\n\n","outputs":1,"noerr":0,"x":620,"y":360,"wires":[["d3f75fc.8c556a"]]},{"id":"d3f75fc.8c556a","type":"http request","z":"b44411e6.28ae6","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":850,"y":360,"wires":[[]]},{"id":"d6bdef4b.09f4b","type":"function","z":"b44411e6.28ae6","name":"Timer","func":"var authentication = flow.get(\"$parent.authentication\");\nvar default2fa = env.get(\"default2fa\");\nvar alarm = flow.get(\"$parent.alarm\");\n\nvar time = new Date();\nvar timeseconds = time.getTime();\n\n//2FA message approved (1)\nif(authentication === \"approved\"){    \n    flow.set(\"$parent.authentication\", \"pending\");\n    return[msg, null, null];\n}\n\n//2FA message declined (2)\nif(authentication === \"declined\"){\n    flow.set(\"$parent.authentication\", \"pending\");\n    return[null, msg, null];\n}\n\n//pending for 2FA message (3)\nif(authentication === \"pending\"){\n    if(timeseconds < alarm){           //loop\n        return[null, null, msg];\n    }\n    \n    if(timeseconds => alarm){\n        if(default2fa === true){         // timeout & default approved\n            \n            return[msg, null, null];\n        }\n        if(default2fa === false){        // timeout & default declined\n            \n            return[null, msg, null];\n        }\n    }\n}","outputs":3,"noerr":0,"x":710,"y":240,"wires":[[],[],["7aedd4b4.d3497c"]]},{"id":"957c5748.7d80c8","type":"tab","label":"2FA","disabled":false,"info":"\n![enter image description here](https://notenoughtech.com/wp-content/uploads/2019/12/YouTube-Thumb-1.jpg)\nTwo Factor Authentication made for NodeRED needs. Control payload flow with an Android prompt. This is best used when the automatic trigger needs a possible human oversight.\n\n - [Complete instructions]([https://notenoughtech.com/home-automation/nodered-home-automation/two-factor-authentication-in-nodered/](https://notenoughtech.com/home-automation/nodered-home-automation/two-factor-authentication-in-nodered/)\n\n\n**Features**:\n-   Android Notification\n- Automatic Timeout\n- Custom Default Action\n- Allow/Reject\n- Progress bar\n- Subflow deployment\n\nYou will need the following Android Apps:\n\nDownload a complete Tasker profile from [TaskerNET](https://taskernet.com/shares/?user=AS35m8mukRNi0KvTv9JF6LyKMewcG%2BW7EzpF3a%2FGvwJJTFwWQ1%2BU3QCMEmxTS%2F07urNK%2FTAL&id=Project%3A2FA)\n\n - [Tasker](https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm&hl=en)\n - [AutoNotification](https://play.google.com/store/apps/details?id=com.joaomgcd.autonotification&hl=en)\n - [AutoTools](https://play.google.com/store/apps/details?id=com.joaomgcd.autotools&hl=en)\n - [AutoRemote](https://play.google.com/store/apps/details?id=com.joaomgcd.autoremote&hl=en)\n - [AutoApps](https://play.google.com/store/apps/details?id=com.joaomgcd.autoappshub&hl=en)\n \n This Setup leans on the following guides:\n [Perfect Autonotifications](https://notenoughtech.com/tasker/tasker-projects/tasker-perfect-autonotifications/), [Credentials in NodeRED](https://notenoughtech.com/home-automation/nodered-home-automation/serving-credentials-with-nodered/),\n\n# Settings\n\n - **default2fa** - Default behaviour true|false\n - **timer**  - timeout in seconds\n - **AR Device**  - name of AutoRemote device served with credential system\n - **title**  - title of the notification\n - **text** - text of the notification\n - **2FApath** -  path for HTTP request\n - **ID** - unique ID  \n "},{"id":"2231f728.d595f8","type":"inject","z":"957c5748.7d80c8","name":"message","topic":"message","payload":"test","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":100,"wires":[["4891f3f2.4e03ac"]]},{"id":"55a0ab1b.bd2e14","type":"debug","z":"957c5748.7d80c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":530,"y":100,"wires":[]},{"id":"d1c68f7a.c9846","type":"http in","z":"957c5748.7d80c8","name":"","url":"/2fa/test","method":"post","upload":false,"swaggerDoc":"","x":170,"y":240,"wires":[["ca4106fd.8cb2a8","bdcdfdd.c1ec3"]]},{"id":"bdcdfdd.c1ec3","type":"function","z":"957c5748.7d80c8","name":"2FA authenticate","func":"var x = msg.payload.authentication;\n\nif(x === true){\n    flow.set(\"authentication\", \"approved\");\n}\nif(x === false){\n    flow.set(\"authentication\", \"declined\");\n}\n\n","outputs":1,"noerr":0,"x":370,"y":240,"wires":[[]]},{"id":"ca4106fd.8cb2a8","type":"http response","z":"957c5748.7d80c8","name":"","statusCode":"","headers":{},"x":340,"y":300,"wires":[]},{"id":"4891f3f2.4e03ac","type":"subflow:b44411e6.28ae6","z":"957c5748.7d80c8","name":"","env":[{"name":"timer","value":"30","type":"num"},{"name":"ARdevice","value":"ARmi9","type":"str"},{"name":"title","value":"NodeRED Authentication","type":"str"},{"name":"text","value":"Confirm the action","type":"str"},{"name":"2FApath","value":"/2fa/test","type":"str"},{"name":"ID","value":"ID","type":"str"},{"name":"default","value":"true","type":"bool"},{"name":"path","value":"path","type":"str"}],"x":330,"y":100,"wires":[["55a0ab1b.bd2e14"]]}]
Created 6 years, 1 month ago
Updated 6 years ago
  • delay (x1)
  • function (x4)
  • http in (x1)
  • http request (x1)
  • http response (x1)
  • subflow (x1)
  • subflow:b44411e6.28ae6 (x1)
  • 2FA
  • two
  • factor
  • authentication
  • android
  • autoremote
  • autonotification
  • tasker
