Govee API control function
Control Function for Govee API
Overview
This function handles all the needed communication with the Govee API. You can input simple control messages, and the function does the rest. You don't need to install anything to your Node-RED, just put the code into a function or import the flow.
API Key Setup
You need to apply for the Govee API through the Govee app. Once you have the key, just copy it to line 8 inside the parentheses. This is a simple and fast process.
Initial Setup
For the very first time, send out this object to the function:
{ "command": "devices" }
This initializes all the global objects and retrieves all your lights from Govee. If you add more lights or change their names, you should send this command again.
Example Control Messages
kuva The flow includes example messages that you can input into your lighting function. You can also connect the examples to a debug node for easy copying.
Turning a Light On
{ "command": "control", "name": "Table", "instance": "powerSwitch", "value": 1 }
Adjusting Brightness
{ "command": "control", "name": "Table", "instance": "brightness", "value": 50 }
Multi-Message Control
You can set multiple settings in one message. For example, to turn Light1 on, enable gradientToggle, call a snapshot, and set the brightness:
    "command": "multi",
    "name": "Light1",
    "powerSwitch": 1,
    "gradientToggle": 1,
    "snapshot": "Day",
    "brightness": 10
Using Snapshots
Using snapshots is the easiest way to get the light into your desired mode. Use the phone app to set up your desired settings, scene, and colors, then save it as a snapshot.
To call a snapshot, use:
{ "command": "control", "name": "Table", "instance": "snapshot", "value": "Morning" }
Handling Multiple Messages
You can send multiple messages at once. The function will store and handle them in order. Due to Govee API limitations, only one message can be sent at a time.
For example, if you have 5 lights and each receives a multi-message with 4 parameters, the function needs to send 20 individual messages. This process happens quickly enough.
Global Object Storage
The function stores the last parameter in the global object. For example, if the last message was brightness, you will see its value, but gradientToggle is undefined.
kuva
You can also check the global object to see the capabilities of a light, helping you determine which instances you can call when controlling the light.
This function streamlines Govee API integration with Node-RED, making smart lighting control simple and efficient.
[{"id":"function","type":"function","z":"6f0c45810e08f8f3","name":"govee function","func":"let messages = []\nlet message\nlet parameters\nlet actionName\nlet code\nlet text\nlet fill\nconst apiKey = \"xxxxxxxxx\"\nconst now = parseFloat(new Date().getTime());\nconst now12h = now - 43200000\nconst now1min = now - 60000;\nlet govee = global.get(\"govee\");\nlet errorstate = global.get(\"govee.errorstate\")\nlet errorMessage\nlet timestamp = global.get(\"govee.timestamp\")\n\nif (govee && govee.messages !== undefined) {\n    messages = govee.messages\n}\n\n\nfunction generateUUID() {\n    return 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function (c) {\n        const r = Math.random() * 16 | 0;\n        const v = c === 'x' ? r : (r & 0x3 | 0x8);\n        return v.toString(16);\n    });\n}\n\nfunction generateArray(min, max) {\n    return Array.from({ length: max - min + 1 }, (_, i) => min + i);\n}\n\nfunction rgbToGoveeColor(r, g, b) {\n    return ((r & 0xFF) << 16) | ((g & 0xFF) << 8) | (b & 0xFF);\n}\n\nfunction hexToRgb(hex) {\n    hex = hex.replace(/^#/, '');\n    let r = parseInt(hex.substring(0, 2), 16);\n    let g = parseInt(hex.substring(2, 4), 16);\n    let b = parseInt(hex.substring(4, 6), 16);\n    return {\n        r: r,\n        g: g,\n        b: b\n    };\n}\n\nconst goveeApiCodes = {\n    403: {\n        message: \"Indicates that the Govee Developer API key is invalid.\",\n        statusCode: 403,\n        text: \"API key issue\",\n        fill: \"red\"\n    },\n    401: {\n    message: \"Authentication failed. API key is missing or invalid.\",\n    statusCode: 401,\n    text: \"API key issue\",\n    fill: \"red\"\n    },\n    500: {\n        message: \"Indicates an internal service error.\",\n        statusCode: 500,\n        text: \"Issue on server side\",\n        fill: \"red\"\n    },\n    400: {\n        message: \"Indicates that a request parameter does not comply with the associated constraints.\",\n        statusCode: 400,\n        text: \"Issue on request\",\n        fill: \"red\"\n    },\n    200: {\n        message: \"GET or POST successfull!\",\n        statusCode: 200,\n        text: \"Success\",\n        fill: \"green\"\n    }\n};\n\nconst actions = {\n    devices: function (obj){\n        let newMsg = {}\n        newMsg.method = \"GET\";\n        newMsg.url = \"https://openapi.api.govee.com/router/api/v1/user/devices\";\n        newMsg.headers = {\n            \"Content-Type\": \"application/json\",\n            \"Govee-API-Key\": apiKey\n        };\n        messages.push(newMsg);\n    },\n    control: function (obj) {\n        if (errorstate === 1){\n            return\n        }\n        for (let i = 0; i < govee.data.length; i++) {\n            let device = govee.data[i];\n\n            if (device.deviceName === obj.name) {\n                obj.sku = device.sku,\n                obj.device = device.device\n                obj.id = i\n                for (let j = 0; j < device.capabilities.length; j++) {\n                    let capabilities = device.capabilities[j]\n                    if (capabilities.instance === obj.instance){\n                        obj.type = capabilities.type\n                        if (obj.instance === \"snapshot\"){\n                            obj.snapshot = capabilities.parameters.options\n                        }\n                    }\n                }\n            }\n        }\n        const checks = [\n            { condition: !obj.device, message: \"Didn't find device\" },\n            { condition: !obj.instance, message: \"Didn't find instance\" },\n            { condition: !obj.sku, message: \"missing SKU\" },\n            { condition: !obj.type, message: \"missing type\" }\n        ];\n\n        if (obj.instance === \"segmentedColorRgb\"){\n            const colorInt = rgbToGoveeColor(obj.value.r, obj.value.g, obj.value.b)\n            let segment = obj.value.segment\n            if (!segment){\n                const minSegment = govee.data[obj.id].capabilities[4].parameters.fields[0].elementRange.min\n                const maxSegment = govee.data[obj.id].capabilities[4].parameters.fields[0].elementRange.max\n                segment = generateArray(minSegment,maxSegment)\n            }\n            obj.value = {\n                segment: segment,\n                rgb:parseFloat(colorInt)\n            }\n        }\n        if (obj.instance === \"segmentedBrightness\"){\n            let segment = obj.value.segment\n            if (!segment) {\n                const minSegment = govee.data[obj.id].capabilities[4].parameters.fields[0].elementRange.min\n                const maxSegment = govee.data[obj.id].capabilities[4].parameters.fields[0].elementRange.max\n                segment = generateArray(minSegment, maxSegment)\n            }\n            obj.value = {\n                segment: segment,\n                brightness: parseFloat(obj.value.brightness)\n            }\n        }\n\n        if (obj.instance === \"snapshot\"){\n            if (isNaN(obj.value) && obj.value && obj.snapshot){\n                for (let i = 0; i < obj.snapshot.length; i++) {\n                    let objOptions =  obj.snapshot[i]\n                    if (obj.value === objOptions.name){\n                        obj.value = objOptions.value\n                    }\n                }\n            }\n        }\n\n        // Loop through the checks and handle errors\n        for (let check of checks) {\n            if (check.condition) {\n                errorMessage = check.message;\n                if (errorstate === 0){\n                    errorstate = 2\n                }\n                if (errorstate === 3){\n                    errorstate = 4\n                }\n\n                break; // Exit the loop after the first error\n            } else {\n                errorstate = 0\n            }\n        }\n        let newMsg = {}\n        newMsg.method = \"POST\";\n        newMsg.url = \"https://openapi.api.govee.com/router/api/v1/device/control\";\n        newMsg.headers = {\n            \"Content-Type\": \"application/json\",\n            \"Govee-API-Key\": apiKey\n        };\n        newMsg.requestId = generateUUID();\n        newMsg.payload = {\n                \"sku\": obj.sku,\n                \"device\": obj.device,\n                \"capability\": {\n                    \"type\": obj.type,\n                    \"instance\": obj.instance,\n                    \"value\": obj.value\n                }\n            }\n        newMsg.payload = JSON.stringify({\n            requestId: newMsg.requestId,\n            payload: newMsg.payload\n        });\n        messages.push(newMsg);\n    },status: function (obj) {\n        for (let i = 0; i < govee.data.length; i++) {\n            let device = govee.data[i];\n\n            if (device.deviceName === obj.name) {\n                obj.sku = device.sku,\n                obj.device = device.device\n            }\n        }\n\n        const checks = [\n            { condition: !obj.device, message: \"Didn't find device\" },\n            { condition: !obj.sku, message: \"missing SKU\" }\n        ];\n\n        for (let check of checks) {\n            if (check.condition) {\n                errorMessage = check.message;\n                if (errorstate === 0){\n                    errorstate = 2\n                }\n                if (errorstate === 3){\n                    errorstate = 4\n                }\n                break;\n            } else {\n                errorstate = 0\n            }\n        }\n        let newMsg = {}\n        newMsg.method = \"POST\";\n        newMsg.url = \"https://openapi.api.govee.com/router/api/v1/device/state\";\n        newMsg.headers = {\n            \"Content-Type\": \"application/json\",\n            \"Govee-API-Key\": apiKey\n        };\n        newMsg.requestId = generateUUID();\n        newMsg.payload = {\n                \"sku\": obj.sku,\n                \"device\": obj.device,\n            }\n        newMsg.payload = JSON.stringify({\n            requestId: newMsg.requestId,\n            payload: newMsg.payload\n        });\n\n        messages.push(newMsg);\n    }\n}\n\nif (!govee && !errorstate){\n    errorstate = 1\n    govee = {}\n    global.set(\"govee\", govee);\n    global.set(\"govee.errorstate\", errorstate);\n    global.set(\"govee.timestamp\", now);\n}\n\nif (isNaN(timestamp)) {\n    errorstate = 1\n    global.set(\"govee.errorstate\", errorstate);\n    global.set(\"govee.timestamp\", now);\n} else {\n    if (timestamp < now12h){\n        errorstate = 1\n    }\n}\n\nif (msg.statusCode !== undefined) {\n    const errorInfo = goveeApiCodes[msg.statusCode] || { text: \"error \" + msg.statusCode, fill: \"red\" };\n    text = errorInfo.text;\n    fill = errorInfo.fill;\n}\n\nif (govee.timestamp < now1min){\n    govee.response = []\n    global.set(\"govee.response\", govee.response);\n    global.set(\"govee.timestamp\", now);\n}\n\nif (msg.payload && msg.payload.code !== undefined){\n    code = msg.payload.code\n    if (code === 200){\n        if (msg.payload && msg.payload.data !== undefined){\n            global.set(\"govee.data\", msg.payload.data);\n            if (errorstate === 1){\n                errorstate = 0;\n            }\n            if (errorstate === 2) {\n                errorstate = 3;\n            }\n        }\n        if (msg.payload && msg.payload.requestId && msg.payload.capability){\n            let thisResponseDevice\n            for (let l = 0; l < govee.response.length; l++) {\n                if (govee.response[l].rId === msg.payload.requestId){\n                    thisResponseDevice = govee.response[l].device\n                }\n            }\n            for (let i = 0; i < govee.data.length; i++) {\n                if (govee.data[i].device === thisResponseDevice){\n                    for (let j = 0; j < govee.data[i].capabilities.length; j++) {\n                        if (govee.data[i].capabilities[j].type === msg.payload.capability.type){\n                            if (msg.payload.capability.instance !== undefined){\n                                if (govee.data[i].capabilities[j].instance === msg.payload.capability.instance){\n                                    govee.data[i].capabilities[j].value = msg.payload.capability.value;\n                                } else {\n                                    govee.data[i].capabilities[j].value = undefined;\n                                }\n                            } else {\n                                govee.data[i].capabilities[j].value = msg.payload.capability.value;\n                            }\n                        } else {\n                            govee.data[i].capabilities[j].value = undefined;\n                        }\n                    }\n                }\n            }\n        global.set(\"govee.data\", govee.data);\n        }\n\n    }\n    global.set(\"govee.timestamp\", now);\n    if (code >= 400){\n        text = msg.payload.msg\n        fill = \"yellow\"\n    }\n}\n\nif (errorstate === 3){\n    msg.payload = global.get(\"govee.payloadMemory\")\n}\n\nif (msg.payload && msg.payload.command !== undefined){\n    global.set(\"govee.payloadMemory\", msg.payload);\n    messages = []\n    global.set(\"govee.messages\", messages);\n    actionName = msg.payload.command\n    if (actionName === \"multi\"){\n        global.set(\"govee.messages\", []);\n        if (msg.payload.powerSwitch){\n            parameters = {\n                name: msg.payload.name,\n                instance: \"powerSwitch\",\n                value: msg.payload.powerSwitch\n            }\n            actions[\"control\"](parameters);\n        }\n        if (msg.payload.gradientToggle) {\n            parameters = {\n                name: msg.payload.name,\n                instance: \"gradientToggle\",\n                value: msg.payload.gradientToggle\n            }\n            actions[\"control\"](parameters);\n        }\n        if (msg.payload.color) {\n            let value = hexToRgb(msg.payload.color)\n            parameters = {\n                name: msg.payload.name,\n                instance: \"segmentedColorRgb\",\n                value: value\n            }\n            actions[\"control\"](parameters);\n        }\n        if (msg.payload.brightness) {\n            parameters = {\n                name: msg.payload.name,\n                instance: \"brightness\",\n                value: msg.payload.brightness\n                }\n            actions[\"control\"](parameters);\n        }\n        if (msg.payload.colorTemp) {\n            parameters = {\n                name: msg.payload.name,\n                instance: \"colorTemperatureK\",\n                value: msg.payload.colorTemp\n                }\n            actions[\"control\"](parameters);\n        }\n        if (msg.payload.snapshot) {\n            parameters = {\n                name: msg.payload.name,\n                instance: \"snapshot\",\n                value: msg.payload.snapshot\n            }\n            actions[\"control\"](parameters);\n        }\n        if (msg.payload.segments) {\n            for (let i = 0; i < msg.payload.segments.length; i++) {\n                if (msg.payload.segments[i].color) {\n                    let value = hexToRgb(msg.payload.segments[i].color)\n                    value.segment = [msg.payload.segments[i].id]\n                    parameters = {\n                        name: msg.payload.name,\n                        instance: \"segmentedColorRgb\",\n                        value: value\n                    }\n                    actions[\"control\"](parameters);\n                }\n                if (msg.payload.segmentedBrightness) {\n                    parameters = {\n                        name: msg.payload.name,\n                        instance: \"segmentedBrightness\",\n                        value: {\n                            brightness: msg.payload.segments[i].brightness,\n                            segment: [msg.payload.segments[i].id]\n                        }\n                    }\n                    actions[\"control\"](parameters);\n                }\n\n            }\n        }\n\n\n    }\n    if (msg.payload && msg.payload.name!== undefined){\n        parameters = {\n            name : msg.payload.name,\n        } \n    }\n\n    if (msg.payload && msg.payload.name && msg.payload.instance && msg.payload.value !== undefined){\n        parameters = {\n            name : msg.payload.name,\n            instance : msg.payload.instance,\n            value : msg.payload.value\n        } \n    }\n}\n\n\nif (actions[actionName]) {\n    actions[actionName](parameters);\n    if (!text){\n        text = \"Executing \" + actionName\n        fill = \"yellow\"\n    }\n} else {\n    if (!msg.statusCode){\n        text = \"No action\"\n        fill = \"red\"\n    }\n}\n\nif (messages.length > 1){\n    text = \"multi: \" + messages.length + \" actions left\"\n    fill = \"yellow\"\n}\n\nif (msg.payload === \"\"){\n    text = \"idle\"\n    fill = \"gray\"\n}\n\nif (errorstate){\n\n    if (errorstate === 1){\n        global.set(\"govee.messages\", messages);\n        messages = []\n        actions[\"devices\"](parameters)\n        message = messages.shift();\n        text = \"updating devices\"\n        fill = \"yellow\"\n    }\n    if (errorstate === 2){\n        global.set(\"govee.messages\", messages);\n        messages = []\n        actions[\"devices\"](parameters)\n        message = messages.shift();\n        global.set(\"govee.errorMessage\", errorMessage);\n        text = errorMessage\n        text = text + \". Updating...\"\n        fill = \"yellow\"\n    }\n    if (errorstate === 3) {\n        message = messages.shift();\n        global.set(\"govee.messages\", messages);\n    }\n    if (errorstate === 4) {\n        messages = []\n        global.set(\"govee.messages\", messages);\n        text = global.get(\"govee.errorMessage\");\n        text = text + \". Stopping!\"\n        fill = \"red\"\n        errorstate = 0;\n        global.set(\"govee.errorMessage\", undefined);\n    }\n} else {\n    message = messages.shift();\n    global.set(\"govee.messages\", messages);\n}\n\nglobal.set(\"govee.errorstate\", errorstate);\n\nif (message && message.payload) {\n    try {\n        const parsedPayload = JSON.parse(message.payload);\n        node.warn(parsedPayload);\n        const responsemsg = {\n            rId: parsedPayload.requestId,\n            device: parsedPayload.payload.device\n        };\n        govee.response.push(responsemsg)\n        global.set(\"govee.response\", govee.response);\n    } catch (err) {\n        // Do nothing if payload is invalid\n    }\n}\n\nnode.status({ fill: fill, shape: \"dot\", text: text});\nreturn message;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":440,"wires":[["http_request"]]},{"id":"http_request","type":"http request","z":"6f0c45810e08f8f3","name":"Govee API Call","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":780,"y":440,"wires":[["d8e8e1912ab605f6","a40a892b29cb3021"]]},{"id":"d8e8e1912ab605f6","type":"delay","z":"6f0c45810e08f8f3","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":990,"y":440,"wires":[["function"]]},{"id":"d7386c3d9fb353ec","type":"inject","z":"6f0c45810e08f8f3","name":"Devices","props":[{"p":"payload.command","v":"devices","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":290,"y":400,"wires":[["function"]]},{"id":"771f51940b109654","type":"function","z":"6f0c45810e08f8f3","name":"check govee global","func":"\nmsg.payload = global.get(\"govee\");\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":600,"wires":[["6efe11d47590f510"]]},{"id":"6efe11d47590f510","type":"debug","z":"6f0c45810e08f8f3","name":"global","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":600,"wires":[]},{"id":"fd22cca139612053","type":"inject","z":"6f0c45810e08f8f3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":600,"wires":[["771f51940b109654"]]},{"id":"a40a892b29cb3021","type":"debug","z":"6f0c45810e08f8f3","name":"debug 12","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":980,"y":400,"wires":[]},{"id":"1b4038e426bf3430","type":"inject","z":"6f0c45810e08f8f3","name":"Off","props":[{"p":"payload.command","v":"control","vt":"str"},{"p":"payload.name","v":"Light1","vt":"str"},{"p":"payload.instance","v":"powerSwitch","vt":"str"},{"p":"payload.value","v":"0","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":290,"y":320,"wires":[[]]},{"id":"dc3a76a614275182","type":"inject","z":"6f0c45810e08f8f3","name":"State","props":[{"p":"payload.command","v":"status","vt":"str"},{"p":"payload.name","v":"Table","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":290,"y":240,"wires":[[]]},{"id":"9af2d6c25ab711b7","type":"inject","z":"6f0c45810e08f8f3","name":"On","props":[{"p":"payload.command","v":"control","vt":"str"},{"p":"payload.name","v":"Table","vt":"str"},{"p":"payload.instance","v":"powerSwitch","vt":"str"},{"p":"payload.value","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":290,"y":280,"wires":[[]]},{"id":"7facdf410c96cc88","type":"inject","z":"6f0c45810e08f8f3","name":"snapshot","props":[{"p":"payload.command","v":"control","vt":"str"},{"p":"payload.name","v":"Light1","vt":"str"},{"p":"payload.instance","v":"snapshot","vt":"str"},{"p":"payload.value","v":"Night","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":280,"y":200,"wires":[[]]},{"id":"18bdd12c115bbf79","type":"inject","z":"6f0c45810e08f8f3","name":"segment color","props":[{"p":"payload.command","v":"control","vt":"str"},{"p":"payload.name","v":"Light1","vt":"str"},{"p":"payload.instance","v":"segmentedColorRgb","vt":"str"},{"p":"payload.value.r","v":"0","vt":"num"},{"p":"payload.value.g","v":"0","vt":"str"},{"p":"payload.value.b","v":"255","vt":"str"},{"p":"payload.value.segment","v":"[0,1,2]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":270,"y":160,"wires":[[]]},{"id":"ad771e9b13554054","type":"inject","z":"6f0c45810e08f8f3","name":"segment brightness","props":[{"p":"payload.command","v":"control","vt":"str"},{"p":"payload.name","v":"Table","vt":"str"},{"p":"payload.instance","v":"segmentedBrightness","vt":"str"},{"p":"payload.value.brightness","v":"10","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":120,"wires":[[]]},{"id":"fc3a98b6a726011d","type":"inject","z":"6f0c45810e08f8f3","name":"gradient","props":[{"p":"payload.command","v":"control","vt":"str"},{"p":"payload.name","v":"Light1","vt":"str"},{"p":"payload.instance","v":"gradientToggle","vt":"str"},{"p":"payload.value","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":280,"y":360,"wires":[[]]},{"id":"bba62a8aeecdfafd","type":"template","z":"6f0c45810e08f8f3","name":"color and brightness","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n    \"command\": \"multi\",\n    \"name\": \"Light1\",\n    \"powerSwitch\": 1,\n    \"gradientToggle\": 1,\n    \"color\": \"#FF0000\",\n    \"brightness\": 10\n}","output":"json","x":520,"y":180,"wires":[[]]},{"id":"8387eaa369172bf3","type":"template","z":"6f0c45810e08f8f3","name":"segment rgb","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n    \"command\": \"multi\",\n    \"name\": \"Pöytä\",\n    \"powerSwitch\": 1,\n    \"gradientToggle\": 0,\n    \"segments\": [\n        {\n            \"id\": 0,\n            \"color\": \"#0000FF\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 1,\n            \"color\": \"#0000FF\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 2,\n            \"color\": \"#0000FF\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 3,\n            \"color\": \"#0000FF\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 4,\n            \"color\": \"#FF0000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 5,\n            \"color\": \"#FF0000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 6,\n            \"color\": \"#FF0000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 7,\n            \"color\": \"#FF0000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 8,\n            \"color\": \"#FF0000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 9,\n            \"color\": \"#008000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 10,\n            \"color\": \"#008000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 11,\n            \"color\": \"#008000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 12,\n            \"color\": \"#008000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 13,\n            \"color\": \"#008000\",\n            \"brightness\": 70\n        },\n        {\n            \"id\": 14,\n            \"color\": \"#008000\",\n            \"brightness\": 70\n        }\n    ]\n}","output":"json","x":490,"y":260,"wires":[[]]},{"id":"9cd1a9a670a2457f","type":"template","z":"6f0c45810e08f8f3","name":"snapshot and brightness","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n    \"command\": \"multi\",\n    \"name\": \"Light1\",\n    \"powerSwitch\": 1,\n    \"gradientToggle\": 1,\n    \"snapshot\": 2335341,\n    \"brightness\": 10\n}","output":"json","x":530,"y":220,"wires":[[]]}]
Created 1 year, 3 months ago
  • debug (x2)
  • delay (x1)
  • function (x2)
  • http request (x1)
  • inject (x9)
  • template (x3)
  • govee
