ServiceNow Incidents
Basic interactions with ServiceNow for testing APIs in incident response flows.
After instantiating the ServiceNow instance, you can either get incidents or create incidents. These are basic examples of how to interact with the ServiceNow API and should be built upon depending on need.
Get a ServiceNow developer instance here
See here for information on ServiceNow's API Explorer.
[{"id":"a538e06a.cfed5","type":"subflow","name":"get-incident","info":"","category":"ServiceNow","in":[{"x":140,"y":180,"wires":[{"id":"a526d17c.a46e3"}]}],"out":[{"x":1940,"y":140,"wires":[{"id":"62f9b6be.0d1258","port":0}]},{"x":1940,"y":220,"wires":[{"id":"69cc935c.bd621c","port":0}]}],"env":[],"status":{"x":320,"y":80,"wires":[{"id":"79fba0d8.bd0f2","port":0}]}},{"id":"3c258348.1cc89c","type":"function","z":"a538e06a.cfed5","name":"Prepare Request","func":"msg.url = [msg.cb.url, 'api/now/table/incident'].join('/');\n\nmsg.headers = {\n    'authorization': [msg.cb.custom_api_key, msg.cb.custom_api_id].join('/'),\n    'Content-Type': 'Basic ' + msg.sn.auth\n};\n\nmsg.payload = msg.sn.body;\ndelete msg.sn.body;\ndelete msg.sn.auth;\n\nreturn msg;","outputs":1,"noerr":0,"x":1190,"y":180,"wires":[["505a2109.4c85e"]]},{"id":"505a2109.4c85e","type":"http request","z":"a538e06a.cfed5","name":"get incident","method":"GET","ret":"obj","paytoqs":false,"url":"","tls":"","proxy":"","authType":"","x":1390,"y":180,"wires":[["45ba0e54.457a5"]]},{"id":"45ba0e54.457a5","type":"switch","z":"a538e06a.cfed5","name":"status code","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1570,"y":180,"wires":[["62f9b6be.0d1258"],["69cc935c.bd621c"]]},{"id":"79fba0d8.bd0f2","type":"status","z":"a538e06a.cfed5","name":"","scope":["62f9b6be.0d1258","a526d17c.a46e3","69cc935c.bd621c"],"x":200,"y":80,"wires":[[]]},{"id":"62f9b6be.0d1258","type":"function","z":"a538e06a.cfed5","name":"set status","func":"node.status({\n    fill: 'green',\n    text: msg.payload.name\n})\n\nreturn msg;","outputs":1,"noerr":0,"x":1780,"y":140,"wires":[[]]},{"id":"a526d17c.a46e3","type":"function","z":"a538e06a.cfed5","name":"set status","func":"if (!msg.cb) {\n    node.status({\n        fill: 'red',\n        text: 'cb not instantiated'\n    });\n    return;\n}\n\nelse {\n    node.status({\n        fill: 'grey',\n        text: 'getting device ' + msg.payload\n    });\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":280,"y":180,"wires":[["d2ecb83c.3a4c28"]]},{"id":"69cc935c.bd621c","type":"function","z":"a538e06a.cfed5","name":"set status","func":"node.status({\n    fill: 'red',\n    shape: 'ring',\n    text: [msg.statusCode, msg.payload.message].join(': ')\n});\n\nreturn msg;","outputs":1,"noerr":0,"x":1780,"y":220,"wires":[[]]},{"id":"d2ecb83c.3a4c28","type":"delay","z":"a538e06a.cfed5","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":460,"y":180,"wires":[["cb972086.11f88"]]},{"id":"5b951bc2.0f44e4","type":"base64","z":"a538e06a.cfed5","name":"encode credentials","action":"str","property":"sn.auth","x":950,"y":180,"wires":[["3c258348.1cc89c"]]},{"id":"cb972086.11f88","type":"function","z":"a538e06a.cfed5","name":"prepare authentication","func":"msg.sn.body = msg.payload;\nmsg.sn.auth = [msg.sn.username, ms.sn.password].join(':');\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":180,"wires":[["5b951bc2.0f44e4"]]},{"id":"6602dbf.7812b24","type":"subflow","name":"create-incident","info":"","category":"ServiceNow","in":[{"x":160,"y":180,"wires":[{"id":"d0757d31.3542b"}]}],"out":[{"x":1860,"y":140,"wires":[{"id":"d65e5913.113278","port":0}]},{"x":1860,"y":220,"wires":[{"id":"21531c4f.cf2374","port":0}]}],"env":[],"status":{"x":320,"y":80,"wires":[{"id":"9ea9dc75.c1806","port":0}]}},{"id":"748f26c2.1e0928","type":"function","z":"6602dbf.7812b24","name":"create ticket","func":"msg.url = [msg.cb.url, 'api/now/table/incident'].join('/');\n\nmsg.headers = {\n    'authorization': [msg.cb.custom_api_key, msg.cb.custom_api_id].join('/'),\n    'Content-Type': 'Basic ' + msg.sn.auth\n};\n\nmsg.payload = msg.sn.body;\ndelete msg.sn.body;\ndelete msg.sn.auth;\n\nreturn msg;","outputs":1,"noerr":0,"x":1110,"y":180,"wires":[["fbc92c75.e7653"]]},{"id":"fbc92c75.e7653","type":"http request","z":"6602dbf.7812b24","name":"create incident","method":"GET","ret":"obj","paytoqs":false,"url":"","tls":"","proxy":"","authType":"","x":1320,"y":180,"wires":[["c18462bf.e06bf"]]},{"id":"c18462bf.e06bf","type":"switch","z":"6602dbf.7812b24","name":"status code","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1510,"y":180,"wires":[["d65e5913.113278"],["21531c4f.cf2374"]]},{"id":"9ea9dc75.c1806","type":"status","z":"6602dbf.7812b24","name":"","scope":["d65e5913.113278","d0757d31.3542b","21531c4f.cf2374"],"x":200,"y":80,"wires":[[]]},{"id":"d65e5913.113278","type":"function","z":"6602dbf.7812b24","name":"set status","func":"node.status({\n    fill: 'green',\n    text: msg.payload.name\n})\n\nreturn msg;","outputs":1,"noerr":0,"x":1720,"y":140,"wires":[[]]},{"id":"d0757d31.3542b","type":"function","z":"6602dbf.7812b24","name":"set status","func":"if (!msg.cb) {\n    node.status({\n        fill: 'red',\n        text: 'cb not instantiated'\n    });\n    return;\n}\n\nelse {\n    node.status({\n        fill: 'grey',\n        text: 'getting device ' + msg.payload\n    });\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":280,"y":180,"wires":[["f80c6412.5cef78"]]},{"id":"21531c4f.cf2374","type":"function","z":"6602dbf.7812b24","name":"set status","func":"node.status({\n    fill: 'red',\n    shape: 'ring',\n    text: [msg.statusCode, msg.payload.message].join(': ')\n});\n\nreturn msg;","outputs":1,"noerr":0,"x":1720,"y":220,"wires":[[]]},{"id":"f80c6412.5cef78","type":"delay","z":"6602dbf.7812b24","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":460,"y":180,"wires":[["fc03388b.4d5a58"]]},{"id":"916eda48.9b44a8","type":"base64","z":"6602dbf.7812b24","name":"","action":"str","property":"sn.auth","x":920,"y":180,"wires":[["748f26c2.1e0928"]]},{"id":"fc03388b.4d5a58","type":"function","z":"6602dbf.7812b24","name":"prepare authentication","func":"msg.sn.body = msg.payload;\nmsg.sn.auth = [msg.sn.username, ms.sn.password].join(':');\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":180,"wires":[["916eda48.9b44a8"]]},{"id":"fedd182.e0ce6e8","type":"subflow","name":"initialize","info":"","category":"ServiceNow","in":[{"x":160,"y":140,"wires":[{"id":"82011eac.ee18f"}]}],"out":[{"x":600,"y":140,"wires":[{"id":"246ea08e.5c881","port":0}]}],"env":[],"status":{"x":320,"y":80,"wires":[{"id":"eb7b489a.3dcfb8","port":0}]}},{"id":"82011eac.ee18f","type":"change","z":"fedd182.e0ce6e8","name":"","rules":[{"t":"set","p":"sn.url","pt":"msg","to":"URL","tot":"env"},{"t":"set","p":"sn.username","pt":"msg","to":"USERNAME","tot":"env"},{"t":"set","p":"sn.password","pt":"msg","to":"PASSWORD","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":140,"wires":[["246ea08e.5c881"]]},{"id":"246ea08e.5c881","type":"function","z":"fedd182.e0ce6e8","name":"set status","func":"node.status({\n    fill: 'green',\n    text: 'instantiated'\n});\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":140,"wires":[[]]},{"id":"eb7b489a.3dcfb8","type":"status","z":"fedd182.e0ce6e8","name":"","scope":null,"x":200,"y":80,"wires":[[]]},{"id":"ee7d7e15.e8ad","type":"subflow:fedd182.e0ce6e8","z":"3c0945fd.ca1b9a","name":"","env":[],"x":830,"y":840,"wires":[[]]},{"id":"5fb39144.5f9c2","type":"subflow:6602dbf.7812b24","z":"3c0945fd.ca1b9a","name":"","env":[],"x":860,"y":920,"wires":[[],[]]},{"id":"e4f45b14.d264a8","type":"subflow:a538e06a.cfed5","z":"3c0945fd.ca1b9a","name":"","env":[],"x":850,"y":880,"wires":[[],[]]}]
Created 7 years, 1 month ago
  • change (x1)
  • delay (x2)
  • function (x11)
  • http request (x2)
  • status (x3)
  • switch (x2)
  • base64 (x2)
  • subflow (x3)
  • subflow:6602dbf.7812b24 (x1)
  • subflow:a538e06a.cfed5 (x1)
  • subflow:fedd182.e0ce6e8 (x1)
  • ServiceNow
