Contol Sonoff with Tasmota from NR
This flow shows how to control a Sonoff Basic running Tasmota firmware from Node Red.
For full details, see my Youtube video on this topic: https://youtu.be/pVPPiYAo8NI
[{"id":"181ebae.427af45","type":"tab","label":"Tasmota","disabled":false,"info":""},{"id":"c1aa56ff.b14e78","type":"mqtt in","z":"181ebae.427af45","name":"","topic":"stat/Sonoff5/#","qos":"0","broker":"cea5258a.b34038","x":150,"y":80,"wires":[["5472bf06.015ec"]]},{"id":"63ff6881.463a18","type":"debug","z":"181ebae.427af45","name":"","active":true,"console":"false","complete":"false","x":790,"y":140,"wires":[]},{"id":"ccd2aa21.514678","type":"mqtt out","z":"181ebae.427af45","name":"","topic":"cmnd/Sonoff5/power","qos":"0","retain":"","broker":"cea5258a.b34038","x":400,"y":300,"wires":[]},{"id":"a3fe5654.a107d8","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"x":170,"y":300,"wires":[["ccd2aa21.514678"]]},{"id":"9d353b99.5aa628","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"x":170,"y":340,"wires":[["ccd2aa21.514678"]]},{"id":"680a7b7d.d2baa4","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"toggle","payloadType":"str","repeat":"","crontab":"","once":false,"x":170,"y":380,"wires":[["ccd2aa21.514678"]]},{"id":"d73ca460.a6f9b8","type":"comment","z":"181ebae.427af45","name":"Subscribe to all messages","info":"This is just to subscribe to all messages \ncoming from ESPurna. You can turn this off\nonce you are completed the setup.\n\nHere I put the same topic ID as what I entered\non the UI and # at the end.","x":150,"y":40,"wires":[]},{"id":"bb4c6492.c181e8","type":"comment","z":"181ebae.427af45","name":"MQTT control","info":"Controlling the relay via MQTT\n\nroot topic followed by relay/0/set\naccepted messages:\n0: off\n1: on\n2: toggle","x":130,"y":260,"wires":[]},{"id":"1aadef2e.7a6461","type":"mqtt out","z":"181ebae.427af45","name":"","topic":"cmnd/Sonoff5/status","qos":"0","retain":"","broker":"cea5258a.b34038","x":380,"y":200,"wires":[]},{"id":"ba7373d.040b89","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"x":150,"y":200,"wires":[["1aadef2e.7a6461"]]},{"id":"b397fa40.e6bcb8","type":"json","z":"181ebae.427af45","name":"","pretty":false,"x":610,"y":80,"wires":[["63ff6881.463a18"]]},{"id":"5472bf06.015ec","type":"switch","z":"181ebae.427af45","name":"JSON format?","property":"$substring(msg.payload, 0, 1)=\"{\"","propertyType":"jsonata","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","outputs":2,"x":380,"y":80,"wires":[["b397fa40.e6bcb8"],["63ff6881.463a18"]]},{"id":"c687fd48.8ab08","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"blink","payloadType":"str","repeat":"","crontab":"","once":false,"x":170,"y":420,"wires":[["ccd2aa21.514678"]]},{"id":"b03db395.42b01","type":"mqtt in","z":"181ebae.427af45","name":"","topic":"tele/Sonoff5/#","qos":"0","broker":"cea5258a.b34038","x":150,"y":140,"wires":[["5472bf06.015ec"]]},{"id":"3915750.222fa8c","type":"comment","z":"181ebae.427af45","name":"Control from UI","info":"This section shows a simple dashboard UI to \ncontrol and display the status of the unit.\n\nI use MQTT to control it, but it could also be\nHTTP as well.","x":120,"y":840,"wires":[]},{"id":"76bacf4d.9011c","type":"ui_switch","z":"181ebae.427af45","name":"","label":"Switch relay","group":"12e8425e.99449e","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":150,"y":880,"wires":[["37105e76.de1182"]]},{"id":"37105e76.de1182","type":"mqtt out","z":"181ebae.427af45","name":"","topic":"cmnd/Sonoff5/power","qos":"0","retain":"","broker":"cea5258a.b34038","x":540,"y":880,"wires":[]},{"id":"eef7866d.e61608","type":"ui_button","z":"181ebae.427af45","name":"","group":"12e8425e.99449e","order":2,"width":0,"height":0,"passthru":false,"label":"Toggle relay","color":"","bgcolor":"","icon":"","payload":"toggle","payloadType":"str","topic":"","x":150,"y":920,"wires":[["37105e76.de1182"]]},{"id":"78f75a7c.c76df4","type":"ui_template","z":"181ebae.427af45","group":"12e8425e.99449e","name":"Relay state","order":3,"width":"","height":"","format":"<div layout=\"row\" layout-align=\"space-between\">\n    <p>Relay state</p>\n    <p ng-style=\"{color: msg.payload === 'ON' ? 'blue' : 'grey'}\">\n        <b>{{msg.payload === 'ON' ? 'ON' : 'OFF'}}</b>\n    </p>\n</div>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":510,"y":1060,"wires":[[]]},{"id":"b1e90981.e768a8","type":"mqtt in","z":"181ebae.427af45","name":"","topic":"stat/Sonoff5/POWER","qos":"0","broker":"cea5258a.b34038","x":180,"y":1060,"wires":[["78f75a7c.c76df4"]]},{"id":"f3e24c3f.17bdb","type":"ui_button","z":"181ebae.427af45","name":"","group":"12e8425e.99449e","order":4,"width":0,"height":0,"passthru":false,"label":"Turn On","color":"","bgcolor":"","icon":"","payload":"on","payloadType":"str","topic":"","x":140,"y":960,"wires":[["37105e76.de1182"]]},{"id":"bf52119c.64815","type":"ui_slider","z":"181ebae.427af45","name":"","label":"Pulse Time","group":"12e8425e.99449e","order":6,"width":0,"height":0,"passthru":true,"topic":"","min":0,"max":"200","step":1,"x":150,"y":1140,"wires":[["9afc0d4d.5af65"]]},{"id":"9afc0d4d.5af65","type":"mqtt out","z":"181ebae.427af45","name":"","topic":"cmnd/Sonoff5/PulseTime","qos":"0","retain":"","broker":"cea5258a.b34038","x":610,"y":1140,"wires":[]},{"id":"e6239a94.1e8088","type":"mqtt in","z":"181ebae.427af45","name":"","topic":"tele/Sonoff5/STATE","qos":"0","broker":"cea5258a.b34038","x":170,"y":1240,"wires":[["39dc90ea.ef63"]]},{"id":"119c1e6f.33b242","type":"function","z":"181ebae.427af45","name":"Store last update","func":"var devicename = \"Sonoff5\";\n\nvar temp = global.get(devicename+\"_wifi\");\nvar current = new Date();\nif (temp!== undefined && temp!==null) {\n    msg.payload = current.getTime() - temp;\n    global.set(devicename+\"_wifi\",current.getTime());\n} else {\n    msg.payload = \"\";\n    global.set(devicename+\"_wifi\",current.getTime());\n}\n\n// Update the status with current timestamp\nvar now = new Date();\nvar yyyy = now.getFullYear();\nvar mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nvar dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nvar hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nvar mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nvar ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\nnode.status({fill:\"blue\",shape:\"ring\",text:\"Last update: \"+dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss});\n\nmsg.formattedtime = dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss;\n\nreturn msg;","outputs":1,"noerr":0,"x":650,"y":1340,"wires":[[]]},{"id":"8eb394c3.8f6ef8","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"x":170,"y":1400,"wires":[["38183682.36655a"]]},{"id":"38183682.36655a","type":"function","z":"181ebae.427af45","name":"From last update","func":"var devicename = \"Sonoff5\";\n\nvar temp = global.get(devicename+\"_wifi\");\nvar current = new Date();\nmsg.payload = \"No data\";\nmsg.warning = false;\n\nif (temp!==undefined) {\n    current = current - temp;\n    current = Math.floor(current/1000);\n    var minute = Math.floor(current/60);\n    var hour = Math.floor(minute/60);\n    var day = Math.floor(hour/24);\n    if (current>24*60*60) {\n        msg.payload = \"Last update \" + day + \" days, \" + hour%24 + \" hours, \" + minute%60 + \" minutes, \" + current%60 + \" seconds ago\";\n    } else if (current>60*60) {\n        msg.payload = \"Last update \" + hour%24 + \" hours, \" + minute%60 + \" minutes, \" + current%60 + \" seconds ago\";\n    } else if (current>60) {\n        msg.payload = \"Last update \" + minute%60 + \" minutes, \" + current%60 + \" seconds ago\";\n    } else {\n        msg.payload = \"Last update \" + current%60 + \" seconds ago\";\n    }\n\n}\n\nnode.status({fill:\"blue\",shape:\"ring\",text:msg.payload});\n\n\nreturn msg;","outputs":1,"noerr":0,"x":410,"y":1400,"wires":[["d4b0f7eb.5a2178"]]},{"id":"17128322.7905fd","type":"ui_text","z":"181ebae.427af45","group":"12e8425e.99449e","order":7,"width":0,"height":0,"name":"","label":"Uptime","format":"{{msg.payload.Uptime}}","layout":"row-spread","x":620,"y":1240,"wires":[]},{"id":"d4b0f7eb.5a2178","type":"ui_text","z":"181ebae.427af45","group":"12e8425e.99449e","order":9,"width":0,"height":0,"name":"Last Update","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":1400,"wires":[]},{"id":"e4100f8d.81bf5","type":"ui_gauge","z":"181ebae.427af45","name":"Wifi gauge","group":"12e8425e.99449e","order":8,"width":0,"height":0,"gtype":"gage","title":"","label":"","format":"{{value}}","min":"0","max":"100","colors":["#ff0000","#e6e600","#00b500"],"seg1":"","seg2":"","x":830,"y":1300,"wires":[]},{"id":"39dc90ea.ef63","type":"json","z":"181ebae.427af45","name":"","pretty":false,"x":350,"y":1240,"wires":[["17128322.7905fd","119c1e6f.33b242","4c8ea663.ccc388"]]},{"id":"4c6731d4.ec9e2","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":180,"y":560,"wires":[["645e0b44.542954"]]},{"id":"645e0b44.542954","type":"http request","z":"181ebae.427af45","name":"Relay off","method":"GET","ret":"txt","url":"http://192.168.1.129/cm?cmnd=POWER OFF","tls":"","x":380,"y":560,"wires":[[]]},{"id":"bdd35d4d.e8a0f","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":180,"y":600,"wires":[["a696085c.4320a8"]]},{"id":"a696085c.4320a8","type":"http request","z":"181ebae.427af45","name":"Relay on","method":"GET","ret":"txt","url":"http://192.168.1.129/cm?cmnd=POWER ON","tls":"","x":380,"y":600,"wires":[[]]},{"id":"6a1c7504.74d50c","type":"http request","z":"181ebae.427af45","name":"Relay toggle","method":"GET","ret":"txt","url":"http://192.168.1.129/cm?cmnd=POWER TOGGLE","tls":"","x":390,"y":640,"wires":[[]]},{"id":"ec24064b.f628d8","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":180,"y":640,"wires":[["6a1c7504.74d50c"]]},{"id":"1c715e7d.da7d72","type":"http request","z":"181ebae.427af45","name":"Status","method":"GET","ret":"txt","url":"http://192.168.1.129/cm?cmnd=STATUS","tls":"","x":370,"y":700,"wires":[["26418c87.51e1b4"]]},{"id":"67314bd.aaa56b4","type":"inject","z":"181ebae.427af45","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":180,"y":700,"wires":[["1c715e7d.da7d72"]]},{"id":"26418c87.51e1b4","type":"debug","z":"181ebae.427af45","name":"","active":true,"console":"false","complete":"false","x":570,"y":700,"wires":[]},{"id":"cf7d1162.961f8","type":"comment","z":"181ebae.427af45","name":"HTTP control","info":"Controlling the relay via HTTP\nHTTP API in the admin page need to be turned off\nCopy the api key from the admin page\n\nURL http://<ip>/api/relay/0?apikey=<api key>&value=0\naccepted values (at the end):\n0: off\n1: on\n2: toggle","x":130,"y":520,"wires":[]},{"id":"8d09887b.9f33e8","type":"ui_button","z":"181ebae.427af45","name":"","group":"12e8425e.99449e","order":5,"width":0,"height":0,"passthru":false,"label":"Turn Off","color":"","bgcolor":"","icon":"","payload":"off","payloadType":"str","topic":"","x":140,"y":1000,"wires":[["37105e76.de1182"]]},{"id":"4c8ea663.ccc388","type":"change","z":"181ebae.427af45","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Wifi.RSSI","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":1300,"wires":[["e4100f8d.81bf5"]]},{"id":"cea5258a.b34038","type":"mqtt-broker","z":"","broker":"192.168.1.80","port":"1883","clientid":"node-red","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"12e8425e.99449e","type":"ui_group","z":"","name":"Sonoff Basic","tab":"43af4535.136d5c","disp":true,"width":"6"},{"id":"43af4535.136d5c","type":"ui_tab","z":"","name":"Tasmota","icon":"dashboard"}]
Created 9 years ago
Updated 6 years, 5 months ago
  • change (x1)
  • comment (x4)
  • debug (x2)
  • function (x2)
  • http request (x4)
  • inject (x10)
  • json (x2)
  • mqtt in (x4)
  • mqtt out (x4)
  • mqtt-broker (x1)
  • switch (x1)
  • ui_button (x3)
  • ui_gauge (x1)
  • ui_group (x1)
  • ui_slider (x1)
  • ui_switch (x1)
  • ui_template (x1)
  • ui_text (x2)
  • sonoff
  • tasmota
