Crypto-Blue: Public Key Infrastructure Node
The PKI
node is used to generate Ed25519 key-pairs, sign message payloads and verify payload signatures. The following properties can be configured for the node:
Function
: The node's functions, choices include:- Generate Keys
- Sign Payload
- Verify Signature
Private Key
(string): The private key to use in the signing process, must be inhex
format. This can also be configured through themsg.privateKey
field of an injected message.Public Key
(string): The public key to use in the signature verification process, must be inhex
format. This can also be configured through themsg.publicKey
[{"id":"7c3f6a136657225e","type":"inject","z":"d4703d9e2676369d","name":"PKI Injector","props":[{"p":"message","v":"Hello World","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1190,"y":680,"wires":[["90622efcab74bc6c"]]},{"id":"90622efcab74bc6c","type":"pki","z":"d4703d9e2676369d","name":"","function":"Generate Keys","privateKey":"","publicKey":"","x":1480,"y":680,"wires":[["00468b1e27963b46","6517de1a33dabbdf"]]},{"id":"00468b1e27963b46","type":"debug","z":"d4703d9e2676369d","name":"Print Payload Result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1740,"y":740,"wires":[]},{"id":"04cf4d21c4ea859e","type":"pki","z":"d4703d9e2676369d","name":"","function":"Sign Payload","privateKey":"","publicKey":"","x":1490,"y":740,"wires":[["00468b1e27963b46","c160f5df437874c3"]]},{"id":"6517de1a33dabbdf","type":"change","z":"d4703d9e2676369d","name":"Set Key-Pair","rules":[{"t":"move","p":"payload.privateKey","pt":"msg","to":"privateKey","tot":"msg"},{"t":"move","p":"payload.publicKey","pt":"msg","to":"publicKey","tot":"msg"},{"t":"move","p":"message","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":740,"wires":[["04cf4d21c4ea859e"]]},{"id":"c160f5df437874c3","type":"pki","z":"d4703d9e2676369d","name":"","function":"Verify Signature","privateKey":"","publicKey":"","x":1480,"y":800,"wires":[["00468b1e27963b46"]]}]
