Download a solar system forecast from Solcast
Solcast allows you to setup the details of your solar system, size, orientation, location etc. It then provides an API so you can download this forecast on a regular basis.
This flow downloads that 3 day forecast on an hourly basis, provides a simple dashboard as well as sets up a bunch of global values for use within your flows.
This code downloads a solar forecast for use with home automation within node-red.
Firstly you need to setup an account with solcast. https://solcast.com/
Setup your site with details on your solar panels, size, orientation etc. This will then provide you with a site ID an authentication details.
You will need to edit the http node (SolarForecast) in node-red. Change the URL to include your resource-id and also change the bearer token.
Resource ID is the API URL from the solcast site page Bearer tolken is the API key which comes from your account page in solcast.
By default it’s scheduled to run every hour.
Download Solcast dashboard as well to give you a working dashboard
[{"id":"c6e1753f802e5da8","type":"tab","label":"Solcast","disabled":false,"info":""},{"id":"29c5c88c5e35da06","type":"http request","z":"c6e1753f802e5da8","name":"SolarForecast","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.solcast.com.au/rooftop_sites/<resource-id>/forecasts?format=json&hours=72","tls":"","persist":false,"proxy":"","authType":"bearer","senderr":false,"x":480,"y":180,"wires":[["f65a76176e9dd131","c81382fa001876e9"]]},{"id":"f65a76176e9dd131","type":"debug","z":"c6e1753f802e5da8","name":"Solarforecast","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":200,"wires":[]},{"id":"d88272138bc4c31c","type":"inject","z":"c6e1753f802e5da8","name":"Get PV Forecast","props":[{"p":"payload"}],"repeat":"3600","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":230,"y":180,"wires":[["29c5c88c5e35da06"]]},{"id":"193ee9b5f86b2563","type":"inject","z":"c6e1753f802e5da8","name":"Read cache PV Forecast","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"300","crontab":"","once":false,"onceDelay":"30","topic":"","payloadType":"date","x":260,"y":400,"wires":[["f866835aad44babf","96b69b48654fc80a"]]},{"id":"1bc841a4b0c71079","type":"function","z":"c6e1753f802e5da8","name":"Extract All","func":"// add up all the values:\nfor (var i in msg.payload.forecasts) {\n    msg.payload.forecasts[i] = Number(msg.payload.forecasts[i].pv_estimate);\n    }\n        msg.payload.pvtotal = msg.payload.forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nmsg.payload.pvtotal = msg.payload.pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1000,"y":380,"wires":[["fe68be8f09db61f3","488f446ff16a34c7","f3c4d443bdcf9c9b"]]},{"id":"fe68be8f09db61f3","type":"debug","z":"c6e1753f802e5da8","name":"GetPVArray","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1270,"y":300,"wires":[]},{"id":"f866835aad44babf","type":"debug","z":"c6e1753f802e5da8","name":"Working","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":520,"y":400,"wires":[]},{"id":"488f446ff16a34c7","type":"change","z":"c6e1753f802e5da8","name":"PVForecast to global","rules":[{"t":"set","p":"pvforecast","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300,"y":380,"wires":[[]]},{"id":"a7bcc02538495e28","type":"change","z":"c6e1753f802e5da8","name":"PVForecastObject to global","rules":[{"t":"set","p":"pvobject","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":120,"wires":[["dd13c7fc9b94e5fe"]]},{"id":"aceb03b0541d8887","type":"json","z":"c6e1753f802e5da8","name":"","property":"payload","action":"","pretty":false,"x":930,"y":80,"wires":[["a0c23e9492571fe7"]]},{"id":"a0c23e9492571fe7","type":"file","z":"c6e1753f802e5da8","name":"","filename":"solarforecast.txt","appendNewline":true,"createDir":false,"overwriteFile":"true","encoding":"none","x":1100,"y":80,"wires":[["46e434c99ee79771"]]},{"id":"96b69b48654fc80a","type":"file in","z":"c6e1753f802e5da8","name":"","filename":"solarforecast.txt","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":540,"y":340,"wires":[["7d17eb6ce917c778"]]},{"id":"7d17eb6ce917c778","type":"json","z":"c6e1753f802e5da8","name":"","property":"payload","action":"","pretty":false,"x":710,"y":340,"wires":[["c6cfb79dbbe4dbb1","1bc841a4b0c71079","288d3550032d180b","c0f579822b8d909a","6ad7b82cf0605133","29753a32b6532691","97dca6b84dfa01ce","af0f4a169f3b2d90","1ffcbdd0b57ee130","58e18f365ec16b92","031c5b77e02c21be"]]},{"id":"c6cfb79dbbe4dbb1","type":"debug","z":"c6e1753f802e5da8","name":"readfile","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":940,"y":340,"wires":[]},{"id":"46e434c99ee79771","type":"debug","z":"c6e1753f802e5da8","name":"GetSolcastSuccess","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1310,"y":80,"wires":[]},{"id":"f247f2acd3080a6d","type":"comment","z":"c6e1753f802e5da8","name":"Get Forecast from Solcast","info":"","x":230,"y":140,"wires":[]},{"id":"ce45c7ed7dbbbd48","type":"comment","z":"c6e1753f802e5da8","name":"Check for update every 5 minutes","info":"","x":250,"y":360,"wires":[]},{"id":"f3c4d443bdcf9c9b","type":"change","z":"c6e1753f802e5da8","name":"Write forecasts array to global","rules":[{"t":"set","p":"individualforecast","pt":"global","to":"payload.forecasts","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":340,"wires":[[]]},{"id":"288d3550032d180b","type":"function","z":"c6e1753f802e5da8","name":"Extract 12 hours","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 0; i < 24; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":526,"wires":[["0ee688a2564d6376","b36cd078b5a4138a"]]},{"id":"0ee688a2564d6376","type":"change","z":"c6e1753f802e5da8","name":"12 hour PVForecast to global","rules":[{"t":"set","p":"pvforecast12","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":566,"wires":[[]]},{"id":"b36cd078b5a4138a","type":"debug","z":"c6e1753f802e5da8","name":"12h PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1310,"y":526,"wires":[]},{"id":"c0f579822b8d909a","type":"function","z":"c6e1753f802e5da8","name":"Extract 24 hours","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 0; i < 48; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":614,"wires":[["92226e02b661802b","3f29ce2e9729e699"]]},{"id":"92226e02b661802b","type":"change","z":"c6e1753f802e5da8","name":"24 hour PVForecast to global","rules":[{"t":"set","p":"pvforecast24","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300,"y":654,"wires":[[]]},{"id":"3f29ce2e9729e699","type":"debug","z":"c6e1753f802e5da8","name":"24h PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1280,"y":614,"wires":[]},{"id":"6ad7b82cf0605133","type":"function","z":"c6e1753f802e5da8","name":"Extract pessimistic 12 hours","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 0; i < 24; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate10;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1040,"y":860,"wires":[["e86270033a0eaa22","54e053f062c19b9e"]]},{"id":"e86270033a0eaa22","type":"change","z":"c6e1753f802e5da8","name":"12 hour P10 forecast to global","rules":[{"t":"set","p":"pvforecast12P10","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1410,"y":902,"wires":[[]]},{"id":"54e053f062c19b9e","type":"debug","z":"c6e1753f802e5da8","name":"12h PV P10","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1350,"y":860,"wires":[]},{"id":"29753a32b6532691","type":"function","z":"c6e1753f802e5da8","name":"Extract pessimistic 24 hours","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 0; i < 48; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate10;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1060,"y":946,"wires":[["ceaaaab9aaea4c95","cae9b08088d89387"]]},{"id":"ceaaaab9aaea4c95","type":"change","z":"c6e1753f802e5da8","name":"24 hour P10 forecast to global","rules":[{"t":"set","p":"pvforecast24P10","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1410,"y":989,"wires":[[]]},{"id":"cae9b08088d89387","type":"debug","z":"c6e1753f802e5da8","name":"24h PV P10","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1350,"y":946,"wires":[]},{"id":"97dca6b84dfa01ce","type":"function","z":"c6e1753f802e5da8","name":"Extract Day 48","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 49; i < 96; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":694,"wires":[["69ce95ae3fc488b3","32cdc62ac5d14f66"]]},{"id":"69ce95ae3fc488b3","type":"change","z":"c6e1753f802e5da8","name":"48 hour PVForecast to global","rules":[{"t":"set","p":"PVForecast48","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":734,"wires":[[]]},{"id":"32cdc62ac5d14f66","type":"debug","z":"c6e1753f802e5da8","name":"24h PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1300,"y":694,"wires":[]},{"id":"af0f4a169f3b2d90","type":"function","z":"c6e1753f802e5da8","name":"Extract Day 72","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 97; i < 143; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":774,"wires":[["e6eba56cf54fe404","88d2d9b62c68fe73"]]},{"id":"e6eba56cf54fe404","type":"change","z":"c6e1753f802e5da8","name":"Day 72 PVForecast to global","rules":[{"t":"set","p":"PVForecast72","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":814,"wires":[[]]},{"id":"88d2d9b62c68fe73","type":"debug","z":"c6e1753f802e5da8","name":"24h PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1320,"y":774,"wires":[]},{"id":"1ffcbdd0b57ee130","type":"function","z":"c6e1753f802e5da8","name":"Extract P10 Day 2","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 49; i < 96; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate10;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1070,"y":1035,"wires":[["64aa203b4f464137","3f8b74ccafba9125"]]},{"id":"64aa203b4f464137","type":"change","z":"c6e1753f802e5da8","name":"Day 2 PVForecast to global","rules":[{"t":"set","p":"PVForecastD2P10","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1360,"y":1075,"wires":[[]]},{"id":"3f8b74ccafba9125","type":"debug","z":"c6e1753f802e5da8","name":"24h PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1340,"y":1035,"wires":[]},{"id":"58e18f365ec16b92","type":"function","z":"c6e1753f802e5da8","name":"Extract P10 Day 3","func":"// add up all the values:\nvar pvtotal = 0\nvar forecasts = []\nfor (var i = 97; i < 143; i++) {\n    forecasts[i] = msg.payload.forecasts[i].pv_estimate10;\n    }\n        pvtotal = forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nset = msg.payload.forecasts = forecasts\nmsg.payload.pvtotal = pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1070,"y":1115,"wires":[["e7b6074d13f19ea6","793dee2a3998928f"]]},{"id":"e7b6074d13f19ea6","type":"change","z":"c6e1753f802e5da8","name":"Day 3 PVForecast to global","rules":[{"t":"set","p":"PVForecastD3P10","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":1155,"wires":[[]]},{"id":"793dee2a3998928f","type":"debug","z":"c6e1753f802e5da8","name":"24h PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1360,"y":1115,"wires":[]},{"id":"c81382fa001876e9","type":"switch","z":"c6e1753f802e5da8","name":"Check Forecast Status","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"neq","v":"200","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":730,"y":120,"wires":[["aceb03b0541d8887","a7bcc02538495e28"],["5e46f558db6621c7"]]},{"id":"2197686ef7a50128","type":"debug","z":"c6e1753f802e5da8","name":"GetSolcastFailed","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1230,"y":160,"wires":[]},{"id":"bd3b26d855ed2473","type":"inject","z":"c6e1753f802e5da8","name":"Read cache PV Forecast","props":[{"p":"payload"}],"repeat":"10","crontab":"","once":false,"onceDelay":"30","topic":"","payload":"individualforecast","payloadType":"global","x":250,"y":1240,"wires":[["f9e6352b98d1eaaa"]]},{"id":"1f28eb7b9c53b545","type":"debug","z":"c6e1753f802e5da8","name":"Daily Rollup","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1060,"y":1240,"wires":[]},{"id":"f9e6352b98d1eaaa","type":"function","z":"c6e1753f802e5da8","name":"Extract Daily Total","func":"// add up all the values:\nvar pvtotal = 0\nvar x = -1\nvar zeroday = 0\nvar forecasts = []\nvar dailypv = []\nfor (var i in msg.payload) {\n if (msg.payload[i]==0) {\n   zeroday = 0;\n } else if (zeroday==1) {\n    dailypv[x] = dailypv[x] + msg.payload[i]/2;\n }else{\n    zeroday = 1\n    x = x + 1\n    dailypv[x] = 0\n    dailypv[x] = dailypv[x] + msg.payload[i]/2;\n}}\nmsg.payload = dailypv;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":1240,"wires":[["4878dd1b4cce73a5"]]},{"id":"4878dd1b4cce73a5","type":"change","z":"c6e1753f802e5da8","name":"Set Daily Total to Global","rules":[{"t":"set","p":"DailyTotal","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":1240,"wires":[["1f28eb7b9c53b545"]]},{"id":"82f8f3adac2bdeb4","type":"inject","z":"c6e1753f802e5da8","name":"Read cache PV Forecast","props":[{"p":"payload"}],"repeat":"10","crontab":"","once":false,"onceDelay":"30","topic":"","payload":"individualforecastP10","payloadType":"global","x":250,"y":1280,"wires":[["fcda0bcd9e547ec1"]]},{"id":"c837717139186f2a","type":"debug","z":"c6e1753f802e5da8","name":"Daily Rollup","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1060,"y":1280,"wires":[]},{"id":"fcda0bcd9e547ec1","type":"function","z":"c6e1753f802e5da8","name":"Extract DailyP10 Total","func":"// add up all the values:\nvar pvtotal = 0\nvar x = -1\nvar zeroday = 0\nvar forecasts = []\nvar dailypv = []\nfor (var i in msg.payload) {\n if (msg.payload[i]==0) {\n   zeroday = 0;\n } else if (zeroday==1) {\n    dailypv[x] = dailypv[x] + msg.payload[i]/2;\n }else{\n    zeroday = 1\n    x = x + 1\n    dailypv[x] = 0\n    dailypv[x] = dailypv[x] + msg.payload[i]/2;\n}}\nmsg.payload = dailypv;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":510,"y":1280,"wires":[["2b06f27f02c9e7f7"]]},{"id":"2b06f27f02c9e7f7","type":"change","z":"c6e1753f802e5da8","name":"Set Daily Total to Global","rules":[{"t":"set","p":"DailyTotalP10","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":1280,"wires":[["c837717139186f2a"]]},{"id":"bd7319d721ca078a","type":"change","z":"c6e1753f802e5da8","name":"PVForecast to global","rules":[{"t":"set","p":"pvforecastP10","pt":"global","to":"payload.pvtotal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300,"y":480,"wires":[[]]},{"id":"c5c6050f03989745","type":"change","z":"c6e1753f802e5da8","name":"Write forecasts array to global","rules":[{"t":"set","p":"individualforecastP10","pt":"global","to":"payload.forecasts","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":440,"wires":[[]]},{"id":"031c5b77e02c21be","type":"function","z":"c6e1753f802e5da8","name":"Extract All P10","func":"// add up all the values:\nfor (var i in msg.payload.forecasts) {\n    msg.payload.forecasts[i] = Number(msg.payload.forecasts[i].pv_estimate10);\n    }\n        msg.payload.pvtotal = msg.payload.forecasts.reduce(function(a, b){\n        return a + b;\n    }, 0);\n// halve the value due to a reading every 30 minutes:\nmsg.payload.pvtotal = msg.payload.pvtotal/2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":480,"wires":[["bd7319d721ca078a","c5c6050f03989745"]]},{"id":"dd13c7fc9b94e5fe","type":"change","z":"c6e1753f802e5da8","name":"Forecast Status","rules":[{"t":"set","p":"SolCastStatus","pt":"global","to":"Successful","tot":"str"},{"t":"set","p":"SolCastLastFetch","pt":"global","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":120,"wires":[[]]},{"id":"5e46f558db6621c7","type":"change","z":"c6e1753f802e5da8","name":"Forecast Status","rules":[{"t":"set","p":"SolCastStatus","pt":"global","to":"payload.response_status.error_code","tot":"msg"},{"t":"set","p":"SolCastLastFetch","pt":"global","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":160,"wires":[["2197686ef7a50128"]]}]
Rating: 4.5 2
  • change (x17)
  • comment (x2)
  • debug (x16)
  • file (x1)
  • file in (x1)
  • function (x12)
  • http request (x1)
  • inject (x4)
  • json (x2)
  • switch (x1)
  • #solcast
  • #solar
  • #offgrid
