xBee transmit and recieve
Send a personalised message through one xBee and get it on the other one!
Remember to configure your Port number before deploying. This can be found in Windows by going to 'Device Manager' and seeing which ports are connected.
[{"id":"aee4e13d.075b7","type":"tab","label":"Send/Recieve xBee","disabled":true,"info":"Send a personalised message to your xBee transmitter and see that message on your xBee reciever"},{"id":"428bdecb.3eef2","type":"xbee-rx","z":"aee4e13d.075b7","name":"xBee rx","xBee":"f466bf11.58b12","x":230,"y":40,"wires":[["be678a3.11bb678"]]},{"id":"be678a3.11bb678","type":"debug","z":"aee4e13d.075b7","name":"xbee recieved","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":480,"y":40,"wires":[]},{"id":"947859d8.5e11c8","type":"xbee-tx","z":"aee4e13d.075b7","name":"","xBee":"662f3166.97e2a","x":500,"y":160,"wires":[]},{"id":"7cc39ec6.350d3","type":"function","z":"aee4e13d.075b7","name":"dataFrame","func":" var myDataFrame1 = {\n            type: 0x10,\n            id: 0x01,\n            destination64: \"0013a200400a0127\",\n            destination16: \"fffe\",\n            broadcastRadius: 0x00,\n            options: 0x00,\n            data: flow.get(\"words\")||\"hello\"\n        };\n    msg.payload=myDataFrame1;\n\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":160,"wires":[["947859d8.5e11c8","37b8bc95.232c14"]]},{"id":"9df8b4c8.697da8","type":"inject","z":"aee4e13d.075b7","name":"inputLoop","topic":"","payload":"[]","payloadType":"json","repeat":"5","crontab":"","once":true,"onceDelay":0.1,"x":130,"y":160,"wires":[["7cc39ec6.350d3"]]},{"id":"79abc143.509d5","type":"ui_text_input","z":"aee4e13d.075b7","name":"dataIn","label":"DATA INPUT","tooltip":"TYPE HERE","group":"8a213d1c.f3679","order":4,"width":0,"height":0,"passthru":false,"mode":"text","delay":300,"topic":"words","x":250,"y":240,"wires":[["1dd55121.d4815f"]]},{"id":"37b8bc95.232c14","type":"debug","z":"aee4e13d.075b7","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":490,"y":100,"wires":[]},{"id":"1dd55121.d4815f","type":"function","z":"aee4e13d.075b7","name":"save input","func":"flow.set(\"words\", msg.payload)\nreturn msg;","outputs":1,"noerr":0,"x":390,"y":240,"wires":[[]]},{"id":"f466bf11.58b12","type":"xbee-config","z":"","apiMode":"2","rawFrames":false,"convertAdc":true,"vrefAdc":"1200","serialPort":"COM5","lock":true,"baudRate":"9600","dataBits":"8","stopBits":"1","parity":"none","bufferSize":"65536","rtscts":false,"xon":false,"xoff":false,"xany":false,"vmin":"1","vtime":"0"},{"id":"662f3166.97e2a","type":"xbee-config","z":"","apiMode":"2","rawFrames":false,"convertAdc":true,"vrefAdc":"1200","serialPort":"COM6","lock":true,"baudRate":"9600","dataBits":"8","stopBits":"1","parity":"none","bufferSize":"65536","rtscts":false,"xon":false,"xoff":false,"xany":false,"vmin":"1","vtime":"0"},{"id":"8a213d1c.f3679","type":"ui_group","z":"","name":"DATA INPUT","tab":"11214bd0.b00df4","disp":true,"width":"6","collapse":false},{"id":"11214bd0.b00df4","type":"ui_tab","z":"","name":"XBEE STUFF","icon":"dashboard","disabled":false,"hidden":false}]
Created 8 years, 3 months ago
Updated 6 years, 7 months ago
  • debug (x2)
  • function (x2)
  • xbee
  • dashboard
  • text_input
