save data change to database (SQLite)
  • Example JSON object data within an object consists of various separate items.
  • Utilize Function Nodes to access data for each item.
  • Send the obtained data through a filter to check for changes. If the data has changed from the original, it will be sent to the next section.
  • Organize the data into a new format, creating a set of insert commands to store the data in the database.
  • Database section.
[{"id":"7f42f0eec47392cc","type":"sqlite","z":"285ecd284afc36bc","mydb":"95be1cdf72319762","sqlquery":"msg.topic","sql":"","name":"","x":1160,"y":240,"wires":[["1450fb96a13985ab"]]},{"id":"b9e641260d07ae6c","type":"inject","z":"285ecd284afc36bc","name":"select all data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"SELECT * FROM datalog","payload":"","payloadType":"date","x":950,"y":340,"wires":[["7f42f0eec47392cc"]]},{"id":"1450fb96a13985ab","type":"debug","z":"285ecd284afc36bc","name":"debug out","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1340,"y":240,"wires":[]},{"id":"1e74cba1232c842a","type":"rbe","z":"285ecd284afc36bc","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":470,"y":80,"wires":[["18c86194ca931450","673e308d2ff9b92d"]]},{"id":"022fabef50d9af16","type":"inject","z":"285ecd284afc36bc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"item1\":10,\"item2\":20,\"item3\":30,\"item4\":40}","payloadType":"json","x":130,"y":80,"wires":[["9af65dff20cd00b5","8c18bbd3dafc019f","b62c936f28b52683","034ae14bea9fd568","0d895f52ec055f4d"]]},{"id":"18c86194ca931450","type":"debug","z":"285ecd284afc36bc","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":80,"wires":[]},{"id":"be519059c9295bab","type":"rbe","z":"285ecd284afc36bc","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":470,"y":120,"wires":[["941390fb7004e3fc","673e308d2ff9b92d"]]},{"id":"941390fb7004e3fc","type":"debug","z":"285ecd284afc36bc","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":120,"wires":[]},{"id":"9af65dff20cd00b5","type":"function","z":"285ecd284afc36bc","name":"get item1","func":"let data = msg.payload.item1 | 0\nmsg.topic = \"item1\"\nmsg.payload = data\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":80,"wires":[["1e74cba1232c842a"]]},{"id":"8c18bbd3dafc019f","type":"function","z":"285ecd284afc36bc","name":"get item2","func":"let data = msg.payload.item2 | 0\nmsg.topic = \"item2\"\nmsg.payload = data\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":120,"wires":[["be519059c9295bab"]]},{"id":"b0b0ac7479d7ee76","type":"rbe","z":"285ecd284afc36bc","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":470,"y":160,"wires":[["195eaaa6e15ac0c2","673e308d2ff9b92d"]]},{"id":"84d8edc4b53e6b4f","type":"rbe","z":"285ecd284afc36bc","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":470,"y":200,"wires":[["2d3b02bcdd5a4a09","673e308d2ff9b92d"]]},{"id":"b62c936f28b52683","type":"function","z":"285ecd284afc36bc","name":"get item3","func":"let data = msg.payload.item3 | 0\nmsg.topic = \"item3\"\nmsg.payload = data\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":160,"wires":[["b0b0ac7479d7ee76"]]},{"id":"034ae14bea9fd568","type":"function","z":"285ecd284afc36bc","name":"get item4","func":"let data = msg.payload.item4 | 0\nmsg.topic = \"item4\"\nmsg.payload = data\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":200,"wires":[["84d8edc4b53e6b4f"]]},{"id":"195eaaa6e15ac0c2","type":"debug","z":"285ecd284afc36bc","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":160,"wires":[]},{"id":"2d3b02bcdd5a4a09","type":"debug","z":"285ecd284afc36bc","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":200,"wires":[]},{"id":"634d0d8a05fdef63","type":"sql-prepare","z":"285ecd284afc36bc","name":"","x":950,"y":240,"wires":[["7f42f0eec47392cc"]]},{"id":"673e308d2ff9b92d","type":"function","z":"285ecd284afc36bc","name":"mapping data to database","func":"let getmoment = new moment();\nlet datetime = getmoment.tz('Asia/Bangkok').format(\"YYYY-MM-DD HH:mm:ss\");\nlet name = msg.topic\nlet value = msg.payload | 0\n\nmsg.column_name = [\"datetime\", \"name\", \"value\"]\nmsg.column_sort = [datetime, name, value]\nmsg.database = \"datalog\"\nmsg.command = \"insert\"\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"moment","module":"moment"}],"x":710,"y":240,"wires":[["634d0d8a05fdef63"]]},{"id":"52e66c98ec7446f1","type":"inject","z":"285ecd284afc36bc","name":"delete all data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"DELETE FROM datalog;","payload":"","payloadType":"date","x":950,"y":300,"wires":[["7f42f0eec47392cc"]]},{"id":"3ad485d677f8b144","type":"comment","z":"285ecd284afc36bc","name":"CREATE TABLE","info":"CREATE TABLE datalog (\n    id INTEGER PRIMARY KEY,\n    datetime DATETIME,\n    name TEXT,\n    value REAL\n);","x":1160,"y":200,"wires":[]},{"id":"0d895f52ec055f4d","type":"debug","z":"285ecd284afc36bc","name":"debug 0","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":320,"y":240,"wires":[]},{"id":"95be1cdf72319762","type":"sqlitedb","db":"/data/datalog.db","mode":"RWC"}]
Created 3 years, 4 months ago
Rating: 3 1
  • debug (x6)
  • function (x5)
  • inject (x3)
  • rbe (x4)
  • data change
  • database
  • IIoT
  • SQLite
