Orisec2MQTT
My first Node-RED flow, which has been running reliably for a few months. The primary purpose of this flow was to provide real-time zone state updates (PIR movement detected; door open) from an Orisec alarm panel to Home Assistant via MQTT discovery. Orisec alarm panels are becoming increasingly popular in the UK, and the inspiration for this flow was to mimic the functionality of the popular Texecom2MQTT integration for Home Assistant by emulating the Orisec Android app requests/responses.
Note - I have not attempted to establish how the Android app constructs the UDP payload requests to the alarm panel. Instead I am simply sending the same UDP payloads via Node-RED and interpreting the response messages (see Config below).
To-Do
  • Panel States (armed/disarmed)
  • Full armed/disarmed/night-armed commands
  • Improved documentation
Prerequisites
Config/UDP requests
The following requests occur in sequence:
  • Initiate Connection (PIN sent to panel)
  • Fetch panel serial
  • Fetch supporting info (model no, etc.)
  • Fetch Zone names (see below)
  • Fetch Zone Config (MQTT binary sensor)
  • Fetch Zone States (ON/OFF - repeat every 4 secs)
Each request has a unique payload which is defined, for ease of admin, as an environment variable against the flow. These can be obtained by analysing the UDP packets sent as a hex string between a device running the Android app and the Alarm panel.
Zones explained
Zones names are fetched in batches of 10. My alarm system contains 13 zones (combination of PIRs, PAs, Door/window sensors), therefore I am sending two requests (i) Zones 1-10, (ii) Zones 11-20, and adding these to a zone array. In theory this could be extended for 20+ zones but I have no way to test this. A single request is subsequently made to fetch states for all zones.
[{"id":"5da13b0604777abc","type":"tab","label":"Orisec2MQTT","disabled":false,"info":"","env":[{"name":"login_payload","value":"","type":"str"},{"name":"getSerial_payload","value":"","type":"str"},{"name":"getZones1_payload","value":"","type":"str"},{"name":"getZones2_payload","value":"","type":"str"},{"name":"getZoneConfig_payload","value":"","type":"str"},{"name":"getZoneState_payload","value":"","type":"str"},{"name":"orisec_ip","value":"192.168.0.xxx","type":"str"},{"name":"orisec_port","value":"20202","type":"str"},{"name":"getSupportInfo_payload","value":"","type":"str"}]},{"id":"4aab97eb282cb78a","type":"udp out","z":"5da13b0604777abc","name":"","addr":"","iface":"","port":"","ipv":"udp4","outport":"49988","base64":false,"multicast":"false","x":1130,"y":340,"wires":[]},{"id":"7048d22e8ac25ede","type":"udp in","z":"5da13b0604777abc","name":"","iface":"","port":"49988","ipv":"udp4","multicast":"false","group":"","datatype":"buffer","x":180,"y":800,"wires":[["2deb0dd241da6f12","db398457498d61ae"]]},{"id":"208e126558cb0558","type":"inject","z":"5da13b0604777abc","name":"Start","props":[{"p":"ip","v":"orisec_ip","vt":"env"},{"p":"port","v":"orisec_port","vt":"env"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["b4a90dfcccb9d978"]]},{"id":"e789184a20393dc3","type":"function","z":"5da13b0604777abc","name":"","func":"msg.oldPayload = msg.payload; //save it for later debugging\nvar noSpaces = msg.payload.replace(/ /g, '');// remove spaces\nmsg.payload = Buffer.from(noSpaces, \"hex\"); //convert to buffer\n\nmsg.ip = msg.ip;\nmsg.port = msg.port;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":340,"wires":[["4aab97eb282cb78a","07ba0503016a7b38"]]},{"id":"0c99cb14a6f1f8ea","type":"debug","z":"5da13b0604777abc","name":"OUTBOUND","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1150,"y":340,"wires":[]},{"id":"f77cd6d4adf75f41","type":"split","z":"5da13b0604777abc","name":"","splt":"[0]","spltType":"bin","arraySplt":"100","arraySpltType":"len","stream":false,"addname":"","x":910,"y":880,"wires":[["2aafc61fb5a150f2"]]},{"id":"b69bfdb5dfbf28fd","type":"function","z":"5da13b0604777abc","name":"GetZoneStates","func":"//Reset Sensor Counter\n//flow.set('sensor',undefined);\n\n//fetch zoneStates array from buffer\nvar b = msg.payload;\n\nmsg.payload = b.slice(10,32);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":1000,"wires":[["7319b56b3dc23e19"]]},{"id":"f6e18728cc1c2311","type":"function","z":"5da13b0604777abc","name":"","func":"//Reset Zone Counter\nflow.set('zone',undefined);\n\n//Reset Zone Array\nflow.set('arr',undefined);\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":340,"wires":[["e789184a20393dc3"]]},{"id":"6ede93e0af1d24c7","type":"split","z":"5da13b0604777abc","name":"","splt":"2","spltType":"len","arraySplt":"2","arraySpltType":"len","stream":false,"addname":"","x":910,"y":940,"wires":[["085be7c90f1b8db3"]]},{"id":"085be7c90f1b8db3","type":"function","z":"5da13b0604777abc","name":"","func":"var count=flow.get('sensor')||0;\ncount +=1;\nflow.set('sensor',count);\n\n//offset -1, to get 0 array position\ncount = count-1;\nvar inactive = new Buffer([0,0]);\nvar state = \"...\";\nvar result = inactive.compare(msg.payload);\n\n\nvar obj = flow.get(\"arr[\"+count+\"]\");\nvar unique_id = flow.get(\"arr[\"+count+\"].unique_id\");\n\nflow.set(\"arr[\"+count+\"].state\",state);\n//flow.set(\"arr[\"+count+\"].raw\",msg.payload);\n\nvar topic = 'homeassistant/binary_sensor/OrisecZone' + unique_id;\n\nflow.set(\"arr[\"+count+\"].state_topic\",topic);\n\n\n\n//  \"name\": \"FrontDoorTest\",\n//  \"device_class\": \"motion\",\n//  \"state_topic\": \"homeassistant/binary_sensor/1/state\"\nconfig = {}\n\nconfig.name = obj.name;\nconfig.unique_id = 'OrisecZone' + unique_id;\nconfig.device_class = 'motion';\nconfig.state_topic = topic + '/state';\n\n//device map for mqtt discovery\nconfig.device = flow.get('deviceMap')\n\nmsg.payload = config;\nmsg.topic = topic + '/config';\nmsg.mqttpayload = state;\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1080,"y":940,"wires":[["188a28cafa928f94","3de3889ea870ab91"]]},{"id":"b8a09709706ee3ec","type":"debug","z":"5da13b0604777abc","name":"STATE","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1270,"y":1060,"wires":[]},{"id":"7319b56b3dc23e19","type":"split","z":"5da13b0604777abc","name":"","splt":"2","spltType":"len","arraySplt":"2","arraySpltType":"len","stream":false,"addname":"","x":910,"y":1000,"wires":[["def49e105b9fabe6","b8a09709706ee3ec"]]},{"id":"def49e105b9fabe6","type":"function","z":"5da13b0604777abc","name":"","func":"var count=flow.get('sensor')||0;\ncount +=1;\nflow.set('sensor',count);\n\n//offset -1, to get 0 array position\ncount = count-1;\n\nvar clearState =  new Buffer([0]);\n//var clearState = new Buffer([0,0]);\n  var state = \"...\";\n\nif(Buffer.compare(msg.payload.slice(0,1),clearState) === 0) {\n  state = \"OFF\";\n} else {\n  state = \"ON\"\n}\n\n//var obj = flow.get(\"arr[\"+count+\"]\");\nvar unique_id = flow.get(\"arr[\"+count+\"].unique_id\");\n\n//flow.set(\"arr[\"+count+\"].state\",state);\n//flow.set(\"arr[\"+count+\"].raw\",msg.payload);\n//flow.set(\"arr[\"+count+\"].state_topic\",topicState);\n\nvar topic = 'homeassistant/binary_sensor/OrisecZone' + unique_id;\n\nmsg.payload = state;\nmsg.topic = topic + '/state';\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1080,"y":1000,"wires":[["188a28cafa928f94","b8a09709706ee3ec"]]},{"id":"188a28cafa928f94","type":"mqtt out","z":"5da13b0604777abc","name":"","topic":"","qos":"1","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"c162f505.1920e8","x":1270,"y":1000,"wires":[]},{"id":"cf1f44acb92f1129","type":"mqtt in","z":"5da13b0604777abc","d":true,"name":"","topic":"#","qos":"2","datatype":"auto","broker":"c162f505.1920e8","nl":false,"rap":false,"inputs":0,"x":190,"y":900,"wires":[["db398457498d61ae"]]},{"id":"986077107cc532f5","type":"function","z":"5da13b0604777abc","name":"GetZoneList","func":"//fetch zone array from buffer\nvar b = msg.payload;\n\nmsg.payload = b.slice(10,b.length-2); //last 2 chars are checksum\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":710,"y":880,"wires":[["f77cd6d4adf75f41"]]},{"id":"2aafc61fb5a150f2","type":"function","z":"5da13b0604777abc","name":"","func":"//Skip Null Zones\nvar zoneName = msg.payload.toString();\nif (zoneName != \"\") {\n\nvar count=flow.get('zone')||0;\ncount +=1;\nflow.set('zone',count);\n\nvar arr = flow.get('arr') || [];\n//arr.push(msg.payload);\nflow.set(\"arr\", arr);\n\n\n    obj = {}\n    obj.unique_id = count//i\n    obj.name = zoneName\n    obj.state = '...'    \n    //obj.raw = msg.payload        \n    arr.push(obj)\n\nmsg.payload = obj\nreturn msg\n}\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1080,"y":880,"wires":[["8b95537964de399f"]]},{"id":"8b95537964de399f","type":"debug","z":"5da13b0604777abc","name":"ZONES","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1280,"y":880,"wires":[]},{"id":"10fd2a5fe4d00af7","type":"function","z":"5da13b0604777abc","name":"GetZoneConfig","func":"//Reset Sensor Counter\n//flow.set('sensor',undefined);\n\n//fetch zoneStates array from buffer\nvar b = msg.payload;\n\nmsg.payload = b.slice(10,32);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":940,"wires":[["6ede93e0af1d24c7"]]},{"id":"3de3889ea870ab91","type":"debug","z":"5da13b0604777abc","name":"CONFIG","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1280,"y":940,"wires":[]},{"id":"2deb0dd241da6f12","type":"function","z":"5da13b0604777abc","name":"MessageType","func":"var b = msg.payload.slice(2,3);\nmsg.payload;\n\nvar zonesmsg = new Buffer([96]);\nvar configmsg = new Buffer([176]);\nvar statemsg = new Buffer([126]);\nvar serialmsg = new Buffer([2]);\nvar supportmsg = new Buffer([182]);\nvar errormsg = new Buffer([99]);\n\nif (Buffer.compare(b,zonesmsg) === 0) {\n//match configmsg\n   return [ msg,null,null, null,null,null,null ];\n}    \nelse if (Buffer.compare(b,configmsg) === 0) {\n//match configmsg\n   return [ null,msg, null,null,null,null,null ];\n} \nelse if (Buffer.compare(b,statemsg) === 0) {\n//match configmsg\n   return [ null,null,msg,null, null,null,null ];\n}\nelse if (Buffer.compare(b,serialmsg) === 0) {\n//match configmsg\n   return [ null,null,null,msg, null,null ];\n}\nelse if (Buffer.compare(b,supportmsg) === 0) {\n//match configmsg\n   return [ null,null,null,null,msg, null,null ];\n}\nelse if (Buffer.compare(b,errormsg) === 0) {\n//match errormsg\n   return [ null,null,null, null,null,msg,null ];\n}\nelse {\n//no match\n   return [ null,null,null, null,null,null,msg ];\n}","outputs":7,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":800,"wires":[["986077107cc532f5"],["10fd2a5fe4d00af7"],["b69bfdb5dfbf28fd"],["9a8fa1182f3c8962"],["27ee063cde5f2933"],["b4a90dfcccb9d978"],["db398457498d61ae"]]},{"id":"db398457498d61ae","type":"debug","z":"5da13b0604777abc","name":"DEBUG","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":700,"y":1100,"wires":[]},{"id":"9a8fa1182f3c8962","type":"function","z":"5da13b0604777abc","name":"GetSerial","func":"//Reset SerialNo\nflow.set('serialNo',undefined);\n//fetch zoneStates array from buffer\nvar b = msg.payload;\n\nmsg.payload = b.slice(52,68);\n\nflow.set('serialNo',msg.payload.toString());\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":700,"y":720,"wires":[["ef2416fc9cdd0cd8"]]},{"id":"beda5244af3269fe","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"4","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":140,"wires":[["e789184a20393dc3"],["e836df271d789d22"]]},{"id":"e836df271d789d22","type":"change","z":"5da13b0604777abc","name":"GetSerial","rules":[{"t":"set","p":"payload","pt":"msg","to":"getSerial_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":220,"wires":[["2344066221bf9216"]]},{"id":"2344066221bf9216","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"1","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":220,"wires":[["e789184a20393dc3"],["241d7d59315e9335"]]},{"id":"fdb6e1135c93bf58","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"4","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":340,"wires":[["f6e18728cc1c2311"],["5e6e7b5d121a1db3"]]},{"id":"4ac53b44f7f8ca09","type":"change","z":"5da13b0604777abc","name":"GetZones1-10","rules":[{"t":"set","p":"payload","pt":"msg","to":"getZones1_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":340,"wires":[["fdb6e1135c93bf58"]]},{"id":"5e6e7b5d121a1db3","type":"change","z":"5da13b0604777abc","name":"GetZones11-20","rules":[{"t":"set","p":"payload","pt":"msg","to":"getZones2_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":400,"wires":[["2298418815cc2ee3"]]},{"id":"2298418815cc2ee3","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"4","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":400,"wires":[["e789184a20393dc3"],["89672e0a1ca202a0"]]},{"id":"89672e0a1ca202a0","type":"change","z":"5da13b0604777abc","name":"Get Zones (Config)","rules":[{"t":"set","p":"payload","pt":"msg","to":"getZoneConfig_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":460,"wires":[["255a76ee1aeb1b04"]]},{"id":"255a76ee1aeb1b04","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"4","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":460,"wires":[["1142f8dedc0c0745"],["b594b19f69eabab4"]]},{"id":"b594b19f69eabab4","type":"change","z":"5da13b0604777abc","name":"Get ZoneState (Repeat)","rules":[{"t":"set","p":"payload","pt":"msg","to":"getZoneState_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":520,"wires":[["adcdd9a1e48bd15f"]]},{"id":"adcdd9a1e48bd15f","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"4","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":560,"wires":[["1142f8dedc0c0745"],["b594b19f69eabab4"]]},{"id":"1142f8dedc0c0745","type":"function","z":"5da13b0604777abc","name":"","func":"//Reset Sensor Counter\nflow.set('sensor',undefined);\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":480,"wires":[["e789184a20393dc3"]]},{"id":"b4a90dfcccb9d978","type":"change","z":"5da13b0604777abc","name":"Send PIN","rules":[{"t":"set","p":"payload","pt":"msg","to":"login_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":140,"wires":[["beda5244af3269fe"]]},{"id":"ef2416fc9cdd0cd8","type":"debug","z":"5da13b0604777abc","name":"SERIAL","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":720,"wires":[]},{"id":"241d7d59315e9335","type":"change","z":"5da13b0604777abc","name":"GetSupportInfo","rules":[{"t":"set","p":"payload","pt":"msg","to":"getSupportInfo_payload","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":280,"wires":[["13fbca93b458305a"]]},{"id":"13fbca93b458305a","type":"trigger","z":"5da13b0604777abc","name":"","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"1","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":540,"y":280,"wires":[["e789184a20393dc3"],["4ac53b44f7f8ca09"]]},{"id":"f548a4fdc30b7f9a","type":"debug","z":"5da13b0604777abc","name":"PANEL","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1280,"y":720,"wires":[]},{"id":"9ffd11d4a689f4e1","type":"comment","z":"5da13b0604777abc","name":"UDP request to Alarm","info":"","x":180,"y":80,"wires":[]},{"id":"be90edab2ccaeae9","type":"comment","z":"5da13b0604777abc","name":"Parse response from Alarm, send MQTT out","info":"","x":270,"y":640,"wires":[]},{"id":"27ee063cde5f2933","type":"split","z":"5da13b0604777abc","name":"","splt":"[0]","spltType":"bin","arraySplt":"100","arraySpltType":"len","stream":false,"addname":"","x":690,"y":780,"wires":[["55165c9c40700687"]]},{"id":"55165c9c40700687","type":"switch","z":"5da13b0604777abc","name":"GetModel","property":"payload","propertyType":"msg","rules":[{"t":"index","v":"12","vt":"num","v2":"12","v2t":"num"},{"t":"index","v":"9","vt":"num","v2":"9","v2t":"num"}],"checkall":"true","repair":false,"outputs":2,"x":900,"y":780,"wires":[["b67df2989af2beb4"],[]]},{"id":"b67df2989af2beb4","type":"function","z":"5da13b0604777abc","name":"","func":"//Reset ModelNo\nflow.set('modelNo',undefined);\n//fetch ModelNo from message\nmsg.payload = msg.payload.toString();\n//Set ModelNo flow variable\nflow.set('modelNo',msg.payload);\n\n//device map for mqtt discovery\ndevice = {}\ndevice.manufacturer = \"Orisec\";\ndevice.name = \"Alarm System\";\n//device.identifiers = env.get(\"orisec_ip\");\ndevice.identifiers = flow.get('serialNo')\ndevice.model = flow.get('modelNo')\n\n//Set ModelNo flow variable\nflow.set('deviceMap',device);\n\n\n//build mqtt message for panel\nvar obj;\nvar topic = 'homeassistant/alarm_control_panel/Orisec';\n\nconfig = {}\n\nconfig.name = \"Alarm Panel\";\nconfig.unique_id = flow.get('modelNo')\n//config.device_class = 'motion';\nconfig.state_topic = topic + '';\nconfig.command_topic = topic + '/set';\n\nconfig.device = flow.get('deviceMap')\n\nmsg.payload = config;\nmsg.topic = topic + '/config';\nmsg.mqttpayload = 'pending';\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1080,"y":720,"wires":[["f548a4fdc30b7f9a","188a28cafa928f94","db46dd2c45ca02a5"]]},{"id":"b2b784a8ee56c363","type":"comment","z":"5da13b0604777abc","name":"Any unknown messages, print to DEBUG","info":"","x":800,"y":1060,"wires":[]},{"id":"83a5be9c775ac907","type":"comment","z":"5da13b0604777abc","name":"Zone/Sensors","info":"","x":710,"y":820,"wires":[]},{"id":"fabe6e846b5022f5","type":"comment","z":"5da13b0604777abc","name":"Panel/Device","info":"","x":710,"y":680,"wires":[]},{"id":"db46dd2c45ca02a5","type":"function","z":"5da13b0604777abc","name":"","func":"//build mqtt state message for panel\nvar obj;\nvar topic = 'homeassistant/alarm_control_panel/Orisec';\n\nmsg.topic = topic;\nmsg.payload = 'pending';\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1080,"y":780,"wires":[["188a28cafa928f94","f548a4fdc30b7f9a"]]},{"id":"92d003fd49d71a5f","type":"comment","z":"5da13b0604777abc","name":"Readme","info":"","x":120,"y":40,"wires":[]},{"id":"07ba0503016a7b38","type":"udp out","z":"5da13b0604777abc","name":"","addr":"$orisec_ip","iface":"","port":"$orisec_port","ipv":"udp4","outport":"","base64":false,"multicast":"false","x":1250,"y":260,"wires":[]},{"id":"c162f505.1920e8","type":"mqtt-broker","name":"","broker":"192.168.0.xxx","port":"1883","clientid":"","usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Updated 4 years, 3 months ago
  • change (x7)
  • comment (x6)
  • debug (x7)
  • function (x13)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • split (x4)
  • switch (x1)
  • trigger (x7)
  • udp in (x1)
  • udp out (x2)
  • alarm
  • home-assistant
  • mqtt
