Ultrasonic range sensor for smart trash bin with AWS and an ESP8266
Two LEDS are connected to the ESP8266. When the low threshold is surpassed, then the first LED goes on if the garbage goes that high (less than). When the high threshold is surpassed, then the second LED goes on, and the bin is completely full.
[{"id":"9581a256.f967c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"f9100a08.56d2d8","type":"mqtt in","z":"9581a256.f967c","name":"","topic":"voltage/#","qos":"0","datatype":"auto","broker":"ca490a2e.b63e58","x":140,"y":80,"wires":[["bfee19ad.124178"]]},{"id":"baf531b3.6059c","type":"ui_gauge","z":"9581a256.f967c","name":"","group":"bf1821a8.c694e","order":3,"width":"0","height":"0","gtype":"wave","title":"Bin","label":" gal.","format":"{{value}}","min":0,"max":"20","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":290,"y":360,"wires":[],"info":"#00ff00"},{"id":"d700faa9.ee5758","type":"mosca in","z":"9581a256.f967c","mqtt_port":1883,"mqtt_ws_port":8080,"name":"","username":"ajusurvey","password":"123klASDF","dburl":"","x":150,"y":40,"wires":[[]]},{"id":"34c97bcd.f2e1a4","type":"debug","z":"9581a256.f967c","name":"raw","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":150,"y":140,"wires":[]},{"id":"7ba32fb1.92b24","type":"function","z":"9581a256.f967c","name":"voltage to inches","func":"const mul = 16.8;\nconst add = 8.54;\n\n//msg.payload = parseInt(msg.payload);\n\nmsg.payload = msg.payload*mul + add;\n\nreturn msg;","outputs":1,"noerr":0,"x":290,"y":220,"wires":[["97b49a28.68c208","d80d22fd.77726","42938a30.47b174"]]},{"id":"97b49a28.68c208","type":"function","z":"9581a256.f967c","name":"capacity","func":"const pih = -314.1592653589793;\nconst pls = 7854;\nconst div = 231;\n\nmsg.payload = (msg.payload*pih+pls)/div;\n\nreturn msg;","outputs":1,"noerr":0,"x":120,"y":360,"wires":[["29654962.a116f6"]]},{"id":"2437ebe8.21d3f4","type":"ui_text","z":"9581a256.f967c","group":"bf1821a8.c694e","order":1,"width":0,"height":0,"name":"","label":"Smart Bin: Capacity","format":"","layout":"col-center","x":380,"y":40,"wires":[]},{"id":"29654962.a116f6","type":"ui_gauge","z":"9581a256.f967c","name":"","group":"bf1821a8.c694e","order":4,"width":0,"height":0,"gtype":"gage","title":"Inches full","label":" inches","format":"{{inches}}","min":0,"max":"20","colors":["#00bf00","#ffff00","#ff0000"],"seg1":"","seg2":"","x":140,"y":420,"wires":[]},{"id":"d80d22fd.77726","type":"ui_chart","z":"9581a256.f967c","name":"","group":"bf1821a8.c694e","order":2,"width":0,"height":0,"label":"Real-Time","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"25","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":330,"y":420,"wires":[[]]},{"id":"b97090c4.82238","type":"function","z":"9581a256.f967c","name":"Everything","func":"var lo_thres = context.get('lowpointSet') || 0;\nvar hi_thres = context.get('highpointSet') || 0;\nvar begin = context.get('begin') || 0;\nvar value = context.get('voltage') || 0;\n\nif( msg.topic === 'lowpointSet')\n{\n    lo_thres = msg.payload;\n\n    context.set('lowpointSet', lo_thres);\n}\nelse if( msg.topic === 'highpointSet')\n\n{\n    hi_thres = msg.payload;\n    context.set('highpointSet', hi_thres);\n}\n\nelse if( msg.topic === 'voltage')\n{\n    value = parseFloat(msg.payload);\n\n    if(value < 0)\n    {\n        value = 0;\n    }\n    begin = 1;\n    context.set('begin', begin);\n    context.set('voltage', value);\n}\n\n \n\nvar mqtt_msg = { payload: lo_thres.toString() + \";\" + hi_thres.toString() };\nvar email_subject = \"Capacity Update\";\nvar measurement_value = {payload: value};\nvar th_debug = {payload: [lo_thres, hi_thres] };\n\nif(value < lo_thres)\n    var email_msg = {topic: email_subject, payload: \"Warning: Full capacity! Low Value : \" + measurement_value.payload.toString() + '\"', begin: begin };\n\nelse if (value < hi_thres)\n    var email_msg = {topic: email_subject, payload: \"Warning: Nearly filled. High Value : \" + measurement_value.payload.toString() + '\"', begin: begin };\n\nreturn [mqtt_msg, email_msg, measurement_value, th_debug];","outputs":3,"noerr":0,"x":450,"y":360,"wires":[["6f97c0b7.14464"],["e8a06686.b06ae8"],["883664c5.e09f78"]]},{"id":"6f97c0b7.14464","type":"mqtt out","z":"9581a256.f967c","name":"","topic":"MQTTtoboard","qos":"0","retain":"","broker":"ca490a2e.b63e58","x":660,"y":340,"wires":[]},{"id":"e8a06686.b06ae8","type":"delay","z":"9581a256.f967c","name":"","pauseType":"delay","timeout":"20","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":520,"y":420,"wires":[["1d1a4fb5.ac4d6"]]},{"id":"adb46194.58d57","type":"ui_slider","z":"9581a256.f967c","name":"","label":"Too full","tooltip":"","group":"bf1821a8.c694e","order":5,"width":"5","height":"1","passthru":true,"outs":"all","topic":"lowpointSet","min":".07","max":"0.23","step":".05","x":540,"y":80,"wires":[["1c09c66e.5c613a"]]},{"id":"1c09c66e.5c613a","type":"ui_numeric","z":"9581a256.f967c","name":"","label":"low thresh.","tooltip":"","group":"bf1821a8.c694e","order":6,"width":0,"height":0,"passthru":true,"topic":"lowpointSet","format":"{{value}}","min":".07","max":"0.23","step":"0.01","x":570,"y":140,"wires":[["adb46194.58d57","70fba7be.8b7888"]]},{"id":"678214c9.348a9c","type":"ui_slider","z":"9581a256.f967c","name":"","label":"Nearly full","tooltip":"","group":"bf1821a8.c694e","order":7,"width":"5","height":"1","passthru":true,"outs":"all","topic":"highpointSet","min":"0.24","max":"0.5","step":".05","x":460,"y":180,"wires":[["ef8778ed.52e7c8"]]},{"id":"ef8778ed.52e7c8","type":"ui_numeric","z":"9581a256.f967c","name":"","label":"high thresh.","tooltip":"","group":"bf1821a8.c694e","order":8,"width":0,"height":0,"passthru":true,"topic":"highpointSet","format":"{{value}}","min":"0.24","max":"0.5","step":"0.01","x":530,"y":240,"wires":[["678214c9.348a9c","c5ae4f71.72f8a"]]},{"id":"5613f2ab.ff997c","type":"inject","z":"9581a256.f967c","name":"","topic":"volts","payload":"0.08","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":360,"y":120,"wires":[["adb46194.58d57","1c09c66e.5c613a"]]},{"id":"55d28044.bbf78","type":"inject","z":"9581a256.f967c","name":"","topic":"inches","payload":"0.3","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":300,"y":180,"wires":[["678214c9.348a9c","ef8778ed.52e7c8"]]},{"id":"70fba7be.8b7888","type":"change","z":"9581a256.f967c","name":"flo.low→msg.payload","rules":[{"t":"set","p":"low","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":180,"wires":[["b97090c4.82238"]]},{"id":"c5ae4f71.72f8a","type":"change","z":"9581a256.f967c","name":"flo→msg","rules":[{"t":"set","p":"high","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":280,"wires":[["b97090c4.82238"]]},{"id":"bfee19ad.124178","type":"range","z":"9581a256.f967c","minin":"30","maxin":"360","minout":"0","maxout":"1","action":"scale","round":false,"property":"payload","name":"","x":130,"y":200,"wires":[["7ba32fb1.92b24","34c97bcd.f2e1a4","8f0ac55b.2b6118"]]},{"id":"8f0ac55b.2b6118","type":"change","z":"9581a256.f967c","name":"flo→msg","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":260,"wires":[["b97090c4.82238","d365cf2b.0d3bf"]]},{"id":"1d1a4fb5.ac4d6","type":"e-mail","z":"9581a256.f967c","server":"smtp.gmail.com","port":"465","secure":true,"tls":false,"name":"[email protected]","dname":"email","x":670,"y":440,"wires":[]},{"id":"d365cf2b.0d3bf","type":"debug","z":"9581a256.f967c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":470,"y":300,"wires":[]},{"id":"883664c5.e09f78","type":"debug","z":"9581a256.f967c","name":"end","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":670,"y":400,"wires":[]},{"id":"42938a30.47b174","type":"range","z":"9581a256.f967c","minin":"8","maxin":"26","minout":"25","maxout":"0","action":"scale","round":false,"property":"payload","name":"","x":210,"y":320,"wires":[["baf531b3.6059c"]]},{"id":"ca490a2e.b63e58","type":"mqtt-broker","z":"","name":"","broker":"m16.cloudmqtt.com","port":"12131","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"bf1821a8.c694e","type":"ui_group","z":"","name":"Default","tab":"6e1e16a4.908bc8","disp":false,"width":"6","collapse":false},{"id":"6e1e16a4.908bc8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 8 years, 2 months ago
  • change (x3)
  • debug (x3)
  • delay (x1)
  • function (x3)
  • inject (x2)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • range (x2)
  • e-mail (x1)
  • mosca in (x1)
  • ui_chart (x1)
  • ui_gauge (x2)
  • ui_group (x1)
  • ui_numeric (x2)
  • ui_slider (x2)
  • ui_text (x1)
