GPS tracker - TK103/TK10x
This flow is for GPS tracker devices that require a "logon" and "heartbeat" response, these have to be answered upon connection.
Change the TCP port to your liking.
In the Switch Node, decisions are made based on incoming traffic. The GPS tracker usually sends eg.:
Logon request: ##,imei:359586015829802,A;
Flow sends: LOAD
Heartbeat requests: 359586015829802;
Flow sends: ON
Change the switch node to match your imei.
End result is an object with converted longitude/latitude coordinates, speed etc. The format works with node-red-contrib-web-worldmap
Example sql statement is in the function node.
Send an SMS to your tracker: imei<passcode> to determine your imei
[{"id":"2671037d.537ca4","type":"tcp in","z":"619627e3.aaed6","name":"From GPS","server":"server","host":"","port":"5001","datamode":"stream","datatype":"utf8","newline":"","topic":"","base64":false,"x":100,"y":240,"wires":[["d47998cc.3cdfd","105016d3.1c63d1"]]},{"id":"bf4ef4f6.36852","type":"tcp out","z":"619627e3.aaed6","host":"","port":"","beserver":"reply","base64":false,"end":false,"name":"to GPS","x":780,"y":260,"wires":[]},{"id":"d47998cc.3cdfd","type":"switch","z":"619627e3.aaed6","name":"logon/heartbeat/tracker/move","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"##,imei:864180031021079,A;","vt":"str"},{"t":"eq","v":"864180031021079;","vt":"str"},{"t":"cont","v":"tracker","vt":"str"},{"t":"cont","v":"move","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":370,"y":280,"wires":[["971ae96c.693ab"],["e3ccc0b8.39479"],["579e60af.64dfb"],["579e60af.64dfb"]]},{"id":"971ae96c.693ab","type":"change","z":"619627e3.aaed6","name":"LOAD","rules":[{"t":"set","p":"payload","pt":"msg","to":"LOAD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":240,"wires":[["bf4ef4f6.36852"]]},{"id":"579e60af.64dfb","type":"function","z":"619627e3.aaed6","name":"To object or SQL","func":"\n//   Incoming data\n//   [0] => imei:864180031021079\n//   [1] => tracker,\n//   [2] => 170805122543,\n//   [3] => ,\n//   [4] => F,\n//   [5] => 112540.000,\n//   [6] => A,\n//   [7] => 5208.3026,\n//   [8] => N,\n//   [9] => 00428.1723,\n//   [10] => E,\n//   [11] => 0.00,\n//   [12] => 0; \n\n\nfunction convertlatlon(lat,lon){\n\n    latout = (Math.floor(lat / 100) + (lat - 100 * Math.floor(lat / 100)) / 60).toFixed(5);\n    lonout = (Math.floor(lon / 100) + (lon - 100 * Math.floor(lon / 100)) / 60).toFixed(5);\n\n    return [latout,lonout];\n }\n\nflow.set(\"session\",msg._session)\n\nvar today = new Date();\nvar date = today.getFullYear()+'-'+(today.getMonth()+1)+'-'+today.getDate();\nvar time = today.getHours() + \":\" + today.getMinutes() + \":\" + today.getSeconds();\n\nm = msg.payload\nt = m.split(\",\")\nlatitude = t[7]\nlongitude = t[9]\nlatlon = convertlatlon(latitude,longitude)\n\n\nimei = t[0];\nstatus = t[1];\ntrackerdate = t[2]\n\nsatelliteDerivedTime = t[5];\nsatelliteFixStatus = t[6];\ntimestamp = t[2];\nlatitudeDecimalDegrees = latlon[0];\nlatitudeHemisphere = t[8];\nlongitudeDecimalDegrees = latlon[1];\nlongitudeHemisphere = t[10];\nbearing = ''\nutcDate = ''\nspeed = t[11]\ngpsSignalIndicator = t[4]\ncurrdate = date+' '+time;\nother = t[12]\nchecksum = ''\n\n// For SQL usage:\n// sql = \"INSERT INTO gprmc (locationdate, imei, phone, trackerdate, satelliteDerivedTime, satelliteFixStatus, latitudeDecimalDegrees, latitudeHemisphere, longitudeDecimalDegrees, longitudeHemisphere, speed, Bearing, utcDate, Checksum, gpsSignalIndicator, other) VALUES ('\"+currdate+\"', '\"+imei+\"', '\"+phone+\"', '\"+trackerdate+\"', '\"+satelliteDerivedTime+\"', '\"+satelliteFixStatus+\"', '\"+latitudeDecimalDegrees+\"', '\"+latitudeHemisphere+\"', '\"+longitudeDecimalDegrees+\"', '\"+longitudeHemisphere+\"', '\"+speed+\"', '\"+bearing+\"', '\"+utcDate+\"', '\"+checksum+\"', '\"+gpsSignalIndicator+\"', '\"+other+\"')\"\n// return {topic:sql}\n\nreturn {payload:{\n\tlocationdate:currdate,\n\timei:imei,\n\tstatus:status,\n\ttrackerdate:trackerdate,\n\tsatelliteDerivedTime:satelliteDerivedTime,\n\tsatelliteFixStatus:satelliteFixStatus,\n\tlatitudeDecimalDegrees:latitudeDecimalDegrees,\n\tlatitudeHemisphere:latitudeHemisphere,\n\tlongitudeDecimalDegrees:longitudeDecimalDegrees,\n\tlongitudeHemisphere:longitudeHemisphere,\n\tspeed:speed,\n\tbearing:bearing,\n\tutcDate:utcDate,\n\tchecksum:checksum,\n\tgpsSignalIndicator:gpsSignalIndicator\t\n\n}}\n\n\n","outputs":1,"noerr":0,"x":650,"y":320,"wires":[["f27c551d.6089b"]]},{"id":"e3ccc0b8.39479","type":"change","z":"619627e3.aaed6","name":"ON","rules":[{"t":"set","p":"payload","pt":"msg","to":"ON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":280,"wires":[["bf4ef4f6.36852"]]},{"id":"f27c551d.6089b","type":"debug","z":"619627e3.aaed6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":810,"y":320,"wires":[]},{"id":"105016d3.1c63d1","type":"debug","z":"619627e3.aaed6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":290,"y":220,"wires":[]},{"id":"f485b01e.782728","type":"inject","z":"619627e3.aaed6","name":"Test input","topic":"","payload":"imei:864180031021079,tracker,190310160322,,F,170317.000,A,5208.3287,N,00428.1048,E,0.00,0;","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":100,"y":280,"wires":[["d47998cc.3cdfd","105016d3.1c63d1"]]},{"id":"e6d551b3.db315","type":"comment","z":"619627e3.aaed6","name":"TK102B based GPS tracker - see info","info":"This flow is for GPS tracker devices that require a \"logon\" and \"heartbeat\" response, these have to be answered upon connection.\n\nChange the TCP port to your liking.\n\nIn the Switch Node, decisions are made based on incoming traffic. \nThe GPS tracker usually sends eg.:\n\nLogon request: ```##,imei:359586015829802,A;``` \n\nFlow sends: ```LOAD``` \n\n\nHeartbeat requests: ```359586015829802;``` \n\nFlow sends: ```ON```\n\nChange the switch node to match your imei.\n\nEnd result is an object with converted longitude/latitude coordinates, speed etc.\nThe format works with [node-red-contrib-web-worldmap](https://flows.nodered.org/node/node-red-contrib-web-worldmap)\n\nExample sql statement is in the function node.\n\n\nSend an SMS to your tracker: ```imei<passcode>``` to determine your imei\n","x":190,"y":160,"wires":[]}]
Created 6 years, 11 months ago
  • change (x2)
  • debug (x2)
  • switch (x1)
  • tcp in (x1)
  • tcp out (x1)
  • gps
  • tracker
  • map
  • tk103
