Change Color of ui_text in Dashboard based on input value
To change the font colour of the text displayed in ui_text node in dashboard depending on the value of the input.
[{"id":"917b8d1e3d71db60","type":"change","z":"d1d5b47695a238e0","name":"","rules":[{"t":"set","p":"fcolor","pt":"msg","to":"red","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":380,"wires":[["027c4571b7afc0e2"]]},{"id":"39af0df5fe1c06a2","type":"switch","z":"d1d5b47695a238e0","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"0","vt":"num"},{"t":"eq","v":"0","vt":"num"},{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":3,"x":570,"y":420,"wires":[["917b8d1e3d71db60"],["2385c18f0f324c76"],["a75de53149517996"]]},{"id":"027c4571b7afc0e2","type":"ui_text","z":"d1d5b47695a238e0","group":"0df4552f9d69039d","order":7,"width":9,"height":6,"name":"","label":"Value","format":"<font face='arial'><font size=6><font color={{fcolor}}>{{msg.payload}}","layout":"row-spread","className":"","x":950,"y":420,"wires":[]},{"id":"c4dcf81b6c43aebd","type":"ui_button","z":"d1d5b47695a238e0","name":"","group":"0df4552f9d69039d","order":8,"width":3,"height":2,"passthru":false,"label":"Zero","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-heartbeat","payload":"0","payloadType":"num","topic":"topic","topicType":"msg","x":390,"y":420,"wires":[["39af0df5fe1c06a2"]]},{"id":"cf35e882013e04b0","type":"ui_button","z":"d1d5b47695a238e0","name":"","group":"0df4552f9d69039d","order":9,"width":3,"height":2,"passthru":false,"label":"+10","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"10","payloadType":"num","topic":"topic","topicType":"msg","x":390,"y":460,"wires":[["39af0df5fe1c06a2"]]},{"id":"2ff6f57ce6bbc73f","type":"ui_button","z":"d1d5b47695a238e0","name":"","group":"0df4552f9d69039d","order":4,"width":3,"height":2,"passthru":false,"label":"-10","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"-10","payloadType":"num","topic":"topic","topicType":"msg","x":390,"y":380,"wires":[["39af0df5fe1c06a2"]]},{"id":"2385c18f0f324c76","type":"change","z":"d1d5b47695a238e0","name":"","rules":[{"t":"set","p":"fcolor","pt":"msg","to":"yellow","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":420,"wires":[["027c4571b7afc0e2"]]},{"id":"a75de53149517996","type":"change","z":"d1d5b47695a238e0","name":"","rules":[{"t":"set","p":"fcolor","pt":"msg","to":"green","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":460,"wires":[["027c4571b7afc0e2"]]},{"id":"0df4552f9d69039d","type":"ui_group","name":"DEFAULT","tab":"f3a8a67ff0904e39","order":1,"disp":false,"width":"44","collapse":false,"className":""},{"id":"f3a8a67ff0904e39","type":"ui_tab","name":"HOME","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Created 3 years, 11 months ago
Rating: 5 5
  • change (x3)
  • switch (x1)
  • ui_button (x3)
  • ui_group (x1)
  • ui_text (x1)
  • dashboard
  • ui_text
  • font-color
