oscar-phytoplankton-classifier-async
Phytoplankton Species Classifier (VLIZ)
Identifies plankton species at the level of 95 classes.
The Phytoplankton Species Classifier is a phytoplankton classification application that includes the DEEPaaS API. Provided by VLIZ (Flanders Marine Institute).
[{"id":"610be1bbceb42075","type":"subflow","name":"OSCAR Phytoplankton-Classifier Async","info":"","category":"OSCAR","in":[{"x":120,"y":180,"wires":[{"id":"cf6bb2f137d8dc7e"}]}],"out":[{"x":1290,"y":340,"wires":[{"id":"55117d6f4082229e","port":0}]}],"env":[{"name":"Phytoplankton-classifier","type":"str","value":"","ui":{"type":"none"}},{"name":"inputBucket","type":"str","value":"","ui":{"type":"input","opts":{"types":["str"]}}},{"name":"objectName","type":"str","value":"","ui":{"type":"input","opts":{"types":["str"]}}},{"name":"outputBucket","type":"str","value":"","ui":{"type":"input","opts":{"types":["str"]}}},{"name":"Prefix","type":"str","value":"","ui":{"type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#3FADB5","inputLabels":["Image"],"outputLabels":["Json"],"icon":"font-awesome/fa-picture-o","status":{"x":1100,"y":100,"wires":[{"id":"b6863d5583e8025e","port":0},{"id":"b2850769589025f6","port":0},{"id":"8c73b4d3484b1167","port":0}]}},{"id":"17d2270ad85c9d69","type":"notifications","z":"610be1bbceb42075","notifications_name":"","host":"8b1cd69cc4852c7e","notifications_operation":"listenBucketNotification","notifications_bucket":"","notifications_notificationconfig":"","notifications_prefix":"","notifications_suffix":"","notifications_events":"","notifications_events_object_created_put":true,"notifications_events_object_created_post":false,"notifications_events_object_created_copy":false,"notifications_events_object_created_complete_multipart_upload":false,"notifications_events_object_removed_delete":false,"notifications_events_object_accessed_get":false,"notifications_events_object_accessed_head":false,"x":340,"y":340,"wires":[["f1615981a4d26994"],["b2850769589025f6"]]},{"id":"42f960c8cc2926a7","type":"function","z":"610be1bbceb42075","name":"function 76","func":"msg.stream = msg.imageUC5\nmsg.objectName = msg.objectNameUC5\nmsg.bucketName = msg.inBucketUC5\n\nflow.set(\"outBucket_UC5\", msg.outBucketUC5);\nflow.set(\"prefix_UC5\", msg.prefixUC5);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":200,"wires":[["9edc8ea735dc0436"]]},{"id":"9edc8ea735dc0436","type":"objects","z":"610be1bbceb42075","objects_name":"","host":"8b1cd69cc4852c7e","objects_operation":"putObject","objects_bucket":"","objects_object":"","objects_offset":"","objects_length":"","objects_stream":"","objects_size":"","objects_metadata":"","objects_sourceobject":"","objects_conditions":"","objects_objectslist":[],"objects_prefix":"","objects_etag":"","objects_datetime":"","x":780,"y":200,"wires":[["e6d3d1cf60136645"],["b2850769589025f6"]]},{"id":"f1615981a4d26994","type":"function","z":"610be1bbceb42075","name":"function 77","func":"msg.objectName = msg.payload.listenBucketNotification.s3.object.key\nvar out = flow.get(\"outBucket_UC5\")\n\nmsg.bucketName = out\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":340,"wires":[["3ffa70c17612dfa3"]]},{"id":"3ffa70c17612dfa3","type":"objects","z":"610be1bbceb42075","objects_name":"","host":"8b1cd69cc4852c7e","objects_operation":"getObject","objects_bucket":"","objects_object":"","objects_offset":"","objects_length":"","objects_stream":"","objects_size":"","objects_metadata":"","objects_sourceobject":"","objects_conditions":"","objects_objectslist":[],"objects_prefix":"","objects_etag":"","objects_datetime":"","x":840,"y":340,"wires":[["55117d6f4082229e"],["b2850769589025f6"]]},{"id":"55117d6f4082229e","type":"function","z":"610be1bbceb42075","name":"function 78","func":"var data = msg.payload.objectData\nif (Buffer.isBuffer(data)) {\n    msg.payload = data.toString('utf8');\n}\n\n// Si es un objeto con datos binarios (por ejemplo, msg.payload.body en algunos casos)\nelse if (data && data.body && Buffer.isBuffer(data.body)) {\n    msg.payload = data.toString('utf8');\n}\n\n// Si ya es string, lo dejamos igual\nelse if (typeof data !== 'string') {\n    // Si es un objeto JS, puedes convertirlo a string plano (opcional)\n    msg.payload = JSON.stringify(data, null, 2);\n}\n\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1050,"y":340,"wires":[["8c73b4d3484b1167"]]},{"id":"cf6bb2f137d8dc7e","type":"change","z":"610be1bbceb42075","name":"","rules":[{"t":"set","p":"prefixUC5","pt":"msg","to":"Prefix","tot":"env"},{"t":"set","p":"outBucketUC5","pt":"msg","to":"outputBucket","tot":"env"},{"t":"set","p":"imageUC5","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"inBucketUC5","pt":"msg","to":"inputBucket","tot":"env"},{"t":"set","p":"objectNameUC5","pt":"msg","to":"objectName","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":180,"wires":[["42f960c8cc2926a7","b6863d5583e8025e"]]},{"id":"e6d3d1cf60136645","type":"function","z":"610be1bbceb42075","name":"function 79","func":"var out=flow.get(\"outBucket_UC5\")\nvar prefix = flow.get(\"prefix_UC5\")\nmsg.prefix =prefix\nmsg.bucketName=out\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":300,"wires":[["17d2270ad85c9d69"]]},{"id":"b2850769589025f6","type":"function","z":"610be1bbceb42075","name":"Error ","func":"var error = msg.payload\nif (error != null){\n   msg.payload=error;\n   return msg;\n}\nelse {\n   return null;\n}\n \n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":990,"y":280,"wires":[[]]},{"id":"b6863d5583e8025e","type":"change","z":"610be1bbceb42075","name":"Start Service","rules":[{"t":"set","p":"payload","pt":"msg","to":"Processing....","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":60,"wires":[[]]},{"id":"8c73b4d3484b1167","type":"change","z":"610be1bbceb42075","name":"End Service","rules":[{"t":"set","p":"payload","pt":"msg","to":"Finished!!","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1210,"y":260,"wires":[[]]},{"id":"8b1cd69cc4852c7e","type":"minio-config","name":"MinIO Phytoplankton","host":"your.minio-host.com","port":"","useSsl":true},{"id":"6919e8b380cefdeb","type":"subflow:610be1bbceb42075","z":"0a79b7a22704278e","name":"","x":770,"y":520,"wires":[["5d42411890fae819"]]}]
Created 1 year, 6 months ago
  • change (x3)
  • function (x5)
  • minio-config (x1)
  • notifications (x1)
  • objects (x2)
  • subflow (x1)
  • subflow:610be1bbceb42075 (x1)
  • iMagine
  • OSCAR
  • GryCAP
  • UPV
  • Node-RED
  • AI4EOSC
  • AI4OS
  • phytoplankton-classifier
