Using an API to get sunset times from co-ordinates
This flow takes in co-ordinates and name of a location and returns the sunset time and name of the location in a sentence. It uses the https://sunrisesunset.io/api/ to get the sunset time.
This demonstrates how to store data outside of msg.payload for use later in a flow. It also demonstrates simple API usage.
[{"id":"809cc8f4678767b7","type":"inject","z":"67746003c844dbc4","name":"London","props":[{"p":"payload.city","v":"London","vt":"str"},{"p":"payload.lat","v":"51.5072","vt":"str"},{"p":"payload.lng","v":"0.1276","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":80,"wires":[["6b5a6a2ef7a64f1a"]]},{"id":"b86d2d558eebbd7e","type":"inject","z":"67746003c844dbc4","name":"Washington DC","props":[{"p":"payload.city","v":"Washington DC","vt":"str"},{"p":"payload.lat","v":"38.9072","vt":"str"},{"p":"payload.lng","v":"77.0369","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":160,"wires":[["6b5a6a2ef7a64f1a"]]},{"id":"aaecc81a2de233d6","type":"debug","z":"67746003c844dbc4","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":820,"y":160,"wires":[]},{"id":"6b5a6a2ef7a64f1a","type":"change","z":"67746003c844dbc4","name":"","rules":[{"t":"set","p":"store","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":120,"wires":[["273ee743f8d1a5f1","af43cea5866e11f5"]]},{"id":"273ee743f8d1a5f1","type":"template","z":"67746003c844dbc4","name":"create the URL","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"https://api.sunrisesunset.io/json?lat={{store.lat}}&lng={{store.lng}}","output":"str","x":500,"y":120,"wires":[["52e8913233f379eb","1d94053c790791ee"]]},{"id":"af43cea5866e11f5","type":"debug","z":"67746003c844dbc4","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":480,"y":160,"wires":[]},{"id":"52e8913233f379eb","type":"http request","z":"67746003c844dbc4","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":670,"y":120,"wires":[["aaecc81a2de233d6","a245b322ade3a7e9"]]},{"id":"1d94053c790791ee","type":"debug","z":"67746003c844dbc4","name":"debug 6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":80,"wires":[]},{"id":"a245b322ade3a7e9","type":"template","z":"67746003c844dbc4","name":"Create the sentence","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"The sun will set at {{payload.results.sunset}} in {{store.city}}.","output":"str","x":860,"y":120,"wires":[["3e4b2d3644845f91"]]},{"id":"3e4b2d3644845f91","type":"debug","z":"67746003c844dbc4","name":"debug 7","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1040,"y":120,"wires":[]}]
Created 2 years, 4 months ago
  • change (x1)
  • debug (x4)
  • http request (x1)
  • inject (x2)
  • template (x2)
  • API
  • payloads
  • weather
  • templating
