Editable table (CRUD) using flow context as a database
About
This flow uses the html template and js-grid to display, create, remove, update and delete data rows.
No database is required - it utilises flow context only.
If you want to persist the data, you can enable file storage for context (see the node-red docs)
Instructions
  1. Import the flow & deploy it
  2. Open a new tab on your browser at the address http://<node-red>:<port>/index.
Demo
RpbmXbz6t8
Flow
Credit
This flow is an adaption of the great flow developed by rishanaziz
[{"id":"9568c2b2.ae4098","type":"http in","z":"38c5e956.a8e786","name":"","url":"/update","method":"put","swaggerDoc":"","x":198,"y":784,"wires":[["de0d507c.2e3c6"]]},{"id":"80b7d10e.159df","type":"http response","z":"38c5e956.a8e786","name":"","x":930,"y":784,"wires":[]},{"id":"a8dde467.e5dcd8","type":"template","z":"38c5e956.a8e786","name":"Web Template","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<!DOCTYPE html>\n<html lang=\"en-GB\">\n<head>\n    <title>Users</title>\n    <meta charset=\"utf-8\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n    <link rel=\"stylesheet\" href=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css\">\n    <link rel=\"stylesheet\" href=\"https://cdnjs.cloudflare.com/ajax/libs/bootstrap-timepicker/0.5.2/css/bootstrap-timepicker.min.css\" />\n    <script src=\"https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js\"></script>\n    <script src=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js\"></script>\n    <link type=\"text/css\" rel=\"stylesheet\" href=\"https://cdnjs.cloudflare.com/ajax/libs/jsgrid/1.5.3/jsgrid.min.css\" />\n    <link type=\"text/css\" rel=\"stylesheet\" href=\"https://cdnjs.cloudflare.com/ajax/libs/jsgrid/1.5.3/jsgrid-theme.min.css\" />\n    <script type=\"text/javascript\" src=\"https://cdnjs.cloudflare.com/ajax/libs/jsgrid/1.5.3/jsgrid.min.js\"></script>\n\n    <script type=\"text/javascript\">\n        $(function () {\n            console.log(\"crud demo\");\n\n            var db = {{#payload}}{{{.}}}{{/payload}};\n\n            $(\"#jsgrid\").jsGrid({\n                width: \"100%\",\n                inserting: true,\n                editing: true,\n                sorting: true,\n                paging: true,\n\n                data: db,\n\n                fields: [\n                    { title:\"ID\", name: \"id\", type: \"number\", width: 20, readOnly: true },\n                    { title:\"User ID\", name: \"userID\", type: \"text\", width: 50 },\n                    { title:\"First Name\", name: \"foreName\", type: \"text\", width: 50 },\n                    { title:\"Last Name\", name: \"sirName\", type: \"text\", width: 50 },\n                    { title:\"Age\", name: \"age\", type:\"number\", width: 25},\n                    { type: \"control\" }\n                ],\n           \n                controller: {\n                    insertItem: function(item) {\n                        return $.ajax({\n                            type: \"POST\",\n                            url: \"/insert\",\n                            data: item\n                        });\n                    },\n                    updateItem: function(item) {\n                       return $.ajax({\n                            type: \"PUT\",\n                            url: \"/update\",\n                            data: item\n                        });\n                    },\n                    deleteItem: function(item) {\n                        return $.ajax({\n                            type: \"DELETE\",\n                            url: \"/delete\",\n                            data: item\n                        });\n                    }\n                }   \n            });\n        });\n    \n  </script>\n</head>\n<body class=\"container\">\n    <section class=\"row\">\n        \n        <div class=\"col-md-6\"></div>\n        <div class=\"col-md-6\" id=\"jsgrid\">\n        </div>\n    </section>\n</body>\n</html>\n\n","x":720,"y":720,"wires":[["e4bd0337.229be8"]]},{"id":"3fa8dafa.229966","type":"http in","z":"38c5e956.a8e786","name":"","url":"/index","method":"get","upload":false,"swaggerDoc":"","x":188,"y":720,"wires":[["5a339947.2e2cf8"]]},{"id":"e4bd0337.229be8","type":"http response","z":"38c5e956.a8e786","name":"","x":930,"y":720,"wires":[]},{"id":"66d97ed7.39f1c","type":"http response","z":"38c5e956.a8e786","name":"","x":930,"y":848,"wires":[]},{"id":"a60ce791.6f5ae8","type":"http in","z":"38c5e956.a8e786","name":"","url":"/insert","method":"post","swaggerDoc":"","x":198,"y":848,"wires":[["9ca4b651.6f2aa8"]]},{"id":"5f79d9fd.25c4f","type":"http in","z":"38c5e956.a8e786","name":"","url":"/delete","method":"delete","swaggerDoc":"","x":208,"y":912,"wires":[["fe020366.04d91"]]},{"id":"17b5b5c4.a8a7b2","type":"http response","z":"38c5e956.a8e786","name":"","x":930,"y":912,"wires":[]},{"id":"a2dfdc4a.dc161","type":"function","z":"38c5e956.a8e786","name":"Generate dummy data","func":"const firstNames =  [\"Liam\",\"Noah\",\"Oliver\",\"William\",\"Elijah\",\"James\",\"Benjamin\",\"Lucas\",\"Mason\",\"Ethan\",\"Alexander\",\"Henry\",\"Jacob\",\"Michael\",\"Daniel\",\"Logan\",\"Jackson\",\"Sebastian\",\"Jack\",\"Aiden\"];\nconst sirNames = [\"Jones\",\"Taylor\",\"Williams\",\"Brown\",\"White\",\"Harris\",\"Martin\",\"Davies\",\"Wilson\",\"Cooper\",\"Evans\",\"King\",\"Thomas\",\"Baker\",\"Green\",\"Wright\",\"Johnson\",\"Edwards\",\"Clark\",\"Roberts\",\"Robinson\",\"Hall\",\"Lewis\",\"Young\",\"Davis\",\"Turner\",\"Hill\",\"Phillips\",\"Collins\",\"Allen\",\"Moore\",\"Thompson\",\"Carter\",\"James\",\"Knight\",\"Walker\",\"Wood\",\"Hughes\",\"Parker\",\"Ward\",\"Bennett\",\"Cook\",\"Webb\",\"Bailey\",\"Scott\",\"Jackson\",\"Lee\",\"Cox\"];\n         \n         \n\nvar database = [];\n\nfor(let i = 1; i <= 30; i++) {\n    var item = {\"id\":i, \"timestamp\":Date.now()};\n    item.foreName = randomFirstname();\n    item.sirName = randomSirname();\n    item.userID = \"U\" + randomInt(1000, 2999);\n    item.age = randomInt(20, 65);\n    database.push(item);\n}\n\n\nfunction randomFirstname() {\n   return firstNames[randomInt(0, firstNames.length-1)];\n}\n\nfunction randomSirname() {\n    return sirNames[randomInt(0, sirNames.length-1)];\n}\n\nfunction randomInt(min, max) { \n  return Math.floor(Math.random() * (max - min + 1) + min);\n}\n\nflow.set(\"database\", database);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":436,"y":640,"wires":[[]]},{"id":"3b023f12.50205","type":"inject","z":"38c5e956.a8e786","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":159,"y":640,"wires":[["a2dfdc4a.dc161"]],"l":false},{"id":"de0d507c.2e3c6","type":"function","z":"38c5e956.a8e786","name":"update-query","func":"\nvar database = flow.get(\"database\") || [];\n\nvar item = database.find(e => e.id == msg.payload.id );\n\nif(msg.payload.foreName == \"\" || msg.payload.sirName == \"\" || msg.payload.userID == \"\") {\n    msg.statusCode = 400;\n    msg.payload = null;\n    return msg;\n}\n\nif(item) {\n    item.foreName = msg.payload.foreName;\n    item.sirName = msg.payload.sirName;\n    item.age = msg.payload.age;\n    item.userID = msg.payload.userID;\n    flow.set(\"database\", database);\n} else {\n    msg.statusCode = 404;//not found\n    msg.payload = null;\n    return msg;\n}\nmsg.payload = item;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":390,"y":784,"wires":[["80b7d10e.159df"]]},{"id":"9ca4b651.6f2aa8","type":"function","z":"38c5e956.a8e786","name":"insert-query","func":"var database = flow.get(\"database\") || [];\nvar nextID = Math.max.apply(Math, database.map(function(o) { return o.id; })) + 1;\nvar item = {\n    id: nextID,\n    timestamp: Date.now(),\n    foreName : msg.payload.foreName,\n    sirName : msg.payload.sirName,\n    age : msg.payload.age,\n    userID : msg.payload.userID,\n}\n\nif(item.foreName == \"\" || item.sirName == \"\" || item.userID == \"\") {\n    msg.statusCode = 400;\n    msg.payload = null;\n    return msg;\n}\n\ndatabase.push(item);\nflow.set(\"database\", database);\n\nmsg.payload = item;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":390,"y":848,"wires":[["66d97ed7.39f1c"]]},{"id":"fe020366.04d91","type":"function","z":"38c5e956.a8e786","name":"delete-query","func":"\nvar database = flow.get(\"database\") || [];\n\ndatabase = database.filter(function( obj ) {\n    return obj.id != msg.payload.id;\n});\n\nflow.set(\"database\", database);\n\nmsg.payload = database;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":390,"y":912,"wires":[["17b5b5c4.a8a7b2"]]},{"id":"5a339947.2e2cf8","type":"function","z":"38c5e956.a8e786","name":"get database","func":"\nvar database = flow.get(\"database\") || [];\nmsg.payload = database;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":390,"y":720,"wires":[["43fff851.e2c7f8"]]},{"id":"43fff851.e2c7f8","type":"json","z":"38c5e956.a8e786","name":"","x":546,"y":720,"wires":[["a8dde467.e5dcd8"]]}]
Created 5 years, 11 months ago
Rating: 4.833333333333333 6
  • function (x5)
  • http in (x4)
  • http response (x4)
  • json (x1)
  • template (x1)
  • crud
  • table
  • js-grid
