Subflow - Create a folder structure and move files to them by extension using FS
I am very unorganized when it comes to files. I always have my download folder completely cluttered and my media folder empty
this is an easy solution for it
This way I can decide which files to move and where to automatically.
Requires FS assigned as a global variable to work.
It reads the files in a folder ( not recursively ) then it check if the folders you describe on the JSON ( folderStructure) exists on the destination folder then it creates a folder if needed
finally, which files correspond to each folder are checked by means of the extensions and moved
[{"id":"bd4437d9.e96308","type":"subflow","name":"Folder Classifier","info":"\n# Inputs\nIf a msg.path or a msg.folderStructure or msg.destination is sent, the msg will be used.\notherwise the node options will be used\n## path\nmsg.path or the origin folder option assigns the directory to read the files\n## destination\nmsg.destination or the destination folder option assigns the directory to write\n## folderStructure\nmsg.folderStructure or his option creates an structure on the destination to move the files\n\n## How it works\nIt reads the files in a folder ( not recursively )\nthen it check if the folders you describe on the JSON ( folderStructure) exists on the destination folder\nthen it creates a folder if needed\n\nfinally, which files correspond to each folder are checked by means of the extensions  and moved\n\n\n# (i) This node needs FS \n(is assigned on the Funcion inside, first line, you can change it)\n","category":"","in":[{"x":40,"y":120,"wires":[{"id":"1978c645.4bd9fa"}]}],"out":[],"env":[{"name":"setOriginFolder","type":"str","value":"D:\\\\Test Reorder Folder","ui":{"label":{"en-US":"Origin path"}}},{"name":"setDestinationFolder","type":"str","value":"D:\\\\Test Reorder Folder","ui":{"label":{"en-US":"Destination path"}}},{"name":"setFolderStructure","type":"json","value":"[{\"folderName\":\"Documents\",\"extensionsAvailable\":[\"txt\",\"doc\",\"docx\",\"xml\",\"pdf\",\"epub\",\"azw\",\"ibook\"]},{\"folderName\":\"Audio\",\"extensionsAvailable\":[\"mp3\",\"wav\",\"wma\",\"MIDI\"]},{\"folderName\":\"Video\",\"extensionsAvailable\":[\"AVI\",\"BIK\",\"DIV\",\"DIVX\",\"DVD\",\"IVF\",\"mpeg\",\"MOV\",\"MOVIE\",\"MP2V\",\"MP4\",\"MPA\",\"MPE\",\"MPEG\",\"MPG\",\"MPV2\",\"QT\",\"QTL\",\"RPM\",\"SMK\",\"WM\",\"WMV\",\"WOB\"]},{\"folderName\":\"Zips\",\"extensionsAvailable\":[\"zip\",\"rar\",\"tar\"]},{\"folderName\":\"Images\",\"extensionsAvailable\":[\"jpg\",\"jpeg\",\"bmp\",\"png\"]},{\"folderName\":\"Executables\",\"extensionsAvailable\":[\"exe\",\"bat\",\"dll\",\"sys\"]},{\"folderName\":\"Images Animated\",\"extensionsAvailable\":[\"gif\"]},{\"folderName\":\"Virtual Machines\",\"extensionsAvailable\":[\"iso\",\"mds\",\"img\"]},{\"folderName\":\"Others\"}]","ui":{"label":{"en-US":"Folder Structure"},"type":"input","opts":{"types":["json","env"]}}}],"color":"#DDAA99","icon":"node-red/sort.svg","status":{"x":220,"y":180,"wires":[{"id":"2add29ea.adfa26","port":0}]}},{"id":"1978c645.4bd9fa","type":"function","z":"bd4437d9.e96308","name":"","func":"var path = (msg.path) ? msg.path : (env.get(\"setOriginFolder\"));\nvar destination = (msg.destination) ? msg.destination : (env.get(\"setDestinationFolder\"));\n\nconst fs = global.get('fs');\nvar customDirStructure = (msg.folderStructure && typeof msg.folderStructure === \"array\") ? msg.folderStructure : env.get(\"setFolderStructure\");\n\nfunction checkDirectory(parentDir, dirList) {\n    dirList.forEach(item => {\n        if (!fs.existsSync(`${parentDir}/${item.folderName}`)) {\n            fs.mkdirSync(`${parentDir}/${item.folderName}`);\n        }\n    })\n\n}\ncheckDirectory(destination, customDirStructure);\n(function reorderDirectory(__dirname) {\n    fs.readdir(__dirname, (err, files) => {\n        if (err) {\n            node.error(err);\n        }\n        else {\n            files.forEach(file => {\n                var stats = fs.stat(`${__dirname}/${file}`, (err, fileWithStats) => {\n                    if (err) {\n                        node.error(err);\n                    }\n                    else {\n                        if (fileWithStats.isFile()) {\n                            //recursive\n                            fileWithStats.path = `${__dirname}/${file}`\n                            fileWithStats.filename = file\n                            fileWithStats.extension = file.replace(/.*\\./, '').toLowerCase();\n\n                            moveTo(fileWithStats, destination, customDirStructure)\n                        }\n                    }\n                })\n            })\n        }\n    })\n    node.status({ text: \"Ended\", fill: \"green\" })\n\n})(path)\n\n//functions\nfunction moveTo(item, destination, customDirStructure) {\n    try {\n        // node.warn({item:item,destination:destination,customDirStructure:customDirStructure})\n        for (var i = 0; i < customDirStructure.length; i++) {\n            var path = `${destination}/${customDirStructure[i].folderName}/${item.filename}`;\n            if (customDirStructure[i].extensionsAvailable) {\n                var extensions = customDirStructure[i].extensionsAvailable;\n                var valid = extensions.sort().join(\", \");\n                //  node.warn({indexOf:extensions.indexOf(item.extension)})\n                if (extensions.indexOf(item.extension) > 0) {\n                    // node.warn({[path]:item})\n                    move(item.path, path, function (err) {\n                        if (err) {\n                            node.status({ text: \"error\", fill: \"red\" });\n                            node.error(err)\n                        }\n                    })\n                }\n\n            } else {\n                move(item.path, path, function (err) {\n                    if (err) {\n                        node.status({ text: \"error\", fill: \"red\" });\n                        node.error(err)\n                    }\n                })\n            }\n        }\n    } catch (err) { node.error(err) }\n}\nfunction move(oldPath, newPath, callback) {\n\n    fs.rename(oldPath, newPath, function (err) {\n        if (err) {\n            if (err.code === 'EXDEV') {\n                copy();\n            } else {\n                callback(err);\n            }\n            return;\n        }\n        callback();\n    });\n\n    function copy() {\n        var readStream = fs.createReadStream(oldPath);\n        var writeStream = fs.createWriteStream(newPath);\n\n        readStream.on('error', callback);\n        writeStream.on('error', callback);\n\n        readStream.on('close', function () {\n            fs.unlink(oldPath, callback);\n        });\n\n        readStream.pipe(writeStream);\n    }\n}","outputs":0,"noerr":0,"initialize":"","finalize":"","x":220,"y":120,"wires":[]},{"id":"2add29ea.adfa26","type":"status","z":"bd4437d9.e96308","name":"","scope":null,"x":80,"y":180,"wires":[[]]},{"id":"18124f15.e1c7f1","type":"comment","z":"bd4437d9.e96308","name":"link: list of extensions by type","info":"[https://www.geeknetic.es/Guia/91/Los-archivos-tipos-extensiones-y-programas-para-su-uso.html#:~:text=Los%20tipos%20de%20archivo%20m%C3%A1s,%2C%20mpeg%2C%20mwv%2C%20etc.]()","x":140,"y":20,"wires":[]},{"id":"5f1e5450.c37fcc","type":"subflow:bd4437d9.e96308","z":"4fbee581.75591c","name":"","env":[{"name":"setOriginFolder","value":"C:\\Users\\My User\\Downloads","type":"str"},{"name":"setDestinationFolder","value":"D:\\Multimedia","type":"str"},{"name":"setFolderStructure","value":"[{\"folderName\":\"01-Documents\",\"extensionsAvailable\":[\"txt\",\"doc\",\"docx\",\"xml\",\"pdf\",\"epub\",\"azw\",\"ibook\"]},{\"folderName\":\"02-Music\",\"extensionsAvailable\":[\"mp3\",\"wav\",\"wma\",\"MIDI\"]},{\"folderName\":\"03-Videos\",\"extensionsAvailable\":[\"AVI\",\"BIK\",\"DIV\",\"DIVX\",\"DVD\",\"IVF\",\"mpeg\",\"MOV\",\"MOVIE\",\"MP2V\",\"MP4\",\"MPA\",\"MPE\",\"MPEG\",\"MPG\",\"MPV2\",\"QT\",\"QTL\",\"RPM\",\"SMK\",\"WM\",\"WMV\",\"WOB\"]},{\"folderName\":\"06-Zips\",\"extensionsAvailable\":[\"zip\",\"rar\",\"tar\"]},{\"folderName\":\"04-Images\",\"extensionsAvailable\":[\"jpg\",\"jpeg\",\"bmp\",\"png\"]},{\"folderName\":\"07-Executables\",\"extensionsAvailable\":[\"exe\",\"bat\",\"dll\",\"sys\",\"msi\"]},{\"folderName\":\"05-Images Animated\",\"extensionsAvailable\":[\"gif\"]},{\"folderName\":\"08-Virtual Machines\",\"extensionsAvailable\":[\"iso\",\"mds\",\"img\"]}]","type":"json"},{"name":"setOrigin","value":"C:\\Users\\Anxo\\Downloads","type":"str"},{"name":"setDestination","value":"D:\\Multimedia","type":"str"}],"x":360,"y":120,"wires":[]},{"id":"4b49fdd2.86cc94","type":"inject","z":"4fbee581.75591c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"1500","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["5f1e5450.c37fcc"]]}]
Created 6 years ago
  • status (x1)
  • subflow (x1)
  • subflow:bd4437d9.e96308 (x1)
  • folder
  • fs
  • structure
  • json
  • organize
  • file
  • files
  • move
  • extension
  • subflow
