Virtual keyboard
This ui-template displays a virtual keyboard in the dashboard whenever a text input field receives focus. The virtual keyboard is based on https://github.com/javidan/jkeyboard
New features:
  • Numeric keypad now waits for "return" key to send value to input field and auto-closes virtual keyboard
  • Auto-center bottom
  • Auto-detect input type text or number to show proper keyboard layout
  • More compact keyboard
[{"id":"b973810a.e5c0f","type":"debug","z":"4644f093f20e9e40","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":570,"y":320,"wires":[]},{"id":"e26fbcc4.5a681","type":"ui_text_input","z":"4644f093f20e9e40","name":"","label":"Username","tooltip":"","group":"6a4d510d.5de65","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":"0","topic":"","topicType":"str","x":390,"y":340,"wires":[["b973810a.e5c0f"]]},{"id":"3951049.3fad1fc","type":"ui_text_input","z":"4644f093f20e9e40","name":"","label":"Password","tooltip":"","group":"6a4d510d.5de65","order":4,"width":0,"height":0,"passthru":true,"mode":"password","delay":300,"topic":"","x":380,"y":380,"wires":[["b973810a.e5c0f"]]},{"id":"c5db1e72.3ef58","type":"ui_template","z":"4644f093f20e9e40","group":"6a4d510d.5de65","name":"Virtual Keyboard","order":1,"width":0,"height":0,"format":"<div id=\"empty\"></div>\n<button class=\"VK\">V-KeyBoard On</button>\n\n<!-- The Modal -->\n<div id=\"myModal\" class=\"modal\">\n\n  <!-- Modal content -->\n  <div class=\"modal-content\">\n      <div class=\"modal-header\">\n      <span class=\"close\" onclick=\"closeModal()\">&times;</span>\n      <h2 id=\"vkeyname\" style=\"background-color: aliceblue !important; color: black !important; text-align: center; min-height: 30px;\">V-Keyboard</h2>\n    </div>\n    <div class=\"modal-body\">\n        <div id=\"keyboard\"></div>\n        <div>\n        </div>\n    </div>\n  </div>\n</div>\n\n<style>\n.VK{\n    position: fixed;\n    top: 60px;\n    right: 20px;\n    height: 30px;\n}\n</style>\n\n<script>\n\nvar clickState = 1;\nvar btn = document.querySelector('.VK');\n\nbtn.addEventListener('click', function(){\n\n  if (clickState == 0) {\n    this.textContent = 'V-KeyBoard On';\n    modal = document.getElementById('myModal');\n    clickState = 1;\n  } else {\n    this.textContent = 'V-KeyBoard Off';\n    modal = document.getElementById('empty');\n    clickState = 0;\n  }\n\n});\n</script>\n\n<script>\n    // Get the modal\nvar modal = document.getElementById('myModal');\nvar inputTags;\nvar inputType;\nvar inputTarget;\n\nvar getinputs = function() {\n    inputTags = document.getElementsByTagName(\"input\");\n    console.log(inputTags)\n    for (var i = 0; i < inputTags.length; i++) {\n        inputTags[i].addEventListener('click', openModal, false)\n    }\n}\n\nsetTimeout(function(){ getinputs(); }, 1000);\n\nvar openModal = function() {\n    inputType = event.target.type\n    inputTarget = event.target\n    var layoutName;\n    if (inputType == \"number\"){\n        //inputTarget.type = \"number\" //hack because chrome doesn't allow setselection in number inputs\n        //inputTarget.value = \"\"\n        layoutName = \"numbers_only\"\n    }else{\n        layoutName = \"english\"\n    }\n    $('#vkeyname').text(event.target.value)\n    $('#keyboard').unbind().removeData();\n    modal.style.display = \"block\";\n    $('#keyboard').jkeyboard({\n        layout: layoutName,\n        input: $('#'+$(this).attr('id'))\n    });\n}\n\n\n// Get the <span> element that closes the modal\nvar span = document.getElementsByClassName(\"close\")[0];\n\n// When the user clicks anywhere outside of the modal, close it\nwindow.onclick = function(event) {\n    var source = event.target;\n    if (source == modal || source == span) {\n        closeModal(source)\n    }\n};\n\nvar closeModal = function(source){\n    //console.log(\"closing\")\n    modal.style.display = \"none\";\n   \n    if (inputType == \"number\"){\n        inputTarget.type = \"number\" //hack because chrome doesn't allow selectionstart on number inputs\n    }\n}\n\n    \n// the semi-colon before function invocation is a safety net against concatenated\n// scripts and/or other plugins which may not be closed properly.\n; (function ($, window, document, undefined) {\n\n    // undefined is used here as the undefined global variable in ECMAScript 3 is\n    // mutable (ie. it can be changed by someone else). undefined isn't really being\n    // passed in so we can ensure the value of it is truly undefined. In ES5, undefined\n    // can no longer be modified.\n\n    // window and document are passed through as local variable rather than global\n    // as this (slightly) quickens the resolution process and can be more efficiently\n    // minified (especially when both are regularly referenced in your plugin).\n\n    // Create the defaults once\n    var pluginName = \"jkeyboard\",\n        defaults = {\n            layout: \"english\",\n            input: $('#input'),\n            customLayouts: {\n                selectable: []\n            },\n        };\n\n\n    var function_keys = {\n        backspace: {\n            text: 'DEL',\n        },\n        return: {\n            text: 'Enter'\n        },\n        shift: {\n            text: 'Shift'\n        },\n        space: {\n            text: 'Space'\n        },\n        numeric_switch: {\n            text: '123',\n            command: function () {\n                this.createKeyboard('numeric');\n                this.events();\n            }\n        },\n        layout_switch: {\n            text: '<i class=\"fa fa-keyboard-o\" aria-hidden=\"true\"></i>',\n            command: function () {\n                var l = this.toggleLayout();\n                this.createKeyboard(l);\n                this.events();\n            }\n        },\n        character_switch: {\n            text: 'ABC',\n            command: function () {\n                this.createKeyboard(layout);\n                this.events();\n            }\n        },\n        symbol_switch: {\n            text: '#+=',\n            command: function () {\n                this.createKeyboard('symbolic');\n                this.events();\n            }\n        }\n    };\n\n\n    var layouts = {\n        selectable: ['english', 'russian','french', 'emoji'],\n        english: [\n            ['q', 'w', 'e', 'r', 't', 'y', 'u', 'i', 'o', 'p',],\n            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l',],\n            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm', 'backspace'],\n            ['numeric_switch', 'layout_switch', 'space', 'return']\n        ],\n        russian: [\n            ['й', 'ц', 'у', 'к', 'е', 'н', 'г', 'ш', 'щ', 'з', 'х'],\n            ['ф', 'ы', 'в', 'а', 'п', 'р', 'о', 'л', 'д', 'ж', 'э'],\n            ['shift', 'я', 'ч', 'с', 'м', 'и', 'т', 'ь', 'б', 'ю', 'backspace'],\n            ['numeric_switch', 'layout_switch', 'space', 'return']\n        ],\n        french: [\n            ['q', 'w', 'e', 'r', 't', 'y', 'u', 'i', 'o', 'p',],\n            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l','à','ç'],\n            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm','é','è', 'backspace'],\n            ['numeric_switch', 'layout_switch', 'space', 'return']\n        ],\n        emoji: [\n            ['😀', '😁', '😂', '🤣', '😃', '😄', '😅', '😆', '😉', '😊',],\n            ['😋', '😎', '😍', '😘', '❤️', '🙏', '🔥', '✨', '👍','👌','💯'],\n            ['🤷', '🎉', '👏', '🤦', '🙌', '🎶', '💥', '🌈','✅','⭐', '👀'],\n            ['numeric_switch', 'layout_switch', 'space', 'return']\n        ],            \n        numeric: [\n            ['1', '2', '3', '4', '5', '6', '7', '8', '9', '0'],\n            ['-', '/', ':', ';', '(', ')', '$', '&', '@', '\"'],\n            ['symbol_switch', '.', ',', '?', '!', \"'\", 'backspace'],\n            ['character_switch', 'layout_switch', 'space', 'return'],\n        ],\n        numbers_only: [\n            ['1', '2', '3',],\n            ['4', '5', '6',],\n            ['7', '8', '9',],\n            ['0', 'backspace', 'return'],\n        ],\n        symbolic: [\n            ['[', ']', '{', '}', '#', '%', '^', '*', '+', '='],\n            ['_', '\\\\', '|', '~', '<', '>'],\n            ['numeric_switch', '.', ',', '?', '!', \"'\", 'backspace'],\n            ['character_switch', 'layout_switch', 'space', 'return'],\n\n        ]\n    }\n\n    var shift = false, capslock = false, layout = 'english', layout_id = 0;\n\n    // The actual plugin constructor\n    function Plugin(element, options) {\n        this.element = element;\n        // jQuery has an extend method which merges the contents of two or\n        // more objects, storing the result in the first object. The first object\n        // is generally empty as we don't want to alter the default options for\n        // future instances of the plugin\n        this.settings = $.extend({}, defaults, options);\n        // Extend & Merge the cusom layouts\n        layouts = $.extend(true, {}, this.settings.customLayouts, layouts);\n        if (Array.isArray(this.settings.customLayouts.selectable)) {\n            $.merge(layouts.selectable, this.settings.customLayouts.selectable);\n        }\n        this._defaults = defaults;\n        this._name = pluginName;\n        this.init();\n    }\n\n    Plugin.prototype = {\n        init: function () {\n            layout = this.settings.layout;\n            this.createKeyboard(layout);\n            this.events();\n        },\n\n        setInput: function (newInputField) {\n            this.settings.input = newInputField;\n        },\n\n        createKeyboard: function (layout) {\n            shift = false;\n            capslock = false;\n\n            var keyboard_container = $('<ul/>').addClass('jkeyboard'),\n                me = this;\n\n            layouts[layout].forEach(function (line, index) {\n                var line_container = $('<li/>').addClass('jline');\n                line_container.append(me.createLine(line));\n                keyboard_container.append(line_container);\n            });\n\n            $(this.element).html('').append(keyboard_container);\n        },\n\n        createLine: function (line) {\n            var line_container = $('<ul/>');\n\n            line.forEach(function (key, index) {\n                var key_container = $('<li/>').addClass('jkey').data('command', key);\n\n                if (function_keys[key]) {\n                    key_container.addClass(key).html(function_keys[key].text);\n                }\n                else {\n                    key_container.addClass('letter').html(key);\n                }\n\n                line_container.append(key_container);\n            })\n\n            return line_container;\n        },\n\n        events: function () {\n            var letters = $(this.element).find('.letter'),\n                shift_key = $(this.element).find('.shift'),\n                space_key = $(this.element).find('.space'),\n                backspace_key = $(this.element).find('.backspace'),\n                return_key = $(this.element).find('.return'),\n\n                me = this,\n                fkeys = Object.keys(function_keys).map(function (k) {\n                    return '.' + k;\n                }).join(',');\n\n            letters.on('click', function () {\n                me.type((shift || capslock) ? $(this).text().toUpperCase() : $(this).text());\n            });\n\n            space_key.on('click', function () {\n                me.type(' ');\n            });\n\n            return_key.on('click', function () {\n                me.enter();\n            });\n\n            backspace_key.on('click', function () {\n                me.backspace();\n            });\n\n            shift_key.on('click', function () {\n                if (capslock) {\n                    me.toggleShiftOff();\n                    capslock = false;\n                } else {\n                    me.toggleShiftOn();\n                }\n            }).on('dblclick', function () {\n                capslock = true;\n            });\n\n\n            $(fkeys).on('click', function () {\n                var command = function_keys[$(this).data('command')].command;\n                if (!command) return;\n\n                command.call(me);\n            });\n        },\n\n        type: function (key) {\n            var input = this.settings.input,\n                val = input.val(),\n                input_node = input.get(0),\n                start = input_node.selectionStart,\n                end = input_node.selectionEnd;\n\n            var max_length = $(input).attr(\"maxlength\");\n            if (start == end && end == val.length) {\n                if (!max_length || val.length < max_length) {\n                    input.val(val + key);\n                    input.change()\n                    $('#vkeyname').text(val + key)\n                }\n            } else {\n                if (input_node.type == \"text\"){\n                    var new_string = this.insertToString(start, end, val, key);\n                    input.val(new_string);\n                    start++;\n                    end = start;\n                    input_node.setSelectionRange(start, end);\n                    input.change()\n                }else if (input_node.type == \"number\"){\n                    input.val(val + key);\n                }else{\n                    input.val(val + key);\n                    input.change()\n                }\n                $('#vkeyname').text(val + key)\n                \n            }\n            input.trigger('focus');\n\n            if (shift && !capslock) {\n                this.toggleShiftOff();\n            }\n        },\n        \n        enter: function () {\n            var input = this.settings.input,\n                val = input.val();\n                input_node = input.get(0),\n                start = input_node.selectionStart,\n                end = input_node.selectionEnd;\n            if (input_node.type == \"text\"){\n                val = val + \"\\n\";\n                $('#vkeyname').text(val)\n            }\n            input.change()\n            input.focus()\n            if (input_node.type == \"number\"){\n                modal.style.display = \"none\";\n            }\n        },\n\n        backspace: function () {\n            var input = this.settings.input,\n                val = input.val();\n                input_node = input.get(0),\n                start = input_node.selectionStart,\n                end = input_node.selectionEnd;\n            if (input.type == \"text\"){\n                input.val(val.slice(0, start-1) + val.slice(start))\n                input_node.setSelectionRange(start-1, start-1);\n                //console.log(val)\n                $('#vkeyname').text(val)\n            }else{\n                input.val(val.slice(0,-1))\n                $('#vkeyname').text(val.slice(0,-1))\n            }\n            //input.change()\n            //input.focus()\n        },\n\n        toggleShiftOn: function () {\n            var letters = $(this.element).find('.letter'),\n                shift_key = $(this.element).find('.shift');\n\n            letters.addClass('uppercase');\n            shift_key.addClass('active')\n            shift = true;\n        },\n\n        toggleShiftOff: function () {\n            var letters = $(this.element).find('.letter'),\n                shift_key = $(this.element).find('.shift');\n\n            letters.removeClass('uppercase');\n            shift_key.removeClass('active');\n            shift = false;\n        },\n\n        toggleLayout: function () {\n            layout_id = layout_id || 0;\n            var plain_layouts = layouts.selectable;\n            layout_id++;\n\n            var current_id = layout_id % plain_layouts.length;\n            var SelectedLayoutName = plain_layouts[current_id];\n            $('#vkeyname').text('V-Keyboard ' + SelectedLayoutName )\n            return plain_layouts[current_id];\n        },\n\n        insertToString: function (start, end, string, insert_string) {\n            return string.substring(0, start) + insert_string + string.substring(end, string.length);\n        }\n    };\n\n        /*\n\t\t// A really lightweight plugin wrapper around the constructor,\n\t\t// preventing against multiple instantiations\n\t\t$.fn[ pluginName ] = function ( options ) {\n\t\t\t\treturn this.each(function() {\n\t\t\t\t\t\tif ( !$.data( this, \"plugin_\" + pluginName ) ) {\n\t\t\t\t\t\t\t\t$.data( this, \"plugin_\" + pluginName, new Plugin( this, options ) );\n\t\t\t\t\t\t}\n\t\t\t\t});\n\t\t};\n        */\n        var methods = {\n            init: function(options) {\n                if (!this.data(\"plugin_\" + pluginName)) {\n                    this.data(\"plugin_\" + pluginName, new Plugin(this, options));\n                }\n            },\n\t\t\tsetInput: function(content) {\n\t\t\t\tthis.data(\"plugin_\" + pluginName).setInput($(content));\n            },\n            setLayout: function(layoutname) {\n                // change layout if it is not match current\n                object = this.data(\"plugin_\" + pluginName);\n                if (typeof(layouts[layoutname]) !== 'undefined' && object.settings.layout != layoutname) {\n                    object.settings.layout = layoutname;\n                    object.createKeyboard(layoutname);\n                    object.events();\n                };\n            },\n        };\n\n\t\t$.fn[pluginName] = function (methodOrOptions) {\n            if (methods[methodOrOptions]) {\n                return methods[methodOrOptions].apply(this.first(), Array.prototype.slice.call( arguments, 1));\n            } else if (typeof methodOrOptions === 'object' || ! methodOrOptions) {\n                // Default to \"init\"\n                return methods.init.apply(this.first(), arguments);\n            } else {\n                $.error('Method ' +  methodOrOptions + ' does not exist on jQuery.tooltip');\n            }\n        };\n\n})(jQuery, window, document);\n</script>\n\n<style>\nbody {font-family: Arial, Helvetica, sans-serif;}\n\n.nr-dashboard-theme .nr-dashboard-template .md-button:not(:first-of-type) {\n    margin-top: 0px;\n}\n\n/* The Modal (background) */\n.modal {\n    display: none; /* Hidden by default */\n    position: fixed; /* Stay in place */\n    opacity:0.99;\n    z-index: 100; /* Sit on top */\n    left: 0;\n    top: 0;\n    width: 100%; /* Full width */\n    height: 100%; /* Full height */\n    overflow: auto; /* Enable scroll if needed */\n    background-color: rgb(0,0,0); /* Fallback color */\n    background-color: rgba(0,0,0,0.4); /* Black w/ opacity */\n}\n\n/* Modal Content */\n.modal-content {\n    position: fixed;\n    background-color: #fefefe;\n    margin: auto;\n    padding: 0;\n    bottom: 0%;\n    left: 50%;\n    transform: translate(-50%, 0%);\n    border: 1px solid #888;\n    width: fit-content;\n    max-width: 100%;\n    max-height: 100%;\n    box-shadow: 0 4px 8px 0 rgba(0,0,0,0.2),0 6px 20px 0 rgba(0,0,0,0.19);\n    -webkit-animation-name: animate;\n    -webkit-animation-duration: 0.4s;\n    animation-name: animate;\n    animation-duration: 0.4s\n}\n\n/* Add Animation */\n@-webkit-keyframes animate {\n    from {bottom:100%; opacity:0} \n    to {bottom:0%; opacity:1}\n}\n\n@keyframes animate {\n    from {bottom:100%; opacity:0}\n    to {bottom:0%; opacity:1}\n}\n\n/* The Close Button */\n.close {\n    color: black;\n    float: right;\n    font-size: 28px;\n    font-weight: bold;\n}\n\n.close:hover,\n.close:focus {\n    color: #000;\n    text-decoration: none;\n    cursor: pointer;\n}\n\n.modal-header {\n    padding: 2px 16px;\n    background-color: aliceblue;\n    color: white;\n}\n\n.modal-body {padding: 2px 16px;}\n\n.modal-footer {\n    padding: 2px 16px;\n    background-color: #5cb85c;\n    color: white;\n}\n\n.jkeyboard {\n  display: inline-block;\n}\n.jkeyboard, .jkeyboard .jline, .jkeyboard .jline ul {\n  display: block;\n  margin: 0;\n  padding: 0;\n}\n.jkeyboard .jline {\n  text-align: center;\n  margin-left: -14px;\n}\n.jkeyboard .jline ul li {\n  font-family: arial, sans-serif;\n  font-size: 20px;\n  display: inline-block;\n  border: 1px solid #468db3;\n  -webkit-box-shadow: 0 0 3px #468db3;\n  -webkit-box-shadow: inset 0 0 3px #468db3;\n  margin: 5px 0 1px 6px;\n  color: #000000;\n  border-radius: 5px;\n  width: 52px;\n  height: 52px;\n  box-sizing: border-box;\n  text-align: center;\n  line-height: 52px;\n  overflow: hidden;\n  cursor: pointer;\n  -webkit-touch-callout: none;\n  -webkit-user-select: none;\n  -khtml-user-select: none;\n  -moz-user-select: -moz-none;\n  -ms-user-select: none;\n  user-select: none;\n}\n.jkeyboard .jline ul li.uppercase {\n  text-transform: uppercase;\n}\n.jkeyboard .jline ul li:hover, .jkeyboard .jline ul li:active {\n  background-color: #185a82;\n}\n.jkeyboard .jline .return {\n  width: 80px;\n}\n.jkeyboard .jline .space {\n  width: 366px;\n}\n.jkeyboard .jline .numeric_switch {\n  width: 65px;\n}\n.jkeyboard .jline .layout_switch {\n}\n.jkeyboard .jline .shift {\n  width: 60px;\n}\n.jkeyboard .jline .backspace {\n  width: 69px;\n}\n</style>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":400,"y":220,"wires":[[]]},{"id":"32f1ea4.2330616","type":"ui_text_input","z":"4644f093f20e9e40","name":"","label":"","tooltip":"","group":"6a4d510d.5de65","order":5,"width":0,"height":0,"passthru":true,"mode":"email","delay":300,"topic":"","topicType":"str","x":390,"y":300,"wires":[["b973810a.e5c0f"]]},{"id":"d1b0fa5f.bfb838","type":"ui_text_input","z":"4644f093f20e9e40","name":"","label":"","tooltip":"","group":"6a4d510d.5de65","order":5,"width":0,"height":0,"passthru":true,"mode":"number","delay":"0","topic":"","topicType":"str","x":390,"y":260,"wires":[["b973810a.e5c0f"]]},{"id":"6a4d510d.5de65","type":"ui_group","name":"Users","tab":"56715436.c2591c","order":2,"disp":true,"width":"9","collapse":false},{"id":"56715436.c2591c","type":"ui_tab","name":"Home Tab","icon":"dashboard","order":3}]
Created 8 years, 7 months ago
Updated 5 years, 2 months ago
Rating: 5 13
  • ui_group (x1)
  • ui_template (x1)
  • ui_text_input (x4)
  • keyboard
  • virtual
  • text
  • input
