FlowFuse File Nodes
Read file node can read string from a file.
[{"id":"959d232f6856f5bb","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"84222b92.d65d18","type":"inject","z":"959d232f6856f5bb","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Hello, World!","payloadType":"str","x":170,"y":160,"wires":[["b4b9f603.739598"]]},{"id":"7b014430.dfd94c","type":"comment","z":"959d232f6856f5bb","name":"Write string to a file, then read from the file","info":"Read file node can read string from a file.","x":200,"y":80,"wires":[]},{"id":"b4b9f603.739598","type":"file","z":"959d232f6856f5bb","name":"","filename":"/tmp/hello.txt","appendNewline":true,"createDir":false,"overwriteFile":"true","encoding":"none","x":360,"y":160,"wires":[["6dc01cac.5c4bf4"]]},{"id":"2587adb9.7e60f2","type":"debug","z":"959d232f6856f5bb","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":160,"wires":[]},{"id":"6dc01cac.5c4bf4","type":"file in","z":"959d232f6856f5bb","name":"","filename":"/tmp/hello.txt","filenameType":"str","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":580,"y":160,"wires":[["2587adb9.7e60f2"]]},{"id":"f4b4309a.3b78a","type":"comment","z":"959d232f6856f5bb","name":"↑read result from file","info":"","x":570,"y":200,"wires":[]},{"id":"672d3693.3cabd8","type":"comment","z":"959d232f6856f5bb","name":"↓write to /tmp/hello.txt","info":"","x":380,"y":120,"wires":[]}]
Created 3 years ago
  • comment (x3)
  • file (x1)
  • file in (x1)
