if countdown ends
Example to use a countdown timer to check when a door is closed, and to remind to close it and then thank you when its closed.
[{"id":"4b1a599fd15ef72c","type":"inject","z":"a43fdb2b550c9007","name":"close","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":180,"y":330,"wires":[["25b89a05708bd582","17cf37fe5535e44f","f301442b791233a6"]]},{"id":"0cf13b525c31d4d4","type":"inject","z":"a43fdb2b550c9007","name":"open","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":190,"y":170,"wires":[["25b89a05708bd582"]]},{"id":"25b89a05708bd582","type":"countdown","z":"a43fdb2b550c9007","name":"","topic":"","payloadTimerStart":"true","payloadTimerStartType":"bool","payloadTimerStop":"true","payloadTimerStopType":"bool","timer":"5","resetWhileRunning":false,"setTimeToNewWhileRunning":false,"startCountdownOnControlMessage":false,"x":350,"y":170,"wires":[[],["af3601a8b45fdb0f"]]},{"id":"a1c34950f7f64004","type":"debug","z":"a43fdb2b550c9007","name":"play \"close door\"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":160,"wires":[]},{"id":"af3601a8b45fdb0f","type":"switch","z":"a43fdb2b550c9007","name":"if countdown to 1","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":540,"y":190,"wires":[["a1c34950f7f64004","d4a5948d227288aa"]]},{"id":"416fd3f1db790bbb","type":"comment","z":"a43fdb2b550c9007","name":"If countdown end","info":"","x":140,"y":120,"wires":[]},{"id":"17cf37fe5535e44f","type":"gate","z":"a43fdb2b550c9007","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":860,"y":340,"wires":[["41427fb40ad4ac76"]]},{"id":"41427fb40ad4ac76","type":"debug","z":"a43fdb2b550c9007","name":"play \"thanks\"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1020,"y":340,"wires":[]},{"id":"d4a5948d227288aa","type":"function","z":"a43fdb2b550c9007","name":"open gate","func":"msg.payload = 'open';\nmsg.topic = 'control';\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":230,"wires":[["17cf37fe5535e44f"]]},{"id":"f301442b791233a6","type":"function","z":"a43fdb2b550c9007","name":"close gate","func":"msg.payload = 'close';\nmsg.topic = 'control';\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":270,"wires":[["17cf37fe5535e44f"]]}]
Created 3 years, 9 months ago
  • debug (x2)
  • function (x2)
  • inject (x2)
  • switch (x1)
  • countdown (x1)
  • gate (x1)
  • countdown
  • gate
