Schneider POWERLOGIC PM5150 via MODBUS TCP
Subflow to obtain data from Schneider POWERLOGIC PM5150 via MODBUS TCP.
Repository and example of use: https://github.com/aprendiendonodered/POWERLOGIC_PM5150
Input: power meter modbus unitid, also added value “unitid” in output JSON object.
Read data in two parts: from address 3000, 120 registers and from address 21300, 40 registers one second later.
Join all data and form an output JSON object in payload with these data:
  • 'I_A'
  • 'I_B'
  • 'I_C'
  • 'I_N'
  • 'V_A'
  • 'V_B'
  • 'V_C'
  • 'V_N'
  • 'P_A'
  • 'P_B'
  • 'P_C'
  • 'potencia_activa_total' (Active Total Power)
  • 'potencia_reactiva_total' (Reactive Total Power)
  • 'factor_potencia_total' (Power Factor)
  • 'frecuencia' (Frecuency)
  • 'THD_I_A'
  • 'THD_I_B'
  • 'THD_I_C'
  • 'THD_V_A'
  • 'THD_V_B'
  • 'THD_V_C'
[{"id":"4dc335ce.9b905c","type":"subflow","name":"Power Meter Schneider Power Logic PM5110","info":"","category":"","in":[{"x":40,"y":80,"wires":[{"id":"3e9e8646.c1f65a"},{"id":"28bfed2e.2fe892"}]}],"out":[{"x":980,"y":80,"wires":[{"id":"2af0243a.eba7ec","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"64e41f1d.aeb8b","type":"modbus-flex-getter","z":"4dc335ce.9b905c","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"650993c2.faa71c","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":530,"y":80,"wires":[["2f379b2a.a47784"],[]]},{"id":"3e9e8646.c1f65a","type":"function","z":"4dc335ce.9b905c","name":"Datos Modbus","func":"var id = msg.payload;\n\nmsg.payload = { value: msg.payload, 'fc': 3, 'unitid': id, 'address': 2999 , 'quantity': 120 };\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":200,"y":80,"wires":[["64e41f1d.aeb8b","c1edbb80.6b60f8"]]},{"id":"d80fbeb6.69a2d","type":"function","z":"4dc335ce.9b905c","name":"Datos Modbus","func":"var id = flow.get('unitid');\n\nmsg.payload = { value: msg.payload, 'fc': 3, 'unitid': id, 'address': 21299 , 'quantity': 40 };\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":200,"wires":[["64e41f1d.aeb8b"]]},{"id":"c1edbb80.6b60f8","type":"delay","z":"4dc335ce.9b905c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":240,"y":200,"wires":[["d80fbeb6.69a2d"]]},{"id":"2f379b2a.a47784","type":"join","z":"4dc335ce.9b905c","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"2","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":710,"y":80,"wires":[["2af0243a.eba7ec"]]},{"id":"2af0243a.eba7ec","type":"function","z":"4dc335ce.9b905c","name":"","func":"var newMsg = {};\nvar obj = {};\nvar values = ['I_A','I_B','I_C','I_N','V_A','V_B','V_C','V_N','P_A','P_B','P_C','potencia_activa_total','potencia_reactiva_total','factor_potencia_total','frecuencia','THD_I_A','THD_I_B','THD_I_C','THD_V_A','THD_V_B','THD_V_C']\nvar registros = [0,2,4,6,28,30,32,34,54,56,58,60,68,84,110,0,2,4,30,32,34]\nvar fLen = registros.length;\n\nfor (i = 0; i < fLen; i++) {\n    const buf = Buffer.allocUnsafe(4);\n    var dato = registros[i];\n    if (i<15){\n        buf.writeUInt16BE(msg.payload[0][dato],0);\n        buf.writeUInt16BE(msg.payload[0][dato+1],2);\n        if (values[i] == 'factor_potencia_total'){\n            if ( buf.readFloatBE(0).toFixed(3) > 1) {\n                 obj[values[i]] = ((2 - buf.readFloatBE(0)) *  -100).toFixed(3);\n            }\n            else {\n                obj[values[i]] = buf.readFloatBE(0).toFixed(3) * 100;\n            }\n        }\n        else {\n            obj[values[i]] = buf.readFloatBE(0).toFixed(3);\n        }\n    }\n    else {\n        buf.writeUInt16BE(msg.payload[1][dato],0);\n        buf.writeUInt16BE(msg.payload[1][dato+1],2);\n        obj[values[i]] = buf.readFloatBE(0).toFixed(3);\n    }\n    \n    //node.warn(`${values[i]} : ${buf.readFloatBE(0).toFixed(3)}`)\n}\n\nobj['unitid'] = flow.get('unitid');\nnewMsg.payload = obj;\n\nreturn newMsg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":80,"wires":[[]]},{"id":"28bfed2e.2fe892","type":"change","z":"4dc335ce.9b905c","name":"","rules":[{"t":"set","p":"unitid","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":300,"wires":[[]]},{"id":"650993c2.faa71c","type":"modbus-client","name":"Power Meter","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"10.10.10.10","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true},{"id":"d8cdaff9.7c55a","type":"subflow:4dc335ce.9b905c","z":"ab7d75a0.a74bc8","name":"","env":[],"x":350,"y":120,"wires":[["30529a9d.253636","7403a443.d6c0fc"]]}]
Created 6 years, 6 months ago
Rating: 5 1
  • change (x1)
  • delay (x1)
  • function (x3)
  • join (x1)
  • modbus-client (x1)
  • modbus-flex-getter (x1)
  • subflow (x1)
  • subflow:4dc335ce.9b905c (x1)
  • modbus
  • Schneider
  • POWERLOGIC PM5150
