node-red-contrib-ffmpeg-iotcam example flow
This flow shows how to use node-red-contrib-ffmpeg-iotcam and node-red-contrib-samsung-automation-studio-nodes. iotcam2img
execute
  1. Input your smartthings PAT My device node
  2. Select homecamera in command node.
  3. Set capability and command startStream
  4. Set device in status node.
  5. Set variable in iotcam2img node.
[{"id":"f785b96f.ce4538","type":"tab","label":"2iotcam example","disabled":false,"info":""},{"id":"cef06ff1.64cdf","type":"inject","z":"f785b96f.ce4538","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":450,"y":340,"wires":[["28d864bd.a09f7c"]]},{"id":"d8df7951.d0f9a8","type":"iotcam2img","z":"f785b96f.ce4538","rtspURL":"","saveURL":"","totalFrame":"40","timer":"10","name":"","x":950,"y":340,"wires":[[],[],[]]},{"id":"209dbd9b.811412","type":"installed-device","z":"f785b96f.ce4538","name":"","alias":"token:194798e1","device":"","devices":["1b17f114-acff-4c25-a4cf-2459af69f369","51d084c2-a8d2-4966-9624-18b8adaab221","236ab083-eecf-101c-e230-286ed126ef06","ecc14b61-c49d-9e25-7087-fd0dc9ecbc3b","7ea0eda7-101d-2896-d7f8-57997ee022f0","91205853-dab4-3e5f-c009-e621b9824b1c","4e083c8b-4a4f-4518-2eeb-887c5a7131c6","7182a570-8e4f-2112-2c20-a10916f9bd56","158cf65e-dc2d-c58b-6506-f02595f6d98c","7e5f6017-2a28-6b82-1ab3-7b16e8ee7727","6b429d72-b358-1c5f-9fea-745ea3780439","cc5f82f5-f6d5-16a3-ccdb-1baf7a345629","1e2418e2-6009-f156-6c99-bc5964af63a6","c20b8fa0-ba57-41be-963e-e5669788afb3","e0161013-412b-4a33-a3b6-c6a42ec0f95e"],"profileId":"209dbd9b.811412","x":460,"y":280,"wires":[]},{"id":"9f27c8bd.3223c8","type":"status-device","z":"f785b96f.ce4538","name":"Camera status","alias":"홈카메라 360 집","deviceNodeId":"209dbd9b.811412","deviceType":"installed-device","deviceId":"51d084c2-a8d2-4966-9624-18b8adaab221","componentId":"","capabilityId":"audioStream_v1","attributeId":"uri","rules":[],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":760,"y":340,"wires":[["d8df7951.d0f9a8"]]},{"id":"28d864bd.a09f7c","type":"command-device","z":"f785b96f.ce4538","name":"Start Stream","alias":"startStream","deviceNodeId":"209dbd9b.811412","deviceType":"installed-device","deviceId":"51d084c2-a8d2-4966-9624-18b8adaab221","componentId":"","capabilityId":"videoStream_v1","attributeId":"startStream","rules":[{"capaId":"videoStream_v1","attrId":"startStream","args":[]}],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":590,"y":340,"wires":[["9f27c8bd.3223c8"]]}]
Created 4 years ago
  • node-red-contrib-ffmpeg-iotcam
  • ffmpeg
  • smartthings
  • rtsp
