Store Nefit-Easy GasUsage data in InfluxDB
Starting with version 2.0.0 of https://flows.nodered.org/node/node-red-contrib-nefit-easy2 the node now also supports extracting GasUsage data from Nefit-Easy.
The flow runs daily (since the data on Nefit-Easy is only updated daily). It will extract the usage data and transform the data into a format that is usable for InfluxDB.
It then uploads the data to InfluxDB. Running it multiple times is no problem, since the timestamp is taken from the Nefit-Easy report. So the latest data for a data will simply be overwritten if already available within Influx DB.
syncflow
[{"id":"a248bce7.8f79d","type":"nefit-easy","z":"33143d4b.705502","easyconfig":"6a526c87.a87da4","name":"","topic":"nefit-easy","command":"getval-gasusage","value":"","x":440,"y":200,"wires":[["12c9e807.0285c8","326e6cad.8b1bc4"]]},{"id":"12c9e807.0285c8","type":"debug","z":"33143d4b.705502","name":"Easy Results","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":140,"wires":[]},{"id":"326e6cad.8b1bc4","type":"function","z":"33143d4b.705502","name":"Map Nefit to influx","func":"var result = msg.payload.map(v => {\n    return { \n        timestamp : v.date,\n        measurement : \"nefit_easy\",\n        fields: {\n            hot_water : v[\"hot water\"],\n            central_heating : v[\"central heating\"],\n            average_outdoor_temperature : v[\"average outdoor temperature\"]\n        }\n    };\n});\n\nmsg.payload = result;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":670,"y":200,"wires":[["8b8ade76.8c1ac"]]},{"id":"16eeece5.cf6733","type":"inject","z":"33143d4b.705502","name":"Trigger Daily","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 04 * * *","once":false,"onceDelay":"","topic":"","payload":"","payloadType":"num","x":180,"y":200,"wires":[["a248bce7.8f79d"]]},{"id":"8b8ade76.8c1ac","type":"influxdb batch","z":"33143d4b.705502","influxdb":"","precision":"","retentionPolicy":"","name":"","x":940,"y":200,"wires":[]},{"id":"6a526c87.a87da4","type":"nefit-easy-config","z":"","timeout":"30"}]
Created 6 years, 1 month ago
  • influxdb batch (x1)
  • nefit-easy (x1)
  • nefit-easy-config (x1)
  • nefit-easy
  • influxdb
  • gasusage
