homee-Statusmeldung-Huebridge-Wemorueckkanal
Mit diesem Flow kannst du Lampen der Huebridge in homee schalten, indem ein Wemo Switch emuliert wird. Zusätzlich wird per Rückkanal ein Schaltvorgang über die Hue App registriert und der Status übermittelt.
Vielen herzlichen an Dank an Micha2536, der maßgeblich zu diesem Flow beigetragen hat.
[{"id":"3b5a3446.541c14","type":"function","z":"2cc975df.7f8f7a","name":"Switch","func":"var payload = {\n \"on\": msg.payload === 'on'\n}\n\nmsg.payload = payload;\n\nreturn msg;","outputs":1,"noerr":0,"x":290,"y":60,"wires":[["496ee489.0aeafc"]]},{"id":"496ee489.0aeafc","type":"hue-light","z":"2cc975df.7f8f7a","name":"Hue iris rechts","bridge":"1514d048.34582","lightid":"4","colornamer":true,"x":500,"y":60,"wires":[[]]},{"id":"738d188e.7a5708","type":"function","z":"2cc975df.7f8f7a","name":"Prüfen des Zustandes Hue Iris rechts","func":"var nodeid = 299; // node ID in homee vom Wemo\nvar attributid = 1244; // attribut ID in homee vom Wemo\nif (msg.payload.on === false)\n{return {payload: \"PUT:/nodes/\"+nodeid+\"/attributes/\"+attributid+\"?target_value=0\"}}\nif (msg.payload.on === true)\n{return {payload: \"PUT:/nodes/\"+nodeid+\"/attributes/\"+attributid+\"?target_value=1\"}}\n","outputs":1,"noerr":0,"x":390,"y":120,"wires":[["d4ae81e.c8ba58"]]},{"id":"d4ae81e.c8ba58","type":"homee","z":"2cc975df.7f8f7a","name":"homee","host":"192.168.1.168","x":650,"y":120,"wires":[[]]},{"id":"d0751b6e.7b7be8","type":"hue-light","z":"2cc975df.7f8f7a","name":"Hue iris rechts","bridge":"1514d048.34582","lightid":"4","colornamer":true,"x":100,"y":120,"wires":[["738d188e.7a5708"]]},{"id":"b8e99457.7d8928","type":"wemo-emulator","z":"2cc975df.7f8f7a","name":"Hue Iris rechts","friendlyName":"Hue Iris rechts","serial":"100001","port":"49301","onTopic":"switch/hir","onPayload":"on","offTopic":"switch/hir","offPayload":"off","x":90,"y":60,"wires":[["3b5a3446.541c14"]],"icon":"node-red/light.png"},{"id":"1514d048.34582","type":"hue-bridge","z":"","name":"Philips hue","bridge":"192.168.1.121","key":"0s4cblRPnIHWqE7UVop815qZY0vEQPSeMavmlDIH","interval":"3000"}]
