Presence checks based on Unifi & Wifi connection
This flow will Query your unifi wifi controller for all currently connected clients and check for a definied MAC address to be:
  • Connected
  • Non-wired (Unifi leaves a client in wired state some time after it has left the network)
Based on the results it will save global values to be used in other flows.
This flow is dependant on an always on Unifi controller and the Unifi Node. optionally a Domoticz instance for pushing precense to it.
[{"id":"558eca41.b32bb4","type":"inject","z":"29a3949.adffc6c","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"60","crontab":"","once":true,"onceDelay":"","x":90,"y":640,"wires":[["11c68ce3.47f3b3"]]},{"id":"b85d423e.d6e1e","type":"http request","z":"29a3949.adffc6c","name":"","method":"GET","ret":"txt","url":"localhost:8080/json.htm?type=command&param=udevice&idx=[YOUR_IDX_HERE]&nvalue={{{nvalue}}}&svalue={{{message}}}","tls":"","x":730,"y":620,"wires":[["e6ef0710.286cf8"]]},{"id":"e6ef0710.286cf8","type":"debug","z":"29a3949.adffc6c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":930,"y":640,"wires":[]},{"id":"11c68ce3.47f3b3","type":"Unifi","z":"29a3949.adffc6c","name":"Unifi","ip":"[IP-OF-YOUR_UNIFI-CONTROLLER]","port":8443,"site":"w47znjfb","command":"20","x":210,"y":640,"wires":[["c2f30e56.53e1c","f2ee4f97.9df5b"]]},{"id":"c2f30e56.53e1c","type":"function","z":"29a3949.adffc6c","name":"Phone1 Checks","func":"var devices = msg.payload[0];\n\nfor(var i = 0; i < devices.length; i++) {\n   if(devices[i].mac === '[YOUR_PHONE_MAC-ADDRESS_HERE]' && devices[i].is_wired === false) { //PHONE1 MAC\n     msg.place = i ;\n     msg.message = 'Phone1 Present';\n     // msg.deviceInfo = devices[i] ;\n     msg.payload = 1 ;\n     msg.nvalue = 1 ;\n     global.set('Phone1Status',1); // Setting 1 = Home\n     node.status({fill:\"green\",shape:\"dot\",text:\"Home\"});\n     return msg ;\n   }\n    \n}\n\n    msg.payload = 2 ;\n    msg.message = \"Phone1 Away\" ;\n    msg.nvalue = 2 ;\n    global.set('Phone1Status',0); // Setting 0 != Home\n    node.status({fill:\"yellow\",shape:\"dot\",text:\"Away\"});\n// msg.payload = i ;\nreturn msg;","outputs":1,"noerr":0,"x":380,"y":620,"wires":[["eb99877e.799f58"]]},{"id":"47d8e773.7d3378","type":"comment","z":"29a3949.adffc6c","name":"Presence Check","info":"Works only if Mobile Phones are connected to WiFi","x":470,"y":580,"wires":[]},{"id":"eb99877e.799f58","type":"rbe","z":"29a3949.adffc6c","name":"","func":"rbe","gap":"1","start":"","inout":"in","property":"payload","x":570,"y":620,"wires":[["b85d423e.d6e1e"]]}]
Created 8 years, 7 months ago
Updated 7 years, 11 months ago
  • http request (x1)
  • rbe (x1)
  • presence
  • UniFi
  • Uqiquiti
  • Domoticz
  • Homeautomation
  • MAC
  • Wifi
