Tuya power distribution block with MQTT and Domoticz
[{"id":"d7a05887.e7f1f8","type":"tab","label":"Woox","disabled":false,"info":""},{"id":"95b69f1e.bcecd","type":"switch","z":"d7a05887.e7f1f8","name":"payload.data.dps[\"1\"]","property":"payload.data.dps[\"1\"]","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1040,"y":140,"wires":[["4f40af77.8e471"],["d03a6af8.c30428"]]},{"id":"4a8a2af8.95fd94","type":"switch","z":"d7a05887.e7f1f8","name":"payload.data.dps[\"2\"]","property":"payload.data.dps[\"2\"]","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1040,"y":220,"wires":[["85661a34.b3ba48"],["11024689.ab3749"]]},{"id":"c3039438.bb9918","type":"switch","z":"d7a05887.e7f1f8","name":"payload.data.dps[\"3\"]","property":"payload.data.dps[\"3\"]","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1040,"y":300,"wires":[["9c7e7010.984ec"],["9189c43a.59dea8"]]},{"id":"7fee0bed.4ff594","type":"switch","z":"d7a05887.e7f1f8","name":"payload.data.dps[\"7\"]","property":"payload.data.dps[\"7\"]","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1040,"y":380,"wires":[["171d1a51.0e2ac6"],["e3330ced.30976"]]},{"id":"ac87d021.279b6","type":"switch","z":"d7a05887.e7f1f8","name":"","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"282","vt":"num"},{"t":"eq","v":"283","vt":"num"},{"t":"eq","v":"284","vt":"num"},{"t":"eq","v":"285","vt":"num"}],"checkall":"true","repair":false,"outputs":4,"x":370,"y":260,"wires":[["4c761e82.cff38"],["739e413c.bc0cd"],["767cfc93.b2fc84"],["b1705969.745bf8"]]},{"id":"a1fffce5.8a9d6","type":"json","z":"d7a05887.e7f1f8","name":"","property":"payload","action":"","pretty":false,"x":230,"y":260,"wires":[["ac87d021.279b6"]]},{"id":"4c761e82.cff38","type":"switch","z":"d7a05887.e7f1f8","name":"","property":"payload.nvalue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":530,"y":140,"wires":[["15603af4.49d915"],["7efeb41e.f1ccac"]]},{"id":"739e413c.bc0cd","type":"switch","z":"d7a05887.e7f1f8","name":"","property":"payload.nvalue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":530,"y":220,"wires":[["811f9bd5.812238"],["908420df.3a5d6"]]},{"id":"767cfc93.b2fc84","type":"switch","z":"d7a05887.e7f1f8","name":"","property":"payload.nvalue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":530,"y":300,"wires":[["bda81f58.a9b15"],["82a7b95f.947908"]]},{"id":"b1705969.745bf8","type":"switch","z":"d7a05887.e7f1f8","name":"","property":"payload.nvalue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":530,"y":380,"wires":[["869439f.c2a24c8"],["64a6d3bc.1a84ac"]]},{"id":"869439f.c2a24c8","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":true, \"dpsIndex\": 7}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":360,"wires":[["a4ccee94.ce3d5"]]},{"id":"64a6d3bc.1a84ac","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":false, \"dpsIndex\": 7}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":400,"wires":[["a4ccee94.ce3d5"]]},{"id":"15603af4.49d915","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":true, \"dpsIndex\": 1}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":120,"wires":[["a4ccee94.ce3d5"]]},{"id":"7efeb41e.f1ccac","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":false, \"dpsIndex\": 1}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":160,"wires":[["a4ccee94.ce3d5"]]},{"id":"811f9bd5.812238","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":true, \"dpsIndex\": 2}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":200,"wires":[["a4ccee94.ce3d5"]]},{"id":"908420df.3a5d6","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":false, \"dpsIndex\": 2}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":240,"wires":[["a4ccee94.ce3d5"]]},{"id":"bda81f58.a9b15","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":true, \"dpsIndex\": 3}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":280,"wires":[["a4ccee94.ce3d5"]]},{"id":"82a7b95f.947908","type":"function","z":"d7a05887.e7f1f8","name":"","func":"msg.payload = {\"set\":false, \"dpsIndex\": 3}\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":320,"wires":[["a4ccee94.ce3d5"]]},{"id":"171d1a51.0e2ac6","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 289,\n \"nvalue\" : 1  ,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":360,"wires":[["1ee85b53.7753a5"]]},{"id":"e3330ced.30976","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 289,\n \"nvalue\" : 0,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":400,"wires":[["600431dd.02618"]]},{"id":"4f40af77.8e471","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 286,\n \"nvalue\" : 1  ,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":120,"wires":[["e2e49fb8.16e02"]]},{"id":"d03a6af8.c30428","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 286,\n \"nvalue\" : 0,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":160,"wires":[["600431dd.02618"]]},{"id":"85661a34.b3ba48","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 287,\n \"nvalue\" : 1  ,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":200,"wires":[["41db0618.1a58c8"]]},{"id":"11024689.ab3749","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 287,\n \"nvalue\" : 0,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":240,"wires":[["600431dd.02618"]]},{"id":"9c7e7010.984ec","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 288,\n \"nvalue\" : 1  ,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":280,"wires":[["f67818aa.9928e8"]]},{"id":"9189c43a.59dea8","type":"function","z":"d7a05887.e7f1f8","name":"prepare for MQTT","func":"msg.payload = {\n \"idx\" : 288,\n \"nvalue\" : 0,\n \"svalue\" : \"0\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":1270,"y":320,"wires":[["600431dd.02618"]]},{"id":"a891a54b.239dc8","type":"debug","z":"d7a05887.e7f1f8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1010,"y":260,"wires":[]},{"id":"e2e49fb8.16e02","type":"rbe","z":"d7a05887.e7f1f8","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1450,"y":120,"wires":[["fb646294.77c58"]]},{"id":"41db0618.1a58c8","type":"rbe","z":"d7a05887.e7f1f8","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1450,"y":200,"wires":[["fb646294.77c58"]]},{"id":"f67818aa.9928e8","type":"rbe","z":"d7a05887.e7f1f8","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1450,"y":280,"wires":[["fb646294.77c58"]]},{"id":"1ee85b53.7753a5","type":"rbe","z":"d7a05887.e7f1f8","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1450,"y":360,"wires":[["fb646294.77c58"]]},{"id":"8352315f.e8755","type":"link in","z":"d7a05887.e7f1f8","name":"","links":["320f9fb6.0d406"],"x":115,"y":260,"wires":[["a1fffce5.8a9d6"]]},{"id":"fb646294.77c58","type":"link out","z":"d7a05887.e7f1f8","name":"","links":["80ee28b2.1ab318"],"x":2075,"y":120,"wires":[]},{"id":"600431dd.02618","type":"delay","z":"d7a05887.e7f1f8","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1920,"y":300,"wires":[["fb646294.77c58"]]},{"id":"98eb52ed.ba719","type":"inject","z":"d7a05887.e7f1f8","name":"all off","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":830,"y":520,"wires":[["d03a6af8.c30428","11024689.ab3749","9189c43a.59dea8","e3330ced.30976"]]},{"id":"2298b1b5.ccc4ee","type":"inject","z":"d7a05887.e7f1f8","name":"all on","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":830,"y":580,"wires":[["4f40af77.8e471","85661a34.b3ba48","9c7e7010.984ec","171d1a51.0e2ac6"]]},{"id":"a4ccee94.ce3d5","type":"tuya-smart","z":"d7a05887.e7f1f8","d":true,"deviceName":"blok","deviceIp":"0.0.0.0","deviceId":"11","deviceKey":"key","request":"{\"schema\": true}","pollingInterval":"2","x":830,"y":260,"wires":[["95b69f1e.bcecd","4a8a2af8.95fd94","c3039438.bb9918","7fee0bed.4ff594","a891a54b.239dc8"]]}]
Created 6 years, 1 month ago
  • delay (x1)
  • function (x16)
  • inject (x2)
  • json (x1)
  • link in (x1)
  • link out (x1)
  • rbe (x4)
  • switch (x9)
  • tuya-smart (x1)
  • MQTT
  • Domoticz
  • Tuya
