How to Integrate REYAX RYLR998 LoRa Transceiver Module with Node-RED | Flow For 2nd RYLR998 LoRa Transceiver |
[{"id":"552ec3c09d04ad4b","type":"tab","label":"RYLR998 - 2","disabled":false,"info":"","env":[]},{"id":"926eb1d01164723b","type":"debug","z":"552ec3c09d04ad4b","name":"RYLR998 Response Out","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":450,"y":60,"wires":[]},{"id":"a54c48691971024c","type":"serial in","z":"552ec3c09d04ad4b","name":"Response from RYLR998 - 2","serial":"d116ec390b446e2b","x":200,"y":60,"wires":[["926eb1d01164723b"]]},{"id":"cc0fc00e6a98772e","type":"serial out","z":"552ec3c09d04ad4b","name":"Send Commands to RYLR998 - 2 Board","serial":"d116ec390b446e2b","x":640,"y":280,"wires":[]},{"id":"03b4efbb326c46b6","type":"inject","z":"552ec3c09d04ad4b","name":"Check RYLR998 - 2 Module","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT","payloadType":"str","x":220,"y":140,"wires":[["65f56c26a06deddd"]]},{"id":"1908b4ea1eff74e1","type":"inject","z":"552ec3c09d04ad4b","name":"Get RYLR998 - 2 Address","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+ADDRESS?","payloadType":"str","x":230,"y":180,"wires":[["65f56c26a06deddd"]]},{"id":"ef79b3b12e2c5005","type":"inject","z":"552ec3c09d04ad4b","name":"Get RYLR998 - 2 NetworkID","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+NETWORKID?","payloadType":"str","x":220,"y":220,"wires":[["65f56c26a06deddd"]]},{"id":"6b996bc48a138558","type":"inject","z":"552ec3c09d04ad4b","name":"Get RYLR998 - 2 Band","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+BAND?","payloadType":"str","x":240,"y":260,"wires":[["65f56c26a06deddd"]]},{"id":"9b1a505eb6514218","type":"inject","z":"552ec3c09d04ad4b","name":"Check RYLR998 - 2 Last Payload","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+SEND?","payloadType":"str","x":210,"y":300,"wires":[["65f56c26a06deddd"]]},{"id":"28c42823808cd326","type":"inject","z":"552ec3c09d04ad4b","name":"Set RYLR998 - 1 Address to 2","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+ADDRESS=2","payloadType":"str","x":220,"y":420,"wires":[["65f56c26a06deddd"]]},{"id":"651efd0b3e774b55","type":"inject","z":"552ec3c09d04ad4b","name":"Set RYLR998 - 1 NetworkID","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+NETWORKID=5","payloadType":"str","x":220,"y":460,"wires":[["65f56c26a06deddd"]]},{"id":"d8b3ebd18757c92b","type":"inject","z":"552ec3c09d04ad4b","name":"Set RYLR998 - 1 Band","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+BAND=915000000","payloadType":"str","x":240,"y":380,"wires":[["65f56c26a06deddd"]]},{"id":"65f56c26a06deddd","type":"function","z":"552ec3c09d04ad4b","name":"Function","func":"msg.payload += Buffer.from(\"0D0A\", \"hex\");\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":240,"wires":[["cc0fc00e6a98772e"]]},{"id":"a389b5b780af5ea1","type":"inject","z":"552ec3c09d04ad4b","name":"Send Payload to 2 from 1","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+SEND=1,8,AUTOMATE","payloadType":"str","x":230,"y":540,"wires":[["65f56c26a06deddd"]]},{"id":"d116ec390b446e2b","type":"serial-port","name":"RYLR998 - 2","serialport":"COM8","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"\\n","bin":"false","out":"char","addchar":"","responsetimeout":"10000"}]
