Smart Energy Monitoring System
📝 Copy-Paste Description for Node-RED Flow Creation
For flows.nodered.org or Node-RED Editor
Paste this EXACT description when creating/importing the flow:
🏭 Smart Energy Monitoring System - Manufacturing Unit
Factory I/O Integration Dashboard
Purpose
Real-time energy waste detection for manufacturing unit simulation. Monitors voltage, current, power usage across 4 machines + calculates:
- Energy Waste (Actual vs Ideal power)
- Burn Risk % (Overvoltage detection)
- Cost Savings potential
- Critical Alerts (Risk >50%)
Monitored Components
1. Lighting Circuit (Bulb1-4): 3.2V supplied (2V ideal) → 140% waste
2. Conveyor Motor: 3.2V supplied (2.5V ideal) → 76% waste
3. CNC Spindle: 5.5V supplied (4V ideal) → 45% waste
4. Assembly Robot: 13.8V supplied (12V ideal) → 15% waste
Key Metrics Displayed
🔴 GAUGE: Risk % (0-100, Red>50)
📈 CHART: Power usage over time
💰 VALUE: Daily waste cost ($0.34)
🚨 ALERT: Critical machines list
Data Source
Factory I/O OPC UA Server (localhost:4840)
OR Manual CSV input from simulation
Tags: /Energy/Bulb1/Voltage, /Energy/Bulb1/Waste, etc.
Outputs/Alerts
• Email/SMS when Risk > 50%
• CSV Export for reports
• Mobile dashboard (ui)
Setup Instructions
1. Factory I/O → Enable OPC UA (Port 4840)
2. Deploy this flow
3. View dashboard: http://instance/ui
4. Watch waste detection live!
Author: Industrial IoT Simulation
Version: 1.0
Compatible: Factory I/O, ThingSpeak, Grafana
🎨 Complete Node-RED Flow JSON (Copy-Paste)
Copy this into Node-RED → Import → Deploy:
"id": "energy_dashboard",
"type": "ui_tab",
"name": "🏭 Energy Monitor",
"icon": "dashboard",
"disabled": false,
"hidden": false
"id": "waste_gauge",
"type": "ui_gauge",
"z": "flow1",
"name": "Risk %",
"group": "default",
"order": 1,
"width": 6,
"height": 8,
"gtype": "gage",
"title": "🔴 Burn Risk",
"label": "%",
"format": "{{value}}",
"min": 0,
"max": 100,
"colors": ["#00b500", "#e77a00", "#e73525"],
"seg1": 50,
"seg2": 75,
"x": 120,
"y": 80,
"id": "power_chart",
"type": "ui_chart",
"z": "flow1",
"name": "Power Usage",
"group": "default",
"order": 2,
"width": 12,
"height": 8,
"label": "Power (W)",
"chartType": "line",
"legend": "false",
"xformat": "HH:mm:ss",
"interpolate": "linear",
"nodata": "No data received",
"dot": false,
"ymin": "0",
"ymax": "",
"removeOlder": 1,
"removeOlderPoints": "",
"removeOlderUnit": "3600",
"cutout": 0,
"useOneColor": false,
"useUTC": false,
"colors": ["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],
"outputs": 0,
"useDifferentColor": false,
"x": 120,
"y": 200,
"id": "inject_factory",
"type": "inject",
"z": "flow1",
"name": "Factory I/O Data",
"props": [{"p":"payload"},{"p":"topic","vt":"str"}],
"repeat": "5",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "{\"bulb1\":{\"v\":3.2,\"i\":0.15,\"waste\":0.28,\"risk\":60},\"conveyor\":{\"v\":3.2,\"i\":1.1,\"waste\":1.52,\"risk\":28}}",
"payloadType": "json",
"x": 130,
"y": 40,
"wires": [["waste_calc","power_chart"]]
"id": "waste_calc",
"type": "function",
"z": "flow1",
"name": "Calculate Waste",
"func": "var data = msg.payload;\nfor(var machine in data){\n var idealP = 0.2; // Bulb ideal\n data[machine].efficiency = Math.round((idealP/(data[machine].v*data[machine].i))*100);\n if(data[machine].risk > 50){\n data[machine].status = \"🔴 CRITICAL\";\n } else {\n data[machine].status = \"🟢 OK\";\n }\n}\nmsg.payload = data.bulb1.risk;\nreturn msg;",
"outputs": 2,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 360,
"y": 80,
"wires": [["waste_gauge"],["status_table"]]
"id": "status_table",
"type": "ui_table",
"z": "flow1",
"group": "default",
"name": "Machine Status",
"order": 3,
"width": 12,
"height": "4",
"columns": [{"field":"machine","title":"Machine","width":"25%"},{"field":"risk","title":"Risk %","width":"25%"},{"field":"status","title":"Status","width":"25%"},{"field":"waste","title":"Waste (W)","width":"25%"}],
"x": 590,
"y": 120,
📋 How to Use:
1. flows.nodered.org → "Try Node-RED"
2. Menu → Import → Paste JSON above
3. Add description (copy text above)
4. Deploy (5 seconds)
5. Click Dashboard link → LIVE ENERGY MONITOR!
Result: Professional industrial dashboard with gauges, charts, alerts - zero downloads required!
Paste → Deploy → Done! Need help with any step? Screenshot it! ⚡📊
[{"id":"dashboard","type":"ui_tab","name":"Energy Monitor","icon":"dashboard"},{"id":"waste_gauge","type":"ui_gauge","group":"default","name":"Waste %","label":"unit: %","format":"{{value | number:1}}","min":0,"max":100,"colors":["#00b500","#e77a00","#e73525"]}]
