Test IoT
asd
	"id": "5a67cd69.af4de4",
	"type": "function",
	"z": "34c702a4.cb38fe",
	"name": "setArgs2",
	"func": "if(msg.payload.length > 0 && msg.payload[0] && msg.payload[0].link_id){\n    // MapMatch result becomes list and the first one is nearest link_id\n    msg.link_id = msg.payload[0].link_id;\n    // msg.trip_id\n    msg.matched_heading = msg.payload[0].matched_heading;\n    msg.matched_longitude = msg.payload[0].matched_longitude;\n    msg.matched_latitude = msg.payload[0].matched_latitude;\n    // msg.mo_id\n    \n    msg.payload = null;\n    \n    return [msg, null];\n}else{\n    msg.link_id = '';\n    msg.matched_heading = msg.rawData.heading;\n    msg.matched_longitude = msg.rawData.longitude;\n    msg.matched_latitude = msg.rawData.latitude;\n    return [null, msg];\n}\n",
	"outputs": "2",
	"noerr": 0,
	"x": 602,
	"y": 298.28570556640625,
	"wires": [["add978b6.091ae8",
	"12662b88.b8d154"],
	["6fda7a1e.da3064"]]
	"id": "22d0375f.359f38",
	"type": "ibmiot in",
	"authentication": "boundService",
	"apiKey": "",
	"inputType": "evt",
	"deviceId": "",
	"applicationId": "",
	"deviceType": "+",
	"eventType": "+",
	"commandType": "",
	"format": "json",
	"name": "IBM IoT",
	"service": "registered",
	"allDevices": true,
	"allApplications": "",
	"allDeviceTypes": true,
	"allEvents": true,
	"allCommands": "",
	"allFormats": "",
	"x": 144.625,
	"y": 130.35714721679688,
	"wires": [["5d1140dc.1ce48",
	"5793edd9.9635a4"]]
	"id": "8f34f0d7.030e3",
	"type": "http request",
	"name": "carProbe",
	"method": "POST",
	"ret": "obj",
	"url": "https://{{driverHostname}}/driverinsights/datastore/carProbe?tenant_id={{driverTenantId}}",
	"x": 375.375,
	"y": 505.0357074737549,
	"wires": [["698d4f42.3e8e9"]]
	"id": "9c57021f.6a623",
	"type": "function",
	"name": "setArgs1",
	"func": "\nmsg.rawData = msg.payload.d;\n\n// '+' must be URL encoded\n//msg.timestamp = encodeURIComponent(msg.payload.timestamp);\nmsg.timestamp = msg.rawData.timestamp;\nmsg.heading = msg.rawData.heading;\nmsg.mo_id = msg.deviceId;\nmsg.trip_id = msg.rawData.trip_id;\nmsg.longitude = msg.rawData.longitude;\nmsg.latitude = msg.rawData.latitude;\nreturn msg;",
	"outputs": 1,
	"noerr": 0,
	"x": 174.625,
	"y": 293.7856750488281,
	"wires": [["82743408.064ba8",
	"fda52541.63d528"]]
	"id": "698d4f42.3e8e9",
	"type": "debug",
	"active": true,
	"console": "false",
	"complete": "true",
	"x": 516.875,
	"y": 506.03570556640625,
	"id": "82743408.064ba8",
	"type": "debug",
	"active": false,
	"console": "false",
	"complete": "true",
	"x": 230.625,
	"y": 354.7856903076172,
	"id": "fda52541.63d528",
	"name": "mapMatching",
	"method": "GET",
	"ret": "obj",
	"url": "https://{{mapHostname}}/mapinsights/mapservice/map/matching?tenant_id={{mapTenantId}}&heading={{heading}}&mo_id={{mo_id}}&trip_id={{trip_id}}&longitude={{longitude}}&latitude={{latitude}}",
	"x": 367.75,
	"y": 293.2856903076172,
	"wires": [["5a67cd69.af4de4",
	"f588b73.c04f548"]]
	"id": "6fda7a1e.da3064",
	"type": "function",
	"name": "setArgs3",
	"func": "var type = null;\nif(msg.payload.links && msg.payload.links[0] && msg.payload.links[0].properties && msg.payload.links[0].properties.type){\n    type = msg.payload.links[0].properties.type;\n}else {\n    type = '5';\n}\n\n\nmsg.payload = {};\n\nmsg.payload.road_type = type;\nmsg.payload.trip_id = msg.trip_id;\nmsg.payload.timestamp = msg.rawData.timestamp;\nmsg.payload.matched_heading = msg.matched_heading;\nmsg.payload.speed = msg.rawData.speed;\nmsg.payload.matched_longitude = msg.matched_longitude;\nmsg.payload.mo_id = msg.deviceId;\nmsg.payload.matched_latitude = msg.matched_latitude;\nmsg.payload.matched_link_id = msg.link_id;\n\nreturn msg;",
	"outputs": 1,
	"noerr": 0,
	"x": 174.75,
	"y": 502.03570556640625,
	"wires": [["8f34f0d7.030e3",
	"1afc4826.0d2a38"]]
	"id": "f588b73.c04f548",
	"type": "debug",
	"active": true,
	"console": "false",
	"complete": "true",
	"x": 506.5,
	"y": 214.28570556640625,
	"id": "add978b6.091ae8",
	"name": " getLinkInformation",
	"method": "GET",
	"ret": "obj",
	"url": "https://{{mapHostname}}/mapinsights/mapservice/link?tenant_id={{mapTenantId}}&link_id={{link_id}}",
	"x": 857.25,
	"y": 301.03570556640625,
	"wires": [["6fda7a1e.da3064",
	"5d32bca7.d7b174"]]
	"id": "5d32bca7.d7b174",
	"type": "debug",
	"active": false,
	"console": "false",
	"complete": "true",
	"x": 1009.25,
	"y": 255.28570556640625,
	"id": "12662b88.b8d154",
	"type": "debug",
	"active": false,
	"console": "false",
	"complete": "true",
	"x": 757.25,
	"y": 163.53570556640625,
	"id": "1afc4826.0d2a38",
	"type": "debug",
	"active": false,
	"console": "false",
	"complete": "true",
	"x": 264.75,
	"y": 557.5357055664062,
	"id": "5d1140dc.1ce48",
	"type": "debug",
	"active": false,
	"console": "false",
	"complete": "true",
	"x": 293.3035583496094,
	"y": 85,
	"id": "5793edd9.9635a4",
	"type": "function",
	"name": "Common Config",
	"func": "msg.mapTenantId = \"FIX-ME\";\nmsg.driverTenantId = \"FIX-ME\";\nmsg.mapHostname =\"automotive.internetofthings.ibmcloud.com\";\nmsg.driverHostname = \"automotive.internetofthings.ibmcloud.com\";\nreturn msg;",
	"outputs": 1,
	"noerr": 0,
	"x": 428.125,
	"y": 130.78570556640625,
	"wires": [["9c57021f.6a623"]]
xyrox2
created 1 year, 1 month ago
  • debug (x7)
  • function (x4)
  • http request (x3)
  • ibmiot in (x1)
