SD card size (free and used)
Copy JSON
Note: some third-party nodes may appear with blank styling, and not as they appear in the Node-RED Editor.
Copy [{"id":"2be04c82.d0af74","type":"inject","z":"8fd9fd736e54a79d","name":"","repeat":"3","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":227.49996185302734,"y":806.8055562973022,"wires":[["c517fc3e16360e2d","a5de2d3e18693616","ecdeab4f8c540e87","f36b39696ac8d536","09fbf46a531b10dc","82b5b01adc87a6a8"]]},{"id":"09fbf46a531b10dc","type":"exec","z":"8fd9fd736e54a79d","command":"df -h | grep /dev/root | awk '{print ($3)}'","addpay":false,"append":"","useSpawn":"","timer":"","winHide":false,"name":"Used SD","x":540,"y":1060,"wires":[["8fd30f5f18c82658"],[],[]]},{"id":"82b5b01adc87a6a8","type":"exec","z":"8fd9fd736e54a79d","command":"df -h | grep /dev/root | awk '{print ($2)}'","addpay":false,"append":"","useSpawn":"","timer":"","winHide":false,"name":"Avail SD","x":540,"y":1120,"wires":[["debee64f1b52e61c"],[],[]]},{"id":"8fd30f5f18c82658","type":"function","z":"8fd9fd736e54a79d","name":"function 5","func":"msg.topic = \"Used GB\";\nmsg.payload = msg.payload.replace(\"G\", \"\").replace(\"\\n\", \"\")\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":1060,"wires":[["36e2b64a47ab1a43","66e4e2124a9c99cc"]]},{"id":"debee64f1b52e61c","type":"function","z":"8fd9fd736e54a79d","name":"function 6","func":"msg.topic = \"Free GB\";\nmsg.payload = msg.payload.replace(\"G\", \"\").replace(\"\\n\", \"\")\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":1120,"wires":[["36e2b64a47ab1a43"]]},{"id":"a456d1069a6b4366","type":"inject","z":"8fd9fd736e54a79d","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[]","payloadType":"json","x":730,"y":1180,"wires":[["36e2b64a47ab1a43"]]},{"id":"36e2b64a47ab1a43","type":"ui_chart","z":"8fd9fd736e54a79d","name":"","group":"d0525ab1ef0afb2a","order":7,"width":0,"height":0,"label":"SD","chartType":"pie","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":"80","useOneColor":false,"useUTC":false,"colors":["#28c347","#d06c6c","#55aa66","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":970,"y":1140,"wires":[[]]},{"id":"d0525ab1ef0afb2a","type":"ui_group","name":"Group5","tab":"76d6ecdd8be066ac","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"76d6ecdd8be066ac","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
