subflows for check modbus reading done or reading fail
The principle of use is If Status has the message "reading done", set it to be able to read data from Modbus. Other messages than this and no "reading done" message arrived at the specified time. It is assumed that data cannot be read from Modbus.
contact me or follow me : https://www.facebook.com/profile.php?id=61550015338310
[{"id":"d54760571f46d290","type":"subflow","name":"getCommuDone","info":"","category":"","in":[{"x":100,"y":120,"wires":[{"id":"f2723931f83b134d"}]}],"out":[{"x":700,"y":120,"wires":[{"id":"1cda5d91e9df4663","port":0},{"id":"f2723931f83b134d","port":1}]}],"env":[{"name":"setDelay","type":"num","value":"2000"}],"meta":{},"color":"#DDAA99","status":{"x":420,"y":180,"wires":[{"id":"63c167839a625ddc","port":0}]}},{"id":"f2723931f83b134d","type":"function","z":"d54760571f46d290","name":"getCommuDone","func":"let status = msg.payload || msg.status.text;\nlet delay = env.get(\"setDelay\");\nlet topic = msg.topic || '';\nlet commuOK;\nlet commuFail;\n\nif (status === 'done' || status === 'reading done') {\n    commuOK = { payload: 1, delay: delay, topic: topic + '_commu' };\n} else {\n    commuFail = { payload: 0, delay: delay, topic: topic + '_commu' };\n}\n\nreturn [commuFail, commuOK];","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":120,"wires":[["1cda5d91e9df4663"],["1cda5d91e9df4663"]]},{"id":"1cda5d91e9df4663","type":"trigger","z":"d54760571f46d290","name":"","op1":"","op2":"0","op1type":"nul","op2type":"num","duration":"1","extend":false,"overrideDelay":true,"units":"s","reset":"1","bytopic":"all","topic":"topic","outputs":1,"x":520,"y":80,"wires":[[]]},{"id":"63c167839a625ddc","type":"status","z":"d54760571f46d290","name":"","scope":["1cda5d91e9df4663"],"x":280,"y":180,"wires":[[]]},{"id":"4020736609838681","type":"subflow:d54760571f46d290","z":"155ee02bc198cf10","name":"","env":[{"name":"setDelay","value":"3000","type":"num"},{"name":"dd","value":"5000","type":"num"}],"x":1040,"y":320,"wires":[["e819a30b843ba25c"]],"inputLabels":["status"],"outputLabels":["communication"]},{"id":"e819a30b843ba25c","type":"debug","z":"155ee02bc198cf10","name":"debug 58","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1240,"y":320,"wires":[]},{"id":"f1bb531bf4ac32d1","type":"status","z":"155ee02bc198cf10","name":"","scope":["0344095cc3608092"],"x":820,"y":320,"wires":[["4020736609838681","1bde64a1b84fbcd4"]]},{"id":"1bde64a1b84fbcd4","type":"debug","z":"155ee02bc198cf10","name":"status.text","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"status.text","targetType":"msg","statusVal":"","statusType":"auto","x":1030,"y":380,"wires":[]},{"id":"0344095cc3608092","type":"modbus-read","z":"155ee02bc198cf10","name":"","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"1","dataType":"HoldingRegister","adr":"0","quantity":"100","rate":"2","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"64cd1b72167c3369","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":1050,"y":240,"wires":[[],[]]},{"id":"64cd1b72167c3369","type":"modbus-client","name":"127.0.0.1","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":true,"queueLogEnabled":false,"failureLogEnabled":false,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"1","commandDelay":"1","clientTimeout":"3000","reconnectOnTimeout":true,"reconnectTimeout":"5000","parallelUnitIdsAllowed":true,"showErrors":false,"showWarnings":true,"showLogs":true}]
Created 2 years, 7 months ago
  • debug (x2)
  • status (x2)
  • trigger (x1)
  • modbus-client (x1)
  • modbus-read (x1)
  • subflow (x1)
  • subflow:d54760571f46d290 (x1)
  • modbus
  • status
