CPU Temperatur
Dieser Flow misst die CPU Temperatur und sendet sie noch theoretisch an Telegram.
[{"id":"536f8075110451d0","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"ab51a09b20dfd613","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"16bf1493e306a2ba","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"e74f6efff4d1b74e","type":"mqtt-broker","name":"MQTT","broker":"broker.hivemq.com","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"da2f5fe09c177517","type":"ui_tab","name":"Performance","icon":"dashboard","disabled":false,"hidden":false},{"id":"1ee71ad5f802a2b0","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey","palette":"light"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD.MM.YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"684f6985245d2494","type":"ui_group","name":"CPU Performance","tab":"da2f5fe09c177517","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"c10f315dc3b37346","type":"telegram bot","botname":"OkeGraesslich_bot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksprotocol":"socks5","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false},{"id":"ac2bc1dd1233876b","type":"cpu","z":"536f8075110451d0","name":"CPU Usage","msgCore":false,"msgOverall":true,"msgArray":false,"msgTemp":false,"x":430,"y":180,"wires":[["bd771bdd7170d1a5","8b887968a7f73649"]]},{"id":"d46aafcbc0aa0964","type":"inject","z":"536f8075110451d0","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":250,"y":180,"wires":[["ac2bc1dd1233876b"]]},{"id":"bd771bdd7170d1a5","type":"debug","z":"536f8075110451d0","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":600,"y":140,"wires":[]},{"id":"8b887968a7f73649","type":"mqtt out","z":"536f8075110451d0","name":"Output CPU","topic":"HAW/DigiPRO/CPU","qos":"0","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"e74f6efff4d1b74e","x":610,"y":240,"wires":[]},{"id":"8c441a57622de16f","type":"mqtt in","z":"ab51a09b20dfd613","name":"Input CPU","topic":"HAW/DigiPRO/CPU","qos":"0","datatype":"auto-detect","broker":"e74f6efff4d1b74e","nl":false,"rap":true,"rh":0,"inputs":0,"x":160,"y":340,"wires":[["b2b54cfa206236ff","1b417f1b924b10d6","07df9501f1e72156","8fbf73703c2cf24d"]]},{"id":"b2b54cfa206236ff","type":"debug","z":"ab51a09b20dfd613","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":440,"y":220,"wires":[]},{"id":"1b417f1b924b10d6","type":"ui_chart","z":"ab51a09b20dfd613","name":"","group":"684f6985245d2494","order":0,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":430,"y":340,"wires":[[]]},{"id":"07df9501f1e72156","type":"ui_gauge","z":"ab51a09b20dfd613","name":"","group":"684f6985245d2494","order":1,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"60","seg2":"80","diff":false,"className":"","x":430,"y":480,"wires":[]},{"id":"8fbf73703c2cf24d","type":"function","z":"ab51a09b20dfd613","name":"function 1","func":"if(msg.payload >= 5){\nmsg.payload = {\n    \"chatID\":-1155599353,\n    \"type\":\"massage\",\n    \"content\":\"Achtung die CPU Auslastung beträgt\" + msg.payload +\"%\",\n};\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":580,"wires":[["e2be1949e7ce5258"]]},{"id":"e2be1949e7ce5258","type":"telegram sender","z":"ab51a09b20dfd613","name":"","bot":"c10f315dc3b37346","haserroroutput":false,"outputs":1,"x":690,"y":580,"wires":[[]]}]
Created 2 years, 5 months ago
  • debug (x2)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
