Email control from dashboard
The below flow will let you send emails from the dashboard. Not much use as-is, but it will provide the user with full controll over the from field with a flow variable.
it uses a Powershell script so it will only work on windows.
[{"id":"f6d88d0703c4de83","type":"template","z":"cad6e41fa82c02e7","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"$EmailTo = \"{{toemail}}\"\n$EmailFrom = \"{{fromemail}}\"\n$Subject = \"{{subject}}\" \n$Body = \"{{body}}\" \n$SMTPServer = \"{{smtpserver}}\" \n$SMTPPort = \"{{smtmpport}}\"\n$SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body)\n$SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, $SMTPPort) \n$SMTPClient.EnableSsl = $true \n$SMTPClient.Credentials = New-Object System.Net.NetworkCredential(\"{{loginuser}}\", \"{{loginpass}}\"); \n$SMTPClient.Send($SMTPMessage)","output":"str","x":960,"y":600,"wires":[["335db61d32f1f96d","9c398a317d7a3ed9"]]},{"id":"335db61d32f1f96d","type":"powershell","z":"cad6e41fa82c02e7","name":"","x":1150,"y":540,"wires":[[],[]]},{"id":"9c398a317d7a3ed9","type":"debug","z":"cad6e41fa82c02e7","name":"simple mail output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1150,"y":600,"wires":[]},{"id":"1ae4260a6c5f7bf7","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"Username","tooltip":"user name for login, might be same as email","group":"aa4a84804a7816cb","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"loginuser","topicType":"str","x":370,"y":200,"wires":[["249e0de028dce1dc"]]},{"id":"8f448002082c0ff9","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"To email","tooltip":"type recipient","group":"aa4a84804a7816cb","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"toemail","topicType":"str","x":380,"y":280,"wires":[["249e0de028dce1dc"]]},{"id":"4e0ef328e2c9f8ac","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"Body","tooltip":"Type the body of the email","group":"aa4a84804a7816cb","order":5,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"body","topicType":"str","x":390,"y":320,"wires":[["249e0de028dce1dc"]]},{"id":"ff3dee1a63b9b705","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"Subject","tooltip":"email subject","group":"aa4a84804a7816cb","order":6,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"subject","topicType":"str","x":380,"y":360,"wires":[["249e0de028dce1dc"]]},{"id":"f18629dc637019d0","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"SMTP server","tooltip":"","group":"aa4a84804a7816cb","order":7,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"smtpserver","topicType":"str","x":370,"y":400,"wires":[["249e0de028dce1dc"]]},{"id":"119ae9b47af15d03","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"port","tooltip":"usually 587","group":"aa4a84804a7816cb","order":8,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"smtpport","topicType":"str","x":390,"y":440,"wires":[["249e0de028dce1dc"]]},{"id":"249e0de028dce1dc","type":"function","z":"cad6e41fa82c02e7","name":"flow variables","func":"var flowname = msg.topic;\nvar data = msg.payload;\nflow.set(flowname,data);\n\nvar check = flow.get(flowname);\n\nmsg.payload = flowname + \";\" + check;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":360,"wires":[["9e8066915417518a"]]},{"id":"9e8066915417518a","type":"debug","z":"cad6e41fa82c02e7","name":"flowcheck","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":820,"y":360,"wires":[]},{"id":"1fe426c03ae52ff4","type":"function","z":"cad6e41fa82c02e7","name":"get flow variables","func":"msg.toemail = flow.get(\"toemail\");\nmsg.fromemail = flow.get(\"fromemail\");\nmsg.smtpport = flow.get(\"smtpport\");\nmsg.smtpserver = flow.get(\"smtpserver\");\nmsg.subject = flow.get(\"subject\");\nmsg.body = flow.get(\"body\");\nmsg.loginuser = flow.get(\"loginuser\");\nmsg.loginpass = flow.get(\"loginpass\");\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":600,"wires":[["f6d88d0703c4de83","5f808b71083b1588"]]},{"id":"be491af772a2c7c9","type":"ui_button","z":"cad6e41fa82c02e7","name":"","group":"87be8b8d25d85bd9","order":1,"width":0,"height":0,"passthru":true,"label":"Send basic email","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":350,"y":600,"wires":[["76859b957dd2db62"]]},{"id":"76859b957dd2db62","type":"delay","z":"cad6e41fa82c02e7","name":"delay","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":550,"y":600,"wires":[["1fe426c03ae52ff4"]],"info":"this is put here to brigde de 300 ms delay of the text inputs"},{"id":"5f808b71083b1588","type":"debug","z":"cad6e41fa82c02e7","name":"check flow variables","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1180,"y":500,"wires":[]},{"id":"a028f7ede88a233c","type":"inject","z":"cad6e41fa82c02e7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":600,"wires":[["be491af772a2c7c9"]]},{"id":"6c902f0a0cc8eb59","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"From email","tooltip":"sender of email","group":"aa4a84804a7816cb","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"fromemail","topicType":"str","x":370,"y":160,"wires":[["249e0de028dce1dc"]]},{"id":"4547c92c544b6fbe","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"Password","tooltip":"Password for email","group":"aa4a84804a7816cb","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"loginpass","topicType":"str","x":380,"y":240,"wires":[["249e0de028dce1dc"]]},{"id":"64d25c339910b270","type":"template","z":"cad6e41fa82c02e7","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"$EmailTo = \"{{toemail}}\"\n$EmailFrom = \"{{fromemail}}\"\n$Subject = \"{{subject}}\" \n$Body = \"{{body}}\" \n$SMTPServer = \"{{smtpserver}}\" \n$filenameAndPath = \"{{filepath}}\"\n$SMTPPort = \"{{smtmpport}}\"\n$filenameAndPath = \"{{filepath}}\"\n$attachment = New-Object System.Net.Mail.Attachment($filenameAndPath)\n$SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body)\n$SMTPMessage.Attachments.Add($attachment)\n$SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, $SMTPPort) \n$SMTPClient.EnableSsl = $true \n$SMTPClient.Credentials = New-Object System.Net.NetworkCredential(\"{{loginuser}}\", \"{{loginpass}}\"); \n$SMTPClient.Send($SMTPMessage)","output":"str","x":940,"y":760,"wires":[["5a1943d060116cca","e71d8383d207356d"]]},{"id":"5a1943d060116cca","type":"powershell","z":"cad6e41fa82c02e7","name":"","x":1130,"y":700,"wires":[[],[]]},{"id":"e71d8383d207356d","type":"debug","z":"cad6e41fa82c02e7","name":"mail with attach output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1160,"y":760,"wires":[]},{"id":"889aa830ce7d9132","type":"function","z":"cad6e41fa82c02e7","name":"get flow variables","func":"msg.toemail = flow.get(\"toemail\");\nmsg.fromemail = flow.get(\"fromemail\");\nmsg.smtpport = flow.get(\"smtpport\");\nmsg.smtpserver = flow.get(\"smtpserver\");\nmsg.subject = flow.get(\"subject\");\nmsg.body = flow.get(\"body\");\nmsg.loginuser = flow.get(\"loginuser\");\nmsg.loginpass = flow.get(\"loginpass\");\nmsg.filepath = flow.get(\"filepath\");\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":760,"wires":[["64d25c339910b270","63a45942018acc19"]]},{"id":"9d379b9a1a8df839","type":"ui_button","z":"cad6e41fa82c02e7","name":"","group":"87be8b8d25d85bd9","order":2,"width":0,"height":0,"passthru":true,"label":"Send with attachment","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":360,"y":760,"wires":[["3802118af87e8660"]]},{"id":"3802118af87e8660","type":"delay","z":"cad6e41fa82c02e7","name":"delay","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":550,"y":760,"wires":[["889aa830ce7d9132"]],"info":"this is put here to brigde de 300 ms delay of the text inputs"},{"id":"63a45942018acc19","type":"debug","z":"cad6e41fa82c02e7","name":"check flow variables","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1160,"y":660,"wires":[]},{"id":"373844fd99f2c18b","type":"inject","z":"cad6e41fa82c02e7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":760,"wires":[["9d379b9a1a8df839"]]},{"id":"242a4f4ceb76b0a7","type":"ui_text_input","z":"cad6e41fa82c02e7","name":"","label":"Attachment","tooltip":"Type the FULL filepath i.e. \"C:\\Users\\<USER>\\Desktop\\attachment.pdf\"","group":"aa4a84804a7816cb","order":9,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"filepath","topicType":"str","x":370,"y":480,"wires":[["249e0de028dce1dc"]]},{"id":"aa4a84804a7816cb","type":"ui_group","name":"Settings","tab":"9992690cb02c3365","order":1,"disp":true,"width":"6","collapse":false},{"id":"87be8b8d25d85bd9","type":"ui_group","name":"Commands","tab":"9992690cb02c3365","order":2,"disp":true,"width":"6","collapse":false},{"id":"9992690cb02c3365","type":"ui_tab","name":"mail","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 5 years, 1 month ago
Rating: 1 1
  • debug (x5)
  • delay (x2)
  • function (x3)
  • inject (x2)
  • template (x2)
  • email
  • dasboard
