Dashboard Nest thermostat
NEST style thermostat Dashboard widget for Node-red
If you have made heating or cooling controls on Node-red you will need nice thermostat widget to display and control your device via Node-red dashboard.
Nest html widget
Fully responsive design. Touch enabled set-point makes it even more cool. Press and hold finger or mouse and it will activate the set point sliding function.
Also it has several display modes like heating, cooling and away. It makes it more interactable and user intuitive. For ECO friendly folks there is possible to turn on and off that little green leaf.
Don't forget you have to program your own logics for thermostat functions.
Nest html widget Nest html widget Nest html widget
How to install:
Open and copy all text from widget.js then go to your node-red application and press import > cliboard paste the text and your done.
After import you should see somthing like this: Nest html widget
What data can I push to witget
  • ambient_temperature your temperature readings numeric payloads.
  • target_temperature your thermostat setpoint numeric payloads.
  • hvac_state string (off, heating, cooling) payload.
  • has_leave boolean (true, false) payloads.
  • away boolean (true, false) payloads.
If you are familiar with CSS and JAVASSCRIPT there there are more stuff to customize, colors, ranges etc.
Some options in the script:
options = {
       diameter: options.diameter || 400,
       minValue: options.minValue || 10, //Minimum value for target temperature
       maxValue: options.maxValue || 30, //Maximum value for target temperature
       numTicks: options.numTicks || 200, //Number of tick lines to display around the dial
       onSetTargetTemperature: options.onSetTargetTemperature || function() {}, // Function called when new target temperature set by the dial
What if I want several widgets on one page?
import several widget just make sure you edit uniq ID in these 2 lines inside the UI_Template block and function block that have global variables.
<div id="Mythermostat1"></div>
var nest = new thermostatDial(document.getElementById('Mythermostat1')
Data persistance:
Every time you push new vaue to widged values are stored in global context of node-red.
Issues:
Use the GitHub issues log for raising issues or contributing suggestions and enhancements. GITHUB
[{"id":"941d174a.01c348","type":"ui_template","z":"537d4f28.60dc4","group":"8a50f58a.83fee8","name":"Nest","order":1,"width":"0","height":"0","format":"<div id=\"thermostat\"></div>\n\n<style>\n\n@import url(http://fonts.googleapis.com/css?family=Open+Sans:300);\n\n#thermostat {\n margin: 0 auto;\n -webkit-tap-highlight-color: rgba(0, 0, 0, 0);\n}\n\n.dial {\n    -webkit-user-select: none;\n    -moz-user-select: none;\n    -ms-user-select: none;\n    user-select: none;\n}\n.dial.away .dial__ico__leaf {\n    visibility: hidden;\n}\n.dial.away .dial__lbl--target {\n    visibility: hidden;\n}\n.dial.away .dial__lbl--target--half {\n    visibility: hidden;\n}\n.dial.away .dial__lbl--away {\n    opacity: 1;\n}\n.dial .dial__shape {\n    -webkit-transition: fill 0.5s;\n    transition: fill 0.5s;\n}\n.dial path.dial__ico__leaf {\n    fill: #13EB13;\n    opacity: 0;\n    -webkit-transition: opacity 0.5s;\n    transition: opacity 0.5s;\n    pointer-events: none;\n}\n.dial.has-leaf .dial__ico__leaf {\n    display: block;\n    opacity: 1;\n    pointer-events: initial;\n}\n.dial__editableIndicator {\n    fill-rule: evenodd;\n    opacity: 0;\n    -webkit-transition: opacity 0.5s;\n    transition: opacity 0.5s;\n}\n.dial--edit path.dial__editableIndicator {\n    fill: white;\n}\n.dial--edit .dial__editableIndicator {\n    opacity: 1;\n}\n.dial--state--off .dial__shape {\n    fill: #3d3c3c;\n}\n.dial--state--heating .dial__shape {\n    fill: #E36304;\n}\n.dial--state--cooling .dial__shape {\n    fill: #007AF1;\n}\n.dial .dial__ticks path {\n    fill: rgba(255, 255, 255, 0.3);\n}\n.dial .dial__ticks path.active {\n    fill: rgba(255, 255, 255, 0.8);\n}\n.dial text {\n    fill: white;\n    text-anchor: middle;\n    font-family: Helvetica, sans-serif;\n    alignment-baseline: central;\n}\n.dial__lbl--target {\n    font-size: 120px;\n    font-weight: bold;\n}\n.dial__lbl--target--half {\n    font-size: 40px;\n    font-weight: bold;\n    opacity: 0;\n    -webkit-transition: opacity 0.1s;\n    transition: opacity 0.1s;\n}\n.dial__lbl--target--half.shown {\n    opacity: 1;\n    -webkit-transition: opacity 0s;\n    transition: opacity 0s;\n}\n.dial__lbl--ambient {\n    font-size: 22px;\n    font-weight: bold;\n}\n.dial__lbl--away {\n    font-size: 72px;\n    font-weight: bold;\n    opacity: 0;\n    pointer-events: none;\n}\n#controls {\n    font-family: Open Sans;\n    background-color: rgba(255, 255, 255, 0.25);\n    padding: 20px;\n    border-radius: 5px;\n    position: absolute;\n    left: 50%;\n    -webkit-transform: translatex(-50%);\n    transform: translatex(-50%);\n    margin-top: 20px;\n}\n#controls label {\n    text-align: left;\n    display: block;\n}\n#controls label span {\n    display: inline-block;\n    width: 200px;\n    text-align: right;\n    font-size: 0.8em;\n    text-transform: uppercase;\n}\n#controls p {\n    margin: 0;\n    margin-bottom: 1em;\n    padding-bottom: 1em;\n    border-bottom: 2px solid #ccc;\n}\n</style>\n<script>\n    var thermostatDial = (function() {\n\t\n\t/*\n\t * Utility functions\n\t */\n\t\n\t// Create an element with proper SVG namespace, optionally setting its attributes and appending it to another element\n\tfunction createSVGElement(tag,attributes,appendTo) {\n\t\tvar element = document.createElementNS('http://www.w3.org/2000/svg',tag);\n\t\tattr(element,attributes);\n\t\tif (appendTo) {\n\t\t\tappendTo.appendChild(element);\n\t\t}\n\t\treturn element;\n\t}\n\t\n\t// Set attributes for an element\n\tfunction attr(element,attrs) {\n\t\tfor (var i in attrs) {\n\t\t\telement.setAttribute(i,attrs[i]);\n\t\t}\n\t}\n\t\n\t// Rotate a cartesian point about given origin by X degrees\n\tfunction rotatePoint(point, angle, origin) {\n\t\tvar radians = angle * Math.PI/180;\n\t\tvar x = point[0]-origin[0];\n\t\tvar y = point[1]-origin[1];\n\t\tvar x1 = x*Math.cos(radians) - y*Math.sin(radians) + origin[0];\n\t\tvar y1 = x*Math.sin(radians) + y*Math.cos(radians) + origin[1];\n\t\treturn [x1,y1];\n\t}\n\t\n\t// Rotate an array of cartesian points about a given origin by X degrees\n\tfunction rotatePoints(points, angle, origin) {\n\t\treturn points.map(function(point) {\n\t\t\treturn rotatePoint(point, angle, origin);\n\t\t});\n\t}\n\t\n\t// Given an array of points, return an SVG path string representing the shape they define\n\tfunction pointsToPath(points) {\n\t\treturn points.map(function(point, iPoint) {\n\t\t\treturn (iPoint>0?'L':'M') + point[0] + ' ' + point[1];\n\t\t}).join(' ')+'Z';\n\t}\n\t\n\tfunction circleToPath(cx, cy, r) {\n\t\treturn [\n\t\t\t\"M\",cx,\",\",cy,\n\t\t\t\"m\",0-r,\",\",0,\n\t\t\t\"a\",r,\",\",r,0,1,\",\",0,r*2,\",\",0,\n\t\t\t\"a\",r,\",\",r,0,1,\",\",0,0-r*2,\",\",0,\n\t\t\t\"z\"\n\t\t].join(' ').replace(/\\s,\\s/g,\",\");\n\t}\n\t\n\tfunction donutPath(cx,cy,rOuter,rInner) {\n\t\treturn circleToPath(cx,cy,rOuter) + \" \" + circleToPath(cx,cy,rInner);\n\t}\n\t\n\t// Restrict a number to a min + max range\n\tfunction restrictToRange(val,min,max) {\n\t\tif (val < min) return min;\n\t\tif (val > max) return max;\n\t\treturn val;\n\t}\n\t\n\t// Round a number to the nearest 0.5\n\tfunction roundHalf(num) {\n\t\treturn Math.round(num*2)/2;\n\t}\n\t\n\tfunction setClass(el, className, state) {\n\t\tel.classList[state ? 'add' : 'remove'](className);\n\t}\n\t\n\t/*\n\t * The \"MEAT\"\n\t */\n\n\treturn function(targetElement, options) {\n\t\tvar self = this;\n\t\t\n\t\t/*\n\t\t * Options\n\t\t */\n\t\toptions = options || {};\n\t\toptions = {\n\t\t\tdiameter: options.diameter || 400,\n\t\t\tminValue: options.minValue || 10, // Minimum value for target temperature\n\t\t\tmaxValue: options.maxValue || 30, // Maximum value for target temperature\n\t\t\tnumTicks: options.numTicks || 200, // Number of tick lines to display around the dial\n\t\t\tonSetTargetTemperature: options.onSetTargetTemperature || function() {}, // Function called when new target temperature set by the dial\n\t\t};\n\t\t\n\t\t/*\n\t\t * Properties - calculated from options in many cases\n\t\t */\n\t\tvar properties = {\n\t\t\ttickDegrees: 300, // Degrees of the dial that should be covered in tick lines\n\t\t\trangeValue: options.maxValue - options.minValue,\n\t\t\tradius: options.diameter/2,\n\t\t\tticksOuterRadius: options.diameter / 30,\n\t\t\tticksInnerRadius: options.diameter / 8,\n\t\t\thvac_states: ['off', 'heating', 'cooling'],\n\t\t\tdragLockAxisDistance: 15,\n\t\t}\n\t\tproperties.lblAmbientPosition = [properties.radius, properties.ticksOuterRadius-(properties.ticksOuterRadius-properties.ticksInnerRadius)/2]\n\t\tproperties.offsetDegrees = 180-(360-properties.tickDegrees)/2;\n\t\t\n\t\t/*\n\t\t * Object state\n\t\t */\n\t\tvar state = {\n\t\t\ttarget_temperature: options.minValue,\n\t\t\tambient_temperature: options.minValue,\n\t\t\thvac_state: properties.hvac_states[0],\n\t\t\thas_leaf: false,\n\t\t\taway: false\n\t\t};\n\t\t\n\t\t/*\n\t\t * Property getter / setters\n\t\t */\n\t\tObject.defineProperty(this,'target_temperature',{\n\t\t\tget: function() {\n\t\t\t\treturn state.target_temperature;\n\t\t\t},\n\t\t\tset: function(val) {\n\t\t\t\tstate.target_temperature = restrictTargetTemperature(+val);\n\t\t\t\trender();\n\t\t\t}\n\t\t});\n\t\tObject.defineProperty(this,'ambient_temperature',{\n\t\t\tget: function() {\n\t\t\t\treturn state.ambient_temperature;\n\t\t\t},\n\t\t\tset: function(val) {\n\t\t\t\tstate.ambient_temperature = roundHalf(+val);\n\t\t\t\trender();\n\t\t\t}\n\t\t});\n\t\tObject.defineProperty(this,'hvac_state',{\n\t\t\tget: function() {\n\t\t\t\treturn state.hvac_state;\n\t\t\t},\n\t\t\tset: function(val) {\n\t\t\t\tif (properties.hvac_states.indexOf(val)>=0) {\n\t\t\t\t\tstate.hvac_state = val;\n\t\t\t\t\trender();\n\t\t\t\t}\n\t\t\t}\n\t\t});\n\t\tfunction str2bool(strvalue){\n          return (strvalue && typeof strvalue == 'string') ? (strvalue.toLowerCase() == 'true') : (strvalue == true);\n        }\n\t\tObject.defineProperty(this,'has_leaf',{\n\t\t\tget: function() {\n\t\t\t\treturn state.has_leaf;\n\t\t\t},\n\t\t\tset: function(val) {\n\t\t\t\tstate.has_leaf = !!str2bool(val);\n\t\t\t\trender();\n\t\t\t}\n\t\t});\n\t\tObject.defineProperty(this,'away',{\n\t\t\tget: function() {\n\t\t\t\treturn state.away;\n\t\t\t},\n\t\t\tset: function(val) {\n\t\t\t\tstate.away = !!str2bool(val);\n\t\t\t\trender();\n\t\t\t}\n\t\t});\n\t\t\n\t\t/*\n\t\t * SVG\n\t\t */\n\t\tvar svg = createSVGElement('svg',{\n\t\t\twidth: '100%', //options.diameter+'px',\n\t\t\theight: '100%', //options.diameter+'px',\n\t\t\tviewBox: '0 0 '+options.diameter+' '+options.diameter,\n\t\t\tclass: 'dial'\n\t\t},targetElement);\n\t\t// CIRCULAR DIAL\n\t\tvar circle = createSVGElement('circle',{\n\t\t\tcx: properties.radius,\n\t\t\tcy: properties.radius,\n\t\t\tr: properties.radius,\n\t\t\tclass: 'dial__shape'\n\t\t},svg);\n\t\t// EDITABLE INDICATOR\n\t\tvar editCircle = createSVGElement('path',{\n\t\t\td: donutPath(properties.radius,properties.radius,properties.radius-4,properties.radius-8),\n\t\t\tclass: 'dial__editableIndicator',\n\t\t},svg);\n\t\t\n\t\t/*\n\t\t * Ticks\n\t\t */\n\t\tvar ticks = createSVGElement('g',{\n\t\t\tclass: 'dial__ticks'\t\n\t\t},svg);\n\t\tvar tickPoints = [\n\t\t\t[properties.radius-1, properties.ticksOuterRadius],\n\t\t\t[properties.radius+1, properties.ticksOuterRadius],\n\t\t\t[properties.radius+1, properties.ticksInnerRadius],\n\t\t\t[properties.radius-1, properties.ticksInnerRadius]\n\t\t];\n\t\tvar tickPointsLarge = [\n\t\t\t[properties.radius-1.5, properties.ticksOuterRadius],\n\t\t\t[properties.radius+1.5, properties.ticksOuterRadius],\n\t\t\t[properties.radius+1.5, properties.ticksInnerRadius+20],\n\t\t\t[properties.radius-1.5, properties.ticksInnerRadius+20]\n\t\t];\n\t\tvar theta = properties.tickDegrees/options.numTicks;\n\t\tvar tickArray = [];\n\t\tfor (var iTick=0; iTick<options.numTicks; iTick++) {\n\t\t\ttickArray.push(createSVGElement('path',{d:pointsToPath(tickPoints)},ticks));\n\t\t};\n\t\t\n\t\t/*\n\t\t * Labels\n\t\t */\n\t\tvar lblTarget = createSVGElement('text',{\n\t\t\tx: properties.radius,\n\t\t\ty: properties.radius,\n\t\t\tclass: 'dial__lbl dial__lbl--target'\n\t\t},svg);\n\t\tvar lblTarget_text = document.createTextNode('');\n\t\tlblTarget.appendChild(lblTarget_text);\n\t\t//\n\t\tvar lblTargetHalf = createSVGElement('text',{\n\t\t\tx: properties.radius + properties.radius/2.5,\n\t\t\ty: properties.radius - properties.radius/8,\n\t\t\tclass: 'dial__lbl dial__lbl--target--half'\n\t\t},svg);\n\t\tvar lblTargetHalf_text = document.createTextNode('5');\n\t\tlblTargetHalf.appendChild(lblTargetHalf_text);\n\t\t//\n\t\tvar lblAmbient = createSVGElement('text',{\n\t\t\tclass: 'dial__lbl dial__lbl--ambient'\n\t\t},svg);\n\t\tvar lblAmbient_text = document.createTextNode('');\n\t\tlblAmbient.appendChild(lblAmbient_text);\n\t\t//\n\t\tvar lblAway = createSVGElement('text',{\n\t\t\tx: properties.radius,\n\t\t\ty: properties.radius,\n\t\t\tclass: 'dial__lbl dial__lbl--away'\n\t\t},svg);\n\t\tvar lblAway_text = document.createTextNode('AWAY');\n\t\tlblAway.appendChild(lblAway_text);\n\t\t//\n\t\tvar icoLeaf = createSVGElement('path',{\n\t\t\tclass: 'dial__ico__leaf'\n\t\t},svg);\n\t\t\n\t\t/*\n\t\t * LEAF\n\t\t */\n\t\tvar leafScale = properties.radius/5/100;\n\t\tvar leafDef = [\"M\", 3, 84, \"c\", 24, 17, 51, 18, 73, -6, \"C\", 100, 52, 100, 22, 100, 4, \"c\", -13, 15, -37, 9, -70, 19, \"C\", 4, 32, 0, 63, 0, 76, \"c\", 6, -7, 18, -17, 33, -23, 24, -9, 34, -9, 48, -20, -9, 10, -20, 16, -43, 24, \"C\", 22, 63, 8, 78, 3, 84, \"z\"].map(function(x) {\n\t\t\treturn isNaN(x) ? x : x*leafScale;\n\t\t}).join(' ');\n\t\tvar translate = [properties.radius-(leafScale*100*0.5),properties.radius*1.5]\n\t\tvar icoLeaf = createSVGElement('path',{\n\t\t\tclass: 'dial__ico__leaf',\n\t\t\td: leafDef,\n\t\t\ttransform: 'translate('+translate[0]+','+translate[1]+')'\n\t\t},svg);\n\t\t\t\n\t\t/*\n\t\t * RENDER\n\t\t */\n\t\tfunction render() {\n\t\t\trenderAway();\n\t\t\trenderHvacState();\n\t\t\trenderTicks();\n\t\t\trenderTargetTemperature();\n\t\t\trenderAmbientTemperature();\n\t\t\trenderLeaf();\n\t\t}\n\t\trender();\n\n\t\t/*\n\t\t * RENDER - ticks\n\t\t */\n\t\tfunction renderTicks() {\n\t\t\tvar vMin, vMax;\n\t\t\tif (self.away) {\n\t\t\t\tvMin = self.ambient_temperature;\n\t\t\t\tvMax = vMin;\n\t\t\t} else {\n\t\t\t\tvMin = Math.min(self.ambient_temperature, self.target_temperature);\n\t\t\t\tvMax = Math.max(self.ambient_temperature, self.target_temperature);\n\t\t\t}\n\t\t\tvar min = restrictToRange(Math.round((vMin-options.minValue)/properties.rangeValue * options.numTicks),0,options.numTicks-1);\n\t\t\tvar max = restrictToRange(Math.round((vMax-options.minValue)/properties.rangeValue * options.numTicks),0,options.numTicks-1);\n\t\t\t//\n\t\t\ttickArray.forEach(function(tick,iTick) {\n\t\t\t\tvar isLarge = iTick==min || iTick==max;\n\t\t\t\tvar isActive = iTick >= min && iTick <= max;\n\t\t\t\tattr(tick,{\n\t\t\t\t\td: pointsToPath(rotatePoints(isLarge ? tickPointsLarge: tickPoints,iTick*theta-properties.offsetDegrees,[properties.radius, properties.radius])),\n\t\t\t\t\tclass: isActive ? 'active' : ''\n\t\t\t\t});\n\t\t\t});\n\t\t}\n\t\n\t\t/*\n\t\t * RENDER - ambient temperature\n\t\t */\n\t\tfunction renderAmbientTemperature() {\n\t\t\tlblAmbient_text.nodeValue = Math.floor(self.ambient_temperature);\n\t\t\tif (self.ambient_temperature%1!=0) {\n\t\t\t\tlblAmbient_text.nodeValue += '⁵';\n\t\t\t}\n\t\t\tvar peggedValue = restrictToRange(self.ambient_temperature, options.minValue, options.maxValue);\n\t\t\tdegs = properties.tickDegrees * (peggedValue-options.minValue)/properties.rangeValue - properties.offsetDegrees;\n\t\t\tif (peggedValue > self.target_temperature) {\n\t\t\t\tdegs += 8;\n\t\t\t} else {\n\t\t\t\tdegs -= 8;\n\t\t\t}\n\t\t\tvar pos = rotatePoint(properties.lblAmbientPosition,degs,[properties.radius, properties.radius]);\n\t\t\tattr(lblAmbient,{\n\t\t\t\tx: pos[0],\n\t\t\t\ty: pos[1]\n\t\t\t});\n\t\t}\n\n\t\t/*\n\t\t * RENDER - target temperature\n\t\t */\n\t\tfunction renderTargetTemperature() {\n\t\t\tlblTarget_text.nodeValue = Math.floor(self.target_temperature);\n\t\t\tsetClass(lblTargetHalf,'shown',self.target_temperature%1!=0);\n\t\t}\n\t\t\n\t\t/*\n\t\t * RENDER - leaf\n\t\t */\n\t\tfunction renderLeaf() {\n\t\t\tsetClass(svg,'has-leaf',self.has_leaf);\n\t\t}\n\t\t\n\t\t/*\n\t\t * RENDER - HVAC state\n\t\t */\n\t\tfunction renderHvacState() {\n\t\t\tArray.prototype.slice.call(svg.classList).forEach(function(c) {\n\t\t\t\tif (c.match(/^dial--state--/)) {\n\t\t\t\t\tsvg.classList.remove(c);\n\t\t\t\t};\n\t\t\t});\n\t\t\tsvg.classList.add('dial--state--'+self.hvac_state);\n\t\t}\n\t\t\n\t\t/*\n\t\t * RENDER - away\n\t\t */\n\t\tfunction renderAway() {\n\t\t\tsvg.classList[self.away ? 'add' : 'remove']('away');\n\t\t}\n\t\t\n\t\t/*\n\t\t * Drag to control\n\t\t */\n\t\tvar _drag = {\n\t\t\tinProgress: false,\n\t\t\tstartPoint: null,\n\t\t\tstartTemperature: 0,\n\t\t\tlockAxis: undefined\n\t\t};\n\t\t\n\t\tfunction eventPosition(ev) {\n\t\t\tif (ev.targetTouches && ev.targetTouches.length) {\n\t\t\t\treturn [ev.targetTouches[0].clientX, ev.targetTouches[0].clientY];\n\t\t\t} else {\n\t\t\t\treturn [ev.x, ev.y];\n\t\t\t};\n\t\t}\n\t\t\n\t\tvar startDelay;\n\t\tfunction dragStart(ev) {\n\t\t\tstartDelay = setTimeout(function() {\n\t\t\t\tsetClass(svg, 'dial--edit', true);\n\t\t\t\t_drag.inProgress = true;\n\t\t\t\t_drag.startPoint = eventPosition(ev);\n\t\t\t\t_drag.startTemperature = self.target_temperature || options.minValue;\n\t\t\t\t_drag.lockAxis = undefined;\n\t\t\t},1000);\n\t\t};\n\t\t\n\t\tfunction dragEnd (ev) {\n\t\t\tclearTimeout(startDelay);\n\t\t\tsetClass(svg, 'dial--edit', false);\n\t\t\tif (!_drag.inProgress) return;\n\t\t\t_drag.inProgress = false;\n\t\t\tif (self.target_temperature != _drag.startTemperature) {\n\t\t\t\tif (typeof options.onSetTargetTemperature == 'function') {\n\t\t\t\t\toptions.onSetTargetTemperature(self.target_temperature);\n\t\t\t\t};\n\t\t\t};\n\t\t};\n\t\t\n\t\tfunction dragMove(ev) {\n\t\t\tev.preventDefault();\n\t\t\tif (!_drag.inProgress) return;\n\t\t\tvar evPos = eventPosition(ev);\n\t\t\tvar dy = _drag.startPoint[1]-evPos[1];\n\t\t\tvar dx = evPos[0] - _drag.startPoint[0];\n\t\t\tvar dxy;\n\t\t\tif (_drag.lockAxis == 'x') {\n\t\t\t\tdxy = dx;\n\t\t\t} else if (_drag.lockAxis == 'y') {\n\t\t\t\tdxy = dy;\n\t\t\t} else if (Math.abs(dy) > properties.dragLockAxisDistance) {\n\t\t\t\t_drag.lockAxis = 'y';\n\t\t\t\tdxy = dy;\n\t\t\t} else if (Math.abs(dx) > properties.dragLockAxisDistance) {\n\t\t\t\t_drag.lockAxis = 'x';\n\t\t\t\tdxy = dx;\n\t\t\t} else {\n\t\t\t\tdxy = (Math.abs(dy) > Math.abs(dx)) ? dy : dx;\n\t\t\t};\n\t\t\tvar dValue = (dxy*getSizeRatio())/(options.diameter)*properties.rangeValue;\n\t\t\tself.target_temperature = roundHalf(_drag.startTemperature+dValue);\n\t\t}\n\t\t\n\t\tsvg.addEventListener('mousedown',dragStart);\n\t\tsvg.addEventListener('touchstart',dragStart);\n\t\t\n\t\tsvg.addEventListener('mouseup',dragEnd);\n\t\tsvg.addEventListener('mouseleave',dragEnd);\n\t\tsvg.addEventListener('touchend',dragEnd);\n\t\t\n\t\tsvg.addEventListener('mousemove',dragMove);\n\t\tsvg.addEventListener('touchmove',dragMove);\n\t\t//\n\t\t\n\t\t/*\n\t\t * Helper functions\n\t\t */\n\t\tfunction restrictTargetTemperature(t) {\n\t\t\treturn restrictToRange(roundHalf(t),options.minValue,options.maxValue);\n\t\t}\n\t\t\n\t\tfunction angle(point) {\n\t\t\tvar dx = point[0] - properties.radius;\n\t\t\tvar dy = point[1] - properties.radius;\n\t\t\tvar theta = Math.atan(dx/dy) / (Math.PI/180);\n\t\t\tif (point[0]>=properties.radius && point[1] < properties.radius) {\n\t\t\t\ttheta = 90-theta - 90;\n\t\t\t} else if (point[0]>=properties.radius && point[1] >= properties.radius) {\n\t\t\t\ttheta = 90-theta + 90;\n\t\t\t} else if (point[0]<properties.radius && point[1] >= properties.radius) {\n\t\t\t\ttheta = 90-theta + 90;\n\t\t\t} else if (point[0]<properties.radius && point[1] < properties.radius) {\n\t\t\t\ttheta = 90-theta+270;\n\t\t\t}\n\t\t\treturn theta;\n\t\t};\n\t\t\n\t\tfunction getSizeRatio() {\n\t\t\treturn options.diameter / targetElement.clientWidth;\n\t\t}\n\t\t\n\t};\n})();\n\n/* ==== */\nvar initializing = true;\n\n(function(scope) {\n    var nest = new thermostatDial(document.getElementById('thermostat'),{\n    \tonSetTargetTemperature: function(v) {\n    \t    var p = {\n    \t        \"ambient_temperature\":nest.ambient_temperature,\n    \t        \"target_temperature\":v,\n    \t        \"hvac_state\":nest.hvac_state,\n    \t        \"has_leaf\": nest.has_leaf,\n    \t        \"away\":nest.away\n    \t    };\n    \t\tscope.send({topic: \"target_temperature\", payload: p});\n    \t}\n    });\n    \n    scope.$watch('msg', function(data) {\n        if (initializing) {\n            initializing = false;\n            } else {\n            nest.ambient_temperature = data.payload.ambient_temperature || 0;\n            nest.target_temperature = data.payload.target_temperature || 0;\n            nest.hvac_state = data.payload.hvac_state || \"off\";\n            nest.has_leaf = data.payload.has_leaf || false;\n            nest.away = data.payload.away || false;\n        }\n        \n    });\n})(scope);\n\n</script>","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":770,"y":80,"wires":[["9e88fc65.058ff","67b05f3d.1106a"]]},{"id":"7bc1539d.3c518c","type":"function","z":"537d4f28.60dc4","name":"ambient_temperature","func":"msg.topic = 'ambient_temperature';\nglobal.set(\"nest1_ambient_temperature\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":80,"wires":[["dd0f0b69.bbee28"]]},{"id":"f8d3f1dc.c595b","type":"function","z":"537d4f28.60dc4","name":"target_temperature","func":"msg.topic = 'target_temperature';\nglobal.set(\"nest1_target_temperature\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":410,"y":120,"wires":[["dd0f0b69.bbee28"]]},{"id":"b0b241af.71eba","type":"function","z":"537d4f28.60dc4","name":"hvac_state","func":"msg.topic = \"hvac_state\";\nglobal.set(\"nest1_hvac_state\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":390,"y":160,"wires":[["dd0f0b69.bbee28"]]},{"id":"b0857a1b.968f28","type":"function","z":"537d4f28.60dc4","name":"has_leaf","func":"msg.topic = \"has_leaf\";\nglobal.set(\"nest1_has_leaf\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":380,"y":200,"wires":[["dd0f0b69.bbee28"]]},{"id":"a8cb1f70.d9868","type":"function","z":"537d4f28.60dc4","name":"away","func":"msg.topic = \"away\";\nglobal.set(\"nest1_away\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":370,"y":240,"wires":[["dd0f0b69.bbee28"]]},{"id":"17bb82b9.067cad","type":"inject","z":"537d4f28.60dc4","name":"","topic":"has_leaf","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":"","x":110,"y":280,"wires":[["b0857a1b.968f28"]]},{"id":"68934bf3.592ed4","type":"inject","z":"537d4f28.60dc4","name":"","topic":"has_leaf","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"x":110,"y":320,"wires":[["b0857a1b.968f28"]]},{"id":"96bff4b9.e49c48","type":"inject","z":"537d4f28.60dc4","name":"","topic":"away","payload":"true","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":100,"y":360,"wires":[["a8cb1f70.d9868"]]},{"id":"c76a6344.2c80c","type":"inject","z":"537d4f28.60dc4","name":"","topic":"away","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"x":100,"y":400,"wires":[["a8cb1f70.d9868"]]},{"id":"fab31610.ac3148","type":"inject","z":"537d4f28.60dc4","name":"","topic":"hvac_state","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"x":110,"y":160,"wires":[["b0b241af.71eba"]]},{"id":"d38502bb.a2c3e","type":"inject","z":"537d4f28.60dc4","name":"","topic":"hvac_state","payload":"heating","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":200,"wires":[["b0b241af.71eba"]]},{"id":"4b80260.58428dc","type":"inject","z":"537d4f28.60dc4","name":"","topic":"hvac_state","payload":"cooling","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":240,"wires":[["b0b241af.71eba"]]},{"id":"3daf41dc.4e227e","type":"inject","z":"537d4f28.60dc4","name":"","topic":"ambient_temperature","payload":"21.6","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":150,"y":80,"wires":[["7bc1539d.3c518c"]]},{"id":"e65dafa6.3607e","type":"inject","z":"537d4f28.60dc4","name":"","topic":"target_temperature","payload":"18","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":140,"y":120,"wires":[["f8d3f1dc.c595b"]]},{"id":"35aeefed.396f6","type":"debug","z":"537d4f28.60dc4","name":"To your target_temperature MQTT topic","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1280,"y":80,"wires":[]},{"id":"67b05f3d.1106a","type":"debug","z":"537d4f28.60dc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":910,"y":140,"wires":[]},{"id":"dd0f0b69.bbee28","type":"function","z":"537d4f28.60dc4","name":"Data","func":"if (msg.topic == \"target_temperature\") {\n    global.set(\"nest1_target_temperature\",msg.payload);\n}\nmsg.topic = \"update\";\nvar data = {\n    'ambient_temperature': global.get(\"nest1_ambient_temperature\") || 20,\n    'target_temperature': global.get(\"nest1_target_temperature\") || 21,\n    'hvac_state': global.get(\"nest1_hvac_state\") || 'off',\n    'has_leaf': global.get(\"nest1_has_leaf\") || 'false',\n    'away': global.get(\"nest1_away\") || 'false'\n}\nmsg.payload = data;\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":80,"wires":[["941d174a.01c348"]]},{"id":"9e88fc65.058ff","type":"function","z":"537d4f28.60dc4","name":"New setpoint from UI","func":"if (msg.topic == \"target_temperature\") {\n    global.set(\"nest1_target_temperature\",msg.payload.target_temperature);\n    return msg;\n}\n","outputs":1,"noerr":0,"x":960,"y":80,"wires":[["35aeefed.396f6"]]},{"id":"6ac1c80c.e83808","type":"inject","z":"537d4f28.60dc4","name":"Load values on node-red startup","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":390,"y":40,"wires":[["dd0f0b69.bbee28"]]},{"id":"8a50f58a.83fee8","type":"ui_group","z":"","name":"Nest","tab":"d8a3365d.44e008","order":1,"disp":true,"width":"6","collapse":false},{"id":"d8a3365d.44e008","type":"ui_tab","z":"","name":"Nest Thermostat sample","icon":"dashboard","order":3}]
Created 7 years, 8 months ago
Updated 7 years, 6 months ago
Rating: 4.2 5
  • debug (x2)
  • function (x7)
  • inject (x10)
  • ui_group (x1)
  • ui_template (x1)
  • dashboard
  • nest
  • thermostat
  • ui
  • widget
