XY-MD02 Control Panel
XY-MD02-Control-Panel
A Node-RED based control panel for the XY-MD02 RTU Modbus Temperature and Humidity Sensor.
General Description
The XY-MD02 is a cheap Modbus Temperature and Humidity sensor, easy to find in various online store, like Amazon:
Amazon Link
This sensor is pretty handy for various applications and is a valuable resource to play with the Modbus protocol. I used one of this for a demo with Arduino OPTA, and so, sice I needed to double check sensor readings and also to configure some parameter, I created a Node-RED panel to control and configure the device.
With the interface you can:
  • Read Temperature value
  • Read Humidity Value
  • Target diferent Unit ID
  • Chage the device Address on the bus
Fetures that are "In development":
  • Temperature&Humidity Logging
  • Change baud rate and T&H calibration
  • Device Address discovery
  • Dinamyc change of the serial interface (if possible...)
Setup and Dependencies
The node-RED project has some dependecies. They are:
You can run the panel from your PC or from another Linux-capable device, like raspberry and so on (by the way, have a look to the amazing Arduino Portenta X8). In the PC/Raspberry case you may need this RS485 interface
For instruction about how to run Node-RED, please have a look here.
Once you have node-RED up and running and you have installed all the dependencies, the last thing you need to do is to update the serial interface reference in the Modbus configuration node. The serial interface may have different names depending on the platform and overall system configuration. So open the flow, locate one of the modbus nodes and click on the pencil icon to open the Modbus server configuration (see pictures below):
Then identify the Serial Port section and click on the magnifier lens icon and select the correct one (in the picture is COM16):
Update and deploy and you're all set, you should be able to use the Panel now.
Device Address Change
To change the device addressing, put the new address in the "Address Update" Secrtion of the Panel and click on the "Update Address" Button. The device will reply with an updated configuration string that contains the new address. The change on the address will be effective at the next device power on (so make a power cycle if you want to use the new address).
[{"id":"a27e33cfcc8d8501","type":"tab","label":"XY-MD02","disabled":false,"info":"## ","env":[]},{"id":"faea5f928728d516","type":"tab","label":"Routines","disabled":false,"info":"","env":[]},{"id":"7f832d9996928b75","type":"websocket-client","path":"ws://192.168.1.7:8989/test","tls":"","wholemsg":"false","hb":"0","subprotocol":""},{"id":"7851e72408eb9139","type":"websocket-listener","path":"/test","wholemsg":"false"},{"id":"35d9b9f5ea4a1f4c","type":"mqtt-broker","name":"","broker":"192.168.1.200","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"96d4f7bce3a1782f","type":"ui_tab","name":"XY-MD02 Modbus Interface","icon":"dashboard","disabled":false,"hidden":false},{"id":"de3ad1f3cec3f331","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey","palette":"light"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"7b6c5fd924eae0eb","type":"ui_group","name":"Read Data","tab":"96d4f7bce3a1782f","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"3a99a96b963bcf80","type":"modbus-client","name":"THSensor","clienttype":"simpleser","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"COM16","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"","commandDelay":1,"clientTimeout":500,"reconnectOnTimeout":false,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true,"showErrors":false,"showWarnings":true,"showLogs":true},{"id":"5b3844555be35752","type":"ui_group","name":"Address Update","tab":"96d4f7bce3a1782f","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"46c912f2f96406cd","type":"ui_group","name":"Slave Response","tab":"96d4f7bce3a1782f","order":3,"disp":true,"width":"6","collapse":false,"className":""},{"id":"ce10b214ad2791bf","type":"ui_group","name":"Unit ID","tab":"96d4f7bce3a1782f","order":4,"disp":true,"width":"6","collapse":false,"className":""},{"id":"1ff79d59c962b20a","type":"serial-port","name":"","serialport":"COM15","serialbaud":"9600","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"50","bin":"bin","out":"time","addchar":"","responsetimeout":"10000"},{"id":"47aead06ed1e7657","type":"modbus-flex-getter","z":"a27e33cfcc8d8501","name":"","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"server":"3a99a96b963bcf80","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":630,"y":160,"wires":[["f4d35e99834b59f7","e5d1ddffb30f6a3e","39af3be91ab8de28"],[]]},{"id":"e5095efb2256f1e3","type":"inject","z":"a27e33cfcc8d8501","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":120,"wires":[["7aaeecf0f8e9fc5e"]]},{"id":"7aaeecf0f8e9fc5e","type":"function","z":"a27e33cfcc8d8501","name":"Read T&H","func":"msg.payload = {\n'fc': 4,\n'unitid': global.get(\"uid\"),\n'address': 1,\n'quantity': 2\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":160,"wires":[["47aead06ed1e7657"]]},{"id":"6d7b9e15073b8dcc","type":"modbus-flex-getter","z":"a27e33cfcc8d8501","name":"","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"server":"3a99a96b963bcf80","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":630,"y":400,"wires":[["f4d35e99834b59f7","39af3be91ab8de28"],[]]},{"id":"dff78e4a142bc563","type":"inject","z":"a27e33cfcc8d8501","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":360,"wires":[["05e909c16bcc70ab"]]},{"id":"05e909c16bcc70ab","type":"function","z":"a27e33cfcc8d8501","name":"Read Cfg registers","func":"msg.payload = {\n'fc': 3,\n'unitid': global.get(\"uid\"),\n'address': 257,\n'quantity': 4\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":400,"wires":[["6d7b9e15073b8dcc"]]},{"id":"1b39567d011edc8b","type":"modbus-flex-getter","z":"a27e33cfcc8d8501","name":"","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"server":"3a99a96b963bcf80","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":630,"y":320,"wires":[["f4d35e99834b59f7","e068b21b53efb36a","39af3be91ab8de28"],[]]},{"id":"7d378ee843cae2fa","type":"inject","z":"a27e33cfcc8d8501","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":280,"wires":[["a083b7b7aa7a67eb"]]},{"id":"a083b7b7aa7a67eb","type":"function","z":"a27e33cfcc8d8501","name":"Read H","func":"msg.payload = {\n'fc': 4,\n'unitid': global.get(\"uid\"),\n'address': 2,\n'quantity': 1\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":320,"wires":[["1b39567d011edc8b"]]},{"id":"535b052f8c3e23cb","type":"modbus-flex-write","z":"a27e33cfcc8d8501","name":"","showStatusActivities":false,"showErrors":false,"showWarnings":true,"server":"3a99a96b963bcf80","emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":510,"y":660,"wires":[[],[]]},{"id":"f2b23433248acf2a","type":"function","z":"a27e33cfcc8d8501","name":"Write Address","func":"msg.payload = {\n'value': global.get(\"newuid\"),\n'fc': 6,\n'unitid': global.get(\"uid\"),\n'address': 257,\n'quantity': 1\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":660,"wires":[["535b052f8c3e23cb"]]},{"id":"9a7aa91defaafc8a","type":"modbus-flex-getter","z":"a27e33cfcc8d8501","name":"","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"server":"3a99a96b963bcf80","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":630,"y":240,"wires":[["f4d35e99834b59f7","655f6a78e83e5b8e","39af3be91ab8de28"],[]]},{"id":"45fb295b53372d11","type":"inject","z":"a27e33cfcc8d8501","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":200,"wires":[["b69c5803bd425375"]]},{"id":"b69c5803bd425375","type":"function","z":"a27e33cfcc8d8501","name":"Read T","func":"msg.payload = {\n'fc': 4,\n'unitid': global.get(\"uid\"),\n'address': 1,\n'quantity': 1\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":240,"wires":[["9a7aa91defaafc8a"]]},{"id":"6179c45717c9ebf4","type":"ui_button","z":"a27e33cfcc8d8501","name":"","group":"7b6c5fd924eae0eb","order":0,"width":0,"height":0,"passthru":false,"label":"Read Temperature&Humidity","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":160,"y":160,"wires":[["7aaeecf0f8e9fc5e"]]},{"id":"d6c8a0eda5daf8bf","type":"ui_button","z":"a27e33cfcc8d8501","name":"","group":"7b6c5fd924eae0eb","order":0,"width":0,"height":0,"passthru":false,"label":"Read Temperature","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":190,"y":240,"wires":[["b69c5803bd425375"]]},{"id":"66f10f9e99246902","type":"ui_button","z":"a27e33cfcc8d8501","name":"","group":"7b6c5fd924eae0eb","order":0,"width":0,"height":0,"passthru":false,"label":"Read Humidity","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":200,"y":320,"wires":[["a083b7b7aa7a67eb"]]},{"id":"11865f6c7b18813b","type":"ui_button","z":"a27e33cfcc8d8501","name":"","group":"7b6c5fd924eae0eb","order":0,"width":0,"height":0,"passthru":false,"label":"Read Config Registers","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":180,"y":400,"wires":[["05e909c16bcc70ab"]]},{"id":"326521c27bf387d4","type":"ui_text","z":"a27e33cfcc8d8501","group":"46c912f2f96406cd","order":4,"width":0,"height":0,"name":"","label":"Slave Answer","format":"{{msg.payload}}","layout":"row-spread","className":"","style":false,"font":"","fontSize":16,"color":"#000000","x":1040,"y":520,"wires":[]},{"id":"f4d35e99834b59f7","type":"function","z":"a27e33cfcc8d8501","name":"Parse","func":"msg.payload = msg.payload.map(i =>i.toString()).join(\" \");\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":850,"y":520,"wires":[["326521c27bf387d4"]]},{"id":"eb665b416426c9b1","type":"function","z":"a27e33cfcc8d8501","name":"Set Uid","func":"global.set(\"uid\",msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":500,"wires":[[]]},{"id":"1af04e4e8f3d9fb9","type":"ui_text_input","z":"a27e33cfcc8d8501","name":"","label":"","tooltip":"","group":"ce10b214ad2791bf","order":1,"width":0,"height":0,"passthru":true,"mode":"number","delay":300,"topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":130,"y":500,"wires":[["eb665b416426c9b1"]]},{"id":"059d4128030586aa","type":"ui_button","z":"a27e33cfcc8d8501","name":"","group":"5b3844555be35752","order":0,"width":0,"height":0,"passthru":false,"label":"Update Address","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":120,"y":660,"wires":[["f2b23433248acf2a"]]},{"id":"64e4db06b87ce3b4","type":"ui_text_input","z":"a27e33cfcc8d8501","name":"","label":"","tooltip":"","group":"5b3844555be35752","order":1,"width":0,"height":0,"passthru":true,"mode":"number","delay":300,"topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":130,"y":540,"wires":[["7b2517b3de268d00"]]},{"id":"7b2517b3de268d00","type":"function","z":"a27e33cfcc8d8501","name":"Set New Uid","func":"global.set(\"newuid\",msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":290,"y":540,"wires":[[]]},{"id":"ddd4ec58e62d6c32","type":"ui_gauge","z":"a27e33cfcc8d8501","name":"","group":"46c912f2f96406cd","order":1,"width":0,"height":0,"gtype":"gage","title":"Temperature","label":"°C","format":"{{value}}","min":0,"max":"60","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":1050,"y":240,"wires":[]},{"id":"655f6a78e83e5b8e","type":"function","z":"a27e33cfcc8d8501","name":"Scale","func":"msg.payload = msg.payload/10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":240,"wires":[["ddd4ec58e62d6c32"]]},{"id":"a6414890b75c8296","type":"ui_gauge","z":"a27e33cfcc8d8501","name":"","group":"46c912f2f96406cd","order":1,"width":0,"height":0,"gtype":"gage","title":"Humidity","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":1040,"y":300,"wires":[]},{"id":"e068b21b53efb36a","type":"function","z":"a27e33cfcc8d8501","name":"Scale","func":"msg.payload = msg.payload/10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":300,"wires":[["a6414890b75c8296"]]},{"id":"e5d1ddffb30f6a3e","type":"function","z":"a27e33cfcc8d8501","name":"Get T&H","func":"msg.temp = msg.payload[0];\nmsg.hum = msg.payload[1];\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":840,"y":120,"wires":[["32923da7a40425a2","b59d8f9778016a83"]]},{"id":"32923da7a40425a2","type":"change","z":"a27e33cfcc8d8501","name":"GetT","rules":[{"t":"set","p":"payload","pt":"msg","to":"temp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":100,"wires":[["655f6a78e83e5b8e"]]},{"id":"b59d8f9778016a83","type":"change","z":"a27e33cfcc8d8501","name":"GetH","rules":[{"t":"set","p":"payload","pt":"msg","to":"hum","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":160,"wires":[["e068b21b53efb36a"]]},{"id":"39af3be91ab8de28","type":"debug","z":"a27e33cfcc8d8501","name":"debug 13","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":860,"y":460,"wires":[]},{"id":"bf4e8a9701b11667","type":"inject","z":"a27e33cfcc8d8501","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":90,"y":600,"wires":[["1af04e4e8f3d9fb9","64e4db06b87ce3b4"]]},{"id":"f29a7d5bd34e9b94","type":"comment","z":"a27e33cfcc8d8501","name":"General Description","info":"XY-MD02 Address map\n\nAll registers are 2 bytes long.\n\nInput registers:\n----------------\n0x0001: temperature\n0x0002: humidity\n\nKeep register:\n--------------\n0x0101: Device Modbus Address\n0x0102: Baud rate\n0x0103: Temperature Correction\n0x0104: Humidity correction","x":190,"y":80,"wires":[]},{"id":"04ce160bdef4cd1e","type":"function","z":"faea5f928728d516","name":"Start","func":"let uid = msg.payload;\n\nglobal.set(\"uid\",uid);\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":250,"y":160,"wires":[["77085e7a7dec5fcb"]]},{"id":"61032ed7dee10e84","type":"delay","z":"faea5f928728d516","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":600,"y":220,"wires":[["007dfb2a4407169b"]]},{"id":"77085e7a7dec5fcb","type":"function","z":"faea5f928728d516","name":"Read T&H","func":"msg.payload = {\n'fc': 4,\n'unitid': global.get(\"uid\"),\n'address': 1,\n'quantity': 2\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":160,"wires":[["f83e0867f9c89523","61032ed7dee10e84"]]},{"id":"379fbf48658f8b1d","type":"inject","z":"faea5f928728d516","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":110,"y":160,"wires":[["04ce160bdef4cd1e"]]},{"id":"f83e0867f9c89523","type":"modbus-flex-getter","z":"faea5f928728d516","name":"","showStatusActivities":false,"showErrors":true,"showWarnings":true,"logIOActivities":false,"server":"3a99a96b963bcf80","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":630,"y":160,"wires":[["fdb81d3bebea5d17"],[]]},{"id":"d4ea5554e3914e16","type":"debug","z":"faea5f928728d516","name":"debug 12","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":960,"y":160,"wires":[]},{"id":"007dfb2a4407169b","type":"function","z":"faea5f928728d516","name":"Increment","func":"msg.payload = msg.payload.unitid + 1;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":220,"wires":[["04ce160bdef4cd1e"]]},{"id":"fdb81d3bebea5d17","type":"function","z":"faea5f928728d516","name":"UnitID","func":"msg.payload = global.get(\"uid\");\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":160,"wires":[["d4ea5554e3914e16"]]},{"id":"11e4cef6d2617ecc","type":"comment","z":"faea5f928728d516","name":"Address Discovery","info":"Routine for address discovery. Very useful if you have set the sensor address without noting it down (happened to me).\n\nStill in development.","x":130,"y":100,"wires":[]}]
Created 1 year, 7 months ago
  • change (x2)
  • comment (x2)
  • debug (x2)
  • delay (x1)
  • function (x15)
  • inject (x6)
  • mqtt-broker (x1)
  • websocket-client (x1)
  • websocket-listener (x1)
  • modbus-client (x1)
  • modbus-flex-getter (x5)
  • modbus-flex-write (x1)
  • serial-port (x1)
  • tab (x2)
  • ui_base (x1)
  • ui_button (x5)
  • ui_gauge (x2)
  • ui_group (x4)
  • ui_text (x1)
  • ui_text_input (x2)
  • Modbus
  • XY-MD02
