FireTV Stick Remote via REST-API (fast, no components outside nodered)
A flow to control your FireTV, just with nodered, without a noticable delay.
To make it work you have to do the following:
  1. Enter the IP of your FireTV at all the nodes marked in the flow.
  2. Initiate the https REST-API by using the inject node "Start Sync".
  3. Request your PIN by using the inject node "Get PIN". The 4 digit PIN will be displayed on your FireTV.
  4. Enter the PIN into the inject node "Send PIN 1234", replace the 1234 within the message payload.
  5. Request your Token by using the inject node "Send PIN 1234". The 4 digit PIN will be displayed on your FireTV.
  6. Get the token from debug node "Token".
  7. Enter the Token into the function node "Remote Logic".
The Token created is used from here on out. This flow uses the API used by the FireTV Remote App.
You'll have to execute Step 2 after each reboot of the FireTV Stick and probably in an intervall, if your FTV Stick goes to sleep. edit: Has not happend in my setup within 4 months, yet.
In my setup, I send the wake http-request every minute to keep tha API active.
The Text input works for active Text fields, like the general search field. The number pad does not work for unlocking, actually i haven't found a usecase yet.
Feel free to use this template as you please, but leave a like.
Thanks to SLC-Josh for the foundation.
[{"id":"77e7721a33feed2f","type":"tab","label":"FireTV","disabled":false,"info":"","env":[]},{"id":"706c2671aa5f29cc","type":"ui_button","z":"77e7721a33feed2f","name":"Play/Pause","group":"1986e55c86514c11","order":12,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-play fa-2x","payload":"play","payloadType":"str","topic":"","topicType":"str","x":130,"y":60,"wires":[["010df6c085f7aeb4"]]},{"id":"8e5db06760673f26","type":"ui_button","z":"77e7721a33feed2f","name":"Back","group":"1986e55c86514c11","order":4,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-undo fa-2x","payload":"back","payloadType":"str","topic":"","topicType":"str","x":110,"y":100,"wires":[["010df6c085f7aeb4"]]},{"id":"cd7f7007bded6581","type":"ui_button","z":"77e7721a33feed2f","name":"Home","group":"1986e55c86514c11","order":1,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-home fa-2x","payload":"home","payloadType":"str","topic":"","topicType":"str","x":270,"y":60,"wires":[["010df6c085f7aeb4"]]},{"id":"c736cbf1fd221360","type":"ui_button","z":"77e7721a33feed2f","name":"Menu","group":"1986e55c86514c11","order":3,"width":2,"height":2,"passthru":false,"label":"≡ Menu","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"menu","payloadType":"str","topic":"firetv/control","topicType":"str","x":230,"y":100,"wires":[["010df6c085f7aeb4"]]},{"id":"da75814bc23f453e","type":"ui_button","z":"77e7721a33feed2f","name":"Rewind","group":"1986e55c86514c11","order":10,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-backward fa-2x","payload":"rewind","payloadType":"str","topic":"","topicType":"str","x":120,"y":140,"wires":[["010df6c085f7aeb4"]]},{"id":"e15a50856bb247d4","type":"ui_button","z":"77e7721a33feed2f","name":"Stop","group":"1986e55c86514c11","order":11,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-square fa-2x","payload":"stop","payloadType":"str","topic":"firetv/control","topicType":"str","x":250,"y":140,"wires":[["010df6c085f7aeb4"]]},{"id":"7d9167359fa1a63f","type":"ui_button","z":"77e7721a33feed2f","name":"YouTube","group":"1986e55c86514c11","order":6,"width":2,"height":2,"passthru":false,"label":"▶️ YouTube","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"youtube","payloadType":"str","topic":"firetv/control","topicType":"str","x":120,"y":180,"wires":[["010df6c085f7aeb4"]]},{"id":"7b454e985655c215","type":"ui_button","z":"77e7721a33feed2f","name":"Fast Forward","group":"1986e55c86514c11","order":13,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-forward fa-2x","payload":"fast_forward","payloadType":"str","topic":"","topicType":"str","x":270,"y":180,"wires":[["010df6c085f7aeb4"]]},{"id":"010df6c085f7aeb4","type":"link out","z":"77e7721a33feed2f","name":"link out 5","mode":"link","links":["aba9bfd0634e9bbe","bdb85f007d5c954a","d654a82cd7d5cbe5"],"x":425,"y":120,"wires":[]},{"id":"bc9cd88d4a082cb0","type":"http request","z":"77e7721a33feed2f","name":"1. Wakeup","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://YOUR-FIRETV-IP:8009/apps/FireTVRemote","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":520,"wires":[[]]},{"id":"602b33c79d32c11f","type":"http request","z":"77e7721a33feed2f","name":"2. PIN Req Exec","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://YOUR-FIRETV-IP:8080/v1/FireTV/pin/display","tls":"tls_f","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":570,"y":620,"wires":[[]]},{"id":"33f366b2aaefc164","type":"http request","z":"77e7721a33feed2f","name":"3. Verify Exec","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://YOUR-FIRETV-IP:8080/v1/FireTV/pin/verify","tls":"tls_f","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":560,"y":720,"wires":[["df46d088446b46b0"]]},{"id":"5df84bdea6578feb","type":"change","z":"77e7721a33feed2f","name":"Set Headers PIN","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\"X-Api-Key\":\"0987654321\",\"Content-Type\":\"application/json\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":620,"wires":[["602b33c79d32c11f"]]},{"id":"6a4b29f53d244e81","type":"change","z":"77e7721a33feed2f","name":"Set Headers Verify","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\"X-Api-Key\":\"0987654321\",\"Content-Type\":\"application/json\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":720,"wires":[["33f366b2aaefc164"]]},{"id":"838f3ed62c3c3f70","type":"http request","z":"77e7721a33feed2f","name":"HTTP Send","method":"use","ret":"txt","paytoqs":"ignore","url":"","tls":"tls_f","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":650,"y":420,"wires":[[]]},{"id":"bb4679eaa14f6756","type":"inject","z":"77e7721a33feed2f","name":"Start Sync","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":200,"y":520,"wires":[["bc9cd88d4a082cb0"]]},{"id":"0e52e3bdb2c7baf1","type":"inject","z":"77e7721a33feed2f","name":"Get PIN","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"{\"friendlyName\":\"NodeRed\"}","payloadType":"json","x":210,"y":620,"wires":[["5df84bdea6578feb"]]},{"id":"a5784cfdc0e54fb8","type":"inject","z":"77e7721a33feed2f","name":"Send PIN 1234","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"{\"pin\":\"1234\"}","payloadType":"json","x":180,"y":720,"wires":[["6a4b29f53d244e81"]]},{"id":"d654a82cd7d5cbe5","type":"link in","z":"77e7721a33feed2f","name":"link in 4","links":["010df6c085f7aeb4","8d653174ad0bd447","b3bb774f53dc7c5b","1a23fa03f44756de","ee9e4cde632aa3e1","3f4a497a64737356","86ae8dc3fb17d31b","d11d81146a37c342","7e94452d0d0835a6"],"x":165,"y":420,"wires":[["decaf4a34a6fddc1"]]},{"id":"decaf4a34a6fddc1","type":"function","z":"77e7721a33feed2f","name":"Remote Logic","func":"const token = \"Enter your token here\"; \nconst ip = \"YOUR-FIRETV-IP\";\n\nconst commands = {\n    \"up\": \"dpad_up\", \"down\": \"dpad_down\", \"left\": \"dpad_left\", \"right\": \"dpad_right\",\n    \"ok\": \"select\", \"back\": \"back\", \"home\": \"home\", \"menu\": \"menu\",\n    \"vol_up\": \"volume_up\", \"vol_down\": \"volume_down\", \"mute\": \"volume_mute\",\n    // Mapping für Zahlentasten (KeyEvents)\n    \"0\": \"0\", \"1\": \"1\", \"2\": \"2\", \"3\": \"3\", \"4\": \"4\", \n    \"5\": \"5\", \"6\": \"6\", \"7\": \"7\", \"8\": \"8\", \"9\": \"9\"\n};\n\nconst input = msg.payload.toString();\nmsg.method = \"POST\";\nmsg.headers = {\n    \"X-Api-Key\": \"0987654321\",\n    \"X-Client-Token\": token,\n    \"User-Agent\": \"okhttp/4.10.0\",\n    \"Content-Type\": \"application/json; charset=utf-8\"\n};\n\n// 1. TEXTEINGABE (wenn Payload mit \"text:\" startet)\nif (input.startsWith(\"text:\")) {\n    const textContent = input.replace(\"text:\", \"\");\n    msg.url = `https://${ip}:8080/v1/FireTV/keyboard`;\n    msg.payload = { \"text\": textContent };\n} \n// 2. YOUTUBE START\nelse if (input.toLowerCase() === \"youtube\") {\n    msg.url = `https://${ip}:8080/v1/FireTV/app/com.amazon.firetv.youtube`;\n    msg.payload = {};\n}\n// 3. MEDIA (PLAY/PAUSE/SCAN)\nelse if ([\"play\", \"pause\", \"fast_forward\", \"rewind\"].includes(input.toLowerCase())) {\n    if (input.toLowerCase() === \"fast_forward\" || input.toLowerCase() === \"rewind\") {\n        msg.url = `https://${ip}:8080/v1/media?action=scan`;\n        msg.payload = {\n            \"direction\": (input.toLowerCase() === \"fast_forward\") ? \"forward\" : \"back\",\n            \"keyAction\": { \"keyActionType\": \"keyDown\" }\n        };\n    } else {\n        msg.url = `https://${ip}:8080/v1/media?action=play`;\n        msg.payload = {};\n    }\n}\n// 4. STANDARD TASTEN & ZAHLEN\nelse {\n    const action = commands[input.toLowerCase()] || input;\n    msg.url = `https://${ip}:8080/v1/FireTV?action=${action}`;\n    msg.payload = {};\n}\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":420,"wires":[["838f3ed62c3c3f70"]]},{"id":"1ee31b827591e433","type":"ui_text_input","z":"77e7721a33feed2f","name":"","label":"","tooltip":"","group":"1986e55c86514c11","order":44,"width":8,"height":1,"passthru":true,"mode":"text","delay":"0","topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":540,"y":240,"wires":[["37d18321c390573c","b59b579bb64971b3"]]},{"id":"37d18321c390573c","type":"function","z":"77e7721a33feed2f","name":"reset","func":"return {payload:\"\"};","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":280,"wires":[["1ee31b827591e433"]]},{"id":"b59b579bb64971b3","type":"switch","z":"77e7721a33feed2f","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":690,"y":240,"wires":[["c51bf259b78642a6"]]},{"id":"c51bf259b78642a6","type":"function","z":"77e7721a33feed2f","name":"transform","func":"var payload = \"text:\" + msg.payload;\nreturn {payload: payload};","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":820,"y":240,"wires":[["3f4a497a64737356"]]},{"id":"3f4a497a64737356","type":"link out","z":"77e7721a33feed2f","name":"link out 10","mode":"link","links":["d654a82cd7d5cbe5"],"x":915,"y":240,"wires":[]},{"id":"3d164f4476194288","type":"ui_button","z":"77e7721a33feed2f","name":"left","group":"e22e9fa17b0cd1e3","order":7,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-arrow-left  fa-2x","payload":"left","payloadType":"str","topic":"tasmota/IRRemote/cmnd/IRsend","topicType":"str","x":110,"y":280,"wires":[["d11d81146a37c342"]]},{"id":"e754e65d2c3ec18f","type":"ui_button","z":"77e7721a33feed2f","name":"ok","group":"e22e9fa17b0cd1e3","order":8,"width":2,"height":2,"passthru":false,"label":"OK","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"ok","payloadType":"str","topic":"tasmota/IRRemote/cmnd/IRsend","topicType":"str","x":230,"y":280,"wires":[["d11d81146a37c342"]]},{"id":"4f125755b502cf52","type":"ui_button","z":"77e7721a33feed2f","name":"right","group":"e22e9fa17b0cd1e3","order":9,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-arrow-right  fa-2x","payload":"right","payloadType":"str","topic":"tasmota/IRRemote/cmnd/IRsend","topicType":"str","x":350,"y":280,"wires":[["d11d81146a37c342"]]},{"id":"d11d81146a37c342","type":"link out","z":"77e7721a33feed2f","name":"common","mode":"link","links":["8de7d55f7298c355","d654a82cd7d5cbe5"],"x":385,"y":240,"wires":[]},{"id":"3a259c7d0a46614a","type":"ui_button","z":"77e7721a33feed2f","name":"1","group":"1986e55c86514c11","order":18,"width":2,"height":2,"passthru":false,"label":"1","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"1","payloadType":"num","topic":"","topicType":"str","x":530,"y":60,"wires":[["7e94452d0d0835a6"]]},{"id":"8f978e276ae3c1e7","type":"ui_button","z":"77e7721a33feed2f","name":"4","group":"1986e55c86514c11","order":25,"width":2,"height":2,"passthru":false,"label":"4","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"4","payloadType":"num","topic":"","topicType":"str","x":530,"y":100,"wires":[["7e94452d0d0835a6"]]},{"id":"ac979f35ec0db1c2","type":"ui_button","z":"77e7721a33feed2f","name":"7","group":"1986e55c86514c11","order":32,"width":2,"height":2,"passthru":false,"label":"7","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"7","payloadType":"num","topic":"","topicType":"str","x":530,"y":140,"wires":[["7e94452d0d0835a6"]]},{"id":"7db8b5f5d791024c","type":"ui_button","z":"77e7721a33feed2f","name":"2","group":"1986e55c86514c11","order":19,"width":2,"height":2,"passthru":false,"label":"2","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"2","payloadType":"str","topic":"","topicType":"str","x":650,"y":60,"wires":[["7e94452d0d0835a6"]]},{"id":"a2b75ef2eeccc51e","type":"ui_button","z":"77e7721a33feed2f","name":"5","group":"1986e55c86514c11","order":26,"width":2,"height":2,"passthru":false,"label":"5","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"5","payloadType":"num","topic":"","topicType":"str","x":650,"y":100,"wires":[["7e94452d0d0835a6"]]},{"id":"1e681c0930c01228","type":"ui_button","z":"77e7721a33feed2f","name":"8","group":"1986e55c86514c11","order":33,"width":2,"height":2,"passthru":false,"label":"8","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"8","payloadType":"num","topic":"","topicType":"str","x":650,"y":140,"wires":[["7e94452d0d0835a6"]]},{"id":"e955722c85ee0e6e","type":"ui_button","z":"77e7721a33feed2f","name":"0","group":"1986e55c86514c11","order":39,"width":2,"height":2,"passthru":false,"label":"0","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"0","payloadType":"num","topic":"","topicType":"str","x":650,"y":180,"wires":[["7e94452d0d0835a6"]]},{"id":"013eb32ecc25efe8","type":"ui_button","z":"77e7721a33feed2f","name":"3","group":"1986e55c86514c11","order":20,"width":2,"height":2,"passthru":false,"label":"3","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"3","payloadType":"num","topic":"","topicType":"str","x":770,"y":60,"wires":[["7e94452d0d0835a6"]]},{"id":"6dec8b19add92278","type":"ui_button","z":"77e7721a33feed2f","name":"6","group":"1986e55c86514c11","order":27,"width":2,"height":2,"passthru":false,"label":"6","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"6","payloadType":"num","topic":"","topicType":"str","x":770,"y":100,"wires":[["7e94452d0d0835a6"]]},{"id":"c2095de8d90189f5","type":"ui_button","z":"77e7721a33feed2f","name":"9","group":"1986e55c86514c11","order":34,"width":2,"height":2,"passthru":false,"label":"9","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"9","payloadType":"num","topic":"tasmota/IRRemote/cmnd/IRsend","topicType":"str","x":770,"y":140,"wires":[["7e94452d0d0835a6"]]},{"id":"7e94452d0d0835a6","type":"link out","z":"77e7721a33feed2f","name":"link out 9","mode":"link","links":["d654a82cd7d5cbe5"],"x":885,"y":100,"wires":[]},{"id":"a1581f04f84bacaa","type":"ui_button","z":"77e7721a33feed2f","name":"up","group":"e22e9fa17b0cd1e3","order":2,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-arrow-up  fa-2x","payload":"up","payloadType":"str","topic":"","topicType":"str","x":230,"y":240,"wires":[["d11d81146a37c342"]]},{"id":"03ceb7fabd832b2f","type":"ui_button","z":"77e7721a33feed2f","name":"down","group":"e22e9fa17b0cd1e3","order":14,"width":2,"height":2,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"fa-arrow-down  fa-2x","payload":"down","payloadType":"str","topic":"tasmota/IRRemote/cmnd/IRsend","topicType":"str","x":230,"y":320,"wires":[["d11d81146a37c342"]]},{"id":"18647e34ab1c5526","type":"comment","z":"77e7721a33feed2f","name":"1. Enter IP","info":"","x":540,"y":480,"wires":[]},{"id":"53d14df78578548a","type":"comment","z":"77e7721a33feed2f","name":"1. Enter IP","info":"","x":540,"y":580,"wires":[]},{"id":"81e43c17ed7e10e4","type":"comment","z":"77e7721a33feed2f","name":"1. Enter IP","info":"","x":540,"y":680,"wires":[]},{"id":"9c796ccbd84cd448","type":"comment","z":"77e7721a33feed2f","name":"1. Enter IP","info":"","x":220,"y":380,"wires":[]},{"id":"0a896b2254f40557","type":"comment","z":"77e7721a33feed2f","name":"2. Wake FireTV","info":"","x":180,"y":480,"wires":[]},{"id":"535a7b72bdd8e7e1","type":"comment","z":"77e7721a33feed2f","name":"3. Request PIN, will be displayed on FireTV","info":"","x":260,"y":580,"wires":[]},{"id":"9c09b47d08f8189e","type":"comment","z":"77e7721a33feed2f","name":"6. Get Token","info":"","x":730,"y":680,"wires":[]},{"id":"5c70cc3976a2fc6a","type":"comment","z":"77e7721a33feed2f","name":"4. Enter PIN","info":"","x":170,"y":680,"wires":[]},{"id":"1a437c7a0872d1c5","type":"comment","z":"77e7721a33feed2f","name":"5. Request Token","info":"","x":180,"y":760,"wires":[]},{"id":"df46d088446b46b0","type":"debug","z":"77e7721a33feed2f","name":"Token","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":720,"wires":[]},{"id":"a48675e9e10e39c6","type":"comment","z":"77e7721a33feed2f","name":"7. Enter Token","info":"","x":350,"y":380,"wires":[]},{"id":"38665854958d1c7d","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":1,"width":4,"height":1},{"id":"c35060e06a382ade","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":3,"width":5,"height":1},{"id":"15ae905e2aef766c","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":4,"width":4,"height":1},{"id":"e8083b49c82c7537","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":5,"width":5,"height":1},{"id":"f2787aebac1be3d1","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":6,"width":2,"height":1},{"id":"6bdccf2aa57b0f90","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":10,"width":3,"height":1},{"id":"c8e5aa8090900915","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":11,"width":2,"height":1},{"id":"0769809814ccbce5","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":12,"width":3,"height":1},{"id":"0e5a96a1adc63da5","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":13,"width":4,"height":1},{"id":"441817e57cead728","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":15,"width":5,"height":1},{"id":"792a055b504043ea","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":16,"width":4,"height":1},{"id":"aecc44da41c46c00","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"e22e9fa17b0cd1e3","order":17,"width":5,"height":1},{"id":"0ba42eb1ccc36aa2","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":2,"width":2,"height":1},{"id":"27735d01702d8ce3","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":5,"width":2,"height":1},{"id":"cc8cb4e21d30af89","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":7,"width":2,"height":1},{"id":"a8ff0e88d29e2453","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":8,"width":2,"height":1},{"id":"311f22ce4cb163cb","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":9,"width":2,"height":1},{"id":"1e0e39bda449c5dc","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":14,"width":2,"height":1},{"id":"4dd954a65274844b","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":15,"width":2,"height":1},{"id":"79713482fa9705ba","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":16,"width":2,"height":1},{"id":"5a591e6e72c9a136","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":17,"width":3,"height":1},{"id":"455a3309900162b4","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":21,"width":3,"height":1},{"id":"6ed04198f06b4893","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":22,"width":3,"height":1},{"id":"c84daadb1278e7ca","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":23,"width":3,"height":1},{"id":"3077fd9dfd610927","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":24,"width":3,"height":1},{"id":"ab6136154859ddaa","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":28,"width":3,"height":1},{"id":"bc8d28a33d1f54b2","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":29,"width":3,"height":1},{"id":"c9f8f0e51455ce54","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":30,"width":3,"height":1},{"id":"892f6e2ebe7f0f8a","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":31,"width":3,"height":1},{"id":"ed55ef8124e08c03","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":35,"width":3,"height":1},{"id":"7027c4bb898e267f","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":36,"width":3,"height":1},{"id":"1d2cc11ee524e588","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":37,"width":3,"height":1},{"id":"ed819363337bc70d","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":38,"width":5,"height":1},{"id":"449f15a64617baf8","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":40,"width":5,"height":1},{"id":"26955f267d5cc75e","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":41,"width":5,"height":1},{"id":"d21d3642925cc1e2","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":42,"width":5,"height":1},{"id":"5c0cba03a6b9cbfe","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":43,"width":2,"height":1},{"id":"51a5d0f3d36d4cf0","type":"ui_spacer","z":"77e7721a33feed2f","name":"spacer","group":"1986e55c86514c11","order":45,"width":2,"height":1},{"id":"1986e55c86514c11","type":"ui_group","name":"firetv","tab":"d928bd0a6ef8ba5b","order":8,"disp":false,"width":"12","collapse":false,"className":""},{"id":"tls_f","type":"tls-config","name":"NoVerify","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":false,"alpnprotocol":""},{"id":"e22e9fa17b0cd1e3","type":"ui_group","name":"common","tab":"d928bd0a6ef8ba5b","order":2,"disp":false,"width":"11","collapse":false,"className":""},{"id":"d928bd0a6ef8ba5b","type":"ui_tab","name":"Remote","icon":"dashboard","order":2,"disabled":false,"hidden":false},{"id":"1bb7ee5d7af3b790","type":"global-config","env":[],"modules":{"node-red-dashboard":"3.6.6"}}]
Created 10 months, 2 weeks ago
Updated 6 months ago
  • change (x2)
  • comment (x10)
  • function (x3)
  • http request (x4)
  • inject (x3)
  • link in (x1)
  • link out (x4)
  • switch (x1)
  • tls-config (x1)
  • global-config (x1)
  • ui_button (x23)
  • ui_group (x2)
  • ui_spacer (x38)
  • ui_text_input (x1)
  • firetv
  • remote
  • API
