Marin Pegel
Marin
[{"id":"3fbffdd2.2dd6f2","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"ae8e7ee1.81566","type":"telegram bot","z":"","botname":"Limmat Pegel","usernames":"","chatids":"128208662, 569102853","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"verboselogging":false},{"id":"a0eea0.10b2716","type":"http request","z":"3fbffdd2.2dd6f2","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.hydrodaten.admin.ch/de/2243.html","tls":"","proxy":"","authType":"","x":350,"y":380,"wires":[["3fb8d146.bc32ce"]]},{"id":"3f6bdb23.4accb4","type":"debug","z":"3fbffdd2.2dd6f2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":455,"y":274,"wires":[]},{"id":"a22eb13c.29082","type":"inject","z":"3fbffdd2.2dd6f2","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":143,"y":254,"wires":[["a0eea0.10b2716"]]},{"id":"3fb8d146.bc32ce","type":"html","z":"3fbffdd2.2dd6f2","name":"","property":"payload","outproperty":"payload","tag":"tr","ret":"html","as":"single","x":350,"y":460,"wires":[["d0c5b49a.d66e88"]]},{"id":"d0c5b49a.d66e88","type":"function","z":"3fbffdd2.2dd6f2","name":"","func":"msg.payload = msg.payload[1];\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":540,"wires":[["cbd0de49.8fc75"]]},{"id":"cbd0de49.8fc75","type":"html","z":"3fbffdd2.2dd6f2","name":"","property":"payload","outproperty":"payload","tag":"td","ret":"html","as":"single","x":670,"y":360,"wires":[["23507071.66ddc","abae1538.0a6808"]]},{"id":"23507071.66ddc","type":"function","z":"3fbffdd2.2dd6f2","name":"","func":"msg.payload = {\n content: msg.payload[0],\n chatId: 569102853,\n type: \"message\"\n};\n\n\n//msg.payload.content = msg.payload[1];\n//msg.paylaod.chatId = 128208662;\n//msg.payload.type = \"message\";\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":440,"wires":[["79e95323.59294c","abae1538.0a6808"]]},{"id":"79e95323.59294c","type":"telegram sender","z":"3fbffdd2.2dd6f2","name":"","bot":"ae8e7ee1.81566","x":891.5,"y":495,"wires":[[]]},{"id":"500f7e16.1cd08","type":"telegram receiver","z":"3fbffdd2.2dd6f2","name":"","bot":"ae8e7ee1.81566","saveDataDir":"","x":386.5,"y":94,"wires":[["9fc19b6c.af83d8"],[]]},{"id":"9fc19b6c.af83d8","type":"debug","z":"3fbffdd2.2dd6f2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":642.5,"y":92,"wires":[]},{"id":"404d3d29.deb534","type":"telegram command","z":"3fbffdd2.2dd6f2","name":"","command":"/pegel","bot":"ae8e7ee1.81566","strict":false,"x":119.5,"y":324,"wires":[["a0eea0.10b2716","3f6bdb23.4accb4"],[]]},{"id":"abae1538.0a6808","type":"debug","z":"3fbffdd2.2dd6f2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":854.5,"y":292,"wires":[]},{"id":"9948452.6b543b8","type":"http request","z":"3fbffdd2.2dd6f2","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.hydrodaten.admin.ch/de/2243.html","tls":"","proxy":"","authType":"","x":360,"y":810,"wires":[["a98e22cf.eb4f8"]]},{"id":"bef4bca8.cca84","type":"debug","z":"3fbffdd2.2dd6f2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":465,"y":704,"wires":[]},{"id":"70b09790.313938","type":"inject","z":"3fbffdd2.2dd6f2","name":"","topic":"","payload":"","payloadType":"date","repeat":"3600","crontab":"","once":true,"onceDelay":0.1,"x":165,"y":653,"wires":[["9948452.6b543b8","bef4bca8.cca84"]]},{"id":"a98e22cf.eb4f8","type":"html","z":"3fbffdd2.2dd6f2","name":"","property":"payload","outproperty":"payload","tag":"tr","ret":"html","as":"single","x":360,"y":890,"wires":[["b7a13add.882518"]]},{"id":"b7a13add.882518","type":"function","z":"3fbffdd2.2dd6f2","name":"","func":"msg.payload = msg.payload[1];\nreturn msg;","outputs":1,"noerr":0,"x":360,"y":970,"wires":[["c1d837c0.2c68e8"]]},{"id":"c1d837c0.2c68e8","type":"html","z":"3fbffdd2.2dd6f2","name":"","property":"payload","outproperty":"payload","tag":"td","ret":"html","as":"single","x":680,"y":790,"wires":[["229fa8aa.aa9dd8"]]},{"id":"229fa8aa.aa9dd8","type":"function","z":"3fbffdd2.2dd6f2","name":"","func":"msg.payload = {\n content: \"Pegel zwischen 85 und 135 und zwar: \" + msg.payload[0],\n chatId: 569102853, \n type: \"message\",\n pegel: msg.payload[0]\n};\n\n\n//msg.payload.content = msg.payload[1];\n//msg.paylaod.chatId = 128208662;\n//msg.payload.type = \"message\";\nreturn msg;","outputs":1,"noerr":0,"x":700,"y":870,"wires":[["46971076.101ab"]]},{"id":"b1704aa4.bdd7e8","type":"telegram sender","z":"3fbffdd2.2dd6f2","name":"","bot":"ae8e7ee1.81566","x":1309.5,"y":920,"wires":[[]]},{"id":"78bbadd7.2f5054","type":"telegram command","z":"3fbffdd2.2dd6f2","name":"","command":"/pegel","bot":"ae8e7ee1.81566","strict":false,"x":129.5,"y":754,"wires":[["9948452.6b543b8"],[]]},{"id":"70d72e8b.74c51","type":"switch","z":"3fbffdd2.2dd6f2","name":"","property":"payload.pegel","propertyType":"msg","rules":[{"t":"btwn","v":"85","vt":"num","v2":"135","v2t":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1109.5,"y":906,"wires":[["b1704aa4.bdd7e8"]]},{"id":"46971076.101ab","type":"delay","z":"3fbffdd2.2dd6f2","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"6","rateUnits":"hour","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":889.5,"y":903,"wires":[["70d72e8b.74c51"]]},{"id":"8e6c2c29.b88f7","type":"http request","z":"3fbffdd2.2dd6f2","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.hydrodaten.admin.ch/de/2243.html","tls":"","proxy":"","authType":"","x":306.5,"y":1185,"wires":[["1f103d82.ee11c2"]]},{"id":"82a3c53a.e6cf68","type":"debug","z":"3fbffdd2.2dd6f2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":411.5,"y":1079,"wires":[]},{"id":"5cb506a1.991ed8","type":"inject","z":"3fbffdd2.2dd6f2","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":101.5,"y":1028,"wires":[["8e6c2c29.b88f7","82a3c53a.e6cf68"]]},{"id":"1f103d82.ee11c2","type":"html","z":"3fbffdd2.2dd6f2","name":"","property":"payload","outproperty":"payload","tag":"tr","ret":"html","as":"single","x":306.5,"y":1265,"wires":[["6e5a585c.902af8"]]},{"id":"6e5a585c.902af8","type":"function","z":"3fbffdd2.2dd6f2","name":"","func":"msg.payload = msg.payload[1];\nreturn msg;","outputs":1,"noerr":0,"x":306.5,"y":1345,"wires":[["7a72dc16.f69004"]]},{"id":"7a72dc16.f69004","type":"html","z":"3fbffdd2.2dd6f2","name":"","property":"payload","outproperty":"payload","tag":"td","ret":"html","as":"single","x":626.5,"y":1165,"wires":[["f2dd07cd.f83608"]]},{"id":"f2dd07cd.f83608","type":"function","z":"3fbffdd2.2dd6f2","name":"","func":"msg.payload = {\n content: \"Pegel zwischen 85 und 135 und zwar: \" + msg.payload[0],\n chatId: 128208662, \n type: \"message\",\n pegel: msg.payload[0]\n};\n\n\n//msg.payload.content = msg.payload[1];\n//msg.paylaod.chatId = 128208662;\n//msg.payload.type = \"message\";\nreturn msg;","outputs":1,"noerr":0,"x":646.5,"y":1245,"wires":[["dc831d0.fb61be"]]},{"id":"4d939b8b.2a74d4","type":"telegram sender","z":"3fbffdd2.2dd6f2","name":"","bot":"ae8e7ee1.81566","x":1256,"y":1295,"wires":[[]]},{"id":"5236819a.be55c","type":"telegram command","z":"3fbffdd2.2dd6f2","name":"","command":"/pegel","bot":"ae8e7ee1.81566","strict":false,"x":76,"y":1129,"wires":[["8e6c2c29.b88f7"],[]]},{"id":"b7fa567d.bb2be8","type":"switch","z":"3fbffdd2.2dd6f2","name":"","property":"payload.pegel","propertyType":"msg","rules":[{"t":"btwn","v":"85","vt":"num","v2":"135","v2t":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1056,"y":1281,"wires":[["4d939b8b.2a74d4"]]},{"id":"dc831d0.fb61be","type":"delay","z":"3fbffdd2.2dd6f2","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":846,"y":1278,"wires":[["b7fa567d.bb2be8"]]}]
