How to Integrate REYAX RYLR998 LoRa Transceiver Module with Node-RED | Flow For 1st RYLR998 LoRa Transceiver |
[{"id":"e1bcf0d41adb6ac3","type":"tab","label":"RYLR998 - 1","disabled":false,"info":"","env":[]},{"id":"8d7199e9.55e978","type":"debug","z":"e1bcf0d41adb6ac3","name":"RYLR998 Response Out","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":450,"y":60,"wires":[]},{"id":"6b7a2b6a.740544","type":"serial in","z":"e1bcf0d41adb6ac3","name":"Response from RYLR998 -  1","serial":"f280def6d07e3260","x":200,"y":60,"wires":[["8d7199e9.55e978"]]},{"id":"874482becea7b625","type":"inject","z":"e1bcf0d41adb6ac3","name":"Check RYLR998 -  1 Module","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT","payloadType":"str","x":220,"y":140,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"c6bb63c68e9da1bb","type":"inject","z":"e1bcf0d41adb6ac3","name":"Get RYLR998 -  1 Address","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+ADDRESS?","payloadType":"str","x":230,"y":180,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"5503a23458199bf6","type":"inject","z":"e1bcf0d41adb6ac3","name":"Get RYLR998 -  1 NetworkID","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+NETWORKID?","payloadType":"str","x":220,"y":220,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"dfc3cdde208df2f0","type":"inject","z":"e1bcf0d41adb6ac3","name":"Get RYLR998 -  1 Band","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+BAND?","payloadType":"str","x":240,"y":260,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"a415922ca097587c","type":"inject","z":"e1bcf0d41adb6ac3","name":"Check RYLR998 -  1 Last Payload","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+SEND?","payloadType":"str","x":210,"y":300,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"a00630ab36f9ff6d","type":"serial out","z":"e1bcf0d41adb6ac3","name":"Send Commands to RYLR998 - 1 Board","serial":"f280def6d07e3260","x":640,"y":280,"wires":[]},{"id":"75f1fd835b61d937","type":"inject","z":"e1bcf0d41adb6ac3","name":"Set RYLR998 - 1 Address to 1","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+ADDRESS=1","payloadType":"str","x":220,"y":420,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"d5a7dc12d99c79f8","type":"inject","z":"e1bcf0d41adb6ac3","name":"Set RYLR998 - 1 NetworkID","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+NETWORKID=5","payloadType":"str","x":220,"y":460,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"15208ed43423f224","type":"inject","z":"e1bcf0d41adb6ac3","name":"Set RYLR998 - 1 Band","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+BAND=915000000","payloadType":"str","x":240,"y":380,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"bdbc4a6547a9e5ae","type":"function","z":"e1bcf0d41adb6ac3","name":"Function","func":"msg.payload += Buffer.from(\"0D0A\", \"hex\");\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":240,"wires":[["a00630ab36f9ff6d"]]},{"id":"a04dfc4cc988af3c","type":"inject","z":"e1bcf0d41adb6ac3","name":"Send Payload to 1 from 2","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AT+SEND=2,6,FUSION","payloadType":"str","x":230,"y":540,"wires":[["bdbc4a6547a9e5ae"]]},{"id":"f280def6d07e3260","type":"serial-port","name":"RYLR998 - 1","serialport":"COM4","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"\\n","bin":"false","out":"char","addchar":"","responsetimeout":"10000"}]
Created 8 months ago
  • inject (x9)
  • serial in (x1)
  • serial out (x1)
  • serial-port (x1)
