Turn off & Reboot Raspberry Pi from Dashboard - Apagar y Reiniciar desde Dashboard
Set of nodes to shut down the Raspberry from the Dashboard, using warning signs.
Set de nodos que permiten mostrar opciones de apagado y reinicio de la Raspberry Pi desde el Dashboard, mostrando mensaje de confirmación.
[{"id":"2b277841.d47e58","type":"inject","z":"7f137852.8b9328","name":"","topic":"","payload":"sudo reboot","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":590,"y":140,"wires":[["5f42b30b.baefac"]]},{"id":"5f42b30b.baefac","type":"exec","z":"7f137852.8b9328","command":"sudo reboot now","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":910,"y":140,"wires":[[],[],[]]},{"id":"c7dc3767.abafd8","type":"inject","z":"7f137852.8b9328","name":"","topic":"","payload":"sudo halt","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":580,"y":191.25000190734863,"wires":[["6ea70a47.2ae674"]]},{"id":"251b557b.e61f7a","type":"link in","z":"7f137852.8b9328","name":"sistema-reiniciar","links":["6a520e15.ac8b1"],"x":735,"y":140,"wires":[["5f42b30b.baefac"]]},{"id":"68f0bf15.0668","type":"comment","z":"7f137852.8b9328","name":"Básicas ","info":"","x":550,"y":80,"wires":[]},{"id":"6ea70a47.2ae674","type":"exec","z":"7f137852.8b9328","command":"sudo halt","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":900,"y":191.25000190734863,"wires":[[],[],[]]},{"id":"91876530.101f28","type":"link in","z":"7f137852.8b9328","name":"sistema-apagar","links":["b30fea42.8f09c8","cdf0abde.c1eb28"],"x":735,"y":191.25000190734863,"wires":[["6ea70a47.2ae674"]]},{"id":"cbb36376.c561c","type":"ui_button","z":"7f137852.8b9328","name":"","group":"5236b089.d4c8b","order":0,"width":0,"height":0,"passthru":false,"label":"Apagar","tooltip":"","color":"","bgcolor":"","icon":"","payload":"¿Apagar?","payloadType":"str","topic":"","x":100,"y":140,"wires":[["2bf2cc62.b20d14"]]},{"id":"814cc8d0.e42f98","type":"link out","z":"7f137852.8b9328","name":"from-ui-apagar","links":["91bf57d9.5736c8"],"x":415,"y":140,"wires":[]},{"id":"c7a4dd1a.ef02e","type":"ui_button","z":"7f137852.8b9328","name":"","group":"5236b089.d4c8b","order":0,"width":0,"height":0,"passthru":false,"label":"Reiniciar","tooltip":"","color":"","bgcolor":"","icon":"","payload":"¿Reiniciar?","payloadType":"str","topic":"","x":100,"y":180,"wires":[["b2d323f.56ae5e"]]},{"id":"dcb8e334.c4f29","type":"comment","z":"7f137852.8b9328","name":"Básicos","info":"","x":90,"y":80,"wires":[]},{"id":"2bf2cc62.b20d14","type":"ui_toast","z":"7f137852.8b9328","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":270,"y":140,"wires":[["814cc8d0.e42f98"]]},{"id":"3fef1992.0aabb6","type":"link out","z":"7f137852.8b9328","name":"from-ui-reiniciar","links":["cb98fd1d.23657"],"x":415,"y":180,"wires":[]},{"id":"b2d323f.56ae5e","type":"ui_toast","z":"7f137852.8b9328","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":270,"y":180,"wires":[["3fef1992.0aabb6"]]},{"id":"5236b089.d4c8b","type":"ui_group","name":"Apagar","tab":"22cd6119.2672ae","order":1,"disp":true,"width":"6","collapse":false},{"id":"22cd6119.2672ae","type":"ui_tab","name":"Sistema","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
Created 5 years, 4 months ago
  • comment (x2)
  • exec (x2)
  • inject (x2)
  • link in (x2)
  • link out (x2)
  • ui_button (x2)
  • ui_group (x1)
  • ui_toast (x2)
  • Inventoteca
  • VAPRI
  • RaspberryPi
  • Halt
  • TurnOff
