DEMO: multiple devices (pickable via a dropdown) feeding single gauge
Prerequisites: this flow uses node-red-contrib-random
This is a simple demo showing how you could have a single dashboard page with one gauge and a dropdown that is used to select which device is sending data to the gauge.
The three devices are simulated with inject nodes connected to random nodes connected to a change node that sets msg.topic to the unique device name. The random node for device 1 generates numbers between 1 and 10, the random node for device 2 generates numbers between 11 and 21, the random node for device 3 generates numbers between 20 and 31.
The msg from all three devices are then passed to a switch node that checks the msg.topic against a flow variable that is initialized to device1 and is changed by selecting a device from the dropdown. Only msgs that match are passed on.
The gauge displays numbers between 0-10 will display in the green color range, 11-20 in the yellow range and 21-30 in the red color range to give a visual clue to which device is reporting the data along with the label of the gauge changing to the device number.
multi-device-gauge-demo
[{"id":"13170589.bf6fd2","type":"tab","label":"Multi device-gauge ","disabled":false,"info":""},{"id":"7b531c11.f67024","type":"inject","z":"13170589.bf6fd2","name":"Device 1","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":300,"wires":[["a83780c5.b055e8"]]},{"id":"a308ede3.ab1868","type":"inject","z":"13170589.bf6fd2","name":"Device 2","topic":"","payload":"","payloadType":"date","repeat":"2","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":340,"wires":[["160d3204.08c70e"]]},{"id":"1c3da3c1.1f22a4","type":"inject","z":"13170589.bf6fd2","name":"Device 3","topic":"","payload":"","payloadType":"date","repeat":"3","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":380,"wires":[["eb872888.48fd4"]]},{"id":"738911c4.73b9d","type":"change","z":"13170589.bf6fd2","name":"topic = \"device1\"","rules":[{"t":"set","p":"topic","pt":"msg","to":"device1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":300,"wires":[["b9a84f61.ebdef8"]]},{"id":"3fb16384.6742dc","type":"change","z":"13170589.bf6fd2","name":"topic = \"device2\"","rules":[{"t":"set","p":"topic","pt":"msg","to":"device2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":340,"wires":[["b9a84f61.ebdef8"]]},{"id":"a24359b7.98ef48","type":"change","z":"13170589.bf6fd2","name":"topic = \"device3\"","rules":[{"t":"set","p":"topic","pt":"msg","to":"device3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":380,"wires":[["b9a84f61.ebdef8"]]},{"id":"44db16e6.dc6e18","type":"ui_dropdown","z":"13170589.bf6fd2","name":"","label":"","tooltip":"","place":"Select option","group":"48cfdbc6.f90534","order":2,"width":0,"height":0,"passthru":true,"options":[{"label":"Device 1","value":"device1","type":"str"},{"label":"Device 2","value":"device2","type":"str"},{"label":"Device 3","value":"device3","type":"str"}],"payload":"","topic":"","x":110,"y":480,"wires":[["a63e3ed2.d8549"]]},{"id":"a63e3ed2.d8549","type":"change","z":"13170589.bf6fd2","name":"topic = msg.payload","rules":[{"t":"set","p":"device","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":304,"y":479,"wires":[[]]},{"id":"cf58110c.4440c","type":"ui_gauge","z":"13170589.bf6fd2","name":"","group":"48cfdbc6.f90534","order":1,"width":0,"height":0,"gtype":"gage","title":"{{msg.topic}}","label":"units","format":"{{value}}","min":0,"max":"30","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":930,"y":340,"wires":[]},{"id":"b9a84f61.ebdef8","type":"switch","z":"13170589.bf6fd2","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"device","vt":"flow"},{"t":"eq","v":"device","vt":"flow"},{"t":"eq","v":"device","vt":"flow"}],"checkall":"true","repair":false,"outputs":3,"x":650,"y":340,"wires":[["cf58110c.4440c","f6cd1dc7.a4f808"],["cf58110c.4440c","7d69424f.e79c24"],["cf58110c.4440c","5551adfd.26e7c4"]]},{"id":"b552a78.116b258","type":"inject","z":"13170589.bf6fd2","name":"initilize the flow variable \"device\"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":200,"y":220,"wires":[["1fd4d6db.4555a1"]]},{"id":"1fd4d6db.4555a1","type":"change","z":"13170589.bf6fd2","name":"topic = \"device1\"","rules":[{"t":"set","p":"device","pt":"flow","to":"device1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":220,"wires":[[]]},{"id":"5551adfd.26e7c4","type":"debug","z":"13170589.bf6fd2","name":"DEBUG: Device 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":730,"y":500,"wires":[]},{"id":"7d69424f.e79c24","type":"debug","z":"13170589.bf6fd2","name":"DEBUG: Device 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":730,"y":460,"wires":[]},{"id":"f6cd1dc7.a4f808","type":"debug","z":"13170589.bf6fd2","name":"DEBUG: Device 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":730,"y":420,"wires":[]},{"id":"a83780c5.b055e8","type":"random","z":"13170589.bf6fd2","name":"random  1-10","low":"1","high":"10","inte":"true","property":"payload","x":270,"y":300,"wires":[["738911c4.73b9d"]]},{"id":"160d3204.08c70e","type":"random","z":"13170589.bf6fd2","name":"random 11-20","low":"11","high":"20","inte":"true","property":"payload","x":280,"y":340,"wires":[["3fb16384.6742dc"]]},{"id":"eb872888.48fd4","type":"random","z":"13170589.bf6fd2","name":"random 21-30","low":"21","high":"30","inte":"true","property":"payload","x":280,"y":380,"wires":[["a24359b7.98ef48"]]},{"id":"a6e5289c.ef0c8","type":"comment","z":"13170589.bf6fd2","name":"initilize flow variable at deploy","info":"","x":160,"y":180,"wires":[]},{"id":"10781d93.540e2a","type":"comment","z":"13170589.bf6fd2","name":"This section simulates data coming from three devices","info":"","x":240,"y":260,"wires":[]},{"id":"fa1f44f4.f1c948","type":"comment","z":"13170589.bf6fd2","name":"the switch determines which data goes to the gauge","info":"","x":790,"y":300,"wires":[]},{"id":"29195282.9ba90e","type":"comment","z":"13170589.bf6fd2","name":"Dropdown to pick device to monitor","info":"","x":180,"y":440,"wires":[]},{"id":"f98827b5.2c2f6","type":"comment","z":"13170589.bf6fd2","name":"This flow demonstrate how three devices could send data to a single gauge","info":"","x":310,"y":40,"wires":[]},{"id":"8cc5fca3.17512","type":"comment","z":"13170589.bf6fd2","name":"The devices send random data in groups to trigger the gauge's color","info":"","x":280,"y":80,"wires":[]},{"id":"7bb7e4fc.66bf0c","type":"comment","z":"13170589.bf6fd2","name":"Device 1 : 1-10 (green) - Device 2 : 11-20 (yellow) - Device 3 : 21-30 (red)","info":"","x":300,"y":120,"wires":[]},{"id":"48cfdbc6.f90534","type":"ui_group","z":"","name":"Dynamic device gauge Picker","tab":"10fce37c.85a72d","order":2,"disp":true,"width":"6","collapse":false},{"id":"10fce37c.85a72d","type":"ui_tab","name":"Tab 3","icon":"dashboard","order":1}]
Created 8 years, 1 month ago
  • change (x5)
  • comment (x7)
  • debug (x3)
  • inject (x4)
  • switch (x1)
  • multiple
  • devices
  • single
  • dashboard
  • page
  • selectable
