OpenHAB2 - Wake on LAN
A simple Flow to turn your computer on and off.
[{"id":"cfec2aea.b49c68","type":"tab","label":"Wake On LAN","disabled":false,"info":""},{"id":"6f8aea70.5e3c04","type":"openhab2-in","z":"cfec2aea.b49c68","name":"","controller":"f30862a6.34bc8","itemname":"LucaPC","x":82.10000228881836,"y":50.60000228881836,"wires":[["8b645f4d.df1b9"],[]]},{"id":"8b645f4d.df1b9","type":"rbe","z":"cfec2aea.b49c68","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":240.10000610351562,"y":43,"wires":[["de577e47.dac4b"]]},{"id":"de577e47.dac4b","type":"switch","z":"cfec2aea.b49c68","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":390.1000518798828,"y":100.00000190734863,"wires":[["8ccb7dee.24409"],["d84b171a.884408"]]},{"id":"8ccb7dee.24409","type":"wake on lan","z":"cfec2aea.b49c68","mac":"MAC ADRESSE","host":"192.168.32.255","name":"Luca-PC","x":589.1000366210938,"y":63.600006103515625,"wires":[]},{"id":"d84b171a.884408","type":"exec","z":"cfec2aea.b49c68","command":"net rpc shutdown -C OpenHAB -I 192.168.32.85 -U USERNAME%PASSWORD -f -t 120","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":568.1000518798828,"y":212.10000610351562,"wires":[[],[],[]]},{"id":"513ff420.7ed12c","type":"ping","z":"cfec2aea.b49c68","name":"","host":"192.168.32.85","timer":"60","x":93.10000610351562,"y":358.60000801086426,"wires":[["9a6845b3.e785c8","887f93f.6dcbd7"]]},{"id":"9a6845b3.e785c8","type":"debug","z":"cfec2aea.b49c68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":173.10000228881836,"y":467.00000762939453,"wires":[]},{"id":"887f93f.6dcbd7","type":"rbe","z":"cfec2aea.b49c68","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":321.1000556945801,"y":358.00000762939453,"wires":[["8a541adb.310048"]]},{"id":"8a541adb.310048","type":"switch","z":"cfec2aea.b49c68","name":"","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"number","vt":"number"},{"t":"istype","v":"boolean","vt":"boolean"}],"checkall":"true","repair":false,"outputs":2,"x":457.10008239746094,"y":412.0000057220459,"wires":[["e310ef06.301ea"],["ea05ea4.7f07018"]]},{"id":"e310ef06.301ea","type":"openhab2-out","z":"cfec2aea.b49c68","name":"","controller":"f30862a6.34bc8","itemname":"LucaPC","topic":"ItemCommand","payload":"ON","x":612.1000556945801,"y":364.0000057220459,"wires":[[]]},{"id":"ea05ea4.7f07018","type":"openhab2-out","z":"cfec2aea.b49c68","name":"","controller":"f30862a6.34bc8","itemname":"LucaPC","topic":"ItemCommand","payload":"OFF","x":611.1000556945801,"y":448.0000057220459,"wires":[[]]},{"id":"f30862a6.34bc8","type":"openhab2-controller","z":"","name":"OpenHAB2","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""}]
Created 6 years, 10 months ago
  • exec (x1)
  • rbe (x2)
  • switch (x2)
  • Wake
  • on
  • LAN
  • Shutdown
  • over
