Daily Motivational Telegram Message
What it does
This flow uses a http GET request at 11am daily to get a random quote from https://type.fit/api/quotes.
The quote is displayed on the NodeRED dashboard as well as sent to phone via the Telegram Bot
What Needs Modified for you to run
  1. The Telegram Sender Node needs to have the BOT configuration field filled in
  2. Your ChatID needs to be set in the Change Node
  3. Your Group needs to be set in the Dashboard Text Node
Contact
Alex Trostle - GitHub - Email - LinkedIn - Instagram - My Website
Buy Me A Coffee
Check out my NodeRED template for creating your own flows: https://gist.github.com/Alextros00/57903819eef31f4beaa4cd24c9d57865
[{"id":"877abdbd.80d6e","type":"comment","z":"f0403142.05187","g":"cbea36fe.113488","name":"Use an API to disply a motivational quote to the motivation tab","info":"","x":320,"y":2900,"wires":[]},{"id":"f04fd779.cea4c8","type":"inject","z":"f0403142.05187","g":"cbea36fe.113488","name":"At 11:00am","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 11 * * *","once":false,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":170,"y":2940,"wires":[["b031a18e.59b03"]]},{"id":"b031a18e.59b03","type":"http request","z":"f0403142.05187","g":"cbea36fe.113488","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://type.fit/api/quotes","tls":"","persist":false,"proxy":"","authType":"","x":330,"y":2940,"wires":[["e6a4d14d.ce6a8"]]},{"id":"e6a4d14d.ce6a8","type":"function","z":"f0403142.05187","g":"cbea36fe.113488","name":"","func":"msg.payload = msg.payload[getRndInteger(0,1642)];\nreturn msg;\n\n// this code gets a random interger\nfunction getRndInteger(min, max) {\n    return Math.floor(Math.random() * (max - min + 1) ) + min;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":480,"y":2940,"wires":[["94bfd95f.2c89a8","88378938.731448"]]},{"id":"94bfd95f.2c89a8","type":"ui_text","z":"f0403142.05187","g":"cbea36fe.113488","group":"cbe50c39.f38f1","order":1,"width":6,"height":3,"name":"Daily Quote from https://type.fit/api/quotes","label":"text","format":"{{msg.payload.text}}","layout":"col-center","x":740,"y":2940,"wires":[]},{"id":"88378938.731448","type":"change","z":"f0403142.05187","g":"cbea36fe.113488","name":"set","rules":[{"t":"delete","p":"_msgid","pt":"msg"},{"t":"move","p":"payload.text","pt":"msg","to":"payload.content","tot":"msg"},{"t":"delete","p":"payload.author","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"delete","p":"statusCode","pt":"msg"},{"t":"delete","p":"headers","pt":"msg"},{"t":"delete","p":"responseUrl","pt":"msg"},{"t":"delete","p":"redirectList","pt":"msg"},{"t":"delete","p":"responseCookies","pt":"msg"},{"t":"set","p":"payload.chatId","pt":"msg","to":"","tot":"str"},{"t":"set","p":"payload.type","pt":"msg","to":"message","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":2900,"wires":[["fdd86dc2.a28f2"]]},{"id":"fdd86dc2.a28f2","type":"telegram sender","z":"f0403142.05187","g":"cbea36fe.113488","name":"","bot":"","haserroroutput":false,"outputs":1,"x":810,"y":2900,"wires":[[]]},{"id":"cbe50c39.f38f1","type":"ui_group","z":"","name":"Quote","tab":"27a5131.81170ec","order":2,"disp":true,"width":6,"collapse":false},{"id":"27a5131.81170ec","type":"ui_tab","z":"","name":"Motivation","icon":"dashboard","disabled":false,"hidden":false}]
Created 4 years, 10 months ago
  • change (x1)
  • http request (x1)
  • Telegram
  • Home-Automation
  • Motivation
  • GET-Request
