Crypto-Blue: Password key Derivation Function Node
The PKDF node is used to used for generating and recreating encryption keys. The following properties can be configured for the node:
  • Iterations (number): Define the number of iterations to perform for the key derivation function. This can also be configured through the msg.iterations field of an injected message.
  • Key Size: The key size to generate, options include 128 bit, 192 bit, 256 bit.
  • Salt Size: The size of the salt to use, options include 128 bit, 192 bit, 256 bit.
  • Salt (string): The salt to use for the key derivation function, must be in hex format. This can also be configured through the msg.salt field of an injected message.
  • Password (string): The password to use in the key derivation function. This can also be configured through the msg.password field of an injected message.
[{"id":"b5d796b9e6213bd8","type":"inject","z":"d4703d9e2676369d","name":"PKDF Injector","props":[{"p":"password","v":"MySecretPassword","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":540,"wires":[["3da33a90d6b838a5"]]},{"id":"3da33a90d6b838a5","type":"pkdf","z":"d4703d9e2676369d","name":"Generate Encryption Key","keySize":"16","iterations":"10","salt":"","saltSize":"16","password":"","x":410,"y":540,"wires":[["143cfa16f14be5d1","e1a3b98a756c2b90"]]},{"id":"143cfa16f14be5d1","type":"debug","z":"d4703d9e2676369d","name":"Print Payload Result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":720,"y":600,"wires":[]},{"id":"52edbee3c4a5a60f","type":"pkdf","z":"d4703d9e2676369d","name":"Recreate Encryption Key","keySize":"16","iterations":"10","salt":"73da2dd430730da44a7e82a2dc82cdbc","saltSize":"16","password":"","x":410,"y":660,"wires":[["143cfa16f14be5d1"]]},{"id":"e1a3b98a756c2b90","type":"change","z":"d4703d9e2676369d","name":"Set Salt to Recreate Key","rules":[{"t":"move","p":"payload.salt","pt":"msg","to":"salt","tot":"msg"},{"t":"set","p":"password","pt":"msg","to":"MySecretPassword","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":600,"wires":[["52edbee3c4a5a60f"]]}]
Collection Info
prev
Created 3 years, 5 months ago
  • change (x1)
  • crypto-blue
  • blue-sec
