Rachio Irrigation Controller Integration
Example that shows how to use your API credentials to get the irrigation "run schedule" - the results of "today's run" of the sprinkler system and display it in a table format on the Node-RED Dashboard.
Shows also how to build up Headers and credentials to send into an HTTP Node.
Several JSonata examples to build up URL's
API Docs here: https://support.rachio.com/en_us/public-api-documentation-S1UydL1Fv
[{"id":"ba27fd9a553910a2","type":"tab","label":"Rachio Irrigation","disabled":false,"info":"","env":[]},{"id":"1794093b36f0ea6a","type":"credentials","z":"ba27fd9a553910a2","name":"API Key","props":[{"value":"APIKey","type":"msg"}],"x":280,"y":240,"wires":[["c8a1dc9d7cd7aee7"]]},{"id":"68aa144663fd92de","type":"change","z":"ba27fd9a553910a2","name":"Get Person","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"url","pt":"msg","to":"https://api.rach.io/1/public/person/info","tot":"str"},{"t":"set","p":"method","pt":"msg","to":"GET","tot":"str"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"'Bearer ' & $.APIKey","tot":"jsonata"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":240,"wires":[["b88ddba08c4f573a"]]},{"id":"061c54f809b2fd72","type":"inject","z":"ba27fd9a553910a2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payloadType":"date","x":120,"y":240,"wires":[["1794093b36f0ea6a"]]},{"id":"c58145babfeea499","type":"debug","z":"ba27fd9a553910a2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":870,"y":80,"wires":[]},{"id":"27a800ddd3573fe4","type":"change","z":"ba27fd9a553910a2","name":"Store PersonID","rules":[{"t":"set","p":"PersonID","pt":"flow","to":"payload.id","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":160,"wires":[["b034c5cab1aadfbb","c58145babfeea499"]]},{"id":"b034c5cab1aadfbb","type":"change","z":"ba27fd9a553910a2","name":"Get Device ID","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"url","pt":"msg","to":"'https://api.rach.io/1/public/person/' & $.payload.id","tot":"jsonata"},{"t":"set","p":"method","pt":"msg","to":"GET","tot":"str"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"'Bearer ' & $.APIKey","tot":"jsonata"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1140,"y":240,"wires":[["d4fd11829089b30a"]]},{"id":"6b16956aa5725eb6","type":"change","z":"ba27fd9a553910a2","name":"Store DeviceID","rules":[{"t":"set","p":"DeviceID","pt":"flow","to":"payload.devices[0].id","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1520,"y":160,"wires":[["f6c146d94c87aaee"]]},{"id":"b88ddba08c4f573a","type":"http request","z":"ba27fd9a553910a2","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":810,"y":240,"wires":[["27a800ddd3573fe4"]]},{"id":"d4fd11829089b30a","type":"http request","z":"ba27fd9a553910a2","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":1330,"y":240,"wires":[["6b16956aa5725eb6"]]},{"id":"f6c146d94c87aaee","type":"debug","z":"ba27fd9a553910a2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1690,"y":240,"wires":[]},{"id":"b0d234e058b219a3","type":"change","z":"ba27fd9a553910a2","name":"Get today's events","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"url","pt":"msg","to":"'https://api.rach.io/1/public/device/' & $.DeviceID & '/event?startTime=' &\t $toMillis($now('[Y0001]-[M01]-[D01]T00:00:00.0')) & '&endTime=' & $toMillis($now())","tot":"jsonata"},{"t":"set","p":"method","pt":"msg","to":"GET","tot":"str"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"'Bearer ' & $.APIKey","tot":"jsonata"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":460,"wires":[["5684060f07152476"]]},{"id":"2c3ee6e0e0300fae","type":"debug","z":"ba27fd9a553910a2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":420,"wires":[]},{"id":"9e92e1883c4002d2","type":"inject","z":"ba27fd9a553910a2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"7200","crontab":"","once":true,"onceDelay":"5","topic":"","payloadType":"date","x":140,"y":460,"wires":[["6397b735bbba4954"]]},{"id":"6397b735bbba4954","type":"change","z":"ba27fd9a553910a2","name":"Get Globals","rules":[{"t":"set","p":"DeviceID","pt":"msg","to":"DeviceID","tot":"flow"},{"t":"set","p":"APIKey","pt":"msg","to":"APIKey","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":460,"wires":[["b0d234e058b219a3"]]},{"id":"5684060f07152476","type":"http request","z":"ba27fd9a553910a2","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":690,"y":460,"wires":[["2c3ee6e0e0300fae","fd6100a13e6d75b6"]]},{"id":"c8a1dc9d7cd7aee7","type":"change","z":"ba27fd9a553910a2","name":"Save API Key in Global","rules":[{"t":"set","p":"APIKey","pt":"flow","to":"APIKey","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":160,"wires":[["68aa144663fd92de"]]},{"id":"b5cefc6ba77161b7","type":"comment","z":"ba27fd9a553910a2","name":"Init globals we need later","info":"","x":160,"y":160,"wires":[]},{"id":"8c595693e05a3a59","type":"comment","z":"ba27fd9a553910a2","name":"Periodic check of events","info":"","x":180,"y":420,"wires":[]},{"id":"fd6100a13e6d75b6","type":"ui_template","z":"ba27fd9a553910a2","group":"87ec3d0c242f0c79","name":"","order":3,"width":"24","height":"20","format":"<head>\n    <style>\n    \ntr:nth-child(even) td {\n    background: black;\n    color: white;\n}\n\ntr:nth-child(odd) td {\n    background: lightgray;\n    color: black;\n}\n    </style>\n</head>\n\n<table>\n  <tr ng-repeat=\"obj in msg.payload\">\n    <td width=200>{{ obj.eventDate | date:'short' }}</td>\n    <td>{{ obj.subType }} </td>\n    <td>{{ obj.summary }}</td>\n  </tr>\n</table>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":860,"y":520,"wires":[[]]},{"id":"87ec3d0c242f0c79","type":"ui_group","name":"Sprinkler Log","tab":"7dacd1899a023c99","order":1,"disp":true,"width":"24","collapse":false,"className":""},{"id":"7dacd1899a023c99","type":"ui_tab","name":"Sprinkler System","icon":"wi-wu-chancerain","order":11,"disabled":false,"hidden":false}]
Created 3 years, 4 months ago
  • change (x7)
  • comment (x2)
  • debug (x3)
  • http request (x3)
  • inject (x2)
  • Irrigation
  • Rachio
  • JSonata
