Vehicle OBD2 with Torque
I first posted this to OpenHAB community here
OK here is the flow. the simple part is receiving the get. The HTTP in node splits out the data and the HTTP out node gives the “OK!” the torque app is looking for. I also have a write to MySQL to store the data. that can be removed if you only want to see it real time or have openHAB do the logging.
In torque under Settings > Data Logging and Upload
Select what to log = All the PID’s you want to sent to node-red
Upload to web server = checked
Webserver URL = http://your.nodered.server:1880/torque/
let me know if you have any more questions.
[{"id":"2ce0055.8743efa","type":"tab","label":"Torque","disabled":false,"info":""},{"id":"67436221.b54c0c","type":"http in","z":"2ce0055.8743efa","name":"","url":"/torque","method":"get","upload":true,"swaggerDoc":"","x":221,"y":143,"wires":[["f98f22cc.807ba","557d7766.022168","33d571b3.db242e","69b56cf.77bc694","683933fa.d76f1c","ab2ff853.e8b808","c005b8b1.f06b98","96abaa53.c70988","ee5bc723.594bf8","dfdc4763.7a8fd8","cee9fa09.98b6d8","f2d748c5.d92da8","936bc33f.bcd27","97ab65f2.1a0728"]]},{"id":"f98f22cc.807ba","type":"http response","z":"2ce0055.8743efa","name":"","statusCode":"","headers":{"OK!":""},"x":1290,"y":140,"wires":[]},{"id":"557d7766.022168","type":"change","z":"2ce0055.8743efa","name":"Barometer","rules":[{"t":"move","p":"payload.kff1270","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\phone\\barometer","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":731,"y":403,"wires":[["536ae3f0.1980dc","5ef6a21e.75ce4c"]]},{"id":"3b30fefa.3f9012","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"9b558fbc.438aa","order":1,"width":"6","height":"6","gtype":"gage","title":"RPM","label":"RPM","format":"{{value}}","min":0,"max":"7000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1061,"y":443,"wires":[]},{"id":"33d571b3.db242e","type":"change","z":"2ce0055.8743efa","name":"RPM","rules":[{"t":"move","p":"payload.kc","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\rpm","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":721,"y":443,"wires":[["3b30fefa.3f9012","5ef6a21e.75ce4c"]]},{"id":"69b56cf.77bc694","type":"change","z":"2ce0055.8743efa","name":"Mass Air Flow Rate","rules":[{"t":"move","p":"payload.k10","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\mafrate","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":761,"y":483,"wires":[["7ee21162.28cdb","5ef6a21e.75ce4c"]]},{"id":"683933fa.d76f1c","type":"change","z":"2ce0055.8743efa","name":"Throttle Position","rules":[{"t":"move","p":"payload.k11","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\throttle","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":751,"y":523,"wires":[["3765c6b.fb70f3a","5ef6a21e.75ce4c"]]},{"id":"ab2ff853.e8b808","type":"change","z":"2ce0055.8743efa","name":"Coolant Temp","rules":[{"t":"move","p":"payload.k5","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\coolant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":741,"y":563,"wires":[["258b6f62.e82ab"]]},{"id":"c005b8b1.f06b98","type":"change","z":"2ce0055.8743efa","name":"Volage","rules":[{"t":"move","p":"payload.kff1238","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\obd\\voltage","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":721,"y":603,"wires":[["5b8bdb33.d96134","5ef6a21e.75ce4c"]]},{"id":"96abaa53.c70988","type":"change","z":"2ce0055.8743efa","name":"Vacuum","rules":[{"t":"move","p":"payload.kff1202","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\vacuum","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":731,"y":643,"wires":[["913a6311.540cd","5ef6a21e.75ce4c"]]},{"id":"3765c6b.fb70f3a","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"9b558fbc.438aa","order":2,"width":"3","height":"3","gtype":"donut","title":"Throttle Position","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1091,"y":523,"wires":[]},{"id":"ee5bc723.594bf8","type":"change","z":"2ce0055.8743efa","name":"Speed","rules":[{"t":"move","p":"payload.kd","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\speed","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":721,"y":683,"wires":[["c3863c64.b8c2d","5ef6a21e.75ce4c"]]},{"id":"c3863c64.b8c2d","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"ea9cdc42.4bbc8","order":0,"width":0,"height":0,"gtype":"gage","title":"Speed","label":"MPH","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1061,"y":683,"wires":[]},{"id":"7ee21162.28cdb","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"9b558fbc.438aa","order":3,"width":"2","height":"3","gtype":"wave","title":"Mass Air Flow","label":"g/s","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1091,"y":483,"wires":[]},{"id":"536ae3f0.1980dc","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"26a930d9.ff8c","order":0,"width":"3","height":"3","gtype":"gage","title":"Barometer","label":"units","format":"{{value}}","min":"800","max":"1100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1071,"y":403,"wires":[]},{"id":"dfdc4763.7a8fd8","type":"change","z":"2ce0055.8743efa","name":"Speed GPS","rules":[{"t":"move","p":"payload.kff1001","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\phone\\speed","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":741,"y":723,"wires":[["535662ad.f1628c","5ef6a21e.75ce4c"]]},{"id":"535662ad.f1628c","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"26a930d9.ff8c","order":0,"width":"3","height":"3","gtype":"gage","title":"Speed GPS","label":"MPH","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1081,"y":723,"wires":[]},{"id":"5b8bdb33.d96134","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"ea9cdc42.4bbc8","order":0,"width":"3","height":"3","gtype":"gage","title":"Voltage","label":"V","format":"{{value}}","min":"9","max":"15","colors":["#ff0000","#008000","#ff0000"],"seg1":"13","seg2":"14.3","x":1071,"y":603,"wires":[]},{"id":"b0123228.4a063","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"9b558fbc.438aa","order":5,"width":"3","height":"3","gtype":"gage","title":"Coolant Temp","label":"F","format":"{{value}}","min":0,"max":"250","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1081,"y":563,"wires":[]},{"id":"913a6311.540cd","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"9b558fbc.438aa","order":6,"width":"3","height":"3","gtype":"donut","title":"Vacuum","label":"","format":"{{value}}","min":"-20","max":"0","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1071,"y":643,"wires":[]},{"id":"cee9fa09.98b6d8","type":"json","z":"2ce0055.8743efa","name":"","pretty":false,"x":751,"y":198,"wires":[["3b9be5d8.84e04a"]]},{"id":"f2d748c5.d92da8","type":"function","z":"2ce0055.8743efa","name":"Parse Date","func":"var date = parseInt(msg.payload.time);\n\nmsg.payload = new Date(date* 1).toLocaleString([], { hour12: true}).slice(0, 19).replace('T', ' ');\nreturn msg;","outputs":1,"noerr":0,"x":730,"y":780,"wires":[["88bfc628.5727b8"]]},{"id":"88bfc628.5727b8","type":"ui_text","z":"2ce0055.8743efa","group":"26a930d9.ff8c","order":1,"width":0,"height":0,"name":"Last Update","label":"Updated","format":"{{msg.payload}}","layout":"row-spread","x":1070,"y":780,"wires":[]},{"id":"258b6f62.e82ab","type":"function","z":"2ce0055.8743efa","name":"CtoF","func":"var tempc = msg.payload;\n    tempf = tempc * 9/5 + 32;\n    tempf = Math.round(tempf * 10) / 10;\n    msg.payload = tempf;\n    return msg;","outputs":1,"noerr":0,"x":910,"y":560,"wires":[["b0123228.4a063","5ef6a21e.75ce4c"]]},{"id":"936bc33f.bcd27","type":"change","z":"2ce0055.8743efa","name":"IntakeTemp","rules":[{"t":"move","p":"payload.kf","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"torque\\vehicle\\intake","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":840,"wires":[["a6732e91.735a9"]]},{"id":"ee354102.4a8d8","type":"ui_gauge","z":"2ce0055.8743efa","name":"","group":"9b558fbc.438aa","order":4,"width":"3","height":"3","gtype":"gage","title":"Intake Temp","label":"F","format":"{{value}}","min":0,"max":"250","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1070,"y":840,"wires":[]},{"id":"a6732e91.735a9","type":"function","z":"2ce0055.8743efa","name":"CtoF","func":"var tempc = msg.payload;\n    tempf = tempc * 9/5 + 32;\n    tempf = Math.round(tempf * 10) / 10;\n    msg.payload = tempf;\n    return msg;","outputs":1,"noerr":0,"x":899,"y":837,"wires":[["ee354102.4a8d8","5ef6a21e.75ce4c"]]},{"id":"3b9be5d8.84e04a","type":"change","z":"2ce0055.8743efa","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"torque\\raw","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1034,"y":202,"wires":[["5ef6a21e.75ce4c"]]},{"id":"5ef6a21e.75ce4c","type":"mqtt out","z":"2ce0055.8743efa","name":"","topic":"","qos":"0","retain":"true","broker":"fee1fac2.261a88","x":1292,"y":193,"wires":[]},{"id":"97ab65f2.1a0728","type":"function","z":"2ce0055.8743efa","name":"copy to json","func":"msg.payload.json = JSON.stringify(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":770,"y":100,"wires":[["72347975.0e2688"]]},{"id":"72347975.0e2688","type":"function","z":"2ce0055.8743efa","name":"Create query in topic","func":"var out = \"INSERT INTO torque_json (timestamp,json)\"\nvar date = Number(msg.payload.time);\nout = out + \"VALUES ('\" + new Date(date* 1).toISOString().slice(0, 19).replace('T', ' ') + \"','\" \nout = out + String(msg.payload.json)  + \"');\"\n    \nmsg.topic=out;\n\nreturn msg;","outputs":1,"noerr":0,"x":960,"y":100,"wires":[["dba0040d.49d798"]]},{"id":"dba0040d.49d798","type":"mysql","z":"2ce0055.8743efa","mydb":"4cd2c8.ee368d38","name":"","x":1300,"y":100,"wires":[[]]},{"id":"9b558fbc.438aa","type":"ui_group","z":"","name":"Motor","tab":"ac99e377.fdb83","order":1,"disp":true,"width":"9"},{"id":"ea9cdc42.4bbc8","type":"ui_group","z":"","name":"Van","tab":"ac99e377.fdb83","order":2,"disp":true,"width":"6"},{"id":"26a930d9.ff8c","type":"ui_group","z":"","name":"Phone","tab":"ac99e377.fdb83","order":3,"disp":true,"width":"6"},{"id":"fee1fac2.261a88","type":"mqtt-broker","z":"","broker":"mqtt.YOUR.SERVER","port":"1883","clientid":"nodered","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"4cd2c8.ee368d38","type":"MySQLdatabase","z":"","host":"drobo5n.YOUR.SERVER","port":"3306","db":"openhab","tz":"CST"},{"id":"ac99e377.fdb83","type":"ui_tab","z":"","name":"Torque","icon":"fa-car","order":2}]
Created 8 years, 7 months ago
Rating: 5 1
  • change (x11)
  • function (x5)
  • http in (x1)
  • http response (x1)
  • json (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • MySQLdatabase (x1)
  • mysql (x1)
  • ui_gauge (x10)
  • ui_group (x3)
  • ui_text (x1)
  • car
  • torque
  • OBD2
