recevoir une notification Telegram en cas de mauvaise qualité de l’air
[{"id":"def44007e0dc3ae4","type":"zigbee2mqtt-in","z":"a38ed9b1f55067cf","name":"Qualité de l'air Parents tVOC","server":"","friendly_name":"qualite_de_l_aire_parents (E2112)","device_id":[],"state":"0","outputAtStartup":true,"filterChanges":false,"enableMultiple":false,"x":220,"y":1940,"wires":[["e4e42c89c011426b"]]},{"id":"e4e42c89c011426b","type":"switch","z":"a38ed9b1f55067cf","name":"tVOC >= 201 ppm","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"201","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":1940,"wires":[["d825a75016213ce3"]]},{"id":"d825a75016213ce3","type":"trigger","z":"a38ed9b1f55067cf","name":"","op1":"","op2":"","op1type":"pay","op2type":"nul","duration":"60","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":710,"y":1940,"wires":[["62fba05db3fde00f"]]},{"id":"62fba05db3fde00f","type":"time-range-switch","z":"a38ed9b1f55067cf","name":"","lat":"","lon":"","startTime":"07:30","endTime":"23:00","startOffset":0,"endOffset":0,"x":910,"y":1940,"wires":[["9854fbae61fd6c13"],[]]},{"id":"bc5a98b9b99415c9","type":"zigbee2mqtt-in","z":"a38ed9b1f55067cf","name":"Qualité de l'air Parents PM2.5","server":"","friendly_name":"qualite_de_l_aire_parents (E2112)","device_id":[],"state":"0","outputAtStartup":true,"filterChanges":false,"enableMultiple":false,"x":220,"y":2040,"wires":[["64e7398fe415ad7e"]]},{"id":"64e7398fe415ad7e","type":"switch","z":"a38ed9b1f55067cf","name":"PM2.5 >= 50 µg/m³","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":2040,"wires":[["eb55dceb2b65777e"]]},{"id":"eb55dceb2b65777e","type":"trigger","z":"a38ed9b1f55067cf","name":"","op1":"","op2":"","op1type":"pay","op2type":"nul","duration":"10","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":710,"y":2040,"wires":[["d35f71b50d5d8fef"]]},{"id":"d35f71b50d5d8fef","type":"time-range-switch","z":"a38ed9b1f55067cf","name":"","lat":"","lon":"","startTime":"07:30","endTime":"23:00","startOffset":0,"endOffset":0,"x":910,"y":2040,"wires":[["9854fbae61fd6c13"],[]]},{"id":"9854fbae61fd6c13","type":"change","z":"a38ed9b1f55067cf","name":"Message aérer chambre parentale","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"type\":\"message\",\"chatId\":\"tonchatid\",\"content\":\"☢️ il faudrait aérer la chambre parentale ❤️\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":1980,"wires":[["a66eb247d7a0dfe7"]]},{"id":"a66eb247d7a0dfe7","type":"telegram sender","z":"a38ed9b1f55067cf","name":"","bot":"","haserroroutput":false,"outputs":1,"x":1600,"y":1880,"wires":[[]]}]
