GPS watch
Creates a TCP server for GPS Watches (usually Chinese, like Smart Baby Watch) and analyzes received data. Also has ability to send simple commands to watches (show message, request location, etc)
[{"id":"4f34fe7a.28ec2","type":"tcp in","z":"bfdbbee.bfabd4","name":"","server":"server","host":"","port":"8002","datamode":"stream","datatype":"utf8","newline":"]","topic":"","base64":false,"x":220,"y":150,"wires":[["33e678d5.e9fdf8","b342b5ec.58c288"]]},{"id":"33e678d5.e9fdf8","type":"debug","z":"bfdbbee.bfabd4","name":"watch receive","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","x":430,"y":100,"wires":[]},{"id":"35182fa.fe493d","type":"tcp out","z":"bfdbbee.bfabd4","host":"","port":"","beserver":"reply","base64":false,"end":false,"name":"","x":1000,"y":420,"wires":[]},{"id":"4ecd1fc3.8bf75","type":"change","z":"bfdbbee.bfabd4","name":"LK","rules":[{"t":"set","p":"payload","pt":"msg","to":"LK","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":310,"wires":[["bd068d2b.51a4"]]},{"id":"99c36ea0.d14a9","type":"inject","z":"bfdbbee.bfabd4","name":"1❤","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":260,"wires":[["fef33a6a.aba838"]]},{"id":"58bd9c65.dea714","type":"inject","z":"bfdbbee.bfabd4","name":"2❤","topic":"","payload":"2","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":300,"wires":[["fef33a6a.aba838"]]},{"id":"532b4d7.6594bb4","type":"template","z":"bfdbbee.bfabd4","name":"format","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{id}}*{{length}}*{{payload}}{{param}}]","output":"str","x":760,"y":420,"wires":[["35182fa.fe493d","9444bf88.b7f64"]]},{"id":"f2af699a.c38fd8","type":"change","z":"bfdbbee.bfabd4","name":"save session","rules":[{"t":"set","p":"sesion","pt":"flow","to":"_session","tot":"msg"},{"t":"set","p":"id","pt":"flow","to":"parts[0] & '*' & parts[1]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":840,"y":130,"wires":[[]]},{"id":"3a7bcf60.91782","type":"change","z":"bfdbbee.bfabd4","name":"load session","rules":[{"t":"set","p":"_sesion","pt":"msg","to":"session","tot":"flow"},{"t":"set","p":"id","pt":"msg","to":"id","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":370,"wires":[["532b4d7.6594bb4"]]},{"id":"c3ef72fd.56d72","type":"switch","z":"bfdbbee.bfabd4","name":"command","property":"parts[3]","propertyType":"msg","rules":[{"t":"regex","v":"^LK","vt":"str","case":false},{"t":"regex","v":"^UD","vt":"str","case":false},{"t":"regex","v":"^UD2","vt":"str","case":false}],"checkall":"false","repair":false,"outputs":3,"x":580,"y":190,"wires":[["4ecd1fc3.8bf75","f2af699a.c38fd8","af4eb8c4.a11aa8"],["d55df99a.879808"],["d55df99a.879808"]],"outputLabels":["LK","UD","UD2"]},{"id":"725f7c10.07e2a4","type":"inject","z":"bfdbbee.bfabd4","name":"","topic":"","payload":"привет","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":370,"wires":[["1a206769.2e69b9"]]},{"id":"9444bf88.b7f64","type":"debug","z":"bfdbbee.bfabd4","name":"watch send","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":1020,"y":470,"wires":[]},{"id":"f5c92b1a.df0158","type":"inject","z":"bfdbbee.bfabd4","name":"","topic":"","payload":"hello","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":410,"wires":[["1a206769.2e69b9"]]},{"id":"1a206769.2e69b9","type":"function","z":"bfdbbee.bfabd4","name":"hex","func":"var buf = Buffer.from(msg.payload, 'utf16le');\nbuf.swap16();\nmsg.payload = buf.toString('hex');\nreturn msg;","outputs":1,"noerr":0,"x":360,"y":390,"wires":[["b6c13ed3.812be"]]},{"id":"bd068d2b.51a4","type":"function","z":"bfdbbee.bfabd4","name":"hex(length)","func":"var len = msg.payload.length\nif (msg.param)\n    len += msg.param.toString().length\nmsg.length = (len+0x10000).toString(16).substr(-4)\nreturn msg;","outputs":1,"noerr":0,"x":770,"y":310,"wires":[["3a7bcf60.91782"]]},{"id":"345ea465.ff95ac","type":"inject","z":"bfdbbee.bfabd4","name":"TZ+2","topic":"","payload":"+2","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":470,"wires":[["a597a9d9.f1a028"]]},{"id":"a3affbe7.33bf08","type":"inject","z":"bfdbbee.bfabd4","name":"TZ+3","topic":"","payload":"+3","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":510,"wires":[["a597a9d9.f1a028"]]},{"id":"9a3ae2a.780a62","type":"inject","z":"bfdbbee.bfabd4","name":"","topic":"","payload":"12345678","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":560,"wires":[["d03de180.21695"]]},{"id":"b342b5ec.58c288","type":"function","z":"bfdbbee.bfabd4","name":"split(*)","func":"msg.parts = msg.payload.split(\"*\")\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":150,"wires":[["c3ef72fd.56d72"]]},{"id":"b6c13ed3.812be","type":"change","z":"bfdbbee.bfabd4","name":"MESSAGE,","rules":[{"t":"set","p":"param","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"MESSAGE,","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":390,"wires":[["bd068d2b.51a4"]]},{"id":"fef33a6a.aba838","type":"change","z":"bfdbbee.bfabd4","name":"FLOWER,","rules":[{"t":"set","p":"param","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"FLOWER,","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":350,"wires":[["bd068d2b.51a4"]]},{"id":"d03de180.21695","type":"change","z":"bfdbbee.bfabd4","name":"MONITOR,","rules":[{"t":"set","p":"param","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"MONITOR,","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":470,"wires":[["bd068d2b.51a4"]]},{"id":"a597a9d9.f1a028","type":"change","z":"bfdbbee.bfabd4","name":"LZ,9,","rules":[{"t":"set","p":"param","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"LZ,9,","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":430,"wires":[["bd068d2b.51a4"]]},{"id":"2a599e7a.dacf02","type":"inject","z":"bfdbbee.bfabd4","name":"","topic":"","payload":"87654321","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":600,"wires":[["d03de180.21695"]]},{"id":"c8a70c7f.bc2cb","type":"change","z":"bfdbbee.bfabd4","name":"CR","rules":[{"t":"set","p":"payload","pt":"msg","to":"CR","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":510,"wires":[["bd068d2b.51a4"]]},{"id":"a8a4dbb5.069cd8","type":"inject","z":"bfdbbee.bfabd4","name":"location","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":650,"wires":[["c8a70c7f.bc2cb"]]},{"id":"af4eb8c4.a11aa8","type":"function","z":"bfdbbee.bfabd4","name":"split(,)","func":"msg.parts = msg.parts[3].split(\",\")\nreturn msg;","outputs":1,"noerr":0,"x":820,"y":170,"wires":[["397aa990.f8a4b6"]]},{"id":"d55df99a.879808","type":"function","z":"bfdbbee.bfabd4","name":"split(,)","func":"msg.parts = msg.parts[3].split(\",\")\nreturn msg;","outputs":1,"noerr":0,"x":820,"y":230,"wires":[["fbbcaef4.ea668"]]},{"id":"397aa990.f8a4b6","type":"change","z":"bfdbbee.bfabd4","name":"pedometer/battery","rules":[{"t":"set","p":"pedometer","pt":"msg","to":"parts[1]","tot":"msg"},{"t":"set","p":"battery","pt":"msg","to":"parts[3]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":170,"wires":[["b13536f6.68ad88","bf21d195.9785a"]]},{"id":"fbbcaef4.ea668","type":"change","z":"bfdbbee.bfabd4","name":"pedometer/battery/location","rules":[{"t":"set","p":"pedometer","pt":"msg","to":"parts[14]","tot":"msg"},{"t":"set","p":"battery","pt":"msg","to":"parts[13]","tot":"msg"},{"t":"set","p":"location","pt":"msg","to":"[parts[4], parts[6]]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":230,"wires":[["b13536f6.68ad88","bf21d195.9785a","dd8879aa.6f6bc8","504022cf.77a41c"]]},{"id":"b13536f6.68ad88","type":"debug","z":"bfdbbee.bfabd4","name":"Pedometer","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"pedometer","x":1330,"y":170,"wires":[]},{"id":"bf21d195.9785a","type":"debug","z":"bfdbbee.bfabd4","name":"Battery","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"battery","x":1320,"y":230,"wires":[]},{"id":"dd8879aa.6f6bc8","type":"debug","z":"bfdbbee.bfabd4","name":"Location","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"location","x":1320,"y":290,"wires":[]},{"id":"2002e444.7b90cc","type":"worldmap","z":"bfdbbee.bfabd4","name":"GPS watch","lat":"","lon":"","zoom":"10","layer":"OSM grey","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"false","x":1530,"y":360,"wires":[]},{"id":"504022cf.77a41c","type":"change","z":"bfdbbee.bfabd4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"name\": \"GPS watch\", \"lat\" : location[0], \"lon\": location[1]}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":360,"wires":[["2002e444.7b90cc"]]}]
Created 9 years, 4 months ago
  • change (x11)
  • debug (x5)
  • function (x5)
  • inject (x9)
  • switch (x1)
  • tcp in (x1)
  • tcp out (x1)
  • template (x1)
  • worldmap (x1)
  • gps
  • watches
  • chinese
  • worldmap
  • map
