Alexa Remind us Prayer / Salat / Namaz Time
Namaz Reminder via ALEXA (AMAZON ECHO DEVICE)
Why ?
There is only one skill in amazon alexa marketplace which does announce the namaz time on its actual time (DIRECTLY). If you want you can use it (link below). For me it was not accurate as per my locality and school of thought.
https://www.amazon.in/Peace-Through-Understanding-Prayer-Times/dp/B07MHTJRYX/ref=sr_1_1?dchild=1&keywords=prayer+time&qid=1601483574&s=digital-skills&sr=1-1
The above skill will suffix you for most of the things but still if u want to fine tune than carry on.
What it does ?
Alexa Will remind you Whenever it is time for Fajr,Asr etc. She will Speak up at that time. Nice !
Requirements
  1. node-red-contrib-alexa-remote2
  2. node-red-contrib-cron-plus
  3. Create REMINDERS manually in alexa Fajr, Dhuhr, Asr, Maghrib, Isha, Sunrise, Sunset with everyday !
  4. API from https://aladhan.p.rapidapi.com/ Also please check FIQH as Hanafi, Shafi, etc.Make changes accordingly. Currently using Hanafi time. I removed my api key from below node.
  5. Configure Alexa related parameters. India related parameter is set.
  6. Configure Cornplus parameters. Already set.
For more info and images check https://discourse.nodered.org/t/set-alexa-reminder-via-node-red-once-daily-weekly/33347/5
[{"id":"754099fb.6b44a8","type":"tab","label":"API request for namaz time","disabled":false,"info":""},{"id":"346354d6.45b6fc","type":"inject","z":"754099fb.6b44a8","name":"","topic":"","payload":"{\"FAJR\":\"null\",\"DHUHR\":\"\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":"","x":70,"y":120,"wires":[["43e39941.bfc0f8"]]},{"id":"d7016e5f.f961","type":"http request","z":"754099fb.6b44a8","name":"Get Prayer Times","method":"GET","ret":"obj","paytoqs":false,"url":"https://aladhan.p.rapidapi.com/timingsByCity?method=1&school=1&city=Mumbai&country=India","tls":"","persist":false,"proxy":"","authType":"","x":130,"y":200,"wires":[["937cd073.97603","da66c140.4656e","a0693fd3.45ab7"]]},{"id":"43e39941.bfc0f8","type":"function","z":"754099fb.6b44a8","name":"set payload and headers","func":"msg.payload = \"data to post\";\nmsg.headers = {};\nmsg.headers['x-rapidapi-host'] = 'aladhan.p.rapidapi.com';\nmsg.headers['x-rapidapi-key'] = '';\n\nreturn msg;","outputs":1,"noerr":0,"x":290,"y":120,"wires":[["d7016e5f.f961"]]},{"id":"e90a72fb.e8949","type":"alexa-remote-routine","z":"754099fb.6b44a8","d":true,"name":"Fajr Time","account":"10dce7e8.4def08","routineNode":{"type":"speak","payload":{"type":"regular","text":{"type":"msg","value":"payload"},"devices":["G090XG0692320RRH"]}},"x":140,"y":540,"wires":[[]]},{"id":"937cd073.97603","type":"template","z":"754099fb.6b44a8","d":true,"name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Todays Date {{payload.data.date.readable}} and time {{payload.data.timings.Fajr}} !\nIt is time for Fajr Namaz!\n\n","output":"str","x":120,"y":340,"wires":[["e90a72fb.e8949"]]},{"id":"da66c140.4656e","type":"function","z":"754099fb.6b44a8","name":"Date Processing","func":"msg.payload.fajr = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Fajr}`;\nmsg.payload.fajrmsg = \"It is time for Fajr Namaz\";\nmsg.payload.dhuhr = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Dhuhr}`;\nmsg.payload.dhuhrmsg = \"It is time for dhuhr Namaz\";\nmsg.payload.asr = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Asr}`;\nmsg.payload.asrmsg = \"It is time for Asr Namaz\";\nmsg.payload.maghrib = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Maghrib}`;\nmsg.payload.maghribmsg = \"It is time for Maghrib Namaz\";\nmsg.payload.isha = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Isha}`;\nmsg.payload.ishamsg = \"It is time for Isha Namaz\";\nmsg.payload.sunrise = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Sunrise}`;\nmsg.payload.sunrisemsg = \"Good Morning! Sunrise\";\nmsg.payload.sunset = `${msg.payload.data.date.readable} ${msg.payload.data.timings.Sunset}`;\nmsg.payload.sunsetmsg = \"Good Evening! Sunset\";\nreturn msg;","outputs":1,"noerr":0,"x":360,"y":200,"wires":[["b88a1f85.532e5","1ec8e7c8.ae93f8","1a32c37f.9499fd","1ae78fa3.dc23f","9b522170.73e3","3c1f213f.431d1e","66f15e05.3939e"]]},{"id":"a0693fd3.45ab7","type":"debug","z":"754099fb.6b44a8","d":true,"name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":410,"y":500,"wires":[]},{"id":"b88a1f85.532e5","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Fajr Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"aabb42bb-d834-4cac-ab46-7b36e27654e4"},"label":{"type":"msg","value":"payload.fajrmsg"},"time":{"type":"msg","value":"msg.payload.fajr"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":700,"y":200,"wires":[["84e4d6b0.952998"]]},{"id":"84e4d6b0.952998","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":200,"wires":[]},{"id":"1ec8e7c8.ae93f8","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Dhuhr Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"a1b61a10-0552-45bd-a420-176928c59110"},"label":{"type":"msg","value":"payload.dhuhrmsg"},"time":{"type":"msg","value":"payload.dhuhr"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":710,"y":260,"wires":[["bbad1043.472b3"]]},{"id":"bbad1043.472b3","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":260,"wires":[]},{"id":"1a32c37f.9499fd","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Asr Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"a5e51c61-7708-475a-9619-4deda64ab522"},"label":{"type":"msg","value":"payload.asrmsg"},"time":{"type":"msg","value":"payload.asr"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":700,"y":320,"wires":[["d1aeace0.90af7"]]},{"id":"d1aeace0.90af7","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":320,"wires":[]},{"id":"1ae78fa3.dc23f","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Maghrib Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"51462c2b-6486-4631-b4e4-a5a27c6578a5"},"label":{"type":"msg","value":"payload.maghribmsg"},"time":{"type":"msg","value":"payload.maghrib"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":720,"y":380,"wires":[["39b225e6.bd13da"]]},{"id":"39b225e6.bd13da","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":380,"wires":[]},{"id":"9b522170.73e3","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Isha Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"89077fd9-648e-43be-96c6-4058b5486ef0"},"label":{"type":"msg","value":"payload.ishamsg"},"time":{"type":"msg","value":"payload.isha"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":680,"y":440,"wires":[["fff358ba.262798"]]},{"id":"fff358ba.262798","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":440,"wires":[]},{"id":"66f15e05.3939e","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Sunrise Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"6ba4ea76-2a47-40db-9e27-611360cb5417"},"label":{"type":"msg","value":"payload.sunrisemsg"},"time":{"type":"msg","value":"payload.sunrise"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":710,"y":120,"wires":[["c5d1b0b9.e2238"]]},{"id":"c5d1b0b9.e2238","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":120,"wires":[]},{"id":"3c1f213f.431d1e","type":"alexa-remote-other","z":"754099fb.6b44a8","name":"Sunset Notification","account":"10dce7e8.4def08","config":{"option":"changeNotification","value":{"notification":{"type":"str","value":"2c09c40a-d712-421d-bcb6-a2eae562948c"},"label":{"type":"msg","value":"payload.sunsetmsg"},"time":{"type":"msg","value":"payload.sunset"},"status":{"type":"str","value":"on"},"sound":{"type":"json","value":"null"}}},"x":690,"y":500,"wires":[["f63ef61f.e9f7e8"]]},{"id":"f63ef61f.e9f7e8","type":"debug","z":"754099fb.6b44a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":500,"wires":[]},{"id":"9d802aaf.a5b118","type":"cronplus","z":"754099fb.6b44a8","name":"","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output1","outputs":1,"options":[{"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 15 0,15 * * *","location":"","offset":"0","solarType":"selected","solarEvents":"sunrise,sunset"}],"x":80,"y":40,"wires":[["43e39941.bfc0f8","9a05bde3.dca39"]]},{"id":"9a05bde3.dca39","type":"debug","z":"754099fb.6b44a8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":390,"y":40,"wires":[]},{"id":"10dce7e8.4def08","type":"alexa-remote-account","z":"","name":"Alexa","authMethod":"proxy","proxyOwnIp":"192.168.0.100","proxyPort":"3456","cookieFile":"authFile","refreshInterval":"3","alexaServiceHost":"alexa.amazon.in","amazonPage":"amazon.in","acceptLanguage":"en-IN","userAgent":"","useWsMqtt":"on","autoInit":"on"}]
Created 6 years, 8 months ago
  • debug (x9)
  • function (x2)
  • http request (x1)
  • template (x1)
  • alexa-remote-account (x1)
  • alexa-remote-other (x7)
  • alexa-remote-routine (x1)
  • cronplus (x1)
  • salat
  • namaz
  • prayer
  • remind
  • alexa
  • azan
  • salah
