Remote command compliance flow
This is a flow I wrote that gives you buttons and "LED's" to control a couple of devices to toggle between two states/conditions and to get a visual display of what is going on.
You may have to cycle the buttons through each state to get the variables set - yes, I know. Slack of me. Sorry in hindsight.
But buttons are usually GREEN when all is good. Beside them are TWO LEDs. The first one (closest to the buttons) indicates what you want the state to be, and the second one indicates what state it IS. This is because sometimes things don't "just happen" there and then. It may take time for the state to change.
While the state and what IS are different, the buttons (of the device) are turned RED to indicate a miss-match.
After 2 seconds - in this example - the actual state will match what you want and the buttons will return to being GREEN.
There is a lot of "debug" code in the two "Set variables" NODES, the "Check Same" NODE.
the only other big editing which may be needed is in the SWITCH nodes if you want to change the messages being used/sent for your functions.
[{"id":"8c5d8a50.8e2a7","type":"tab","label":"Switch Example","disabled":false,"info":""},{"id":"160f50ff.d34d37","type":"ui_button","z":"8c5d8a50.8e2a7","name":"","group":"40989d90.ab76dc","order":1,"width":"3","height":"1","passthru":false,"label":"Device 1 Option 1","color":"","bgcolor":"{{msg.background}}","icon":"","payload":"{\"DEVICE\":\"Device_1\", \"COMMAND\":\"Option_1\"}","payloadType":"json","topic":"","x":490,"y":150,"wires":[["b3341b73.ebab7","67665c54.fabea4"]]},{"id":"e50283f5.b8a148","type":"ui_button","z":"8c5d8a50.8e2a7","name":"","group":"696ffa17.2c9564","order":1,"width":"3","height":"1","passthru":false,"label":"Device 1 Option 2","color":"","bgcolor":"{{msg.background}}","icon":"","payload":"{\"DEVICE\":\"Device_1\", \"COMMAND\":\"Option_2\"}","payloadType":"json","topic":"","x":490,"y":190,"wires":[["b3341b73.ebab7","67665c54.fabea4"]]},{"id":"4b96cee2.1ecb88","type":"comment","z":"8c5d8a50.8e2a7","name":"Device 1","info":"","x":500,"y":110,"wires":[]},{"id":"610cef4e.cf1e6","type":"comment","z":"8c5d8a50.8e2a7","name":"Device 2","info":"","x":500,"y":240,"wires":[]},{"id":"a537c27b.4b5eb","type":"ui_button","z":"8c5d8a50.8e2a7","name":"","group":"40989d90.ab76dc","order":5,"width":"3","height":"1","passthru":false,"label":"Device 2 Option 1","color":"","bgcolor":"{{msg.background}}","icon":"","payload":"{\"DEVICE\":\"Device_2\", \"COMMAND\":\"Option_1\"}","payloadType":"json","topic":"","x":490,"y":310,"wires":[["4819e8c.1b06618","67665c54.fabea4"]]},{"id":"9c78308.b7bc35","type":"ui_button","z":"8c5d8a50.8e2a7","name":"","group":"696ffa17.2c9564","order":5,"width":"3","height":"1","passthru":false,"label":"Device 2 Option 2","color":"","bgcolor":"{{msg.background}}","icon":"","payload":"{\"DEVICE\":\"Device_2\", \"COMMAND\":\"Option_2\"}","payloadType":"json","topic":"","x":490,"y":350,"wires":[["4819e8c.1b06618","67665c54.fabea4"]]},{"id":"24d00871.4378d8","type":"mqtt out","z":"8c5d8a50.8e2a7","name":"Send command","topic":"COMMAND","qos":"2","retain":"true","broker":"7fc03edd.ff1498","x":860,"y":240,"wires":[]},{"id":"9d5bb75d.facb98","type":"ui_text","z":"8c5d8a50.8e2a7","group":"696ffa17.2c9564","order":2,"width":"1","height":"1","name":"LED T T S","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1030,"y":186,"wires":[]},{"id":"752d6967.a45bc8","type":"ui_text","z":"8c5d8a50.8e2a7","group":"40989d90.ab76dc","order":2,"width":"1","height":"1","name":"LED  T M S","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1030,"y":134,"wires":[]},{"id":"b3341b73.ebab7","type":"switch","z":"8c5d8a50.8e2a7","name":"","property":"payload.COMMAND","propertyType":"msg","rules":[{"t":"cont","v":"Option_1","vt":"str"},{"t":"cont","v":"Option_2","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":690,"y":170,"wires":[["f42dccd1.d8c598"],["8c5ae1b2.d815f8"],[]]},{"id":"f42dccd1.d8c598","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"lime\";\nvar msg2 = {payload:\"red\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":850,"y":140,"wires":[["752d6967.a45bc8"],["9d5bb75d.facb98"]]},{"id":"8c5ae1b2.d815f8","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"red\";\nvar msg2 = {payload:\"lime\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":850,"y":180,"wires":[["752d6967.a45bc8"],["9d5bb75d.facb98"]]},{"id":"213a4ab2.3c1e0e","type":"ui_text","z":"8c5d8a50.8e2a7","group":"696ffa17.2c9564","order":6,"width":"1","height":"1","name":"LED C T S","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1040,"y":350,"wires":[]},{"id":"7e18efa7.e0337","type":"ui_text","z":"8c5d8a50.8e2a7","group":"40989d90.ab76dc","order":6,"width":"1","height":"1","name":"LED C M S","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1040,"y":298,"wires":[]},{"id":"4819e8c.1b06618","type":"switch","z":"8c5d8a50.8e2a7","name":"","property":"payload.COMMAND","propertyType":"msg","rules":[{"t":"cont","v":"Option_1","vt":"str"},{"t":"cont","v":"Option_2","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":700,"y":334,"wires":[["9a79ee24.732a9"],["500faefc.26533"],[]]},{"id":"9a79ee24.732a9","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"lime\";\nvar msg2 = {payload:\"red\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":860,"y":304,"wires":[["7e18efa7.e0337"],["213a4ab2.3c1e0e"]]},{"id":"500faefc.26533","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"red\";\nvar msg2 = {payload:\"lime\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":860,"y":344,"wires":[["7e18efa7.e0337"],["213a4ab2.3c1e0e"]]},{"id":"c207edc9.38b35","type":"ui_text","z":"8c5d8a50.8e2a7","group":"40989d90.ab76dc","order":3,"width":"1","height":"1","name":"LED T M A","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1050,"y":860,"wires":[]},{"id":"eee366a0.14bd98","type":"comment","z":"8c5d8a50.8e2a7","name":"Selected","info":"","x":990,"y":100,"wires":[]},{"id":"28766648.ffae72","type":"comment","z":"8c5d8a50.8e2a7","name":"Actual","info":"","x":1000,"y":820,"wires":[]},{"id":"ab36d276.83818","type":"comment","z":"8c5d8a50.8e2a7","name":"Mismatch","info":"","x":230,"y":180,"wires":[]},{"id":"a6af187a.56f2d8","type":"ui_text","z":"8c5d8a50.8e2a7","group":"40989d90.ab76dc","order":7,"width":"1","height":"1","name":"LED C M A","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1050,"y":960,"wires":[]},{"id":"432a059f.17c994","type":"ui_text","z":"8c5d8a50.8e2a7","group":"696ffa17.2c9564","order":3,"width":"1","height":"1","name":"LED T T A","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1050,"y":900,"wires":[]},{"id":"e132c43e.8fde08","type":"ui_text","z":"8c5d8a50.8e2a7","group":"696ffa17.2c9564","order":6,"width":"1","height":"1","name":"LED C T A","label":"","format":"<font color={{msg.payload}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"col-center","x":1050,"y":1000,"wires":[]},{"id":"8fa9c85b.bd884","type":"mqtt in","z":"8c5d8a50.8e2a7","name":"","topic":"COMMAND","qos":"2","broker":"7fc03edd.ff1498","x":210,"y":580,"wires":[["22c84fb7.6c458"]]},{"id":"c7bc91ae.9a6508","type":"switch","z":"8c5d8a50.8e2a7","name":"Device select","property":"payload.DEVICE","propertyType":"msg","rules":[{"t":"cont","v":"Device_1","vt":"str"},{"t":"cont","v":"Device_2","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":440,"y":990,"wires":[["17d82faa.b005f8"],["284d9ef1.3a1d02"],[]]},{"id":"17d82faa.b005f8","type":"switch","z":"8c5d8a50.8e2a7","name":"","property":"payload.COMMAND","propertyType":"msg","rules":[{"t":"eq","v":"Option_1","vt":"str"},{"t":"eq","v":"Option_2","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":660,"y":890,"wires":[["eb633196.5af15"],["3c6adbcd.13512c"],[]]},{"id":"284d9ef1.3a1d02","type":"switch","z":"8c5d8a50.8e2a7","name":"","property":"payload.COMMAND","propertyType":"msg","rules":[{"t":"cont","v":"Option _1","vt":"str"},{"t":"cont","v":"Option_2","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":660,"y":990,"wires":[["99d25123.54668"],["659ec169.579d1"],[]]},{"id":"eb633196.5af15","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"lime\";\nvar msg2 = {payload:\"red\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":830,"y":860,"wires":[["c207edc9.38b35"],["432a059f.17c994"]]},{"id":"3c6adbcd.13512c","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"red\";\nvar msg2 = {payload:\"lime\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":830,"y":900,"wires":[["c207edc9.38b35"],["432a059f.17c994"]]},{"id":"fad272a2.61cbb8","type":"comment","z":"8c5d8a50.8e2a7","name":"Telepi","info":"","x":660,"y":840,"wires":[]},{"id":"e3d0235c.49b73","type":"comment","z":"8c5d8a50.8e2a7","name":"Camerapi","info":"","x":670,"y":940,"wires":[]},{"id":"99d25123.54668","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"lime\";\nvar msg2 = {payload:\"red\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":830,"y":960,"wires":[["a6af187a.56f2d8"],["e132c43e.8fde08"]]},{"id":"659ec169.579d1","type":"function","z":"8c5d8a50.8e2a7","name":"Set colour","func":"msg.payload = \"red\";\nvar msg2 = {payload:\"lime\"};\nreturn [msg,msg2];\n","outputs":2,"noerr":0,"x":830,"y":1000,"wires":[["a6af187a.56f2d8"],["e132c43e.8fde08"]]},{"id":"3ef50100.53f36","type":"delay","z":"8c5d8a50.8e2a7","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":310,"y":660,"wires":[["d8c3acae.97864"]]},{"id":"260b0218.0a1e5e","type":"function","z":"8c5d8a50.8e2a7","name":"Set variables","func":"//node.warn(\"MQTT Receive node.  msg.payload.DEVICE is set to \"+ msg.payload.DEVICE);\n//node.warn(\"And the command is \"+ msg.payload.COMMAND);\nif (msg.payload.DEVICE == \"Device_1\")\n{\n    //\n//    node.warn(\"----------------------------------------\");\n//    node.warn(\"Setting Device_1A variable to \" + msg.payload.COMMAND);\n//    node.warn(\"----------------------------------------\");\n    flow.set('Device_1A',msg.payload.COMMAND);\n//    node.warn(flow.get('Device_1A'));\n} else\nif (msg.payload.DEVICE == \"Device_2\")\n{\n    //\n//    node.warn(\"----------------------------------------\");\n//    node.warn(\"Setting Device_2A variable to \" + msg.payload.COMMAND);\n//    node.warn(\"----------------------------------------\");\n    flow.set('Device_2A',msg.payload.COMMAND);\n//    node.warn(flow.get('Device_2A'));\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":240,"y":990,"wires":[["ed700220.f63ac","c7bc91ae.9a6508"]]},{"id":"67665c54.fabea4","type":"function","z":"8c5d8a50.8e2a7","name":"Set variables","func":"if (msg.payload.DEVICE == \"Device_1\")\n{\n    //\n    node.warn(\"MQTT TX.  Setting Device_1 variable to \" + msg.payload.COMMAND);\n    flow.set('Device_1S',msg.payload.COMMAND);\n} else\nif (msg.payload.DEVICE == \"Device_2\")\n{\n    //\n    node.warn(\"Setting Device_2 variable to \" + msg.payload.COMMAND);\n    flow.set('Device_2S',msg.payload.COMMAND);\n}\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":240,"wires":[["24d00871.4378d8","12a45b86.2254ec"]]},{"id":"12a45b86.2254ec","type":"link out","z":"8c5d8a50.8e2a7","name":"Swap 1 TX","links":["4270c298.edf3e4"],"x":745,"y":280,"wires":[]},{"id":"4270c298.edf3e4","type":"link in","z":"8c5d8a50.8e2a7","name":"Swap RX","links":["12a45b86.2254ec","ed700220.f63ac"],"x":145,"y":240,"wires":[["7e5bd5cd.f50ff4"]]},{"id":"ed700220.f63ac","type":"link out","z":"8c5d8a50.8e2a7","name":"Swap 2 TX","links":["4270c298.edf3e4"],"x":495,"y":940,"wires":[]},{"id":"7e5bd5cd.f50ff4","type":"function","z":"8c5d8a50.8e2a7","name":"Check same","func":"//  BGC - BackGroundColour of button with all being good.\n//  MMC - background colour of button if there is a MissMatchColour\nvar BGC = \"green\";  // All ok BackGroundColour\nvar MMC = \"red\";    // MisMatchColour\n\n//  S Selected status of device number.\n//  A Actual status of device number.\nvar Device_1S = flow.get('Device_1S');\nvar Device_1A = flow.get('Device_1A');\nvar Device_2S = flow.get('Device_2S');\nvar Device_2A = flow.get('Device_2A');\n\nnode.warn(\"================\");\nnode.warn(\"The variables are\");\nnode.warn(\"Device 1 Status is set to \"+Device_1S);\nnode.warn(\"Device 1 Actually is set to \"+Device_1A);\nnode.warn(\"Device 2 Status is set to \"+Device_2S);\nnode.warn(\"Device 2 Actually is set to \"+Device_2A);\nnode.warn(\"================\");\n\nif (Device_1A == Device_1S)\n{\n    //\n    var msg1BGC = BGC;\n} else\n{\n    var msg1BGC = MMC;\n}\n\nif (Device_2A == Device_2S)\n{\n    //\n    var msg2BGC = BGC;\n} else\n{\n    //\n    var msg2BGC = MMC;\n}\nvar msg2 = { payload:\"\", background:msg2BGC};\nmsg = {payload:\"\", background:msg1BGC};\nreturn [msg,msg2];","outputs":2,"noerr":0,"x":250,"y":240,"wires":[["9853eb6c.881488","160f50ff.d34d37","e50283f5.b8a148"],["597f9ea0.7e747","a537c27b.4b5eb","9c78308.b7bc35"]]},{"id":"22c84fb7.6c458","type":"json","z":"8c5d8a50.8e2a7","name":"","property":"payload","action":"","pretty":false,"x":370,"y":580,"wires":[["3ef50100.53f36"]]},{"id":"9853eb6c.881488","type":"debug","z":"8c5d8a50.8e2a7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":250,"y":310,"wires":[]},{"id":"597f9ea0.7e747","type":"debug","z":"8c5d8a50.8e2a7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":250,"y":350,"wires":[]},{"id":"310cfba3.e71f54","type":"inject","z":"8c5d8a50.8e2a7","name":"","topic":"","payload":"black","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":270,"y":410,"wires":[["160f50ff.d34d37","e50283f5.b8a148","a537c27b.4b5eb","9c78308.b7bc35"]]},{"id":"a7daf68d.a5822","type":"inject","z":"8c5d8a50.8e2a7","name":"","topic":"","payload":"black","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":840,"y":400,"wires":[["752d6967.a45bc8","9d5bb75d.facb98","7e18efa7.e0337","213a4ab2.3c1e0e","c207edc9.38b35","432a059f.17c994","a6af187a.56f2d8","e132c43e.8fde08"]]},{"id":"d536bc59.59144","type":"comment","z":"8c5d8a50.8e2a7","name":"Part 1 A","info":"","x":730,"y":60,"wires":[]},{"id":"c27e353.964a448","type":"json","z":"8c5d8a50.8e2a7","name":"","property":"payload","action":"","pretty":false,"x":350,"y":900,"wires":[["260b0218.0a1e5e"]]},{"id":"2fa50b74.aade2c","type":"mqtt in","z":"8c5d8a50.8e2a7","name":"","topic":"COMMAND/REPLY","qos":"2","broker":"7fc03edd.ff1498","x":170,"y":900,"wires":[["c27e353.964a448"]]},{"id":"d8c3acae.97864","type":"mqtt out","z":"8c5d8a50.8e2a7","name":"","topic":"COMMAND/REPLY","qos":"","retain":"","broker":"6ccf853d.6f8004","x":490,"y":660,"wires":[]},{"id":"4ccc0526.fa5264","type":"comment","z":"8c5d8a50.8e2a7","name":"Part 1 B","info":"","x":720,"y":780,"wires":[]},{"id":"f1741943.d687d","type":"comment","z":"8c5d8a50.8e2a7","name":"Part 2","info":"","x":390,"y":520,"wires":[]},{"id":"e698f615.7ce228","type":"comment","z":"8c5d8a50.8e2a7","name":"Read Me","info":"This part is on the \"other machine\".\nThe DELAY 2 SECONDS is to simulate a time delay\nbetween the command being sent and actully having\nthe result.\nThe result is sent back to the first machine to\nbe compared to the original command to detect\nif there is a difference, and to indicate to the\nuser if there is or isn't.\n","x":690,"y":590,"wires":[]},{"id":"adb36632.268dd8","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":130,"y":480,"wires":[]},{"id":"ab501bd3.010da","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":240,"y":480,"wires":[]},{"id":"249f4d30.fdeaea","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":350,"y":480,"wires":[]},{"id":"834f7c4d.3e5328","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":460,"y":480,"wires":[]},{"id":"c35c25a0.72ba1","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":570,"y":480,"wires":[]},{"id":"17704718.cb9931","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":680,"y":480,"wires":[]},{"id":"242b80f7.e17d1","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":790,"y":480,"wires":[]},{"id":"95763414.d93558","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":900,"y":480,"wires":[]},{"id":"e5aa0d3e.875da","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1010,"y":480,"wires":[]},{"id":"5886a438.8e74d4","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1120,"y":480,"wires":[]},{"id":"166b9e17.f99682","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1230,"y":480,"wires":[]},{"id":"d813af33.c8d6a8","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1340,"y":480,"wires":[]},{"id":"b906e924.06ca38","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":130,"y":730,"wires":[]},{"id":"b9c559bd.47d918","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":240,"y":730,"wires":[]},{"id":"efddb603.a3a158","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":350,"y":730,"wires":[]},{"id":"1cb0165e.be109a","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":460,"y":730,"wires":[]},{"id":"2bbadcca.b44034","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":570,"y":730,"wires":[]},{"id":"5dabb1c0.4fde2","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":680,"y":730,"wires":[]},{"id":"c8c34899.3a5308","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":790,"y":730,"wires":[]},{"id":"b3996c0.aabbb98","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":900,"y":730,"wires":[]},{"id":"e40102f.5b1ed","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1010,"y":730,"wires":[]},{"id":"a1bea945.99fdd8","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1120,"y":730,"wires":[]},{"id":"3db17dac.54e4b2","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1230,"y":730,"wires":[]},{"id":"80e4b3eb.add8b","type":"comment","z":"8c5d8a50.8e2a7","name":"","info":"","x":1340,"y":730,"wires":[]},{"id":"6d43c8cf.516c78","type":"comment","z":"8c5d8a50.8e2a7","name":"Clear indicators","info":"This is just to clear the \"LEDs\" while testing\nNot really needed, but left here all the same.","x":670,"y":400,"wires":[]},{"id":"efb4c84.8d9cdb8","type":"comment","z":"8c5d8a50.8e2a7","name":"Read me about the flow.","info":"This is a flow I wrote that gives you buttons and \"LED's\" to control a couple of devices to toggle\nbetween two states/conditions and to get a visual display of what is going on.\n\nYou may have to cycle the buttons through each state to get the variables set - yes, I know.  Slack of me.   Sorry in hindsight.\n\nBut buttons are usually GREEN when all is good.\nBeside them are TWO LEDs.  The first one (closest to the buttons) indicates what you want the state\nto be, and the second one indicates what state it IS.\nThis is because sometimes things don't \"just happen\" there and then.  It may take time for the\nstate to change.\n\nWhile the state and what IS are different, the buttons (of the device) are turned RED to indicate\na miss-match.\n\nAfter 2 seconds - in this example - the actual state will match what you want and the buttons will\nreturn to being GREEN.\n\nThere is a lot of \"debug\" code in the two \"Set variables\" NODES, the \"Check Same\" NODE.\n\nthe only other big editing which may be needed is in the SWITCH nodes if you want to change the\nmessages being used/sent for your functions.\n\n","x":1190,"y":60,"wires":[]},{"id":"40989d90.ab76dc","type":"ui_group","z":"","name":"Option 1","tab":"771329b.27a8c58","order":1,"disp":true,"width":"5","collapse":false},{"id":"696ffa17.2c9564","type":"ui_group","z":"","name":"Option 2","tab":"771329b.27a8c58","order":2,"disp":true,"width":"5","collapse":false},{"id":"7fc03edd.ff1498","type":"mqtt-broker","z":"","broker":"192.168.0.99","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"20","cleansession":true,"willTopic":"EOM","willQos":"2","willRetain":"true","willPayload":"'Tele Pi telemetry failure'","birthTopic":"SOM","birthQos":"2","birthPayload":""},{"id":"6ccf853d.6f8004","type":"mqtt-broker","z":"","name":"192.168.0.99:1883","broker":"TimePi","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"771329b.27a8c58","type":"ui_tab","z":"","name":"Switcher","icon":"dashboard","order":13}]
Created 9 years ago
  • comment (x37)
  • debug (x2)
  • delay (x1)
  • function (x11)
  • inject (x2)
  • json (x2)
  • link in (x1)
  • link out (x2)
  • mqtt in (x2)
  • mqtt out (x2)
  • mqtt-broker (x2)
  • switch (x5)
  • ui_button (x4)
  • ui_group (x2)
  • ui_text (x8)
  • Dashboard
  • Buttons
  • MQTT
  • remote_commands
  • compliance
