Philips Hue Log File and E-Mail
Description
This flow logs Philips Hue light switch changes. Please follow the instructions to set up this flow to your environment.
Motivation
I use some rules for my light system and some motion detectors. As I arrive at home, my light switches are automatically triggered by my smartphones WiFi logon. Sometimes I ask myself, if the lights were really off during the day or always on, caused by a potential misconfiguration. So I set up my Raspberry Pi to create a log file of light changes.
Maybe it's usefull for you as well... ;)
Setup Instructions
- Follow the instructions on https://www.developers.meethue.com/documentation/getting-started to get your Philips Hue API URL.
- Inject the api url to the global variable
global.settings.hue.url - Inject your e-mail address into
global.settings.contact.email - Inject project name, which will be used in the e-mail subject, into
global.settings.names.project - Set your desired log file name in the node named
Write to Lights States Log File - Set your SMTP credentials in the node
email(If you're using GMail set up an app password: https://myaccount.google.com/apppasswords) - Now you can check when the lights were switched on and off
_ Note: The format of the timestamp is UTC in ISO 8601 compatible format and may not represent your local timezone. _
[{"id":"596ec16a.2048d","type":"subflow","name":"Array Of Booleans to String","info":"","in":[{"x":40,"y":40,"wires":[{"id":"af39cdd0.144f9"}]}],"out":[{"x":440,"y":40,"wires":[{"id":"af39cdd0.144f9","port":0}]}]},{"id":"af39cdd0.144f9","type":"function","z":"596ec16a.2048d","name":"Array Of Booleans to String","func":"let ret = \"\";\n\nfor (const b of msg.payload) {\n ret += (b === true) ? \"1\" : \"0\";\n}\nmsg.payload = ret;\nreturn msg;","outputs":1,"noerr":0,"x":240,"y":40,"wires":[[]]},{"id":"fdccb947.3480f8","type":"subflow","name":"Get Lights State","info":"","in":[{"x":40,"y":40,"wires":[{"id":"5a751ab7.8f3514"}]}],"out":[{"x":300,"y":40,"wires":[{"id":"5a751ab7.8f3514","port":0}]}]},{"id":"5a751ab7.8f3514","type":"function","z":"fdccb947.3480f8","name":"Get Lights States","func":"let ret = [];\n\nfor (const light in msg.payload) {\n ret.push(msg.payload[light].state.on);\n}\n\nmsg.payload = ret;\nreturn msg;\n","outputs":1,"noerr":0,"x":170,"y":40,"wires":[[]]},{"id":"ff0ee1c6.69484","type":"tab","label":"Report Home State","disabled":false,"info":"# Report Home State\n\n## Description\n\nThis flow logs Philips Hue light switch changes.\nPlease follow the instructions to set up this flow to your environment.\n\n## Motivation\n\nI use some rules for my light system and some motion detectors.\nAs I arrive at home, my light switches are automatically triggered by my smartphones WiFi logon.\nSometimes I ask myself, if the lights were really off during the day or always on, caused by a potential misconfiguration.\nSo I set up my Raspberry Pi to create a log file of light changes.\n\nMaybe it's usefull for you as well... ;)\n\n## Setup Instructions\n\n1. Follow the instructions on https://www.developers.meethue.com/documentation/getting-started to get your Philips Hue API URL.\n2. Inject the api url to the global variable `global.settings.hue.url`\n3. Inject your e-mail address into `global.settings.contact.email`\n4. Inject project name, which will be used in the e-mail subject, into `global.settings.names.project`\n5. Set your desired log file name in the node named `Write to Lights States Log File`\n6. Set your SMTP credentials in the node `email` _(If you're using GMail set up an app password: https://myaccount.google.com/apppasswords)_\n7. Now you can check when the lights were switched on and off\n\n_\n__Note:__\nThe format of the timestamp is UTC in ISO 8601 compatible format and may not represent your local timezone.\n_"},{"id":"43b7079.0cad1f8","type":"inject","z":"ff0ee1c6.69484","name":"","topic":"","payload":"","payloadType":"date","repeat":"5","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":180,"wires":[["a646fed9.c4707"]]},{"id":"72f0c35c.c0d9ac","type":"http request","z":"ff0ee1c6.69484","name":"Get Lights","method":"GET","ret":"obj","url":"","tls":"","x":330,"y":380,"wires":[["44540150.c3bd9"]]},{"id":"5a78994b.8884f8","type":"change","z":"ff0ee1c6.69484","name":"Set Lights URL","rules":[{"t":"set","p":"url","pt":"msg","to":"$globalContext(\"settings.hue.url\") & \"/lights\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":380,"wires":[["72f0c35c.c0d9ac"]]},{"id":"a9958d2a.8a77e","type":"change","z":"ff0ee1c6.69484","name":"Save Last State","rules":[{"t":"set","p":"lastLightsState","pt":"flow","to":"lightsState","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":280,"wires":[["aa099e57.239"]]},{"id":"aa73ebd6.d0e128","type":"change","z":"ff0ee1c6.69484","name":"Set Current State","rules":[{"t":"set","p":"lightsState","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":170,"y":480,"wires":[["1a8479df.871036"]]},{"id":"d7c05f9.56629a","type":"switch","z":"ff0ee1c6.69484","name":"Lights State Changed?","property":"lightsState","propertyType":"flow","rules":[{"t":"neq","v":"lastLightsState","vt":"flow"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":190,"y":580,"wires":[["45d7d2c0.8a203c"],["4f3ce9e2.673078"]],"outputLabels":["yes","no"]},{"id":"feda1399.e1a9b","type":"debug","z":"ff0ee1c6.69484","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1030,"y":660,"wires":[]},{"id":"5cbc9fd3.489b","type":"change","z":"ff0ee1c6.69484","name":"off text","rules":[{"t":"set","p":"payload","pt":"msg","to":"ALL LIGHTS OFF","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"ALL LIGHTS OFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":580,"wires":[["a93d0be5.e98928"]]},{"id":"4f3ce9e2.673078","type":"change","z":"ff0ee1c6.69484","name":"unchanged text","rules":[{"t":"set","p":"payload","pt":"msg","to":"lights unchanged","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"lights unchanged","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":660,"wires":[["feda1399.e1a9b"]]},{"id":"9053e561.d4eeb8","type":"debug","z":"ff0ee1c6.69484","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":870,"y":420,"wires":[]},{"id":"44540150.c3bd9","type":"subflow:fdccb947.3480f8","z":"ff0ee1c6.69484","x":500,"y":380,"wires":[["f4b1114.a61d6f"]]},{"id":"f4b1114.a61d6f","type":"subflow:596ec16a.2048d","z":"ff0ee1c6.69484","name":"Convert to String","x":690,"y":380,"wires":[["9053e561.d4eeb8","6b1950db.6aaa1"]]},{"id":"45d7d2c0.8a203c","type":"switch","z":"ff0ee1c6.69484","name":"Are All Lights Off?","property":"$contains($flowContext(\"lightsState\"), \"1\")","propertyType":"jsonata","rules":[{"t":"false"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":580,"wires":[["5cbc9fd3.489b"],["69162fa8.7249d"]],"outputLabels":["yes","no"]},{"id":"69162fa8.7249d","type":"change","z":"ff0ee1c6.69484","name":"changed text","rules":[{"t":"set","p":"payload","pt":"msg","to":"LIGHTS CHANGED","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"LIGHTS CHANGED","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":620,"wires":[["a93d0be5.e98928"]]},{"id":"39631a9d.7dbb46","type":"file","z":"ff0ee1c6.69484","name":"Write to Lights States Log File","filename":"/home/pi/.node-red/logs/lightsstates.log","appendNewline":true,"createDir":true,"overwriteFile":"false","x":1090,"y":580,"wires":[]},{"id":"a93d0be5.e98928","type":"change","z":"ff0ee1c6.69484","name":"Prepend Timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"$now() & \" - \" & $flowContext(\"lightsState\") & \" - \" & msg.payload","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"$globalContext(\"settings.names.project\") & \": \" & msg.topic","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":580,"wires":[["feda1399.e1a9b","39631a9d.7dbb46","6b5781bc.bbf8f"]]},{"id":"89aa4dbb.f9aa","type":"comment","z":"ff0ee1c6.69484","name":"Set `global.settings.hue.url` to your Philips Hue api url: https://www.developers.meethue.com/documentation/getting-started","info":"> To get detailed step by step instructions, open the flow description.","x":440,"y":40,"wires":[],"icon":"node-red/alert.png"},{"id":"5315b9cc.738bd8","type":"comment","z":"ff0ee1c6.69484","name":"Check for changes every ... seconds","info":"","x":170,"y":140,"wires":[]},{"id":"9dcf6fef.1b09f","type":"comment","z":"ff0ee1c6.69484","name":"Save previous light state","info":"","x":130,"y":240,"wires":[]},{"id":"47f0a7ce.a5fec8","type":"comment","z":"ff0ee1c6.69484","name":"Get the current light state","info":"","x":130,"y":340,"wires":[]},{"id":"18a4fbe7.e23ea4","type":"comment","z":"ff0ee1c6.69484","name":"Save current light state","info":"","x":120,"y":440,"wires":[]},{"id":"f0dc5ba3.683aa8","type":"comment","z":"ff0ee1c6.69484","name":"Log light state changes","info":"","x":120,"y":540,"wires":[]},{"id":"f5d529a9.469eb8","type":"comment","z":"ff0ee1c6.69484","name":"⬇ SET FILENAME HERE","info":"> To get detailed step by step instructions, open the flow description.","x":1070,"y":540,"wires":[],"icon":"node-red/node-changed.png"},{"id":"9f60f3be.8913e","type":"change","z":"ff0ee1c6.69484","name":"Set API URL & E-Mail-Address & Subject Prefix","rules":[],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":80,"wires":[[]]},{"id":"18d30974.dd7e17","type":"inject","z":"ff0ee1c6.69484","name":"Set Initial Variables","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":150,"y":80,"wires":[["9f60f3be.8913e"]]},{"id":"4b6ae102.ac9d9","type":"comment","z":"ff0ee1c6.69484","name":"⬅ SET VARIABLES HERE","info":"> To get detailed step by step instructions, open the flow description.","x":730,"y":80,"wires":[],"icon":"node-red/node-changed.png"},{"id":"ca52298c.be1508","type":"link in","z":"ff0ee1c6.69484","name":"Save previous light state","links":["a646fed9.c4707"],"x":55,"y":280,"wires":[["a9958d2a.8a77e"]]},{"id":"ecf7b9a1.4ca168","type":"link in","z":"ff0ee1c6.69484","name":"Get the current light state","links":["aa099e57.239"],"x":55,"y":380,"wires":[["5a78994b.8884f8"]]},{"id":"6e1da50d.f53c4c","type":"link in","z":"ff0ee1c6.69484","name":"Save current light state","links":["6b1950db.6aaa1"],"x":55,"y":480,"wires":[["aa73ebd6.d0e128"]]},{"id":"9a9334da.405dd8","type":"link in","z":"ff0ee1c6.69484","name":"Log light state changes","links":["1a8479df.871036"],"x":55,"y":580,"wires":[["d7c05f9.56629a"]]},{"id":"a646fed9.c4707","type":"link out","z":"ff0ee1c6.69484","name":"","links":["ca52298c.be1508"],"x":235,"y":180,"wires":[]},{"id":"aa099e57.239","type":"link out","z":"ff0ee1c6.69484","name":"","links":["ecf7b9a1.4ca168"],"x":275,"y":280,"wires":[]},{"id":"6b1950db.6aaa1","type":"link out","z":"ff0ee1c6.69484","name":"","links":["6e1da50d.f53c4c"],"x":815,"y":380,"wires":[]},{"id":"1a8479df.871036","type":"link out","z":"ff0ee1c6.69484","name":"","links":["9a9334da.405dd8"],"x":295,"y":480,"wires":[]},{"id":"bef70981.821368","type":"e-mail","z":"ff0ee1c6.69484","server":"smtp.gmail.com","port":"465","secure":true,"name":"","dname":"","x":1210,"y":620,"wires":[]},{"id":"6b5781bc.bbf8f","type":"change","z":"ff0ee1c6.69484","name":"Get E-Mail Address","rules":[{"t":"set","p":"to","pt":"msg","to":"settings.contact.email","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":620,"wires":[["bef70981.821368"]]},{"id":"d34b4158.5fb44","type":"comment","z":"ff0ee1c6.69484","name":"⬆ SET SMTP CREDENTIALS HERE","info":"> To get detailed step by step instructions, open the flow description.","x":1300,"y":660,"wires":[],"icon":"node-red/node-changed.png"}]
